Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6278044 times)
« Reply #12850 on: Fri, 24 July 2015, 07:15:49 »
Why don't we still have custom keyboards utilizing Cherry MX RGBs? Exclusivity deal ended, not sure if switches are available en mass though. It's not like Korean designers don't redesign PCBs every so often, so i don't get it - what the problem adding controller capable of manipulating RGB switches themselves?
Any predictions of when, if at all, we'll see such Korean/Chinese custom keyboards popping up?
No one has made those switches available yet. I'm guessing they're expensive in terms of raw cost of the MX RGB switch or the accompanying PCB.
« Reply #12851 on: Fri, 24 July 2015, 08:25:38 »
I've heard a rumor that some PCB designers actually are starting to do that.  But that's just a rumor.  :))  We may start to see some pop up in the next year though.
:circle:
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #12852 on: Fri, 24 July 2015, 14:49:00 »
yeah, they require a different controller as well to control the RGB LEDs, it will be exciting when someone does it though!
Offline pr0ximity
« Reply #12853 on: Fri, 24 July 2015, 15:12:37 »
Anyone know what size LEDs I'd need for a Filco MJ2?
Any advice on finding ones with similar brightness/quality/appearance to stock? Not done much work with LEDs before, how do they vary in brightness (assuming equivalently powered)?
« Reply #12854 on: Fri, 24 July 2015, 15:19:40 »
1) Anyone know what size LEDs I'd need for a Filco MJ2?
2) Any advice on finding ones with similar brightness/quality/appearance to stock? Not done much work with LEDs before, how do they vary in brightness (assuming equivalently powered)?
1) Standard 3mm LEDs
2) Check these threads out:
https://geekhack.org/index.php?topic=44798.0
https://geekhack.org/index.php?topic=37266.5
Offline pr0ximity
« Reply #12855 on: Fri, 24 July 2015, 15:29:12 »
Offline njbair
    • nickbair.net
« Reply #12856 on: Fri, 24 July 2015, 20:57:26 »
I wouldn't have carry so many cables around, if my keyboard used microUSB.
You might like this
My boards:
Offline yuiop
« Reply #12857 on: Fri, 24 July 2015, 21:03:19 »
I'm trying to get my Kmac2 re-anodized.  I know it's a long shot but can anyone recommend a good shop in the Chicagoland area?
Offline davkol
  •  Post Editing Timeout
« Reply #12858 on: Sat, 25 July 2015, 03:25:21 »
You might like this
But I don't, because it puts additional strain on the connector (ErgoDox) or doesn't fit the cable routing (QFR). I don't see how it's more convenient to carry two things instead of two things either (two cables can be used with two different devices at the same time at the very least).
Offline njbair
    • nickbair.net
« Reply #12859 on: Sat, 25 July 2015, 22:24:34 »
You might like this
But it doesn't get tangled.
My boards:
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #12860 on: Sat, 25 July 2015, 22:56:18 »
You might like this
A while ago I tried something like these with my QFR, and it worked fine. Just try to find one about 6in, or preferably a little longer.
20cm > http://www.ebay.com/itm/Micro-USB-2-0-female-To-Mini-USB-male-Adapter-Charger-Cable-for-HTC-SAMSUNG-/151572835431?pt=LH_DefaultDomain_0&hash=item234a71ec67
25cm > http://www.ebay.com/itm/USB-2-0-Mini-B-5-Pin-male-to-Micro-female-Adapter-cable-/290598237469?pt=LH_DefaultDomain_0&hash=item43a901351d
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline davkol
« Reply #12861 on: Sun, 26 July 2015, 03:32:34 »
Awesome. Now I'd have two cables instead of two cables. Except I wouldn't be able to recharge my phone or copy music to my DAP, while using the keyboard.
I have one short microUSB cable that can charge virtually any modern phone, DAP and e-book reader. It can be used to connect these devices to desktops/laptops. I sometimes carry two around, just in case one fails, I want to charge/connect two devices at the same time or someone asks me to charge their phone. But I have carry around another cable! Because keyboard makers are stuck in 2008. And that cable recently failed on me, thus I couldn't type on my ErgoDox for a day or two. I guess I should had carried *four* cables around just for redundancy.
Offline dndlmx
« Reply #12862 on: Sun, 26 July 2015, 11:33:44 »
I can't use the 6u spacebar from these keycaps because the mounting is off-center, what do?
Email SP for a quote?
Offline azhdar
  • Praise the AZERTY god
« Reply #12863 on: Sun, 26 July 2015, 11:41:03 »
SP won't have cherry profile.
You could try to cut the mounting, and glue it back with epoxy
exemples here : https://www.reddit.com/r/MechanicalKeyboards/wiki/modifications#wiki_key_stem_modifications
Azerty Propagandiste
Offline dndlmx
« Reply #12864 on: Sun, 26 July 2015, 12:00:16 »
Would a DCS spacebar on Cherry look weird?
Offline azhdar
« Reply #12865 on: Sun, 26 July 2015, 12:03:16 »
« Reply #12866 on: Mon, 27 July 2015, 07:23:08 »
IIRC, it looks fine. But it definitely feels different.
Offline wobbs
« Reply #12867 on: Mon, 27 July 2015, 18:38:44 »
I have a CM Quickfire Tk and some Gateron switches.  To swap the switches, would I just trim the pastic pins and solder the switches the same as i would with Cherry MX switches?
Offline user 18
« Reply #12868 on: Mon, 27 July 2015, 18:40:48 »
Yes, Gateron, like many MX-compatible switches, are designed to be electrically and physically compatible with Cherry MX switches. If you had PCB-mount MX switches, the process would be the same.
Avatar by ashdenej
« Reply #12869 on: Mon, 27 July 2015, 22:06:58 »
This isn't much of a "simple" question, but does any know what size the screws are used for KMAC blockers? I need new ones.
Offline pesky brat
« Reply #12870 on: Mon, 27 July 2015, 22:43:38 »
Can cherry stabilizers be mounted onto a Filco PCB?
« Reply #12871 on: Mon, 27 July 2015, 22:44:22 »
If you've got a plate that supports plate mounted stabs, yes. PCB mounted stabs cannot be mounted onto a Filco PCB without heavy modification, and I don't know of anyone who has done it.
Offline pesky brat
« Reply #12872 on: Mon, 27 July 2015, 22:50:36 »
So, to clarify, if I had a uTKL plate on a Filco PCB, I could mount plate-mounted Cherry stabs on the plate, but not PCB-mount Cherry stabs?
If yes, my next question is where can I buy plate-mount Cherry stabs? nvm
« Last Edit: Mon, 27 July 2015, 22:54:16 by pesky brat »
« Reply #12873 on: Mon, 27 July 2015, 23:19:23 »
This is indeed the case. http://i.imgur.com/0Grvzgj.jpg miss my old Filco
Offline pesky brat
« Reply #12874 on: Mon, 27 July 2015, 23:28:39 »
Thanks for the help. And nice Filco , sad to hear it's gone :(
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #12875 on: Tue, 28 July 2015, 01:33:42 »
LoL.  Well I don't know what else you can do other then buy a Novatouch, or QFR-i.
WTB/WTS/WTT ---->
Offline Zustiur
« Reply #12876 on: Tue, 28 July 2015, 02:03:55 »
I'm getting this error when I try to compile Hasu's tmk firmware:
D:\Programming\Shared Projects\tmk_keyboard\keyboard\ZusDox>make -f makefile
The system cannot find the path specified.
ECHO is off.
-------- begin --------
avr-gcc (WinAVR 20100110) 4.3.3
Copyright (C) 2008 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
-f was unexpected at this time.
make: *** [sizebefore] Error 255
I know hasu didn't write 'make' so I figured I'd ask here first. Any clues as to what '-f was unexpected at this time' means?
I get the feeling it has something to do with winavr or windows rather than my code...
« Last Edit: Tue, 28 July 2015, 03:18:53 by Zustiur »
« Reply #12877 on: Tue, 28 July 2015, 06:23:18 »
ECHO is off.
Might have more luck posting a new thread or in the TMK thread. I think this is beyond the scope of this thread.
Offline BlueNalgene
« Reply #12878 on: Tue, 28 July 2015, 18:27:53 »
Does anyone have the stats on the Model M spring (rod size, height, width, load, rate) ?
Mine are rusty and not behaving.  I would like to replace them.  My calipers can't measure ID and I'm not sure if measuring the load would be simple for something which is meant to buckle.
I realize that replacements are available from Unicomp (see here), but I want to keep my options open.  Maybe there is something compatible from McMaster-Carr.
« Reply #12879 on: Tue, 28 July 2015, 19:25:37 »
Many people have looked at the Model M/F spring question with the idea of getting lighter (or possibly heavier!) action, but I have never seen anybody post positive results.
For 20 cents each, Unicomp is a reasonable source, or buy a slightly-used M (there are lots of terminals that sell cheap and have probably seen little use). And, if you buy the assembly, you don't have to monkey with it. Or PM me, I have some.
- D Trump 2026-10-24
Offline darkspider
« Reply #12880 on: Wed, 29 July 2015, 05:41:49 »
Is a keyboard which is converted from ps2(6pin din) to usb by an adapter hot-swappable?
I've connected my ps2 boards to my m/b's ps2 port directly until today, so I don't well know how ps2-to-usb adapter work.
IBM Model F AT         Model M silver label    Model M gray label    Majestouch 2 Ninja
Brand New F62 Kishsaver / F77 Industrial Model F's made this year
« Reply #12881 on: Wed, 29 July 2015, 06:35:57 »
Yes
I agree with Fohat.digs. No reason to source it elsewhere when Unicomp has it for so cheap.
Offline darkspider
« Reply #12882 on: Wed, 29 July 2015, 06:58:53 »
Yes
Thank you for immediate reply!
Offline PaulMP
« Reply #12883 on: Wed, 29 July 2015, 10:54:28 »
Hello guys!
Which keyboard is on this picture?
(source: https://www.massdrop.com/buy/dsa-dolch-key-set)
I guess it's a Varmilo VA87M, but im not sure.
Offline BrewCaps
« Reply #12884 on: Wed, 29 July 2015, 11:01:14 »
Yes.  Same spacebar.
« Reply #12885 on: Wed, 29 July 2015, 11:10:09 »
Hello guys!
I think your guess is right. I'd ask in the massdrop discussion just in case though.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #12886 on: Wed, 29 July 2015, 11:32:58 »
I'd be pretty confident in saying it's Varmilo because it has raised keys. Few keyboards have that feature.
Offline PaulMP
« Reply #12887 on: Wed, 29 July 2015, 12:41:55 »
Thank you!
I really like the look of this keyboard, especially the rised keys.
Sadly it's quite rare, and aliexpress, where i could find it, is a bad place to buy keyboards imo.
Do you guys know similar, simple looking keyboards like this, with no led background?
Pok3r looks perfect, but I prefer TKL with arrow keys.
« Reply #12888 on: Wed, 29 July 2015, 12:48:07 »
Thank you!
There's various Ducky boards (not 100% on the model names) and Filco Majestouches which I really like.
« Reply #12889 on: Wed, 29 July 2015, 13:24:46 »
ECHO is off.
Have you tried reinstalling winavr?
Offline trees
  • I like bagels.
« Reply #12890 on: Thu, 30 July 2015, 09:55:57 »
I for the life of me can not remember the name of the colored covers you can put over LEDs on your board to change the colors. I cant remember where you can buy them either.
B.Face HHKB - B.mini - Black/Purple Custom
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #12891 on: Thu, 30 July 2015, 09:57:59 »
daydream or something like that. If you scroll through the MD drops for mechanical keyboards you can find it
Edit: here http://www.banggood.com/DayDream-LED-Cover-for-108-Mechanical-Keyboard-White-Backlit-p-925837.html
« Reply #12892 on: Thu, 30 July 2015, 09:58:43 »
They had a name? I thought they were just referred to as "LED covers". And I've only ever seen them on Massdrop. I also haven't kept up with that at all.
Maybe these? https://geekhack.org/index.php?topic=52075.0
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #12893 on: Thu, 30 July 2015, 09:59:03 »
yeah, banggood link here http://www.banggood.com/DayDream-LED-Cover-for-108-Mechanical-Keyboard-White-Backlit-p-925837.html
Offline trees
  • I like bagels.
« Reply #12894 on: Thu, 30 July 2015, 10:05:53 »
Those are them, thanks CPT and seth. I was totally blanking out on them.
Offline njbair
    • nickbair.net
« Reply #12895 on: Thu, 30 July 2015, 21:49:23 »
Anyone ever had trouble with costar stabs rubbing/sticking, like the alignment's just not quite right? Looking for a fix for my spacebar and enter key.
My boards:
« Reply #12896 on: Thu, 30 July 2015, 21:50:36 »
Do you have the inserts facing the right direction?
Might try some square baggy pieces.
« Reply #12897 on: Thu, 30 July 2015, 21:50:41 »
Did you put the inserts in the correct way? The longer leg should face your function row.
Offline njbair
    • nickbair.net
« Reply #12898 on: Thu, 30 July 2015, 21:52:32 »
Yeah, they're in right. I mean it's just barely rubbing. I don't think they'd even come close to fitting if backwards.
BTW this is on an Infinity plate, not an off-the-shelf board, so maybe it's just an alignment/tolerance issue with that....
My boards:
« Reply #12899 on: Thu, 30 July 2015, 21:54:43 »
Hm, could try filing down the stabs a touch so it fits ok? Then try filing the plate's stab holes a bit?
