Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6278752 times)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #13400 on: Sun, 11 October 2015, 22:14:53 »
Any suggestions for getting ball point pen out of PBT caps?
Denture cleaner doesn't seem to be getting through.
My process is: (1) soap (2) alcohol (3) mineral spirits (4) naptha or acetone [careful!] (5) abrasives - white "Mr Clean" sponge eraser - Scotchbrite scrubber - pencil eraser - electric eraser - sandpaper
Water with 15% in weight backing soda, let the caps in the mix for half an hour, and scrub them gently with scothbrite, clean them and you got it. Solvents and abrasives are not recommended by any means.
Thanks guys.  I know the "Mr. Clean" eraser is a mild abrasive, but that worked fine for the pen ink.  It was just along the front face of the bottom row of caps.  Didn't take much and got rid of the ink.
Offline ideus
  • Björkö.
« Reply #13401 on: Sun, 11 October 2015, 22:18:02 »
Awesome. Good job then.  :thumb:
Offline nmur
  • ಠ_ಠ
« Reply #13402 on: Mon, 12 October 2015, 23:06:25 »
What does it feel like to type on ergo clears mounted in a heavy-ass aluminium board (OTD, LZ, KMAC, etc)? I've tried neither.
What would be the first choice that comes to your mind if I asked you about a full-size aluminium board (with winkeys)?
Do I bring dishonour to my family if I said I feel like selling my hhkb for a full size RF?
Offline jonathanyu
« Reply #13403 on: Tue, 13 October 2015, 00:26:41 »
To me the feel is more depends on the plate than the case.
The first one came to my mind is LZ-trikx.  I am not sure it has winkey or not.  The second is Cherry MX6.0
Offline nmur
  • ಠ_ಠ
« Reply #13404 on: Tue, 13 October 2015, 00:48:48 »
hey thanks
Yeah I guess now that I think about it, the case would probably affect the sound more than it would affect the feel.
That LZ-tirks looks pretty nice, albeit not too exciting. I might consider getting a TKL (so many more options) and a seperate numpad or something. This is if I ever hypothetically decided to spend the $$$$
« Reply #13405 on: Tue, 13 October 2015, 07:31:51 »
Solvents and abrasives are the last resort, of course.
The Mr Clean white erasers are pretty good, but they will take the texture off a surface surprisingly fast.
- D Trump 2026-10-24
Offline ideus
  • Björkö.
« Reply #13406 on: Tue, 13 October 2015, 07:42:50 »
I'd say that plate rigidity makes a greater difference in feeling than any other characteristic of the board overall assembly, along with switches of course. If you use a plate made of steel, plastic, acrylic or aluminum, and its thickness will make a difference in typing sound and feeling that are the key aspects of the typing experience.
« Reply #13407 on: Tue, 13 October 2015, 08:12:07 »
1) What does it feel like to type on ergo clears mounted in a heavy-ass aluminium board (OTD, LZ, KMAC, etc)? I've tried neither.
2) What would be the first choice that comes to your mind if I asked you about a full-size aluminium board (with winkeys)?
3) Do I bring dishonour to my family if I said I feel like selling my hhkb for a full size RF?
1) I don't have a good review on ergo-clears but here's one on Zealios which is similar in feeling to me. In addition, here's a plethora of reviews and threads on this topic. I also agree that the feeling depends a lot on the case and keycaps used.
2) In addition to the two options Johnathanyu listed, there was this aftermarket case for Filcos. There's not many options.
3) I don't understand. Do you. If you like full size, get a full size. Why do you care what others think?
Offline Eugene45
« Reply #13408 on: Tue, 13 October 2015, 13:20:08 »
By any chance an european supplier for http://imsto.cn/index.php?route=product/product&path=61&product_id=78 in small size ?
Looking for the same or something similar in quality ?
Thanks
lmao, cut the French some slack, they gave you a big statue
« Reply #13409 on: Tue, 13 October 2015, 16:19:59 »
Thanks
lpwl had a ton. Apparently lpwl has sold out but you can ask. That's all I can think of though. I'd try asking DT too just in case. This forum is definitely CONUS skewed.
Offline ika
« Reply #13410 on: Tue, 13 October 2015, 17:59:03 »
Anyone know how to get a replacement spring for a Topre spacebar? Apparently the previous owner for my Realforce lost it or something, because I don't have a spring under my spacebar. Also apparently I need the spring to make the PBT spacebars return properly. Not sure if Topre sells replacements or where I can fashion a replacement with roughly the same weight.
« Reply #13411 on: Tue, 13 October 2015, 19:36:21 »
Classifieds is probably your best bet. I'm not aware of any vendors that sell those springs as a spare part.
Offline ideus
  • Björkö.
« Reply #13412 on: Tue, 13 October 2015, 21:33:48 »
Unfortunately, the lack of options to replace a single faulty part is the price to pay for using non discrete keyboards . Have you tried the classifieds, or the free stuff threads?.
Offline ika
« Reply #13413 on: Tue, 13 October 2015, 21:44:16 »
Haven't tried Classifieds yet but from a few google searches I see this question asked a lot with no concrete answers. I've just been reaching out to see what my options are. Spamray mentioned springs from an old foam and foil keyboard, anyone got one to try out?
« Reply #13414 on: Wed, 14 October 2015, 14:42:48 »
If I'm looking for cool Alps caps what boards should I look for? ANSI really isn't an issue because none of my layouts are standard.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #13415 on: Wed, 14 October 2015, 17:21:24 »
APC and Clicker.
« Reply #13416 on: Wed, 14 October 2015, 20:42:44 »
Please use the classifieds to try and get a spring. I don't want this to be a place to circumvent the classfifieds.
I forget the model but Toshiba laptops have Dolch-alike Alps caps.
I like Wang 724, 725 the dye-sub caps.
The Apple AEK/AEK2 and Dell AT101 caps are surprisingly good.
My favorite caps are still the ones I found in Classifieds. They're Taiwanese layout Acer 6131 caps.
Offline swimmingbird
  • keyset hoarder
« Reply #13417 on: Thu, 15 October 2015, 08:03:55 »
Is there an alternate controller for the RF 87u that allows you to reprogram the keys like Hasu's one for the HHKB?
« Reply #13418 on: Thu, 15 October 2015, 08:05:41 »
Hasu is working on one that might eventually lead to something. https://geekhack.org/index.php?topic=76040.0
  • keyset hoarder
« Reply #13419 on: Thu, 15 October 2015, 08:08:25 »
Thanks man!
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #13420 on: Thu, 15 October 2015, 11:47:29 »
Where do you buy stand-off led? I need some for Phantom.
« Reply #13421 on: Thu, 15 October 2015, 11:56:22 »
See bottom of this OP -> https://geekhack.org/index.php?topic=46758.0
  • Frenzy Classic.
« Reply #13422 on: Thu, 15 October 2015, 11:59:53 »
Thanks ray. I pm'ed jonathanyu.
Offline alienman82
« Reply #13423 on: Thu, 15 October 2015, 22:57:41 »
removed.
« Last Edit: Thu, 01 March 2018, 17:11:24 by alienman82 »
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #13424 on: Thu, 15 October 2015, 23:07:35 »
Are there any Alps artisans available right now besides the ones that bcredbottle is working on?
I'm pretty sure these are dampened cream alps, but some click.  Any thoughts?
Definitely damped, you can see the notches on the sides. They shouldn't click unless someone replaced them with non-damped switches.
Offline alienman82
« Reply #13425 on: Thu, 15 October 2015, 23:11:41 »
removed.
« Last Edit: Thu, 01 March 2018, 17:11:22 by alienman82 »
Offline pabile
    • pabile online
« Reply #13426 on: Fri, 16 October 2015, 00:54:02 »
can i build a custom keyboard without diode? nkro is not a quirement.
  • Frenzy Classic.
« Reply #13427 on: Fri, 16 October 2015, 04:27:43 »
If you 're not use diodes, switchs isn't work.
Offline pabile
    • pabile online
« Reply #13428 on: Fri, 16 October 2015, 06:21:59 »
oh! thanks quochung!
Offline njbair
    • nickbair.net
« Reply #13429 on: Fri, 16 October 2015, 07:39:07 »
This is wrong. You can replace diodes with jumper wires and it will work fine, just with ghosting issues.
My boards:
Offline njbair
    • nickbair.net
« Reply #13430 on: Fri, 16 October 2015, 07:41:40 »
In the meantime, his USB to USB converter will work. https://geekhack.org/index.php?topic=69169.0
My boards:
« Reply #13431 on: Fri, 16 October 2015, 07:46:21 »
Had not even considered that. Great idea.
« Reply #13432 on: Fri, 16 October 2015, 08:14:45 »
There's a handful of novelty Alps caps floating around out there but there's nothing easily available or new besides bcredbottle's stuff. Previously, do_og@n had painted some Alps caps and there were some Geekhack and MK.com Alps caps. Oh I think SP has a red escape too.
Been dreaming of nice Alps novelties for years now.
  • Frenzy Classic.
« Reply #13433 on: Fri, 16 October 2015, 08:20:45 »
Ok. thanks for showing me. I don't think this way.
« Reply #13434 on: Fri, 16 October 2015, 13:59:32 »
Nubs has done a lot of work with alps too!
« Reply #13435 on: Sat, 17 October 2015, 16:03:35 »
Anybody know what language these represent?
« Reply #13436 on: Sat, 17 October 2015, 20:26:36 »
Looks like Thai.
Also pretty sure the caps are upside down in the pic.
Offline Melvang
« Reply #13437 on: Sat, 17 October 2015, 23:41:43 »
Is there anywhere to source new F springs?
« Reply #13438 on: Sun, 18 October 2015, 00:05:33 »
Not that I'm aware of.
Looks like Thai.
I agree.
Offline Melvang
« Reply #13439 on: Sun, 18 October 2015, 00:07:57 »
Looks like Thai.
I agree.
Thanks cpt, I just sent a pm to Ellipse.  I am doing a spill restoration project and fount 3/4 of the springs rusty.  The spill managed to get under the barrel plate, both sides of the pcb, and below the mylar sheet.
Offline alienman82
« Reply #13440 on: Sun, 18 October 2015, 10:19:47 »
removed.
« Last Edit: Thu, 01 March 2018, 17:10:27 by alienman82 »
Offline bcredbottle
« Reply #13441 on: Sun, 18 October 2015, 11:07:27 »
AFAIK it's currently just nubbinator and me. Quality-wise, I'm not really a legit artisan though. Nubs makes sale-quality caps while I'm more of an amateur/weekend warrior. The only thing that's better about my caps is that they'll always be free  :)
BlueNalgene is working on some artisan Alps so maybe you can PM him; I bet he'd like to hear the interest/encouragement. Hopefully in the future we'll see Alps caps routinely included in artisan sales the way Topre caps are now.
Offline alienman82
« Reply #13442 on: Sun, 18 October 2015, 20:45:57 »
removed.
« Last Edit: Thu, 01 March 2018, 17:10:11 by alienman82 »
« Reply #13443 on: Sun, 18 October 2015, 20:46:53 »
how to use animated gif?
For what? Your avatar or just in a post?
Offline alienman82
« Reply #13444 on: Sun, 18 October 2015, 20:47:25 »
removed.
« Last Edit: Thu, 01 March 2018, 17:10:09 by alienman82 »
« Reply #13445 on: Sun, 18 October 2015, 20:49:05 »
« Last Edit: Sun, 18 October 2015, 20:50:53 by CPTBadAss »
Offline alienman82
« Reply #13446 on: Sun, 18 October 2015, 20:52:03 »
removed.
« Last Edit: Thu, 01 March 2018, 17:10:07 by alienman82 »
Offline raymogi
« Reply #13447 on: Mon, 19 October 2015, 07:35:59 »
What's the 2 dipswitches on the 360 Corsa for?
Please feed my addiction.
Offline apolotary
  • Кто-нибудь купите мои клавиатуры ;__;
« Reply #13448 on: Tue, 20 October 2015, 04:19:54 »
Desoldered almost all switches off my v60, but it seems like there's still something that sticks top plate to the PCB. What could it be? Cherry-style stabilisers?
  • Frenzy Classic.
« Reply #13449 on: Tue, 20 October 2015, 04:29:18 »
What PS2 to USB converter should I buy?
