Author Topic: Escape Key Recommendations  (Read 3893 times)
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
« on: Sat, 16 February 2013, 19:41:04 »
Hey all.... I am probably going to get laughed at, but if anyone knows where I can pick up a Clack Factory Tri-Color Skull key for my Escape, it would be appreciated. EK is sold out.
Also, if that is laughable because they are so hard to get, can anyone recommend any cool ones a bit easier to obtain?
I'd like it to have red in it.
EDIT: I am also looking for 4 blank reds for WASD cluster. KBC double shot PBT with OEM profile.
Offline reaper
Re: Escape Key Recommendations
« Reply #1 on: Sat, 16 February 2013, 19:49:46 »
Keep posting/contributing to the community (no spam) until you've reached 60 posts and then start a WTB thread over in Classifieds.  Good luck!
Din Eli
Offline keymaster
  • Topre Revolution Theorist
« Reply #2 on: Sat, 16 February 2013, 19:52:51 »
Refer to avatar.
Offline OnTheBrink
    • Wired In Store
« Reply #3 on: Sat, 16 February 2013, 21:26:29 »
Got it, I will try that.
Refer to avatar.
Heh, without spending $250! I'm an enthusiast, but just not that hard core... :P
« Reply #4 on: Sat, 16 February 2013, 21:31:36 »
Refer to avatar.
They're only $5 from EK or $4 from Originiative! And they are very nice escapes :)
Offline terran5992
  • One With The Cup Rubber
« Reply #5 on: Sat, 16 February 2013, 22:26:08 »
Get my avatar.
Offline Reomero
  • Manual breather
« Reply #6 on: Sun, 17 February 2013, 00:17:27 »
Cool ones eh? Take a look around at KeyPop, TechKeys, and QWERKeys.
Offline OnTheBrink
    • Wired In Store
« Reply #7 on: Sun, 17 February 2013, 01:39:03 »
I love you. This is exactly what I needed.
Offline Reomero
  • Manual breather
« Reply #8 on: Sun, 17 February 2013, 02:15:42 »
You're welcome :D
Offline kboardvintage
« Reply #9 on: Tue, 19 February 2013, 12:54:07 »
Gmk Esc > all
Offline OnTheBrink
    • Wired In Store
« Reply #10 on: Tue, 19 February 2013, 13:01:27 »
