Author Topic: Thick metal spacebar  (Read 3856 times)
Offline WhiteFireDragon
    • youtube
« on: Wed, 20 February 2013, 01:29:55 »
Anyone interested in one? I have a few aluminum spacebars, but they're pretty thin. I also have a titanium that's thin too, so here's one I would like to make for THICK and heavy. This would probably require a grey or clear spring to compensate for the extra weight.
I'll have to check the wall clearance to make sure it won't rub on the switch/stabilizer.
    • youtube
Re: Thick metal spacebar
« Reply #1 on: Wed, 20 February 2013, 01:30:09 »
Here's another version that's completely solid, although not sure if it's practical because you'd need a superman spring to keep this from constantly holding down the switch. I'm also not sure if those slots are machinable so the design might have to change.
« Last Edit: Wed, 20 February 2013, 01:35:25 by WhiteFireDragon »
« Reply #2 on: Wed, 20 February 2013, 01:41:32 »
Oh make me that one! I have a superblack spring I can use! I bet it would be perfect!
Offline inteli722
« Reply #3 on: Wed, 20 February 2013, 07:59:25 »
how about sticking some springs under Cherry Stabilizers? that would keep it up!
Just kidding. You would likely need a SuperBlack spring under a Clear stem to keep it up...but that would look awesome!
Waiting for: Phantom Plate
« Reply #4 on: Wed, 20 February 2013, 08:02:33 »
I think that would be painful to use.  Slapping my thumb against a space bar with so much inertia would get uncomfortable fast.
Offline esoomenona
  • Gnillort?
« Reply #5 on: Wed, 06 March 2013, 08:29:36 »
« Last Edit: Tue, 27 October 2015, 09:17:23 by esoomenona »
« Reply #6 on: Wed, 06 March 2013, 10:09:58 »
That would not function with a Cherry MX switch.  It wouldn't be able to travel far enough to actuate.
Offline esoomenona
  • Gnillort?
« Reply #7 on: Wed, 06 March 2013, 10:13:55 »
« Last Edit: Tue, 27 October 2015, 09:17:36 by esoomenona »
