Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6278406 times)
0 Members and 7 Guests are viewing this topic.
« Reply #13050 on: Thu, 20 August 2015, 07:28:23 »
What's the best way to remove pad printed labels?
Sandpaper? Isopropyl alcohol? Not really sure tbh.
« Reply #13051 on: Thu, 20 August 2015, 07:28:30 »
This thread might help you
https://geekhack.org/index.php?topic=73551.0
Offline azhdar
  • Praise the AZERTY god
« Reply #13052 on: Thu, 20 August 2015, 09:05:35 »
sorry for the kind of "crazy" question but is there any harmful chemicals in a switch (a gateron here) ?
I'm asking because the other day while modding, I cut my thumb with the pin of a gateron. And since I'm loosing my nail on this thumb, and it's spreading to the other nails of this hand.
I casually asked a doc and he didn't seem concerned.
Azerty Propagandiste
« Reply #13053 on: Thu, 20 August 2015, 09:16:26 »
The lube maybe? Pretty sure you should trust your doc with medical advice more than a keyboard forum though.
Offline azhdar
« Reply #13054 on: Thu, 20 August 2015, 09:18:41 »
The switch wasn't open, my thumb only came in contact with pin and housing.
« Reply #13055 on: Thu, 20 August 2015, 09:21:09 »
The switch wasn't open? Doesn't really matter. Could have had trace amounts of lube on the outside or residues from the manufacturing processes.
Offline azhdar
« Reply #13056 on: Thu, 20 August 2015, 09:47:13 »
mmm haven't considered that, thanks cpt.
Offline Eugene45
« Reply #13057 on: Thu, 20 August 2015, 14:36:29 »
So now that i have my NMB RT-102 what do i use to connect it on my laptop in usb ?
lmao, cut the French some slack, they gave you a big statue
« Reply #13058 on: Thu, 20 August 2015, 14:38:45 »
I'm gonna guess it's a DIN5 connector so you'll need a DIN5 to PS/2 then PS/2 to USB. If it's not DIN5, disregard and show a picture.
Offline Eugene45
« Reply #13059 on: Thu, 20 August 2015, 16:14:43 »
I think its this
TY Captain.
Offline Eugene45
« Reply #13060 on: Thu, 20 August 2015, 16:46:27 »
So i need : DIN 5 female -> PS/2 female
« Reply #13061 on: Thu, 20 August 2015, 18:19:47 »
I honestly didn't even realize you could get multiple kinds of DIN5 to PS/2 adapters. I thought it was just standard. I have a DIN5 female to PS/2 male then female PS/2 to USB male.
« Reply #13062 on: Thu, 20 August 2015, 20:05:32 »
I have both kinds but each is male at one end and female at the other.
However, with a male-male cable, also, you could get there.
- D Trump 2026-10-24
Offline Heliobb
« Reply #13063 on: Fri, 21 August 2015, 07:07:38 »
I want to start making prototype with cardboard like below did for Shergo V1
https://geekhack.org/index.php?action=dlattach;topic=71614.0;attach=99485;image
But I want to do something really cheap. I wonder if buying this one:
And unsolder switches should be a good idea? Never open a cherry
Novatouch TKL - Leopold FC660C - PBT my life.
« Reply #13064 on: Fri, 21 August 2015, 07:46:03 »
So if I understand you correctly, you'd like to buy very cheap MX mount switches to build a prototype. Harvesting an old board isn't a bad idea at all. And old Cherry boards are easy to open up. You could also look into picking up Gateron or Greetech switches from say MechanicalKeyboards.com. AFAIK, the switches are cheap and they're new.
Offline azhdar
« Reply #13065 on: Fri, 21 August 2015, 07:50:10 »
« Last Edit: Fri, 21 August 2015, 07:51:52 by azhdar »
« Reply #13066 on: Fri, 21 August 2015, 07:51:10 »
Edited because azhdar edited.
« Last Edit: Fri, 21 August 2015, 08:07:54 by CPTBadAss »
Offline Heliobb
« Reply #13067 on: Fri, 21 August 2015, 08:02:54 »
Yes completely, thank for your answer. Getting switches and keycaps for around 25$ is great.
I'm in France so buy switches from outside can be expansive with shipping cost. Will check @azhdar. :)
Offline trees
  • I like bagels.
« Reply #13068 on: Fri, 21 August 2015, 13:30:57 »
B.Face HHKB - B.mini - Black/Purple Custom
« Reply #13069 on: Fri, 21 August 2015, 13:32:28 »
Can someone tell me if these will work as in switch LEDs?
http://www.amazon.com/gp/product/B003KWDVHY/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A3AGVPZHIH41EE
Sure. WFD use to use those in his videos. You may have to do a little sanding to get em to fit perfectly though.
Offline trees
  • I like bagels.
« Reply #13070 on: Fri, 21 August 2015, 13:33:03 »
Hmm. Is there a better size to look for that would fit better?
« Reply #13071 on: Fri, 21 August 2015, 13:34:27 »
2x3x4mm. See the OP for more info
Offline trees
  • I like bagels.
« Reply #13072 on: Fri, 21 August 2015, 13:54:29 »
Thanks Cpt, i found some 2x3x4 and ordered them instead. (Even if they were a bit more expensive)
Offline safian
« Reply #13073 on: Sun, 23 August 2015, 13:51:07 »
What keyboard is that? http://imgur.com/a/7fJAl
Hey guys, I have a MK for my main PC already, and I'm looking for a cheap keyboard for my second old PC that I have for experimenting with Linux distros and stuff. My dream is to have a Model M for that, but I don't have any spare money so I'm always checking local annoucments site hoping one will apear some day. I've found this keyboard and I have no idea what is it and if it's worth a buy? I guess it's probably not mechanical, but its ~8 bucks. Does anyone have idea what keyboard is it and if it's any good? http://imgur.com/a/7fJAl
Offline alienman82
« Reply #13074 on: Sun, 23 August 2015, 21:35:06 »
removed.
« Last Edit: Thu, 01 March 2018, 17:13:11 by alienman82 »
« Reply #13075 on: Sun, 23 August 2015, 21:51:24 »
Is it at all possible to get a better picture of the top and the back label? Maybe a picture of a cap pulled off. It's really hard to see what that is at all.
I can't seem to find a guide on programming a duck viper.  Can anyone help me?  Thanks a bunch, sorry I have to asks
https://geekhack.org/index.php?topic=55427.msg1283624#msg1283624
Does this work?
Offline jorgenslee
« Reply #13076 on: Mon, 24 August 2015, 00:36:57 »
Does SA R4 = upside down SA R3? I'm talking about blanks.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #13077 on: Mon, 24 August 2015, 01:25:29 »
R4 probably means row 4, See this link for how the different rows stack against each other.  When a SA set is "uniform" they are all row 3, but profiled sets are all rows.
http://www.keycapsdirect.com/key-caps.php
Offline jorgenslee
« Reply #13078 on: Mon, 24 August 2015, 01:38:23 »
Thanks for the link. Yeah I am talking about the Row 4 and Row 2. I was asking the question because I notice that Row 2 and Row 4 is somewhat like mirrored on some of the pictures posted online. But I can't confirm it since I don't have an SA.
I am curious to know this because I plan to put a 1.25x R4 Mods as Tab on JD40 which requires a 1.25x.
Edit: My original question is incorrect, it should be
Does SA R4 = upside down SA R2
« Last Edit: Mon, 24 August 2015, 01:40:14 by jorgenslee »
Offline safian
« Reply #13079 on: Mon, 24 August 2015, 07:20:54 »
I didn't buy it yet, and these are the pictures I've got. I'll buy it day after tomorrow and update you on it.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #13080 on: Mon, 24 August 2015, 12:42:02 »
Is there a way to convert a mini-DIN 5 to USB? Just got an Alps numpad that uses it.
Offline njbair
    • nickbair.net
« Reply #13081 on: Mon, 24 August 2015, 23:27:03 »
Pretty sure row 2 and row 4 are exact mirrors, yes.
My boards:
Offline Eugene45
« Reply #13082 on: Tue, 25 August 2015, 08:10:45 »
Just use an active converter like this one : http://www.ebay.com/itm/Beige-USB-to-Dual-PS-2-Keyboard-Mouse-Converter-Cable-Active-Adapter-USB-2PS2-/270863821433?hash=item3f10bdea79
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #13084 on: Tue, 25 August 2015, 08:38:40 »
Thanks guys but PS/2 is mini-DIN 6. :P I went ahead and tried one of my PS/2 converter anyways and to my surprise it fit (the last Panasonic I had with a 5 pin connector was different) but it doesn't work.
Offline Sed8op8
  • Keyboard Padawan
« Reply #13085 on: Tue, 25 August 2015, 08:50:17 »
So I have mentioned this in a couple threads but the switch tops on my ergo clears are coming off every time I change caps. I have a gon til I got with switches pre modded by gon and about 1/3 maybe 1/4 of the switches have this problem. I can hold the tops down with a small screw driver but it's a pain in the ass. I'm wondering if anyone else has this problem and if maybe the tabs just got weakened by removing the tops to many times during the luning,stickering and spring swap process.
Does anyone know if replacing the switch tops will fix this? Sorry to post this in a couple of threads but the responses I have gotten is that the caps are too tight on the switch stem. This is very common on cherry clears however this is the first time this has happened to me even though I have a few other boards with clears and change the caps constantly with no problems.
I hope there is some sort of solution besides re soldering in different switches !?
Any ideas or help will be greatly appreciated 8)
Thanks all
« Reply #13086 on: Tue, 25 August 2015, 08:54:54 »
Thanks all
There's a little nubbin or bump on the stem of Cherry MX Clears which seems to lead to this problem. I think some people have said they've solved it by wiggling the caps more and not pulling straight up on the caps as much. But it's definitely worth trying to swap in new tops. I'm not sure where to get new Cherry MX tops but the Gateron tops seem ok. I haven't really had the chance to play with mine too much though.
I can't remember but do GON keyboards have the cutouts for switch top removal? If so you could swap the stems and tops for something else.
« Reply #13087 on: Tue, 25 August 2015, 09:25:37 »
Thanks all
GON keyboards do not have the cutouts for switch top removal, because GON doesn't like that adding the cutouts increases the chances for pulling the tops off when swapping caps.
« Reply #13088 on: Tue, 25 August 2015, 09:27:41 »
Thanks all
That's a bit ironic considering sed8op8's question :))
« Reply #13089 on: Tue, 25 August 2015, 12:54:23 »
Thanks all
It is, and I almost made note of that when I typed it.  :))  But just think of how many more tops she would have lost if he had the cutouts!  :eek:
Offline pr0ximity
« Reply #13090 on: Tue, 25 August 2015, 16:07:17 »
Thanks all
Sounds like the repeated popping-off has worn the tops in a way that makes it even more likely to come off. I know the tabs are a bit prone to bending; a few of the switches I've modded have had their tabs irreversibly bent (but still able to be clipped together only just) without too much effort.
Offline Sed8op8
  • Keyboard Padawan
« Reply #13091 on: Tue, 25 August 2015, 18:06:44 »
Thanks all
Good thing I like Hyperfuse as its not coming off now unless I really need to change my caps haha
Offline Heliobb
« Reply #13092 on: Wed, 26 August 2015, 03:35:42 »
Is an mx3000 ? Mechanical switches ?
Thanks  :D
Offline davkol
  •  Post Editing Timeout
« Reply #13093 on: Wed, 26 August 2015, 03:44:00 »
Probably, although it could be G81-3000 too ("semi-mechanical" MY switches, incompatible stabs and off-center stems on 1.25x modifiers).
Offline Heliobb
« Reply #13094 on: Wed, 26 August 2015, 04:07:35 »
Ok thanks
Offline clacktalk
  • circa 2015
« Reply #13095 on: Wed, 26 August 2015, 04:39:45 »
what's the best lube for cherry stabs? i have some thick lube from EK, but the stabs that I've come across that feel better than any of my work have had thicker, whiter lube.
this is a very serious post. don't sex innuendo me
diary of a clacktalk
radio_killah: too much frank
Offline meiosis
  • Time
« Reply #13096 on: Wed, 26 August 2015, 04:43:00 »
I prefer KY
Keyboards:
Aripeko TKL
« Reply #13097 on: Wed, 26 August 2015, 05:40:42 »
Thanks  :D
If you can get a picture of the back label, that'd be the best way for us to give a definitive answer.
I use the thick krytox grease. Mainly because I've got the really thick grease stuff and the thinner oil stuff. So I mix my own krytox blend but I can also use either or for other things.
Offline Heliobb
« Reply #13098 on: Wed, 26 August 2015, 07:01:20 »
Thanks  :D
I've bought it. I will let you know. :)
« Reply #13099 on: Wed, 26 August 2015, 07:35:30 »
I don't use Cherry switches, but I have used the thick lube from EK on many other wire tabs and I think that it works great.
My syringe (some scant partial spoonful amount) is just now running out and I have had it for a couple of years and done at least a couple of dozen boards, but I only use a tiny amount on each. I love the thin curved nozzle and wish they all were like that.
