Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6278757 times)
Offline kennardsmith
« Reply #13250 on: Sat, 19 September 2015, 13:27:53 »
Anyone know anything about the alu 60% case on MD? The blue looks nice..
I've got the gold one. It's heavy!
Still on the fence about it (no information on the manufacture, can't find any thorough reviews...)
Oh well I'll wait til the last minute I guess.
I'm pretty sure it's the same as these:
http://world.taobao.com/item/40921762675.htm?spm=a312a.7700714.0.0.qbEGO3#detail
Let me know if I can tell you anything about the case. I like it a lot, will probably get another one soon.
[Control] is just left side of [A]. It comes from Sun Type3 key layout.
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #13251 on: Sat, 19 September 2015, 13:45:39 »
I got a silver one on the last drop.
It's  nice. I just wish they would offer it in a grey color.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline Bomble
« Reply #13252 on: Sat, 19 September 2015, 22:43:30 »
My HHKB spacebar has a real click/rattle sound to it, particularly when pressed on the left side (I press space with my left thumb :().
I've searched around a little bit and I couldn't find any solutions - I assume it's the probably the stabiliser? Anyone know what to do?
Bump to this while I'm here
But also, I'm looking to silence mod my HHKB - is there an advantage to Hypersphere's silencing rings other than convenience? Or would I get a similar effect from ironing EK landing pads? The weak Australian dollar is making this very difficult :(
« Reply #13253 on: Sat, 19 September 2015, 23:24:10 »
1) I've searched around a little bit and I couldn't find any solutions - I assume it's the probably the stabiliser? Anyone know what to do?
2) But also, I'm looking to silence mod my HHKB - is there an advantage to Hypersphere's silencing rings other than convenience? Or would I get a similar effect from ironing EK landing pads? The weak Australian dollar is making this very difficult :(
Don't bump please.
1) Here's four threads I found really quick.
https://geekhack.org/index.php?topic=40653.0
https://geekhack.org/index.php?topic=46648.0
https://geekhack.org/index.php?topic=50312.0
https://geekhack.org/index.php?topic=66981.0
2) Here's some popular silence mods:
https://geekhack.org/index.php?topic=40582.0
https://geekhack.org/index.php?topic=34972.0
I don't Topre so I have personal experience on if this works or not.
Offline Bomble
« Reply #13254 on: Sat, 19 September 2015, 23:32:43 »
Don't bump please.
Oops :-X sorry man.
Thanks for the links, the clicking seems to be from when I either rest my thumb on space, or when I bottom out. So I'm guessing I'll just need to lube it.
As for the silencing, I know what options I have, I'm just curious as to a comparison between the two methods that I mentioned :)
Offline edb5s
« Reply #13255 on: Tue, 22 September 2015, 12:29:02 »
Can someone identify this board?
« Reply #13256 on: Tue, 22 September 2015, 12:30:07 »
Either an IBM M2 (low profile BS board) or a rubber dome. I'm leaning towards M2.
Offline edb5s
« Reply #13257 on: Tue, 22 September 2015, 12:35:10 »
Thanks for the input. Since I posted, I did some more searching and it looks like it is an IBM KB-8923, which is a rubber dome board.
https://geekhack.org/index.php?topic=72595.0
« Reply #13258 on: Tue, 22 September 2015, 12:39:14 »
The 8923 is a very well-built rubber dome board, I have had a few of them.
The case of an M2 is considerably smaller.
- D Trump 2026-10-24
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #13259 on: Tue, 22 September 2015, 15:56:53 »
The M2 is also less round than that one.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #13260 on: Tue, 22 September 2015, 19:16:51 »
Can someone post a side shot of some Leopold blanks please?  Also, number of each size and each row for the singles would be great.  Going to be selling mine and just want to check if I have all of them.
Offline Bucake
« Reply #13261 on: Wed, 23 September 2015, 14:54:23 »
what are my options to get an IBM Model F 'XT' to work on new hardware?
(i have PS/2 on this motherboard in case that gives me more options)
« Reply #13262 on: Wed, 23 September 2015, 14:56:19 »
PS/2 to USB converter
Teensy converter
Hasu converter
xwhatsit Controller
I think phosphorglow has a controller out too
Offline Bucake
« Reply #13263 on: Wed, 23 September 2015, 16:36:04 »
Teensy converter
Hasu converter
xwhatsit Controller
thanks a ton for your response :)
did some googling to your suggestions, and eventually found this on ebay: http://www.ebay.com/itm/281476427201
looks pretty damn incredible, can't believe there's a converter in there. anyway, hopefully i'll be able to get one once the seller is processing orders again..
thanks again!
Offline Melvang
« Reply #13264 on: Wed, 23 September 2015, 16:41:23 »
Teensy converter
Hasu converter
xwhatsit Controller
I didn't realize that xwhatsit worked on the XT due to the controller being onboard.  Or am I missing something there with pulling that chip out?
« Reply #13265 on: Wed, 23 September 2015, 18:02:32 »
I assumed if it worked for a Kishsaver, it would work for an XT. Is that not the case?
Offline Melvang
« Reply #13266 on: Wed, 23 September 2015, 18:35:09 »
To my knowldedge no.  Because the xwhatsit is a full controller swap, and reads the matrix directly.  Hence all the cap sense adjustments in the GUI.  With the XT, since it is fixed on the board, I was under the impression that you were limited to converters.  Though there are still options.  Granted I don't remember if XT can be used on USB/PS/2 with simple plug changes.
« Reply #13267 on: Wed, 23 September 2015, 19:58:02 »
No, it takes more. The DIN plug on the XT looks like an AT plug but doesn't speak the same language.
Orihalcon's cables are the cleanest and easiest, but not the cheapest.
Hagstrom makes a plug & play outboard converter.
Soarer's / Teensy probably gives the most options, but you have to buy it and build it.
Offline darkspider
« Reply #13268 on: Thu, 24 September 2015, 06:09:26 »
Anyone know if I can assign FnLock to some key on Model F using Xwhatsit?
IBM Model F AT         Model M silver label    Model M gray label    Majestouch 2 Ninja
Brand New F62 Kishsaver / F77 Industrial Model F's made this year
« Reply #13269 on: Thu, 24 September 2015, 07:58:39 »
Orihalcon listed some programming procedures in his ebay listing that will probably work. Look down in the details.
http://www.ebay.com/itm/271973216154
Offline Melvang
« Reply #13270 on: Thu, 24 September 2015, 09:34:02 »
I know you can with an external switch from the expansion header.
Offline darkspider
« Reply #13271 on: Thu, 24 September 2015, 17:33:33 »
Offline ideus
  • Björkö.
« Reply #13272 on: Fri, 25 September 2015, 10:09:16 »
On switch opening, is there a recommended procedure to open a switch with a simple flat screw driver? I did that yesterday, and I found it to be doable, but wonder if there are some tips to do it better. I know there are fancy switch tools, as well as some DIY clip ones; but the driver had the job done.
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #13273 on: Fri, 25 September 2015, 10:16:54 »
Before I had a switch opener tool I found the easiest thing to use was pointy tipped tweezers, the kind that you can find in the beauty section at a CVS, or other drug store.
Offline davkol
  •  Post Editing Timeout
« Reply #13274 on: Fri, 25 September 2015, 10:19:45 »
Alps SKCM, or Cherry MX compatible? I always use a pair of curved tweezers for MX.
Offline ideus
  • Björkö.
« Reply #13275 on: Fri, 25 September 2015, 11:52:13 »
I am sorry, I did not mention they were Cherry clear switches. Do you have a picture or reference for those particular tweezers, and it sounds like a great idea.
Offline ideus
  • Björkö.
« Reply #13276 on: Fri, 25 September 2015, 12:07:50 »
Is there a place, besides the marketplace, to get Cherry clear stems?
Is there a Gateron switch whose stem is closer to Cherry clear?
« Reply #13277 on: Fri, 25 September 2015, 12:57:07 »
https://geekhack.org/index.php?topic=74807.0 for the gateron equivalent
But there isnt' anywhere to buy just clear cherry mx stems, mechanicalkeyboards.com (https://mechanicalkeyboards.com/shop/index.php?l=product_list&c=58) has some clear cherry mx switches
You can also substitute mx tactile gray stems as they are the same, the spring is what makes the difference.
Offline davkol
« Reply #13278 on: Fri, 25 September 2015, 14:20:21 »
See this video.
Offline ideus
  • Björkö.
« Reply #13279 on: Fri, 25 September 2015, 17:10:42 »
Thank you SpamRay and Davkol for the answers, I will have a sweet time checking them, this afternoon.
Offline ideus
  • Björkö.
« Reply #13280 on: Fri, 25 September 2015, 17:18:13 »
See this video.
Those tweezers work great, thank you again for the reference.
Offline ideus
  • Björkö.
« Reply #13281 on: Fri, 25 September 2015, 17:23:24 »
This Zealios - 65g - Tactile (Purple ergo-clear stem) - have the same specifications of my modded clears; but, the color and the high price.
Thank you for the reference.
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #13282 on: Fri, 25 September 2015, 19:23:43 »
Oh, so you got clear tops and bottom housing on your modded clears for the same price? Where can I get some? :thumb:
Offline LechnerDE
« Reply #13283 on: Sat, 26 September 2015, 02:22:55 »
Has anybody saved the GMK Red Alert mock up pic from Photekq's mini GB?
The link is dead and only the Olivetti pic is still up.
Offline davkol
« Reply #13284 on: Sat, 26 September 2015, 02:35:19 »
Not sure if this is a simple question (or the answer would be simple)… I'm potentially interested in getting a Leeku PCB (probably the 1800 one) and using it with a custom layout (ANSI HHKB, ISO Shift and JIS spacebar row). However, I haven't found a clear statement
  • what the controller is (i.e., the chip or something),
  • how programming is done and/or what firmware is supported.
I have found several threads about what appears to be different revisions, and some GitHub repo, but I wonder if there's some precise specification somewhere (or if anyone can post it).
(For the record, I use GNU/Linux and have dfu-programmer installed among other stuff, but I guess other systems would give me some clue anyway.)
Offline azhdar
  • Praise the AZERTY god
« Reply #13285 on: Sat, 26 September 2015, 02:46:15 »
What pcb are you talking about here?
My LZ-SQ is a leeku PCB and I have the Jigon software, that is almost as good as the Gon one.
And I know he recently moved his 3000 & 1800 pcb onto this Jigon tool. It might be a windows only software tho, I'm not sure.
Azerty Propagandiste
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #13286 on: Sat, 26 September 2015, 02:59:46 »
Here ya go.
WTB/WTS/WTT ---->
Offline LechnerDE
« Reply #13287 on: Sat, 26 September 2015, 03:02:27 »
Here ya go.
Thanks  :thumb:
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #13288 on: Sat, 26 September 2015, 03:03:22 »
Here ya go.
Thanks  :thumb:
No problem  :)
WTB/WTS/WTT ---->
Offline davkol
« Reply #13289 on: Sat, 26 September 2015, 03:19:52 »
…I'm potentially interested in getting a Leeku PCB (probably the 1800 one)… However, I haven't found a clear statement
I've highlighted the 1800 mention and the link to the MX1830 repo (last updated earlier this month).
Thanks anyway; if it's true that there's some migration to a closed solution going on, it might save quite some monies.
Offline azhdar
« Reply #13290 on: Sat, 26 September 2015, 03:29:52 »
I think the Jigon tool is just a facilitator and you can work you own thing, but don't use me as a source I'm not quite certain.
Offline Bucake
« Reply #13291 on: Sun, 27 September 2015, 10:12:42 »
why are industrial IBMs so much more expensive than 'regular' ones?
i've seen top-condition IBMs go for a few dozens of bucks, but then see the industrial version go for 400, or 600, or even 800+? what makes them so special, rarity?
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #13292 on: Sun, 27 September 2015, 10:16:37 »
Offline njbair
    • nickbair.net
« Reply #13293 on: Sun, 27 September 2015, 13:29:51 »
Rarity, hype. It's a bubble.
My boards:
« Reply #13294 on: Sun, 27 September 2015, 13:56:26 »
The same reason that coin collectors pay 100x as much for a 1909S VDB Lincoln cent than for a 1909 VDB.
Offline Bucake
« Reply #13295 on: Mon, 28 September 2015, 18:26:37 »
hehe, got it.
so i have a zenith 100-1886 coming in. does anyone know if this thing is AT, or XT? would it be safe to just try it out with an AT to PS/2 adapter?
also, is there anything i should keep in mind when i open it up for cleaning? like a risk of breaking (stabilized) caps when pulling them up? (it uses Alps SKCL.)
Offline dohbot
« Reply #13296 on: Mon, 28 September 2015, 19:02:00 »
Well my question would be, what would the FC660M aluminum case in titanium grey look like with hyperfuse on it? So if someone has that combo, I'd love a picture, but since I don't know if anyone has that case or one by the same company with the same color, I'll ask, what color aluminum case http://world.taobao.com/item/520940971460.htm?spm=a312a.7700714.0.0.MLdXWo#detail would be best suited towards hyperfuse?
Offline ideus
  • Björkö.
« Reply #13297 on: Mon, 28 September 2015, 23:33:32 »
Where I can get some sip sockets? and what is the main difference between long and short ones?
« Reply #13298 on: Tue, 29 September 2015, 08:47:52 »
I know this question comes up an awful lot regarding various custom boards, but after some light searching I'm coming up empty.  :(  So, sorry to be that guy, but:
Does anyone know the alloy type used in The Cheat's construction?
« Reply #13299 on: Tue, 29 September 2015, 09:10:50 »
1) Well my question would be, what would the FC660M aluminum case in titanium grey look like with hyperfuse on it? So if someone has that combo, I'd love a picture, but since I don't know if anyone has that case or one by the same company with the same color, I'll ask,
2) what color aluminum case http://world.taobao.com/item/520940971460.htm?spm=a312a.7700714.0.0.MLdXWo#detail would be best suited towards hyperfuse?
1) This is the closest picture I could find of that case color and a quick search.
https://www.massdrop.com/buy/aluminum-case-for-leopold-fc660m/talk - Case for reference
http://i.imgur.com/6R7DPK6.jpg - Keyboard (Not sure who is the owner or what keyboard it is :()
2) Definitely personal preference in terms of what you think is "best". I can't do color comparisons on my work computer though to give you my opinion since my work computer's colors are jacked.
1)Where I can get some sip sockets?
2) and what is the main difference between long and short ones?
1) https://geekhack.org/index.php?topic=51792.msg1413823#msg1413823
2) You mean besides the length? :)) I'd just use whatever everyone else used. I would imagine that the longer ones would make it harder to install.
hehe, got it.
I'm guessing AT from these pictures. Alps in general are more susceptible to dirt, dust, and grime affecting the feeling so you may want to clean it. Alps caps are harder to pull off so make sure you rock from side to side while pulling caps. Be very careful pulling stabilizers as they're hard to come off and if you break them, very hard to replace. I suggest checking out chyros' videos on how he cleaned up his Alps boards. Also BlueBar has a good video IIRC.
Seems like the vast majority of customs are Aluminum 6061 but I'm not sure. I couldn't find an answer but I did find this clue from DanGWanG.
