Author Topic: DSA Retro Set (SHIPPED!)  (Read 1950314 times)
Offline AKIMbO
  • HHKBro
Re: DSA Retro Set
« Reply #100 on: Tue, 12 February 2013, 11:38:40 »
I had to remove the 10 pieces limit from the order form (replacing the drop down with a standard input box).
The smartest of you might know what is going on...
I'm not one of the smartest but I think I know why. :P
I'm not smart...so I'm still puzzled.
| KBD75 (box reds)
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: DSA Retro Set
« Reply #101 on: Tue, 12 February 2013, 11:49:02 »
attack of the vendors
Offline jil_jil32
  • Tokyo Press <3
Re: DSA Retro Set
« Reply #102 on: Tue, 12 February 2013, 11:52:15 »
Poor the 1.75x mods kit... I hope you can find a solution for me, I just need one Enter 1.75x key =(
Offline regack
Re: DSA Retro Set
« Reply #103 on: Tue, 12 February 2013, 11:54:52 »
Keep checking back, if what Matt3o is hinting at might happen, could be at the highest quantity/lowest price tier soon enough.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: DSA Retro Set
« Reply #104 on: Tue, 12 February 2013, 11:56:17 »
I'm probably going to remove the C64 key from 1.75 mods and maybe some other keys to try to lower that price.
Offline jil_jil32
  • Tokyo Press <3
Re: DSA Retro Set
« Reply #105 on: Tue, 12 February 2013, 12:02:56 »
Yeye... :3
Re: DSA Retro Set
« Reply #106 on: Tue, 12 February 2013, 12:03:41 »
I'm sure it will happen soon, but we really need at least 12 more people to pick up the Coffee TKL set. Drops the price by over $20.
Re: DSA Retro Set
« Reply #107 on: Tue, 12 February 2013, 12:07:26 »
Yes I hope that one gets there.  I've already called dibs on one.  It's definitely needed for boards with 1x mods since those don't come in plum.
... and there just may be a custom board soon that has that configuration...
Re: DSA Retro Set
« Reply #108 on: Tue, 12 February 2013, 12:16:09 »
Definitely want to get to the 50 tier and beyond, that's where it levels off.
13383-0
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: DSA Retro Set
« Reply #109 on: Tue, 12 February 2013, 12:25:52 »
Form filled!!
-Enzo Ferrari
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: DSA Retro Set
« Reply #110 on: Tue, 12 February 2013, 12:43:25 »
I'd say the sweet spot would be 75, but 50 is good enough.
Offline rknize
    • metaruss
Re: DSA Retro Set
« Reply #111 on: Tue, 12 February 2013, 12:54:05 »
Kicked.
Russ
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: DSA Retro Set
« Reply #112 on: Tue, 12 February 2013, 13:06:21 »
BREAKING NEWS!
Fasten your belts because this is going to blow your guts all over your keyboards.
Signature Plastics just contacted me and informed that they actually have 6.2 units and 7 units spacebars in DSA family (contrary to what they originally said)! Now I just have to understand what kind of mount points they have.
This is what they say about mount points:
The 6.2 unit spacebar has fixed spacing with a center mount and 2 outboard mounts positioned 1.976" from the center mount. The 7 unit spacebar also has fixed mount positions with a center mount and 2 outboard mounts positioned 2.245" from the center mount.
Not the most universal space bars ever, but still...
« Last Edit: Tue, 12 February 2013, 13:10:16 by Matt3o »
Offline jil_jil32
  • Tokyo Press <3
Re: DSA Retro Set
« Reply #113 on: Tue, 12 February 2013, 13:08:07 »
Oh oh oh... SP...
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: DSA Retro Set
« Reply #114 on: Tue, 12 February 2013, 13:45:18 »
If I did the math well this is what we have in DSA:
6 units, 3 stems, 1 center 2 at 40mm from center
6.2 units, 3 stems, 1 center 2 at 50mm from center
7 units, 3 stems, 1 center 2 at 57mm from center
SO
The group buy is probably going to have:
DSA 6
DCS 6
DSA 6.2
DCS 6.2 Universal
DSA 7
oh gosh, what a mess...
Offline elton5354
Re: DSA Retro Set
« Reply #115 on: Tue, 12 February 2013, 13:46:56 »
Will the DSA 6.2 space bar fit Filco, Poker, and the rest keyboards?
Offline rknize
    • metaruss
Re: DSA Retro Set
« Reply #116 on: Tue, 12 February 2013, 13:48:06 »
The DCS space bar is not very well-liked.  Except for the universal 6.25 unit version, I don't see a reason to keep the other DCS, do you?
Russ
Offline Gupgup
DSA Retro Set
« Reply #117 on: Tue, 12 February 2013, 13:48:31 »
Form filled! Can't wait to have that plum color!
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: DSA Retro Set
« Reply #118 on: Tue, 12 February 2013, 13:51:08 »
yes, as far as I can tell, it seems the standard Filco spacebar.
Offline DamienG
    • DamienG
Re: DSA Retro Set
« Reply #119 on: Tue, 12 February 2013, 13:54:29 »
You've probably already considered this where we're close to the upper bound it sometimes makes sense to order the minimum quantity at the next tier and effectively 'dispose' of the extra sets as it's still cheaper for the people in that group.
e.g. ISO kit has 22 people currently at 18.98. That's $417.56 for those key sets.
If you were to order 25 sets at 12.86.. that would be $321.50. i.e. those 22 people could pay $14.61 with three sets left over.
You could actually build this logic into your tool.
current_order_value = order quantity * current tier price;
next_level_min_value = min qty for next tier * next tier price;
if (current_order_value > next_level_min_value) current price = next_level_min_value / order quantity;
[)amien
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: DSA Retro Set
« Reply #120 on: Tue, 12 February 2013, 14:43:07 »
yes, that is something I was considering but for the sake of simplicity I didn't implement it. Most of the kits won't have issues reaching a good tier and higher tiers price difference is low (so that logic would work only when orders are very close to the tier boundary). Anyway I'm going to check prices/tiers before placing the order.
Offline DamienG
    • DamienG
Re: DSA Retro Set
« Reply #121 on: Tue, 12 February 2013, 15:07:31 »
It's really cool that the extras set includes replacement 2 and 3 for UK keyboards! :) Combined with the ISO enter I think the only missing key is the one next to the Z with backslash and vertical bar on it?
[)amien
Offline rknize
    • metaruss
Re: DSA Retro Set
« Reply #122 on: Tue, 12 February 2013, 15:11:44 »
I believe that key is in the extended alpha kit.
Russ
Offline DamienG
    • DamienG
Re: DSA Retro Set
« Reply #123 on: Tue, 12 February 2013, 15:16:19 »
You're totally right, it's hidden up there top left. This set rocks :)
[)amien
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
Re: DSA Retro Set
« Reply #124 on: Tue, 12 February 2013, 15:18:56 »
oh wow, this started, so cool Matt3o!
i am going fill out in the next couple days.
Offline jneffekt
Re: DSA Retro Set
« Reply #125 on: Tue, 12 February 2013, 16:22:15 »
I'm in!
Hopefully it doesn't cost too much to ship to Australia
Offline esoomenona
  • Gnillort?
Re: DSA Retro Set
« Reply #126 on: Tue, 12 February 2013, 16:27:27 »
It would be cool to also be able to search your order by your username, in case you're wanting to view or change your order on another computer or on the go and don't have your order number handy. But I agree with what others have said that the order tool is amazing. Great work!
Offline Tranquilite
Re: DSA Retro Set
« Reply #127 on: Tue, 12 February 2013, 16:28:07 »
I think it's safe to say at this point that blank 1x plum (and probably lime) keys should be added. Already over 1000 1x blanks ordered.
I'm also pretty sure that I am on board for this group buy, but I'll hold off for a few days just to make sure that I can afford it.
Offline tjweir
Re: DSA Retro Set
« Reply #128 on: Tue, 12 February 2013, 16:30:54 »
I'd add lime 1u blanks to my order as well.
Offline esoomenona
  • Gnillort?
Re: DSA Retro Set
« Reply #129 on: Tue, 12 February 2013, 16:31:54 »
Blanks and relegendables in those colors, please.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: DSA Retro Set
« Reply #130 on: Tue, 12 February 2013, 16:41:11 »
blanks in other colors will be added all together, not one at the time. it would be a pain to manage otherwise.
anyone could change your order that way :) we would need username+password and that is a complexity I wanted to avoid. Maybe with the next GB :)
« Last Edit: Tue, 12 February 2013, 16:47:53 by Matt3o »
Offline regack
Re: DSA Retro Set
« Reply #131 on: Tue, 12 February 2013, 16:56:05 »
I just dropped the Order ID in an email to myself, so I have access to it anywhere that I have internet access.
I like not having to make another username/password. :D
« Last Edit: Tue, 12 February 2013, 18:06:30 by regack »
Offline esoomenona
  • Gnillort?
Re: DSA Retro Set
« Reply #132 on: Tue, 12 February 2013, 16:59:52 »
I'll drop it in dropbox when I get home tonight.
Offline jcrouse
Re: DSA Retro Set
« Reply #133 on: Tue, 12 February 2013, 17:10:58 »
Are all the blanks TBN (coffee) color. RBC (plum) blanks would be nice for the Ergodox users.
John
Offline Krogenar
  • The Kontrarian
    • Buried Planet
Re: DSA Retro Set
« Reply #134 on: Tue, 12 February 2013, 17:40:58 »
My first GB and I'm very excited! I don't know what other GBs are like, but this feels very professional and well thought-out. I bought a Cherry keyboard just to try these keys out. (Ok, fine, I was gonna buy a Cherry board, but this GB definitely accelerated the process!)
I love the color scheme, too. (crosses fingers, prays for white on blue)
How can I be sure that I'm getting the right size modifiers? I've ordered a Ducky with MX Greens, and I'm eyeing the keyboard layout and trying to figure out what size is correct. Guessing 1.5 modifiers? Can anyone else with a fullsize Ducky confirm for the newb?
Matt3o -- take a bow!
The ducky will have 1.25 mods and a 6.25 spacebar.
Thanks Halverson! Going to update my order. Someone should compile all the "What will my board require?" answers in this thread and put them on the top page for easy reference.
Thanks again for organizing this groupbuy Matt3o. It can't be easy fielding all these questions.
Quote from: Samuel Adams
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: DSA Retro Set
« Reply #135 on: Tue, 12 February 2013, 17:45:40 »
ahah thanks Krogenar, that gif made my day :)
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: DSA Retro Set
« Reply #136 on: Tue, 12 February 2013, 18:02:50 »
Okay I'm updating the order form, tomorrow (Wednesday) you'll find all the DSA space bars. I'll also update the OP with all the info you need to pick the right one.
You'll probably want to switch from DCS to DSA but remember the DSA 6.25 is not Universal (I'd take some of both families if I were you :P )
Sorry about this space bar mess, but SP gave me the wrong info.
Offline oluf
  • formerly olaph
Re: DSA Retro Set
« Reply #137 on: Tue, 12 February 2013, 18:49:43 »
Your GB software is awesome! Thanks for putting this together!
Offline wasabah
Re: DSA Retro Set
« Reply #138 on: Tue, 12 February 2013, 18:55:14 »
I'm also still holding off because I would prefer blue keys.
But the more I look at the colors, the more I consider just buying both. Especially if we get lime 1 blanks!
Would love a brown-green Ergodox. :)
I have two Ergodoxes anyway, and the blank keys from Massdrop aren't so expensive and I could also just sell them.
Oh my god, the temptation.. *throws money at screen*
ErgoDox Classic | Logitech G400 | Logitech Marble | Logitech M570 | Logitech M235 | Logitech M305
Re: DSA Retro Set
« Reply #139 on: Tue, 12 February 2013, 19:42:55 »
NOW you're getting the hang of it! :D
Offline Acanthophis
Re: DSA Retro Set
« Reply #140 on: Tue, 12 February 2013, 20:02:49 »
Offline rknize
    • metaruss
Re: DSA Retro Set
« Reply #141 on: Tue, 12 February 2013, 20:09:05 »
^ Deathstar needs a GH plastered on the side.
Russ
Offline Hak Foo
  • Make America Clicky Again!
Re: DSA Retro Set
« Reply #142 on: Tue, 12 February 2013, 21:18:00 »
The deathstar is perfect for this GB-- it has a spherical depression on it!
Overton130, Box Pale Blues.
Offline wasabah
Re: DSA Retro Set
« Reply #143 on: Tue, 12 February 2013, 22:43:36 »
Quick question: the size of the return key in kit2/kit3 is 2.25, right?
So is there any way to get a 2.0 return key? Can't find/see it right now..
Offline Hak Foo
Re: DSA Retro Set
« Reply #144 on: Tue, 12 February 2013, 23:30:03 »
The amazing thing is the breakdown.  The base set starts at less than $40 even at a hypothetical five orders.  Meanwhile, the 1.75x modifier set starts at over $200, for just twelve keys.  It's clear SP's system is optimized for the production of 1x keys.
Offline kdash4
Re: DSA Retro Set
« Reply #145 on: Wed, 13 February 2013, 01:17:42 »
blk are blanks right?
What color are they?
Seeing that you are in Italy, how much is shipping to the US?
« Last Edit: Wed, 13 February 2013, 01:21:35 by kdash4 »
Offline funkymeeba
  • CRUMPULAR
  • WEST SHINJUKU PLANTING TUNE
Re: DSA Retro Set
« Reply #146 on: Wed, 13 February 2013, 01:25:28 »
I believe samwisekoi will be doing the sorting/shipping, and he is in the US, so I don't think you need to be worried there.
17:15 < vun> these are the healthiest crisps I've ever come across
17:16 < vun> mostly because I can't get the bag open
meebcats - my bad music
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: DSA Retro Set
« Reply #147 on: Wed, 13 February 2013, 01:31:37 »
you need to take the blanks for that, sorry. We may add it to the extramods, but they are not receiving much love so...
blanks are all coffee/brown.
Please ready carefully the OP, section Logistics. Shipping originates from US.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: DSA Retro Set
« Reply #148 on: Wed, 13 February 2013, 03:03:06 »
Important Update about Spacebars!
Signature Plastics initially said that they couldn't provide DSA spacebars, but they contacted me back saying that they actually have them! This is a great news because we can have a 100% DSA keyboards (except for the ISO and left stem keys).
I've just updated the order form with the new space bars. I'm not going to automatically switch your DCS spacebars to DSA because the DCS ones might still be needed for certain keyboards.
This is how it works
  • 6 units DSA: 3 mount points. 1 centered, 2 at 40mm from center. This is a very peculiar spacebar, suitable for custom keyboards only.
  • 6.2 units DSA: 3 mount points. 1 centered, 2 at 50mm from center. This has the standard Filco and the like mounting position.
  • 7 units DSA: 3 mount points. 1 centered, 2 at 57mm from center. This is mainly for winkeyless.
  • 6 units DCS: 3 mount points. This should be the Cherry G80-xxxx spacebar, PLEASE CONFIRM.
  • 6.25 units Universal DCS: This is the universal Signature Plastics 6 mount points space bar. This should fit most of the keyboards out there
  • 7 units DCS: 3 mount points. 1 centered, 2 at 57mm from center. There's no reason to get this spacebar anymore being the 7u DSA a perfect alternative.
If you don't know which one to take, look at the back of your spacebar and measure the distance of the stems.
I would recommend taking a couple of spacebars in different families (it's 2 bucks at high tiers). This would save you unpleasant surprises! Anyway we will be taking some spares, just in case.
Head to the order form and update your order.
If you don't remember your order ID you can simply send a new order with the same username and the same forum. The previous order will be overwritten. If you really need to recover your previous order, send me a PM.
« Last Edit: Wed, 13 February 2013, 03:31:33 by Matt3o »
Offline fydo
  • Meow!
Re: DSA Retro Set
« Reply #149 on: Wed, 13 February 2013, 03:08:32 »
Woo! 6.2 DSA spacebar! :)
Very exciting stuff!
Any chance of getting spacebars in plum? *hopeful*
CoolerMaster Quickfire Rapid | Ducky Shine II (White LED)
