Author Topic: Apple Extended Keyboard key switch  (Read 1957 times)
Offline vivalarevolución
« on: Mon, 18 February 2013, 16:56:16 »
To be clear, I'm referring the original Apple Extended Keyboard not the Apple Extended Keyboard II.
I was wondering if anybody on these boards knows the standard ALPS switch that came in the Apple Extended Keyboard. I've pictures of them with Orange Alps, but I don't know if they used different switches in that particular keyboard.
Anybody know if Orange Alps was standard in all Apple Extended Keyboards?
Re: Apple Extended Keyboard key switch
« Reply #1 on: Mon, 18 February 2013, 17:53:30 »
I am not sure of your question, but I have owned several (4-5?) AEKs ("Saratoga") and all have had "salmon" (aka pink aka orange) Alps which are very nice switches. I think the smaller boards from the same era had the same switches.
I really like these boards, although since I have pulled most of mine from junk piles, they always seem to have dead switches, especially Enter. And the cases and spacebars yellow atrociously.
Currently I have 2, and I plan to build one really nice one from them, if I can, since 1 case is very nice.
Just one more project on my "to do" list ......
- D Trump 2026-10-24
« Reply #2 on: Mon, 18 February 2013, 18:05:55 »
To clarify, I am just asking what kind of Alps switch is common on the Apple Extended Keyboard. I think you answered the question.
Offline hasu
  • @tmk
« Reply #3 on: Mon, 18 February 2013, 23:24:48 »
IIRC, some Alps savvy said AEK(and AppleIIGS) used orange originally, then pink later.
My AEK(and IIGS) has orange, which has nice tactile.
« Reply #4 on: Tue, 19 February 2013, 11:03:20 »
You know the difference between Pink Alps and Orange Alps?  I used orange Alps and I really liked them.
Also I have an Apple IIGS keyboard, and it has white SMK switches with Alps mount. Those also feel decent for typing. I understand they are the non-clicky version of the Monterey Blues.
Offline hasu
  • @tmk
« Reply #5 on: Tue, 19 February 2013, 19:11:24 »
I have pink on M0116. Orange on AEK is a bit lighter and smoother than that. I prefer orange.
But fair comparison is difficult because condition of both switches is different.
IIGS has two variant at least, I think your is from Taiwan and mine is made in Japan.
« Reply #6 on: Wed, 20 February 2013, 08:31:34 »
Soon enough I might have both Pink and Orange Alps to do a comparison. But as you said, you never know about the condition of the switches considering they are so old.
