Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6277981 times)
Offline Coreda
« Reply #12950 on: Sun, 09 August 2015, 16:08:50 »
Saw this switch on a site and was wondering what type it was:
From this board (NEC PTOS):
Sadly no higher res photos available. Wish Deskthority's wiki switch list page had thumbnails to browse through.
« Last Edit: Sun, 09 August 2015, 16:10:28 by Coreda »
Offline davkol
  •  Post Editing Timeout
« Reply #12951 on: Sun, 09 August 2015, 16:52:19 »
http://deskthority.net/wiki/Category:Recognition_guides
…but that switch isn't there.
The keyboard looks like NEC A-VX N8606 (classified as Topre in DT wiki) and a bunch of other PTOS keyboards.
« Last Edit: Sun, 09 August 2015, 16:59:14 by davkol »
Offline Coreda
« Reply #12952 on: Sun, 09 August 2015, 17:58:24 »
So I did some more looking around it looks like the model is 'NEC CMQ-6D1L' and the switch is a rare NEC branded switch (wiki entry). They apparently came in a couple versions.
From translating some of the original Japanese it said that the early to mid versions of the NEC PTOS used the NEC switches while the latter model they owned (PC-9801-114) featured yellow ALPs switches:
Clearly these boards came with different switches over the years as Topre was also used for some models.
Offline byker
  • Literally Canada
« Reply #12953 on: Sun, 09 August 2015, 22:46:22 »
NVM :D
« Last Edit: Mon, 10 August 2015, 00:09:37 by byker »
« Reply #12954 on: Mon, 10 August 2015, 06:05:41 »
Those look very much like a variant on the NEC blue oval switches.
The blue ones popup from time to time in H4100E and similar keyboards.  They are clicky, although curiously the click happens after actuation, so with a little care it is possible to type silently on the blue switches.
I wonder if the white ones are, perhaps, silent versions of the blue ones.
Offline vivalarevolución
« Reply #12955 on: Mon, 10 August 2015, 09:35:02 »
Where the heck do I get space bars, besides signature plastics?  I'm mostay looking for 6.25 pbt, and nothing too fancy or expensive. But thick would be nice.
NEVERMIND, I'll just get them from SP, they have lots of options for a good price.
« Last Edit: Mon, 10 August 2015, 22:25:22 by vivalarevolución »
Offline Coreda
« Reply #12956 on: Mon, 10 August 2015, 22:28:23 »
Interesting, so there are blue versions of the switches as well. Curious!
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #12957 on: Tue, 11 August 2015, 16:03:36 »
What are the differences between AEKi and AEKii?
Are the keycaps completely interchangeable between the two? I'm looking to get some orange ALPS and solder them into an AEKii, and use the AEKi caps.
« Reply #12958 on: Tue, 11 August 2015, 16:17:01 »
Huh?
The AEK2 caps are considered by some people to be marginally better, but there is very little difference.
The orange Alps are the best, but there is so little difference in the cases that it does not seem to matter.
Both have Apple style details and ADB connections. Why bother?
- D Trump 2026-10-24
Offline Eugene45
« Reply #12959 on: Tue, 11 August 2015, 19:22:37 »
Hello, in the search of a mechanicall keyboard i came across an OLIVETTI.
MODEL : ANK 60 -105       RT4958TWFR
I look several time on the wiki and google, find only one thread talking about a rt4958twfr but was not an olivetti, the guy talking about seems to say that it is mechanical.
But i find literaly nothing Oo
Could somebody say me what type of switch or if the keyboard is worth the time ?
Thanx Eugene.
lmao, cut the French some slack, they gave you a big statue
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #12960 on: Tue, 11 August 2015, 19:37:17 »
Thanx Eugene.
pic?
Offline Eugene45
« Reply #12961 on: Tue, 11 August 2015, 19:55:41 »
Only an ant pic at the moment, Hope to have one taller tomorrow
http://www.noelshack.com/2015-33-1439340854-keyboard.jpg
Offline Eugene45
« Reply #12962 on: Wed, 12 August 2015, 05:59:46 »
Apparently cant use the "balise" to include the pic, seems weird, keyobard has the logo on the right with a black strip, still searching on the net about something similar.
Wanted to add a question, it seems that you can buy some "weird" starwars / or colored key with some face on it ?
Are they some collectible thing like pokemon cards or does it have an other use i dont know ?
Thx
« Last Edit: Wed, 12 August 2015, 06:03:57 by Eugene45 »
« Reply #12963 on: Wed, 12 August 2015, 06:41:02 »
Ideally we'd have a top down picture, picture of the bottom, and a picture with a keycap pulled. Honestly have zero clue with the information you've given and that picture.
Thx
You answered your own question. They're just for fun and collectible.
Offline Eszett
« Reply #12964 on: Wed, 12 August 2015, 06:53:24 »
Hello! Which axis of a matrix is usually strobed and which sensed?
« Last Edit: Wed, 12 August 2015, 07:00:02 by Eszett »
Offline Eugene45
« Reply #12965 on: Wed, 12 August 2015, 07:31:17 »
@CPTBadAss
I dont want to quote / requote and requote a message.
I found a ank 61 105 on ebay italia, seems that the ank 60 105  it was not a meca, so dropt it.
Found a model M on local craiglist but the seller wont sell it without the computer.
And with all of that people are on vacation and just email you, i'am in vacation, dont care, resend on end of month.
So yeah the hunt continue :) So excited.
Thx for the answer.
« Reply #12966 on: Wed, 12 August 2015, 07:52:51 »
https://geekhack.org/index.php?topic=50437.msg1193047#msg1193047
If I understand Soarer's post correctly, the columns (Y axis or function row to spacebar) are strobe lines. The rows (X axis or capslock to backspace) are sense lines.
Offline Eszett
« Reply #12967 on: Wed, 12 August 2015, 07:57:46 »
Thank you Captain! Your answer is quick!
Offline alienman82
« Reply #12968 on: Wed, 12 August 2015, 23:46:23 »
removed.
« Last Edit: Thu, 01 March 2018, 17:16:15 by alienman82 »
« Reply #12969 on: Thu, 13 August 2015, 07:45:37 »
Anywhere I can buy a center stem black spacebar cherry profile 6.25 today?
Don't think anyone stocks actual Cherry/GMK spacebars now. When there was the GMK spacebar random buy last year, there were a few black and whites. You could try putting up a classifieds to get one of those.
If you're looking for Cherry profile, you should be able to pickup DCS spacebars from SP.
« Last Edit: Thu, 13 August 2015, 08:58:44 by CPTBadAss »
Offline alienman82
« Reply #12970 on: Thu, 13 August 2015, 08:58:16 »
removed.
« Last Edit: Thu, 01 March 2018, 17:16:12 by alienman82 »
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #12971 on: Thu, 13 August 2015, 09:11:35 »
From this GB: https://geekhack.org/index.php?topic=71507.0
But I think it's little cost.
Offline MAR82
  • Keyboard Addict
« Reply #12972 on: Thu, 13 August 2015, 09:21:49 »
I know they had them in the JTK Debut GB, and I think Bunny said there will be some extras on ctrlalt.io when it reopens
Offline Ludovician
« Reply #12973 on: Fri, 14 August 2015, 02:33:49 »
Is anyone here familiar with the KBP V80 and how many screws you need to remove to take it apart? I can feel SOMETHING under the label but I don't want to destroy the label just to find that I didn't need to, and I assume there are others under the rubber pads but I haven't looked yet.
In case it makes a difference, mine is the Matias version.
Typing speed:
My collection:
HHKB Pro 2 (Blank, white) | HHKB Pro 2 Type-S (Blank, white) | Topre Realforce 87UB silent-modded (not currently functional) | Das Keyboard Model S Professional Silent (MX Brown) | IBM Model M 1391401 - 9th January 1991 (Bolt+Floss-modded) | Apple keyboard m0116 (Orange Alps) | Unidentified DIN Keyboard (White Alps) | ADDS 1010 (Green Alps) | AEK II (Linear-modded, USB-converted) | IBM PC-AT Model F | Noppoo Choc Mini (MX Black) | Amstrad PC2286 | BigKeys LX | IBM Model M 1391401 - 6th September 1990 | IBM Model M2 1395300 - 28th February 1991 | Leopold FC660C | Cherry G80-11802 (MX Brown) | Matias Tactile Pro (Simplfied grey Alps) | Razer Blackwidow (MX Blue) | Novatouch 55g | Focus FK-2001 (White alps) | DSE Multitech (Blue alps) | Dell AT101W (Matias quiet) | Pok3r (White w/Clears) | KBP V80 (Blue Alps)
Pending:
Infinity kit
« Reply #12974 on: Fri, 14 August 2015, 07:57:25 »
https://geekhack.org/index.php?topic=73438.0
I think there's only 1 screw and snap fits.
Offline Karura
  • SKidata life.
« Reply #12975 on: Fri, 14 August 2015, 08:00:05 »
Was there a special 1.5u sized keycap that is related to Small Fry or something? Does anyone have a photo or more info about it?
I vaguely recall that it was doubleshot, black base, cyan legends. Very neat cap.
« Reply #12976 on: Fri, 14 August 2015, 08:04:04 »
Friends and Family cap. Smallfry and inlikeflynn had caps made by SP. They wanted to send them out to GHers randomly to remind them that Geekhack is more than keyboards.
Here's a picture from rkinze from the 2013 Keycon in Chicago when Smallfry's family came and mkawa handed them out.
Offline Karura
  • SKidata life.
« Reply #12977 on: Fri, 14 August 2015, 08:07:23 »
Ah yes, that's the one, it's very neat. Thanks for sharing :)
« Reply #12978 on: Fri, 14 August 2015, 10:51:31 »
So I just handwired (first time) an external numpad, put in a teensy, burned the firmware following matt3os guide and am now experiencing random inputs of 3 certain characters on my numpad. (fast enough to not allow any other input)
I checked the source code twice and couldn't find any visible shorts.. so what could the problem be? I don't know what to do anymore.  :-X
This post has been split to a separate topic, found here: https://geekhack.org/index.php?topic=74478.0
Offline Eugene45
« Reply #12979 on: Fri, 14 August 2015, 11:20:58 »
2 question :
Someone had a graphic / pics on the part of a mecha, something simple just i can send it to a friend to help him understand how its make.
Case / board / switch / caps, i'am right ?
How do you creat your keyboard pics in your signature like some people do ?
Thanks
« Reply #12980 on: Fri, 14 August 2015, 11:23:02 »
1) Someone had a graphic / pics on the part of a mecha, something simple just i can send it to a friend to help him understand how its make.
2) How do you creat your keyboard pics in your signature like some people do ?
1) This might help. But any build log would be a good place to look. https://geekhack.org/index.php?topic=47093.0. You've essentially got it yes.
2) From the OP: https://geekhack.org/index.php?topic=40501.0#post_GG
Offline Eugene45
« Reply #12981 on: Fri, 14 August 2015, 11:30:13 »
Ok in the thread you link, the plate is the piece at the bottom.
So case / board ( pcb ) / switch / plate / caps ?
Or does it have an other denomination ?
Thanks
« Reply #12982 on: Fri, 14 August 2015, 11:31:12 »
Thanks
Top of the case
Caps
Plate with switches in it
PCB
Bottom of the case
Offline Eugene45
« Reply #12983 on: Fri, 14 August 2015, 11:35:30 »
Oh okay.
Thx Captain.
Offline wlhlm
« Reply #12984 on: Sat, 15 August 2015, 03:58:31 »
IMSTO put up some BSP sets in his store. I'm interested in the Peacock set, but never having a BSP set in my hands before, here's my question: BSP doesn't make spacebars, but I have a PBT spacebar from a Cherry dyesub set, would it fit the BSP color?
Offline Ludovician
« Reply #12985 on: Sat, 15 August 2015, 04:31:40 »
Thank you. This was correct. I thought there would have been some deviously hidden under the pads or the label, like I've seen some other keyboards do.
Typing speed:
My collection:
Pending:
Infinity kit
Offline Karura
  • SKidata life.
« Reply #12986 on: Sat, 15 August 2015, 05:54:05 »
I know about the funding to make the SP Cherry legend replica, but I was wondering, who exactly designed the vector files, and owns the rights to use those moulds?
Offline azhdar
  • Praise the AZERTY god
« Reply #12987 on: Sat, 15 August 2015, 05:59:18 »
Looking for a picture of a keyboard with dolch modifiers with beige alphas <3
Azerty Propagandiste
Offline wlhlm
« Reply #12988 on: Sat, 15 August 2015, 09:16:44 »
Hashbaz has the vectors (and also owns the DCS Cherry legends, I believe). There was a lot of discussion (drama) about the Cherry legends in the Pulse IC.
Offline Eugene45
« Reply #12989 on: Sat, 15 August 2015, 09:48:43 »
That is a lot of talk Oo
Can someone ELI5/TLDR ?
Offline wlhlm
« Reply #12990 on: Sat, 15 August 2015, 09:52:35 »
https://geekhack.org/index.php?topic=42659.0
Offline Eugene45
« Reply #12991 on: Sat, 15 August 2015, 10:32:09 »
Thanks, was great to read.
Offline hikak
« Reply #12992 on: Sat, 15 August 2015, 14:11:12 »
Hello guys. Im new to this forum but i was wondering what is the difference between classic mechanical and gaming mechanical keyboard for example: http://www.amazon.com/QPAD-MK-50-Gaming-Mechanical-Keyboard/dp/B006L3S4OO/ref=sr_1_1?ie=UTF8&qid=1439665231&sr=8-1&keywords=QPAD+MK-50
and
http://www.amazon.com/Cherry-G80-3850LYBEU-2-Professional-Keyboard-Switches/dp/B00H4IKUAG/ref=sr_1_1?ie=UTF8&qid=1439665025&sr=8-1&keywords=cherry+mx+3.0#product-description-iframe
does the response time differ with non gaming? does it not have antighosting? if there are any advatages to gaming keyboard over normal one please let me know... thank you!
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #12993 on: Sat, 15 August 2015, 14:42:12 »
I wouldn't really consider "classic" to be either of those, they are both modern mechanical keyboards. Gaming is just a moniker to sell more keyboards, you won't notice a difference between (most) mechanical keyboards as most of them have at least 6KRO (USB) and even higher than that. The chances that you will ever get ghosting in a mechanical keyboard is slim since each switch is separate, though on older keyboards you may have some issues (old terminal boards from the 80s for example). Any modern board won't really have that problem unless the company that made it just completely cheaped out on it (those generic keyboards you can find on eBay for $30 for example). Average human response time is around 250ms so as long as the keyboard is faster than that there is absolutely no reason to get one that is 10ms response over one that is 20ms response for example.
Offline davkol
« Reply #12994 on: Sun, 16 August 2015, 02:38:12 »
Keyboard matrix (including ghosting) explained.
For example, my TypeMatrix ghosts on a certain keyboard combination. Most keyboards block though.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #12995 on: Mon, 17 August 2015, 03:41:05 »
Does the model number of Model Ms/SSKs change depending on year?
Offline pr0ximity
« Reply #12996 on: Mon, 17 August 2015, 05:38:43 »
Anyone know if puple LEDs with no (or very minimal) light outside of the visible spectrum (UV) exist somewhere? All that I've found are Purple+UV.
Offline njbair
    • nickbair.net
« Reply #12997 on: Mon, 17 August 2015, 06:28:24 »
AFAIK the model numbers denote the legend configuration and type of interface (PS/2 or terminal), not the date the board was made.
EDIT: http://deskthority.net/wiki/IBM_Enhanced_Keyboard#Noteworthy_part_numbers
My boards:
Offline heedpantsnow
  • Old enough to know better
« Reply #12998 on: Mon, 17 August 2015, 07:04:35 »
I have looked high and low and cannot find any.  And at least for cheap LED's, purple and uv seem to be used interchangeably since they are close on the spectrum. Chinese say "差不多".  I don't agree
I'm back.
« Reply #12999 on: Mon, 17 August 2015, 08:07:13 »
I also do not think there are purple LEDs which aren't UV LEDs.
