Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6277791 times)
0 Members and 7 Guests are viewing this topic.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #12600 on: Sun, 14 June 2015, 22:20:02 »
Could someone recommend me a good ps2-->usb adapter for my Cheat? I have a few cheap ones lying around, but I'm sure they aren't going to be powerful enough to drive the keyboard, was thinking about this but would like some feedback from others on what might work best.
Not sure if he still has any left but mkawa had some good ones up on his geekhackers store.
Yeah, the ID innovations one is nice, techkeys currently has it, but it's a little more than I'm looking to spend right now, will definitely go for it if there aren't any cheaper options.
The other one I keep hearing people talk about is the blue cube.
Offline Flyersfan1
  • Hi!
« Reply #12601 on: Sun, 14 June 2015, 22:23:21 »
I'm assuming that's the one I linked?  ;D
Quote from: Photekq
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #12602 on: Mon, 15 June 2015, 01:23:25 »
Yep, that's the one I've always used, never had any problems
« Reply #12603 on: Mon, 15 June 2015, 05:32:06 »
FWIW I can recommend the ID innovations one (I got mine from mkawa, but the TechKeys one is the same).
If it can get a Model M via an AT to PS/2 adaptor then the ID innovations PS/2 to USB converter connected to a Mac and working, it should work for anything!
Offline pr0ximity
« Reply #12604 on: Mon, 15 June 2015, 06:06:44 »
My 356 Mini had a bunch of issues using the BlueCube. Lots of repeated and stuck keys. Got a Monoprice active adapter and it works great:
http://www.amazon.com/Monoprice-Keyboard-Converter-Adapter-110934/dp/B00IACID2C
BlueCube works great for my Model M, but for some reason the 356 is very temperamental.
Offline Zustiur
« Reply #12605 on: Mon, 15 June 2015, 08:39:48 »
Where is the best place to find conventional wisdom about optimal ergonomic angle (in terms of wrist roll) for split keyboards?
I'm sure I read a discussion on it in the Ergonomics section ages ago but I have no recollection of what the thread was actually about.
« Reply #12606 on: Mon, 15 June 2015, 08:50:41 »
You should PM hoggy. He's the go-to guy for ergo stuff.
Offline greath
  • A waffle is like a pancake with a syrup trap.
« Reply #12607 on: Mon, 15 June 2015, 09:03:46 »
Hey,
I'm about to start my Leeku build. I wanted to make sure I was doing the SMD soldering correctly before I started it.
1. Are the diodes and resistors next to their corresponding pads?
2. The diode has a line on one side. I'm assuming align that with the black bar on the pcb?
« Reply #12608 on: Mon, 15 June 2015, 09:06:13 »
Hey,
1. Yes, you have them placed correctly.
2. Yes, line up the line on the diode with the black bar on the silkscreen.
Offline greath
« Reply #12609 on: Mon, 15 June 2015, 09:08:50 »
Hey,
Thanks JD  :thumb:
Wish me luck!
« Reply #12610 on: Mon, 15 June 2015, 09:10:06 »
Hey,
Thanks JD  :thumb:
Wish me luck!
Good luck!
Offline Wilba
  • Keyboard Stuff Person
    • wilba.tech
« Reply #12611 on: Mon, 15 June 2015, 09:56:12 »
I have a Dolch PAC, everything original, which I love typing on... but the "click" sound is inconsistent across keys. Some have a loud and clear click like a buckling spring, while others are much softer and more of a rattle sound. Excuse my n00b terms for these things ;) Does anyone know what the cause is? Is it something I could fix?
« Reply #12612 on: Mon, 15 June 2015, 09:57:55 »
The cause is MX Blue switches.
/snark
But seriously, all MX clicky switches have inconsistent click, from blues to greens to whites.
« Reply #12613 on: Mon, 15 June 2015, 10:03:10 »
You might find this recent thread helpful https://geekhack.org/index.php?topic=72807.0
Offline Wilba
    • wilba.tech
« Reply #12614 on: Mon, 15 June 2015, 10:06:54 »
Sheesh... posted 2 days ago, don't I look foolish now  :-[  thanks!
Offline greath
« Reply #12615 on: Mon, 15 June 2015, 12:17:42 »
For the resistors on my build: I originally used a calculation I found on GH and, based on some orange LEDs I found on ebay, got 1.3k ohm as what I should be using. However, when I emailed kin I asked "should I be using 1.3k?" and he said: 1300 will be dim, 680-820 will be bright, any resistance will work. I was under the impression you had to use specific resistances for specific colors of LED. Is this correct?
I know it's a little sloppy but does this look like it will work ok? This is as difficult as I thought it would be. I need better eyes. lol
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #12616 on: Mon, 15 June 2015, 12:33:47 »
Better eyes?  :))
Offline greath
« Reply #12617 on: Mon, 15 June 2015, 12:39:03 »
Better eyes?  :))
I got an Optivisor that works pretty well:
Still damn hard to see.
Offline MAR82
  • Keyboard Addict
« Reply #12618 on: Mon, 15 June 2015, 13:08:50 »
Sure looks better than the first time I tried  :thumb:
Those SMDs can be a real pain
Offline user 18
« Reply #12619 on: Mon, 15 June 2015, 16:00:48 »
Any resistance will theoretically work, so long as you don't run more electricity through the LED than it can support. Generally, one wants keyboard LEDs to be dim, but using differently-rated resistors allows varying brightness. The calculations you found here were meant likely meant to match LEDs to a relatively dim setting.
You want a resistor to limit current, as putting too much current through a LED can fry it. Higher-rated resistor = lower current through LED = less brightness.
Avatar by ashdenej
Offline greath
« Reply #12620 on: Mon, 15 June 2015, 16:11:42 »
I have finished soldering the diodes. Not the switches and only a couple of the resistors. Is there a way for me to test the brightness of the LEDs on the keyboard with the few resistors I do have soldered on? If not, is there another way I could test the brightnesses with stuff around the house (like a 9v battery)?
Offline phoenix1234
« Reply #12621 on: Mon, 15 June 2015, 19:46:11 »
You don't need to solder on in order to test the led brightness with different resistors.
For long term, you can use a breadboard kit
For short term, a small few alligators test clips would be just fine
If you don't have any 5V power supply, it would be a small problem, however.
You can create 5V power supply from 4xAAA battery
then use a step-down to reduce from 6V to 5V
It would be better if you have an adapter 5V output or an old PSU because you can create a DIY power supply with direct 5V.
I like linear switches
Offline njbair
    • nickbair.net
« Reply #12622 on: Mon, 15 June 2015, 20:31:21 »
Don't forget, USB is 5V. So if you have an old powered hub or a phone charger and a sacrificial USB cable, you can decapitate one end of the cable, strip the power & gnd wires and tin them, and you've got a pretty well-regulated 5V USB power supply.
Technically you could use one of your computer's USB ports but I generally don't recommend building test circuits that are tied into expensive gear like a PC.
My boards:
Offline greath
« Reply #12623 on: Mon, 15 June 2015, 21:46:12 »
Great idea. Thanks!
Offline Melvang
« Reply #12624 on: Mon, 15 June 2015, 22:23:01 »
Great idea. Thanks!
With modern hardware you would be fine.  I have done it.  Pretty much worst case scenerio for anything newer than at least Windows 7, is you will get an error message saying that the port has attempted to draw to much power and has been shut down.
If you are testing stuff from different power sources, you can possibly introduce ground loops.  Not to sure how much possible damage could be done with it, but I feel it would still be a possibility.
Offline Zustiur
« Reply #12625 on: Tue, 16 June 2015, 07:33:21 »
Does Mechanical Keyboards.com usually send a 'your product has been shipped' email? I've got the the order confirmation but nothing else.
« Reply #12626 on: Tue, 16 June 2015, 07:59:26 »
Typically yes but in my experience sometimes they don't come through. You can email their support and they can tell you.
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #12627 on: Tue, 16 June 2015, 14:12:50 »
Why are 3mm purple leds so much cheaper than 1.8mm led's? I need a few to change the 3 indicator led's on my 1800 case.
Offline njbair
    • nickbair.net
« Reply #12628 on: Tue, 16 June 2015, 16:34:23 »
Probably just supply and demand. Where are you buying from? Here are some for $.40/each.
My boards:
Offline digi
  • elite af tbh
« Reply #12629 on: Tue, 16 June 2015, 17:54:17 »
Thanks, yea you can get x100 3mm shipped for $2.50 from Chiner..
« Reply #12630 on: Tue, 16 June 2015, 20:04:09 »
What a nice topic. Thank you for your help.
+1 one of the sweetest gh threads. I got expertz on call, ready for my random newbish questions. Shouts out to Cptbadass.  :))
You're welcome :)
Start a thread and then talk to some people like Hoggy, Acidfire, obra, Haata, dorkvader, and jacobolus.
Anyone know of a source for Krytox keyboard lube? Or when/if Geekhackers/techkeys/MK will restock?
Krytox isn't keyboard lube per se. It's an industrial lube usually used for not keyboard applications. If you're impatient, you can try hunting other sources. I did a quick search and found some on Amazon.
Is there anyway to still buy the KMAC Mini?  I just saw it, and it looks amazing.  Reminds me of the model F/AT a little bit.  I really want this though.  I tried kbdmod.com and it gives a message which translated roughly when I click add to cart as "This item is currently in stock brief interruption due to lack of sales."
I want this bad enough to start a group buy or something but have no idea how to do it.  Obviously I know to try the classifieds, but any help with this would be greatly appreciated.
Think you're best bet is the Classifieds unfortunately.
So I guess next question is do these get restocked often?
I have no idea what I'm looking at.
is a full size realforce with 45g accross the board not readily available anywhere?
I'm honestly horrible with anything Topre but have you checked EliteKeyboards and The Keyboard Co?
I know these are older post, but for reference�
Are there better springs to put into vintage Cherry MX blues while I have the switches apart or will that defeat the purpose of the "vintage" feel?
I don't want to do the jailhouse mod because I like a hard bottoming out (that's what she said).  :))
I think that negates the purpose of so called vintage or worn switches. I think that the spring, stem, and housing all work together to make the switches feel the way they do.
Incorrect. https://geekhack.org/index.php?topic=72626.0
What exactly is incorrect and what are you trying to highlight in your review? Just saying the housing affects the feel isn't good enough proof for me sadly. I'm looking for some more definitive information other than "I said so".
I think this was already covered but I really like the ID Innovations adapters I bought from mkawa and i3oilermaker/TechKeys.
Hello. I changed a 2u backspace switch into 2 x 1u switches. Where do I "find" the extra 1u in the keymapper? What can I do?
What keymapping software are you using?
Im using BootMapper Client.
I've never heard of that client. Maybe you can try using TMK or EasyAVR? I believe both of those support 1x backspace.
Q: Does anyone know where I can find Matias part # FK-303_usb for a http://matias.ca/miniquietpro/pc/? Customer service claims they don't sell them and I banged up my micro USB connector and board.
If they don't sell them and you've already contacted them to try and get the part, I'm not sure where you're gonna get it from other than another board. I know you can get *just* the USB connector from the usual suspects (Amazon, eBay, Mouser, etc). Maybe you can try that? How exactly is it banged up? By board do you mean a daughter board or the actual keyboard?
Hello guys,
Not sure that my question should go in this threat :D
I need to identify a keyboard by a picture, so if anyone could help it would be greatly appreciated.
Here is the pic:
Holy **** that picture is awful. I honestly don't know what I'm looking at other than it's a Bull keyboard and it's got some colorful keycaps. Can you get a better picture? A quick search found these links which might be helpful:
https://geekhack.org/index.php?topic=43697.0
https://geekhack.org/index.php?topic=54174.0
« Last Edit: Tue, 16 June 2015, 20:06:42 by CPTBadAss »
Offline greath
« Reply #12631 on: Tue, 16 June 2015, 20:13:19 »
Used and old phone charger and tested out a couple resistors. Thanks guys. Going for the 1.3k ohms :)
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #12632 on: Tue, 16 June 2015, 20:43:27 »
Ps2 cable from an audiophile cable company
« Reply #12633 on: Tue, 16 June 2015, 20:48:36 »
Hm...Why not talk to your favorite custom cable maker and get something like that made? I'm sure Zeal/tjcaustin/Pexon could hook it up.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #12634 on: Tue, 16 June 2015, 20:50:24 »
Sorta yeah. Just like the connectors and overall look of those a little more
« Reply #12635 on: Tue, 16 June 2015, 21:29:01 »
Anyone know the distance between the mods and arrow keys on a phantom pcb? Also the distance between the num row and the function row?
Offline Zustiur
« Reply #12636 on: Tue, 16 June 2015, 21:43:23 »
hmm
That's concerning. I've already emailed them. No response as yet. Will wait a bit longer.
Offline frosty
  • jukebox hero
« Reply #12637 on: Wed, 17 June 2015, 02:49:30 »
do switches ever have to be re-lubed?
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #12638 on: Wed, 17 June 2015, 04:07:45 »
Yes, but I think you rarely re-lubed switchs except you used it very very very long times.
« Reply #12639 on: Wed, 17 June 2015, 08:31:47 »
Agreed with what quochung1989 said.
http://deskthority.net/wiki/Phantom#Files
Does the plate file help you or no? Maybe the DT Wiki or elsewhere has the Gerber files? I couldn't find it in a quick search.
« Reply #12640 on: Wed, 17 June 2015, 08:34:50 »
The plate should give me what I'm looking for, thanks. Hopefully the spacing isn't as messed up as the rest of those drawings. :))
Offline digi
  • elite af tbh
« Reply #12641 on: Wed, 17 June 2015, 10:59:09 »
Curious if anyone has tried these 2x3x4 purple led's? Do they actually shine purple? The picture from their auction looks blue to me:
http://www.ebay.com/itm/100pcs-2x3x4mm-Square-LED-Diode-Water-Clear-Purple-UV-Light-Rectangular-/381265404854?pt=LH_DefaultDomain_0&hash=item58c53063b6
Offline MAR82
  • Keyboard Addict
« Reply #12642 on: Wed, 17 June 2015, 11:10:18 »
It's because they're UV purple. So it will be somewhat between blue and purple, very hard to take clear pictures of
You can see some round 3mm ones in this album http://imgur.com/a/XXDLq#0
Offline digi
  • elite af tbh
« Reply #12643 on: Wed, 17 June 2015, 11:15:58 »
Thanks mar82, if they shine like your pics, I'd be very happy with that purple. Think I'll pick some up.
Offline davkol
  •  Post Editing Timeout
« Reply #12644 on: Wed, 17 June 2015, 11:52:10 »
The point is that "so called vintage or worn switches" makes it sound like "vintage" is just a buzzword in this context, which is incorrect. The point of my overview is to link other sources in one place. It's a fact that vintage MX Blue switches are different from the modern ones. I added only a screenshot from Audacity to show the difference in sound between old and new stems.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #12645 on: Wed, 17 June 2015, 11:54:08 »
Yeah the UV purple usually isn't captured very well, it will look blue on all but the best of cameras. My case has a UV light strip but in pictures it just looks blue.
« Reply #12646 on: Wed, 17 June 2015, 18:21:16 »
If it's a fact, you'll have no trouble providing me links with dates and what Cherry did to change the manufacturing of the switches. I've been curious for ages to know both of these details and obviously I'm still skeptical.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #12647 on: Wed, 17 June 2015, 18:33:23 »
This was the closest thing I could find, someone acknowledging that it was officially confirmed at some point. I have no idea where or what they did though.
Offline davkol
« Reply #12648 on: Wed, 17 June 2015, 19:08:14 »
See links on that page, there are detailed pictures among other things.
As previously mentioned [there?], I've owned Chicony KB-5191 (old pics of one) keyboards made in 1991/1992 and sold in the same box, that had different stems.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #12649 on: Wed, 17 June 2015, 19:14:23 »
My Chicony KB-5581 also had vintage blues. I added the photo on the DT wiki. I'll see if my camera can show a difference in stem color between a vintage and modern blue.
