Author Topic: Green Smiley's in PBT Doubleshot!  (Read 15370 times)
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
« on: Fri, 25 January 2013, 12:48:57 »
Now available on Techkeys!  http://www.techkeys.us/custom-keys.php
Re: Green Smiley's in PBT Doubleshot!
« Reply #1 on: Fri, 25 January 2013, 13:01:46 »
Schweet.  I picked up a couple.
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #2 on: Fri, 25 January 2013, 13:03:15 »
ordered two. that green looks awesome!
Offline DanGWanG
  • Higher Standards
« Reply #3 on: Fri, 25 January 2013, 13:04:55 »
I'll take a picture of comparing the two different base greens.  The OG's are a tad more yellow, the new ones are more neon green =)
Offline GeorgeK
« Reply #4 on: Fri, 25 January 2013, 13:07:06 »
looks good - ordered a couple :D
« Reply #5 on: Fri, 25 January 2013, 13:09:13 »
Hope the green is bright at this green in person.
Offline keymaster
  • Topre Revolution Theorist
« Reply #6 on: Fri, 25 January 2013, 13:21:22 »
I wonder if this is the MYSTERY item I'll be receiving in the mail...
Offline i3oilermaker
  • * Moderator
  • techkeys.us
    • TechKeys
« Reply #7 on: Fri, 25 January 2013, 13:24:15 »
Nope
Offline longweight
  • philanthropist
« Reply #8 on: Fri, 25 January 2013, 13:27:38 »
Is this another limited run or will there be enough for all?
Offline DanGWanG
  • Higher Standards
« Reply #9 on: Fri, 25 January 2013, 13:30:15 »
It's a limited run
Offline TheProfosist
  • Custom Layouts Only!
« Reply #10 on: Fri, 25 January 2013, 14:19:48 »
I think i should pick one up for my rasta phantom no?
« Reply #11 on: Fri, 25 January 2013, 14:20:16 »
Two, to be safe :D
Offline DanGWanG
  • Higher Standards
« Reply #12 on: Fri, 25 January 2013, 14:22:12 »
At least 3 so your shipping doesn't go to waste =)
« Reply #13 on: Fri, 25 January 2013, 14:37:19 »
I made my order 4 :)
Offline DanGWanG
  • Higher Standards
« Reply #14 on: Fri, 25 January 2013, 14:38:06 »
OG on top, new ones below.
« Reply #15 on: Fri, 25 January 2013, 14:42:36 »
You're the man Dan. You said that they'd be out soon and they really were. None of this SmallFry SoonTM  :p
Gonna snag a few when I get home!
Offline 4LI4Z
« Reply #16 on: Fri, 25 January 2013, 14:56:30 »
Awesome Caps, doubleshot PBT and 420 awesome face!
BLING BLING GOLD SPRING
ErgoClear Filco MJT2 TKL || Apple EK II || Hall Effect Keypad || Cherry G81 HAD || IBM M SSK
« Reply #17 on: Fri, 25 January 2013, 18:01:41 »
Ordered :)
Offline dieseldog49
« Reply #18 on: Fri, 25 January 2013, 18:07:12 »
Just ordered one as well.
« Reply #19 on: Fri, 25 January 2013, 18:08:10 »
Apparently not as "limited" as I thought  :))
