Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 4992286 times)
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2850 on: Sun, 30 June 2013, 11:33:40 »
You can find costar 7x wire from old winkeyless board like Chicony.
Vintage black bottom out something like 77g.
I saw Children of Bodom years ago when they were on North America tour with Dimmu Borgir.
« Last Edit: Sun, 30 June 2013, 11:36:40 by IvanIvanovich »
Offline DavChrFen
« Reply #2851 on: Sun, 30 June 2013, 11:41:21 »
Is there somewhere a summary which keyboard has steel plate?
Thanks
« Reply #2852 on: Sun, 30 June 2013, 11:43:47 »
There's no comprehensive summary.
Offline megaforce
« Reply #2853 on: Sun, 30 June 2013, 15:35:33 »
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline remedyhalopc
« Reply #2854 on: Mon, 01 July 2013, 10:06:13 »
Who makes blank OEM profile PBTs?
« Reply #2855 on: Mon, 01 July 2013, 10:27:41 »
Maybe feng? I think all the stuff imsto has is Cherry profile. Nothing else is jumping out at me at the moment.
Offline Rule16
  • R.I.P. SmallFry
« Reply #2856 on: Mon, 01 July 2013, 11:54:44 »
Anyone know what the windows key is called in auto hot key? I just got my POKER II and I want to swap WIN with FN, its not OS key either.
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
« Reply #2857 on: Mon, 01 July 2013, 12:27:55 »
LWin for left winkey, RWin for right.
If I got it wrong, do some google-fu I pulled this from the AHK site, but it's 2AM and I'm tired.
« Reply #2858 on: Mon, 01 July 2013, 15:41:51 »
I thought the poker 2 was programmable?
« Reply #2859 on: Mon, 01 July 2013, 16:18:38 »
It should be.
« Reply #2860 on: Mon, 01 July 2013, 17:02:53 »
Anyone know the stock voltages a Filco allows for the 2 LEDs?
« Reply #2861 on: Mon, 01 July 2013, 17:11:03 »
Photoelectric just did this swap. Some info can be found here.
Offline Photoelectric
« Reply #2862 on: Mon, 01 July 2013, 17:47:46 »
I've got a few more LEDs in the mail.  Basically I've been getting them from Mouser.com.  Pay attention to luminosity/brightness.  "UV" (really, purple) LEDs didn't turn on at all on my Filco with stock blue LEDs, so that tells me the voltage with the stock resistor is under 3V.  Amber LEDs were fairly faint too, but I did not get any bright ones.  There are a few high-brightness amber and yellow LEDs coming in the mail to compare as well as some green LEDs.
These, for example, did not turn on at all that I could notice:
http://www.mouser.com/ProductDetail/BIVAR/UV3TZ-390-30/?qs=%2fha2pyFadugHc2bKpudzWvcVi%2fwAQl%252be%252bm4ZU%2fcRwj6Ox%2fonSwrFCs1wmFXBxJ0susg6BMx%2fCwmZQrZMZQK8d5XkJADQr9ps
(390nm is still within visible spectrum as violet color)
All of the amber LEDs I got turned on, though some were faint, so 2-2.5V range is tested to be good on my board with stock blue LEDs.
« Last Edit: Mon, 01 July 2013, 17:49:38 by Photoelectric »
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #2863 on: Mon, 01 July 2013, 20:38:19 »
I can't speak for the LEDs on a Filco but if you check the HD LED in the Was link in my SIG I posted the voltages for them with the 3 different brightness settings in the synapse software.
Offline Rule16
  • R.I.P. SmallFry
« Reply #2864 on: Tue, 02 July 2013, 07:56:32 »
It is but I have no idea how to do it because the manual is in Chinese.
Dvorak Only Zone
« Reply #2865 on: Tue, 02 July 2013, 08:24:33 »
There is a translation that has been posted I'd find it and link to it but I'm on my phone.
I'm thinking its even in this thread somewhere.
« Reply #2866 on: Tue, 02 July 2013, 08:34:03 »
English Poker II manual and how to program it can be found here.
« Reply #2867 on: Tue, 02 July 2013, 08:38:30 »
Captain to the rescue!
« Reply #2868 on: Tue, 02 July 2013, 08:39:14 »
Ray, you were correct, it was in this thread. Good memory ^__^
Offline Melvang
« Reply #2869 on: Wed, 03 July 2013, 03:05:11 »
So I am cutting up these usb cables for a home brew style detachable cable mod and came up with a couple questions.
1.  The wire and (guessing here) mylar wrap is just for an EMF/EMI shield correct?
2.  If I want to use this it would get soldered to the shell on the connectors and to the far outside black pin on the mobo usb connector, correct?
3.  Is it required to even hook it up?
4.  What could potentially happen if i don't hook it up?
The reason i am asking is on one cable it tinned nicely and the other cable it won't tin at all.
« Reply #2870 on: Wed, 03 July 2013, 07:34:48 »
Yes. I don't know the answer to the rest of the questions though :(
Offline Melvang
« Reply #2871 on: Wed, 03 July 2013, 09:49:39 »
In additions to my questions in my last post does anyone know if it is possible to take a razer naga epic apart and lube the scroll wheel?  Mine still works 100% but just noticed a couple squeeks from the wheel.
« Reply #2872 on: Wed, 03 July 2013, 09:55:25 »
Why wouldn't it be possible? I'm sure it can be done, I've just never taken apart a mouse so I can't say for sure.
Offline Larken
« Reply #2873 on: Wed, 03 July 2013, 09:58:45 »
never done the naga before, but I've dismantled most of my mice before (logitech mx518, g500, g9, wow joypen) etc to clean the microswitches and apply lube to the scroll wheel. shouldn't be too hard to do same for the naga.
| Ergodox #1 | Ergodox #2 |
« Reply #2874 on: Wed, 03 July 2013, 10:47:19 »
What Korean Customs can be had for $300?
Has anyone added LEDs to the Poker 2 yet?
« Last Edit: Wed, 03 July 2013, 10:49:08 by remedyhalopc »
« Reply #2875 on: Wed, 03 July 2013, 10:50:00 »
From what I've seen, $400 seems to be the magical number for many boards. I think the stuff that GON is doing is around $200-300 though. I seem to remember Calavera's Alps/MX PCB with a GON case going for less than $300.
« Reply #2876 on: Wed, 03 July 2013, 10:50:53 »
You could probably pick up a 38GT + Duck Poker case for around $300, if you can find one. Maybe a 2Tu?
« Reply #2877 on: Wed, 03 July 2013, 10:52:05 »
2TU was around $400 with shipping and assembly costs.
« Reply #2878 on: Wed, 03 July 2013, 11:00:37 »
Ah, I see. Still cheaper than the $500-600 after shipping and assembly for a KMAC or LZ. :)
Offline MJ45
  • HHKB Pro
« Reply #2879 on: Wed, 03 July 2013, 12:44:32 »
What MX switch has the most tactile feel? The blue and green have a separate slider while the white & clear are one piece stems. I am looking for the most tactile feel not necessarily the most noise, Thanks.
« Reply #2880 on: Wed, 03 July 2013, 12:49:54 »
That depends on what you consider to be tactile.  Clears have the biggest bump and Ergo Clears are, IMO, by far the most tactile switches.  Some people, however, think Greens or Blues are the most tactile.  My opinion is that they just have a different kind of tactile feel.  Clears you feel the bump coming and feel the nice large bump going over the metal contact in the switch.  With Blues, you feel the switch start to get resistance, feel a bit of hesitation, then feel the slider shoot past the contact.  That hesitation with a jumping action past the contact makes some people feel that Blues and Greens are more tactile because they have a more sudden feeling in them compared to the gradual and predictable actuation of a Clear.
« Reply #2881 on: Wed, 03 July 2013, 12:51:02 »
This is extremely subjective and not really a simple question. First off, what do you mean by "tactile" feel? Are you looking for a clicky switch or a switch with a bump in it? Second off, I can only offer my own opinion on it. Just because I feel a certain way doesn't mean you'll agree when you try the switch.
Offline Dubsgalore
« Reply #2882 on: Wed, 03 July 2013, 12:56:39 »
you can get 2tu parts for around $200, but a fully assembled and prepped 2tu is near $400
Offline MKULTRA
  • telling it how it is
« Reply #2883 on: Wed, 03 July 2013, 13:16:41 »
Somebody answered this question for me in the GH60 thread but I can't find it.
Can someone recommend a type of LED's for me to use on a kb?  Link would be awesome.
« Reply #2884 on: Wed, 03 July 2013, 13:20:08 »
Square, water clear LEDs. I bought mine from eBay. I can't link because I'm at work. If you don't get a link, I can show you later. People also seem to like "Superbrightleds.com" but it seems kinda sketchy to me.
If you remember the phrase or something from the post in the GH60 thread, you can do a "site:Geekhack.org <phrase>" search on Google to find it. That's usually how I magic up threads.
Offline MKULTRA
« Reply #2885 on: Wed, 03 July 2013, 13:22:14 »
http://www.ebay.com/itm/100-1-8mm-LED-Light-Emitting-Diode-Water-Clear-AMBER-/350491834194?pt=LH_DefaultDomain_0&hash=item519af0f752
Something like this?
« Reply #2886 on: Wed, 03 July 2013, 13:23:19 »
Offline MKULTRA
« Reply #2888 on: Wed, 03 July 2013, 13:41:26 »
It's been a while but back in the day I used MSN Messenger for chat but seems like Skype has now taken over it's place. Do you guys use skype for old school text chat?
Offline MKULTRA
« Reply #2889 on: Wed, 03 July 2013, 13:45:49 »
I miss MSN holy crap
« Reply #2890 on: Wed, 03 July 2013, 13:47:39 »
For talking to my GH friends? Skype and IRC. For talking to some friends? AIM and text.
Offline Tym
« Reply #2891 on: Wed, 03 July 2013, 13:48:14 »
Yes, Skype is great. There are alot of misconceptions about skype but i have a lot of group text chats going on.
« Reply #2892 on: Wed, 03 July 2013, 13:59:59 »
Well I just installed skype my ID is spamray if anyone wants to add me. I'm not much for video/voice but text chat would be cool!
Perhaps I need to look into AIM, I used it back in the day.
Offline findingthelimit
  • Rawr
« Reply #2893 on: Wed, 03 July 2013, 14:20:07 »
where can i buy the backlit poker 2 keyboard? the fact that it comes with ABS caps doesn't bother me, because i'll be replacing them with some custom PBTs. techkeys.us and mechanicalkeyboards.com both sell the PBT, non-backlit version :(
Poker 2 reds, GH60 42g ergo clears
« Reply #2894 on: Wed, 03 July 2013, 14:22:33 »
Buy the non-backlit and either add the LEDs yourself or pay someone to do it.  It's a pretty easy deal to do and it gives you more versatility when it comes to the LEDs you use.
Offline Rule16
  • R.I.P. SmallFry
« Reply #2895 on: Wed, 03 July 2013, 17:54:04 »
Thank you for finding that for me... but apparently it doesn't want the FN key to be changed anyway...
Dvorak Only Zone
Offline KaLam1ty
« Reply #2896 on: Wed, 03 July 2013, 20:53:06 »
Just a quick question pertaining to the Poker and Poker II:
I've heard of people adding lead weights behind the PCB to give it more heft. Do you guys just add
modeling weights such as: http://www.amazon.com/toys-games/dp/B0015KLJE0
between the seams of the back case piece?
Would this mod be applicable to the Poker II? Is there enough space? I know the plate it comes with already adds some weight
but I really like keyboards that are completely solid feeling when carrying it around.
« Reply #2897 on: Wed, 03 July 2013, 21:28:48 »
It would just be heavier...wouldn't feel more solid.
Offline MKULTRA
« Reply #2898 on: Wed, 03 July 2013, 21:29:52 »
When lifting something heavier makes it feel more solid imo.
« Reply #2899 on: Wed, 03 July 2013, 21:33:03 »
Putting lead weights into my Pure case won't make it feel any more solid....
