Author Topic: [EBAY BIN] Dolch keyboard - $125 plus shipping  (Read 3896 times)
Offline khaangaaroo
« on: Fri, 15 February 2013, 15:54:08 »
http://www.ebay.com/itm/DOLCH-PAC-62-Mobile-Sniffer-Network-Analyzer-Keyboard-/370626218517
I dunno how much these usually go for, but shipping kills it for me. If you're near Lawrence, Massachusetts, it looks like they accept local pickup.
« Last Edit: Fri, 15 February 2013, 15:57:22 by khaangaaroo »
Offline MarkPharaoh
Re: [EBAY BIN] Dolch keyboard - $125 plus shipping
« Reply #1 on: Fri, 15 February 2013, 15:57:28 »
Over $20 via UPS Ground? wtf?
Current: HHKB Pro 2, 87u 55g 10AE, FC600C, Model M 1391401
Offline alaricljs
  • I be WOT'ing all day...
« Reply #2 on: Fri, 15 February 2013, 16:14:28 »
~$6 markup on the shipping.
Filco w/ Imsto thick PBT
Offline AKIMbO
  • HHKBro
« Reply #3 on: Fri, 15 February 2013, 16:18:40 »
Vintage blues feel amazing.  I picked up a PAC 62 a few days ago.  I'd be all over this if I didn't have one already.
| KBD75 (box reds)
Offline khaangaaroo
« Reply #4 on: Fri, 15 February 2013, 16:27:14 »
how are they different from modern blues?
Offline AKIMbO
  • HHKBro
« Reply #5 on: Fri, 15 February 2013, 16:28:53 »
Way smoother.  Typing on a Dolch board is the way cherry blues are meant to feel.
| KBD75 (box reds)
Offline calavera
« Reply #6 on: Fri, 15 February 2013, 17:17:35 »
Speaking of Dolch, anyone know how to mod the cables so I can use it on my PC? Or someone makes an adapter perhaps?
I saw a diagram of someone ghetto rigging it but I'm not wire-savvy.
Offline akuJIWA
  • Lock 'N Load!
« Reply #7 on: Fri, 15 February 2013, 17:29:16 »
Sold.... damn...
The Cheat - B/R/B ; Clear switch with 62g springs
quit
Offline AKIMbO
  • HHKBro
Re: Re: [EBAY BIN] Dolch keyboard - $125 plus shipping
« Reply #8 on: Fri, 15 February 2013, 17:38:30 »
I'm interested in this too...preferably someone to do the mod for me.  I already destroyed one dolch PAC 62 pcb.
T___T
| KBD75 (box reds)
Offline SmallFry
« Reply #9 on: Fri, 15 February 2013, 17:39:08 »
They use PS/2 protocol, but phone jack plugs, so buy a phone jack splitter, pop it open, attach corresponding wires to a PS/2 plug inside (should be screw posts) and close it up. Or solder on a PS/2 cable.
« Reply #10 on: Sat, 16 February 2013, 21:45:53 »
How "destroyed" is it? 'cause as long as it's not cracked in half, it should be repairable (And probably even then).
But if it's PS2, and you know the pinout, it should be relatively easy to just solder on a PS2 cable or make an adapter.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #11 on: Sat, 16 February 2013, 22:31:20 »
Yes it is dead simple to either make a ps/2 to 4p4c cable, or just hard solder it depending if you never intend to use it with a PAC again... which in that case I also recommend dropping it into a standard 1800 casebody (especially a white one) because it looks nicer and less bulky.
I still wish the seller with the German ones would come down on price... they have been sitting on ebay for like a year or something now lol.
« Last Edit: Sat, 16 February 2013, 22:33:15 by IvanIvanovich »
Offline Dianoda
« Reply #12 on: Wed, 20 February 2013, 14:03:02 »
Would modding for PS/2 allow me to get the pointer working, too?  The board I ordered is from one of the early PAC 65's with the pointer in the upper right (above the numpad)...
And how about using it over USB, is that possible?  I'm pretty sure the motherboard in my computer does not have a PS/2 port.
« Reply #13 on: Wed, 20 February 2013, 14:14:18 »
The one I got was also a 65, but I simply ignored the trackpoint and dropped mine into a standard 1800 casebody so I can't advise on that. Yes you can use over usb with an active ps/2 to usb adapter.
Offline Dianoda
« Reply #14 on: Wed, 20 February 2013, 18:54:37 »
Thanks for the info.  Depending on what I see once the board arrives, I might try a mod to get the trackpoint working over PS/2 and then USB.  Possibly impossible, but I won't know until I try (and given that I am just getting the keyboard, I do not need to worry about maintaining compatibility with a Dolch PAC system).
