Author Topic: HHKB Key Rattle  (Read 3947 times)
Offline Flyersfan1
  • Hi!
HHKB Key Rattle
« on: Wed, 30 October 2013, 17:23:49 »
Hi Everyone! I'm having a bit of a strange issue with my newly aquired HHKB, it's not the biggest issue in the world, but would really like to perhaps see if there's a way to fix it.  One key in particular is making a very strange rattling noise on the upstroke of the key. I tried the obvious stuff like taking the keycap off and putting it back on, but it unfortunately stayed the same. I took some videos to better articulate what I'm talking about, my assumption is that something is wrong with the spring underneath the dome of the switch.  I'm very nervous about taking apart this board since it was so expensive and all, I did e-mail Brian over at EK for any suggestions from them or to see if it was RMA worthy, but thought it wouldn't hurt just to see if I could get any insight from you guys in the meantime.  Thanks for reading!
http://www.flickr.com/photos/107216566@N08/10579811795/
http://www.flickr.com/photos/107216566@N08/10581709616/
« Last Edit: Wed, 30 October 2013, 17:29:14 by Flyersfan1 »
Quote from: Photekq
Re: HHKB Key Rattle
« Reply #1 on: Wed, 30 October 2013, 17:30:58 »
happens to everyone..  it's fine.. chill... not a defect... you're good to go....
Offline ComradeSniper
  • HHKB Pro
Re: HHKB Key Rattle
« Reply #2 on: Wed, 30 October 2013, 17:34:51 »
Mine does that on a key or two as well, I'm fairly certain that it's normal.
Offline Flyersfan1
  • Hi!
Re: HHKB Key Rattle
« Reply #3 on: Wed, 30 October 2013, 17:35:17 »
Oh ok, sorry, I wouldn't have made a new thread if I knew this.  I didn't find any other topics describing this thing so I thought it might have been worth asking.
Quote from: Photekq
Re: HHKB Key Rattle
« Reply #4 on: Wed, 30 October 2013, 17:52:35 »
no need to be sorry... like I said... YOUR GOOD TO GO....
Offline unicomp_uc
  • Interboardal Love
Re: HHKB Key Rattle
« Reply #5 on: Wed, 30 October 2013, 17:56:35 »
I'm glad you asked because I was kind of wondering the same thing. My letter 'f' key does make a lighter, rattlier noise than the others which I found odd. Glad to know it's just normal non-uniformity. I wish they all had the thockiness of my left shift button... best sounding key I have by far... I'm regularly turning on the sticky key prompt because sometimes I just like to hear the thock in all its glory :)
Realforce 87U Silent (work) | HHKB Pro 2 | Filco Minila browns | Unicomp Ultra Classic
Re: HHKB Key Rattle
« Reply #6 on: Wed, 30 October 2013, 17:57:56 »
At least this thread will stand as a reference for anyone else searching for Thorpe rattle.
Er, Topre rattle.
Um, HHKB rattle.
  • HHKB Pro
Re: HHKB Key Rattle
« Reply #7 on: Wed, 30 October 2013, 18:33:24 »
I agree, seems like all stabilized Topre keys feel and sound much better than non stabilized ones.
