Author Topic: Is This PBT ?  (Read 3032 times)
Offline terran5992
  • One With The Cup Rubber
Is This PBT ?
« on: Sat, 16 February 2013, 21:06:56 »
Just bought this set , wondering if it is pbt?
Cause after a about a week i noticed the WASD Keys are losing their color.
13591-0
13593-1
« Last Edit: Sat, 16 February 2013, 21:27:06 by terran5992 »
Offline Jocelyn
  • 조셀린
Re: Is This PBT ?
« Reply #1 on: Sat, 16 February 2013, 21:11:05 »
Yes, that's Gold on Black (laser etched?) PBT :)
Offline Lunartuna
  • Good bye money!
Re: Is This PBT ?
« Reply #2 on: Sat, 16 February 2013, 21:12:03 »
With spider webs in between!
Shine 2 TKL - Choc Mini
Offline terran5992
Re: Is This PBT ?
« Reply #3 on: Sat, 16 February 2013, 21:24:14 »
HAHAHA its just dust bro XD
Offline Reomero
  • Manual breather
Re: Is This PBT ?
« Reply #4 on: Sun, 17 February 2013, 00:12:51 »
Yeah that's PBT. The fading of the characters have nothing to do with the plastic. :)
Offline terran5992
Re: Is This PBT ?
« Reply #5 on: Sun, 17 February 2013, 00:25:21 »
It seems to be fading alot faster than normal pbt should.
Re: Is This PBT ?
« Reply #6 on: Sun, 17 February 2013, 00:27:47 »
The PBT itself is not fading. It's the way the legends are put on, which on those are laser etched or pad printed, causing them to rub off/fade.
The only legends that won't fade on PBT are deysub, which cannot be a lighter legend on a darker cap. So since yours look to be gold on black or so, those are not dyesub.
