Author Topic: Thinking about getting a board for work...Leopolds?  (Read 2301 times)
Offline babyhands
« on: Sat, 26 January 2013, 12:04:21 »
Hey guys, so I have a ducky 9008g2, and it has blues in it so I figure it will be too annoying for my fellow employees. But, since I am addicted to mechanical keyboards I don't think I can be typing on rubber dome all day, so I was thinking about trying mx red switches (already had browns...loved them but want to try new switches you know?). Any who, I was looking at different TKL boards and this leopold http://elitekeyboards.com/products.php?sub=leopold,tenkeyless&pid=fc200rrab was looking pretty sexy. How are leopolds? My first board was a filco, and I am looking for something with the same quality, so hopefully costar stabilizers etc etc. So does anyone know the quality of these boards? How they feel?
Offline keymaster
  • Topre Revolution Theorist
Re: Thinking about getting a board for work...Leopolds?
« Reply #1 on: Sat, 26 January 2013, 12:15:45 »
As long as you don't plan getting a full set of replacement keys, you should go for it. Leopolds are inexpensive and solidly built. However, they don't have Costar stabilizers -- something that doesn't bother me.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #2 on: Sat, 26 January 2013, 12:17:41 »
Other option with Costar build / stabilizers that is (imo) of equal quality to a filco would be a CM Storm Quickfire Rapid.
Offline babyhands
« Reply #3 on: Sat, 26 January 2013, 12:51:27 »
I have head Quickfire's are the same quality, and even the same thing as a filco...What is the truth in this? Are they really the same board? Also, I don't know if i want one because of their ugly as sin key caps, I don't want to have to buy replacements for a keyboard I may only be using as work you know? But then again it would get a lot of use...I guess I just want to know more about the board, I have heard they are made in the same factory as filcos, that they are basically the same board as filcos, can someone tell me what the actual differences are?
« Reply #4 on: Sat, 26 January 2013, 12:57:49 »
I love my Leopold and it is my work keyboard.  As has been mentioned it has different stabilizers.  As for quality I consider it top-notch.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #5 on: Sat, 26 January 2013, 13:20:56 »
Quickfire Rapid supposedly weighs a little bit less (thinner pcb, iirc) and has a detachable usb cable (filco's is fixed). Keycaps are actually a little better feeling than filco, imo, but the font is fugly.
I'd buy the Rapid OVER a filco if they were the same price, tbh. Just my personal preference.
Offline 1839cc
« Reply #6 on: Sat, 26 January 2013, 18:26:10 »
I'm quite satisfied with my Leopold. Good quality for a good price. They have Cherry style stabilizers, as has been mentioned, but that is no problem for me. With clear switches I can't really feel any difference between the stabilized keys and the normal ones.
I have Cherry Corp. 2-shot ABS keys on mine and it looks fantastic.
i have seen unix admins with john deere trucker hats, and even seen a man in a nascar shirt correct a passerby's klingon.
