Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 5997494 times)
Offline linziyi
  • The one with many questions
« Reply #2750 on: Tue, 25 June 2013, 11:24:02 »
:O so clear switches have even heavier spring? I thought they have 65g peak force?
Korean springs are measured at bottom out force while Cherry springs are measured at actuation. There's a thread about this somewhere but I can never remember the name.
Basically a 60g-ish korean spring = same as springs in blues, reds, browns. If there were a 100g korean spring then it'd be about the same as a clear spring. Clears are 55g and greens are 80g so you'd be looking at a korean spring that's quite a lot over 100g (which doesn't exist).
So the clear switches actually have a bottom out force same as green switches (100g I think)?
Ducky DK9008G2 Pro
"Much to learn you still have" --Yoda
« Reply #2751 on: Tue, 25 June 2013, 11:25:18 »
No. They felt different to me when I tried them recently.
« Reply #2752 on: Tue, 25 June 2013, 11:26:47 »
No.
Clear springs : Actuation = 55g, bottom out = around 100g.
Green springs : Actuation = 80g, bottom out = I don't know exactly but I know it'll be higher than 100g.
Offline linziyi
« Reply #2753 on: Tue, 25 June 2013, 11:27:23 »
The bottom out force on Clears is supposedly really heavy. I forgot how heavy, the DT wiki or Cherry should have it. I'd recommend you just wait until the tour comes or getting your hands on some springs and testing them for yourself.
I would be looking forward to the tour! But the ergodox groupbuy has but 5 days left, so I need to decide around now :S
Ducky DK9008G2 Pro
« Reply #2754 on: Tue, 25 June 2013, 11:28:42 »
What would happen if you put green springs in clears witches?
And does anyone know if SmallFry is ever coming back? It's not the same around here without him. ;(
« Reply #2755 on: Tue, 25 June 2013, 11:31:21 »
It's not like you'll be getting the parts anytime soon...does the buy even have those switches available? You can always order a switch you do like and then find other switches later. You have to assemble it anyways so I don't understand the rush.
1) What would happen if you put green springs in clears witches?
2) And does anyone know if SmallFry is ever coming back? It's not the same around here without him. ;(
1) Try it? I can test this when I get Clear springs. Should be coming soon.
2) I tried contacting him but he hasn't gotten back to me.
« Reply #2756 on: Tue, 25 June 2013, 11:31:59 »
You'd get greys!
Greens = blues with 80g spring
Greys = clears with 80g spring
Dark greys  = reds/blacks with 80g spring
Offline linziyi
« Reply #2757 on: Tue, 25 June 2013, 11:36:24 »
Hmm.. I will just wait until next round I think, need to get to know about more switches before my decision.
« Last Edit: Tue, 25 June 2013, 11:42:45 by linziyi »
Ducky DK9008G2 Pro
Offline Meijiera
« Reply #2758 on: Tue, 25 June 2013, 12:02:14 »
Hey I wanted to know if i could put orings or should i put orings on pbt thick caps?
« Reply #2759 on: Tue, 25 June 2013, 12:30:53 »
Can you? Yes. Should you? I don't know. It's a personal preference thing. You can read my thoughts on them if you look in my signature. I'm pretty sure the imsto caps have the proper supports underneath it. I don't know about other Thick PBT caps.
FWIW, I didn't use o-rings on my boards. I had soft-landing pads on my Leopold that I've since removed.
« Reply #2760 on: Tue, 25 June 2013, 12:34:51 »
Are those landing pads reusable? Are they sticky? I haven't handled any yet.
« Reply #2761 on: Tue, 25 June 2013, 12:42:24 »
Yes they're reusable. They're not sticky. I had a set in my Leopold for 5 months and they held up fine. Soft like the 40A o-rings but with less travel reduction.
« Reply #2762 on: Tue, 25 June 2013, 12:59:53 »
I don't know why I had it in my mind that they were like a cross between switch stickers and o-rings. ;)
Thanks for the info!
« Reply #2763 on: Tue, 25 June 2013, 13:18:40 »
Does anyone know the part number for PCB mounted Costar or Cherry stabilizers?
« Reply #2764 on: Tue, 25 June 2013, 15:58:06 »
There is no such thing as "PCB Mounted" Costar stabilizers. All Costar stabilizers attach to the plate.
Cherry "Plate Mounted" stabilizers are parts: G99-0224 (1x2, 1x2.25, 1x2.75), G99-0379 (1x7), and G99-0226 (1x8, 1x9, 1x10).
These Cherry part numbers are "without frame," and I'm not sure if that means "PCB Mounted" or what: G99-0742 (1x2, 1x2.25, 1x2.75), G99-0745 (1x7), and G99-0744 (1x8, 1x9, 1x10).
This is the link from Cherry: http://www.cherrycorp.com/english/switches/key/mx.htm
« Last Edit: Tue, 25 June 2013, 16:00:25 by jdcarpe »
« Reply #2765 on: Tue, 25 June 2013, 16:49:08 »
Say you put switches in a plate to swap springs and play around with what springs make what switch feel like whatever, how do you go about getting the switches back out of the plate??
« Reply #2766 on: Tue, 25 June 2013, 16:52:47 »
You push them out from the back?
« Reply #2767 on: Tue, 25 June 2013, 16:54:14 »
I didn't know if there was a technique to it or if it was just brute force?  :-[
« Reply #2768 on: Tue, 25 June 2013, 16:57:00 »
I use thumbs. Sometimes a screwdriver if my thumbs hurt. :P
« Reply #2769 on: Tue, 25 June 2013, 16:59:03 »
Perhaps it's time for me to get some of those sweet fitted mechanics gloves!
thanks for the info jd!
« Reply #2770 on: Tue, 25 June 2013, 17:08:28 »
1) Take hands
2) Place on back of switch
3) Push
4) Repeat a lot
5) Use a screwdriver if you're a man and you has the pain or Vulcan mind powers if you're JD
Offline Thimplum
  • Master of all Ponies
« Reply #2771 on: Tue, 25 June 2013, 18:28:33 »
How DARE you link to Deskthority! :^)
TP4 FOR ADMIN 2013
Offline Photoelectric
« Reply #2772 on: Tue, 25 June 2013, 20:24:41 »
Could anyone point me to a discussion on various Korean springs, please?  I'm looking for some differences/similarities between various 55g springs on this image Jocelyn posted
There are 3 different 55g springs.  And also 2 different 62g springs (which ones does Originative stock  Are the Originative 45g springs 45g or 45(50)g?)  Thanks!
« Reply #2773 on: Tue, 25 June 2013, 20:30:05 »
I think it was in sherry's originative thread but he deleted it.
« Reply #2774 on: Tue, 25 June 2013, 20:32:53 »
No other discussion for those? That's surprising, considering how many people use these springs for various mods.  I'll PM Sherry about that thread though.
« Reply #2775 on: Tue, 25 June 2013, 20:35:01 »
Captain will chime in he knows ALL!
« Reply #2776 on: Tue, 25 June 2013, 20:45:51 »
Not sure if there is one. There was a bit of a discussion in my review thread but I've never seen an active thread talking about Korean/Custom springs. There was a rumor that the Originative springs were ordered special for Sherry and that the weights were different from the ones you posted. But I cannot confirm or deny that. I too want Sherry to replace his thread about spring weights. I do know that the number of coils affects how the spring feels. But I haven't had the chance to play with enough springs to properly weigh in with my opinion.
....this was not a Simple Answer lmao.
Offline MKULTRA
  • telling it how it is
« Reply #2777 on: Tue, 25 June 2013, 21:26:45 »
Hey so I just did my first Ergo-Clear mod to a switch.  It doesn't even have a tactile bump anymore, is that what it is supposed to be like...?
« Reply #2778 on: Tue, 25 June 2013, 21:28:36 »
No, there should still be a tactile bump.
Offline MKULTRA
« Reply #2779 on: Tue, 25 June 2013, 21:31:57 »
Yeah I just did another one, ****ed the first up somehow XD
« Reply #2780 on: Tue, 25 June 2013, 21:56:33 »
Look in calavera's springs sale thread for the discussion on these. Sherry sells the ones from KBDMOD.
« Reply #2781 on: Tue, 25 June 2013, 21:57:06 »
Yo how can I break into someone's house and steal their pink 456 GT without them knowing?
« Reply #2782 on: Tue, 25 June 2013, 21:59:30 »
Seems like the relevant discussion begins here in calavera's Group Buy thread.
« Reply #2783 on: Tue, 25 June 2013, 22:00:40 »
List an orange 456 GB on Craigslist, get in touch with them, tell them a place to meet...  put on your Pink Panther gloves, queue Pink Panther music, and head into their house :D
Thank you, JD and CPT!  Found that one.  Just wish there were more detail on 55g spring differences.  And how the number of coils affects the rebound time, if at all.
« Reply #2784 on: Tue, 25 June 2013, 22:01:31 »
Pose as a Kpop girl. Who doesn't trust a Kpop singer?
« Reply #2785 on: Tue, 25 June 2013, 23:15:23 »
Try it in a few different switch housing bottoms.  I noticed that my Clears sometimes get more tactile or less tactile depending on the stem and housing combination.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #2786 on: Wed, 26 June 2013, 00:14:39 »
So i am using the black theme here on GH and sometimes it get white stripes at the top where my avatar is and what not but now the whole page is white.  Any ideas on what is happening here?
« Reply #2787 on: Wed, 26 June 2013, 00:36:38 »
http://geekhack.org/index.php?topic=45171.0
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2788 on: Wed, 26 June 2013, 14:16:30 »
Does anyone know of a place that can make some lock light label replacement, exactly the type on G80 but with my own design on it?
Offline SeriouSSpotS
  • 60% is love, 60% is life
« Reply #2789 on: Wed, 26 June 2013, 14:25:04 »
Why do people flip their space bars around?
example:
« Reply #2790 on: Wed, 26 June 2013, 14:28:14 »
example:
Some find the normal 'edge' too sharp....you should try it....it's interesting ;)
For the record I've only flipped my space bar in two unique instances, on my FC660C I had just to try it that way, and when using DSA retro caps and a imsto thick pbt spacebar, that actually worked really well.
« Last Edit: Wed, 26 June 2013, 14:34:59 by ray4jc »
« Reply #2791 on: Wed, 26 June 2013, 14:29:17 »
example:
Some people can't be like Samuel Jackson and Bruce Willis all the time (by that I mean a bad-a**) and their thumbs start to hurt from hitting the space bar.  They say that flipping it makes it not hurt.  I've never had any issues with it, but some people say it cuts into their thumbs and flipping it stops that from happening.
« Reply #2792 on: Wed, 26 June 2013, 14:32:49 »
Only communists flip their spacebars. Don't do it.
« Reply #2793 on: Wed, 26 June 2013, 14:33:25 »
Don't judge me!!! I go both ways baby ;)
« Reply #2794 on: Wed, 26 June 2013, 14:35:57 »
Ah I see.
Offline raKeto
« Reply #2795 on: Wed, 26 June 2013, 16:48:44 »
Whats the Befits of installing a Custom plate into Filco (or any Keyboard). Whats bad about the Stockplate?
« Reply #2796 on: Wed, 26 June 2013, 16:50:33 »
Custom plate allows you to remove the top of the switches. This allows you to swap the springs & stems or lube the switch. On a stock plate you'd need to desolder the switch/es every time you want to swap anything.
« Reply #2797 on: Wed, 26 June 2013, 16:51:05 »
Many of the custom plates people use let you do things like pop the switch tops without desoldering.  It allows you more freedom to play and experiment and fine tune your switches without having to use PCB mounted.
« Reply #2798 on: Wed, 26 June 2013, 16:51:43 »
Custom plates are often heavier than the stock plates so the keyboard feels heavier and more solid overall. You can also change the layout from the standard. For example, my keyboard is currently 1.25x ANSI but with a custom plate, I could get like HHKB or 1.5x ANSI for example.
Edit: Photekq and nubbinator got that AWP out. So much sniping haha
Offline raKeto
« Reply #2799 on: Wed, 26 June 2013, 16:57:04 »
wow that was quick  ;D
If i would install a custom plate, do i need to make any adjustments or swap the Case aswell?
