Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6213838 times)
Offline Dubsgalore
« Reply #2650 on: Wed, 19 June 2013, 22:57:13 »
is it true lubed tactile/clicky switches have a lesser pronounced bump because of the lube?
from what i've heard, lubing clickys and tactiles are a bad idea if you are looking for a bump
Offline Photoelectric
« Reply #2651 on: Wed, 19 June 2013, 23:08:10 »
As I understand it, the bump becomes more pronounced.  But if you over-lube, the click in the clicky switches diminishes or goes away altogether.  If you lube properly (proper locations) and in a tiny amount, the friction should diminish, but the bump and clicks should still remain.
« Reply #2652 on: Wed, 19 June 2013, 23:31:43 »
It's not that the bump becomes less pronounced, it's that the actuation becomes smoother, so the bump can appear to diminish.  A good, but inaccurate, analogy would be sanding wood.  If you've ever sanded corners with a heavier grit, you notice that the sandpaper tends to catch and offer a little more resistance.  When you swap to a finer grit sandpaper or get a nice build up of sawdust in the heavier grit paper, there's less resistance on those corners.  The lube just makes the action easier.
Offline llovro
« Reply #2653 on: Thu, 20 June 2013, 04:54:07 »
How is that 'bar' attached to lz-gh? Can someone post some pics maybe?
« Reply #2654 on: Thu, 20 June 2013, 06:30:21 »
I was under the impression that lubing clicky switches takes away from the click. From all my reading, I've never seen anyone with lubed Blues or Greens. And the Whites are lubed from the factory and aren't as clicky as Blues and Greens. I agree with nubbinator on tactile switches and lube.
Maybe JD or Sifo will post pictures or answer? Some help me out ^__^
« Reply #2655 on: Thu, 20 June 2013, 06:42:42 »
Sorry, no pics of the LZ-GH yet, but the bar foot attaches with screws from the inside of the case. So you have to disassemble the case to remove the foot or change the angle.
Why do you say that Ivan's "Cherry Replica Dyesub" group buys are not Cherry font, or somehow lasered and not dyesubbed? Both R1 (completed) and R2 (ongoing) are dyesubbed with Ivan's Cherry replica font.
Now those G81-7000 keycaps, those are lasered PBT, not dyesub.
« Reply #2656 on: Thu, 20 June 2013, 06:50:29 »
'Cause I was hella tired and confused my info. :(
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #2657 on: Thu, 20 June 2013, 07:38:51 »
Well maybe if you went to bed instead of up on geekhack at 10:30 at night then you might not be so tired.  lol jk
« Reply #2658 on: Thu, 20 June 2013, 07:39:44 »
Captain is always ready, always waiting......to make moves!!
« Reply #2659 on: Thu, 20 June 2013, 07:40:26 »
Why does Melvang think he can be my mommy and set a bed time for me? :P JK!
« Reply #2660 on: Thu, 20 June 2013, 07:41:58 »
10:30? Lightweight! :))
You can try getting actual Cherry PBT caps. I just got a set for the cost of shipping from a G81-7000. There is also a GB going on now for BSP caps. The company BSP bought the Cherry PBT molds, much like how GMK bought the ABS molds, and is making new Cherry PBT caps. You can also try getting in on Ivan's PBT R2 GB, but these won't be Cherry color or font. Finally, you can try scoring a good deal on Imsto's R1 PBT caps, which are Cherry replica in profile, but again, not color or font.
BSP didn't buy the Cherry moulds. They are the original owners of the Cherry PBT moulds and made all of Cherry's PBT caps (the dyesubs anyway). GMK on the other hand did buy Cherry's moulds.
« Last Edit: Thu, 20 June 2013, 07:47:45 by Photekq »
« Reply #2661 on: Thu, 20 June 2013, 07:47:32 »
10:30? Lightweight!
First off, it was 2330. Second off, some of us work a day job too. :P
Offline Melvang
« Reply #2662 on: Thu, 20 June 2013, 07:57:57 »
It's all good Cpt.  When I was in the Navy I only slept about every other night.
« Reply #2663 on: Thu, 20 June 2013, 08:11:21 »
Is usps.com down for anyone besides me?
« Reply #2664 on: Thu, 20 June 2013, 08:12:28 »
Working fine for me but... http://www.downforeveryoneorjustme.com/usps.com
« Reply #2665 on: Thu, 20 June 2013, 08:20:15 »
I forgot about that website thanks!
Offline llovro
« Reply #2666 on: Thu, 20 June 2013, 10:40:43 »
are wasd keyboards keycaps thin or thick abs?
« Reply #2667 on: Thu, 20 June 2013, 10:41:28 »
Thin.
Offline llovro
« Reply #2668 on: Thu, 20 June 2013, 10:51:30 »
SP keycaps are thick then right?
« Reply #2669 on: Thu, 20 June 2013, 10:54:18 »
Their regular caps are thin. Their retro DSA etc are a bit thicker.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2670 on: Thu, 20 June 2013, 18:38:00 »
**** son! I made lots of sweat, blood, tears, probably other various bodily fluids making my Cherry replica legends the best I could... not Cherry font, well it's true but they are really close, like 96%. Sure BSP has the 'original' dyesubs, but if you need 1.25 modifiers, center stem fulltouch caps locks, spacebars.... well you are ****ed cause they don't have them. Also my groupbuy PBT dyesubs sets are nearly 50% less than BSP sets from sherryton/originative and just as good.
Offline llovro
« Reply #2671 on: Fri, 21 June 2013, 04:37:14 »
Offline Melvang
« Reply #2672 on: Fri, 21 June 2013, 05:14:31 »
I can't speak for the entire board as I have not delved that far into the tech side of this hobby/bank account draining curse, but the ATMEGA32U4 is the same controller chip that is found in the Teensy 2.0
Offline llovro
« Reply #2673 on: Fri, 21 June 2013, 05:50:59 »
Yeah, I know that. I would use teensy but I want to mount the controller on plate so I need mounting holes...
« Reply #2674 on: Fri, 21 June 2013, 06:33:26 »
I didn't mean to insult your work bro, I just didn't like how the R1 legends turned out. Please don't hurt me!  :-*
* CPTBadAss hides behind a couch
« Reply #2675 on: Fri, 21 June 2013, 08:27:52 »
What are 7-bit legends?  Is it some size designation?  I don't suppose it could be related to username 7bit?
« Reply #2676 on: Fri, 21 June 2013, 08:29:28 »
You're correct, they're legends that 7bit came up with. Sort of like how Ivan made those Cherry replica fonts for the Imsto sets. I *think* they're the legend sets that have super/meta in them from Round 3 and Round 4 Dolch Replica.
« Reply #2677 on: Fri, 21 June 2013, 08:35:37 »
http://geekhack.org/index.php?topic=44481.0
These are called "7-bit" (spelled properly), and there are no Super and Meta keys.  Just wondering what that's about.
« Reply #2678 on: Fri, 21 June 2013, 08:37:05 »
Ooo. Forgive me, it's early. It's the symbols on the modifiers.
Offline hasu
  • @tmk
« Reply #2679 on: Fri, 21 June 2013, 08:41:19 »
It will work... but Leonardo bootloader is what I don't want to work with the most. I mean it is suck.
I don't recommend it unless you can replace it with new bootloader yourself.
« Reply #2680 on: Fri, 21 June 2013, 08:50:19 »
Yes, it's the symbol-only modifiers. And the spelling should be "7bit" to correspond with his username.
« Reply #2681 on: Fri, 21 June 2013, 08:56:25 »
Thanks for the clarification!
Yes, this added to the confusion.
Offline linziyi
  • The one with many questions
« Reply #2682 on: Sat, 22 June 2013, 13:09:44 »
Does usb-ps2 adapter for mouse(it has a mouse icon on it) works for keyboard?
Ducky DK9008G2 Pro
"Much to learn you still have" --Yoda
« Reply #2683 on: Sat, 22 June 2013, 13:10:57 »
If everything plugs in fine then it should. I don't see why it wouldn't. Test it?
Offline domoaligato
« Reply #2684 on: Sat, 22 June 2013, 13:25:21 »
they work fine. this is one of ripster's reddit wiki science fact things.
Offline inteli722
« Reply #2685 on: Sat, 22 June 2013, 13:48:45 »
Yeah, it does. I've tested it. Don't sweat it.
Waiting for: Phantom Plate
Offline Jocelyn
  • 조셀린
« Reply #2686 on: Sat, 22 June 2013, 14:44:22 »
Why are Cherry ABS caps so difficult to pull off?!?!?! I know, I know, that's just how they are, but I'm wondering if it would be a good idea to put them on some spare switches a few times to loosen them up or if this would be a waste of time. Granted my plate allows for removable switch tops, but I opened up at least three switches on my Poker when pulling off six caps and I don't like it :(
Edit - I need to know before my purple GMK mods arrive lol
« Reply #2687 on: Sat, 22 June 2013, 14:46:39 »
Are you asking a serious question or are you continuing your campaign of bashing ABS caps? I've never had an issue taking them off my boards.
Offline Jocelyn
  • 조셀린
« Reply #2688 on: Sat, 22 June 2013, 14:47:56 »
I'm serious and I'm okay with ABS mods :)
Edit - It's totally cool, but I'm surprised you thought I might be joking seeing as I bought GMK goods :p
« Last Edit: Sat, 22 June 2013, 14:50:12 by Jocelyn »
« Reply #2689 on: Sat, 22 June 2013, 14:50:04 »
I've been using the Olivetti GMK caps on my Leopold and have never had an issue removing the caps. I guess you could try the method you suggested but I've never encountered the problem that you suggested. Maybe someone else has had this issue and can suggest a solution?
Edit: I didn't want to assume. Maybe you're just a great person and wanted to help out with the MOQ. If you took that the wrong way then I apologize but I can't tell if people are being serious or not sometimes.
« Last Edit: Sat, 22 June 2013, 14:53:08 by CPTBadAss »
« Reply #2690 on: Sat, 22 June 2013, 14:56:04 »
Where did my wire key cap puller disappear to?  It up and walked away on me.
« Reply #2691 on: Sat, 22 June 2013, 14:56:48 »
I stole it! I didn't want you doing all these sweet keyboard mods. You're too cool and I wanted to take you down a peg. :P
Offline Jocelyn
  • 조셀린
« Reply #2692 on: Sat, 22 June 2013, 14:59:00 »
Lol it's cool!!! Anyway, I know for a fact that cherry ABS doubleshots are tighter than thick PBT. I guess I'll wait until someone else sees my post :)
PS - Thanks!
« Reply #2693 on: Sat, 22 June 2013, 14:59:23 »
« Reply #2694 on: Sat, 22 June 2013, 17:11:11 »
Stop using glue when fitting them keycaps, and they are not hard to take back off :p
New keycaps are often just tight, but that's a good thing. Better than them flying off when typing because they are too loose.
Offline Jocelyn
  • 조셀린
« Reply #2695 on: Sat, 22 June 2013, 17:15:25 »
lol I agree with you about it being a good thing. It's less that they're difficult to remove and more that they're pulling my switch tops off when I pull of the caps (I'm very patient and gentle when doing this). I guess I'll have to keep the purple mods on forever, thanks :p
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
« Reply #2696 on: Sat, 22 June 2013, 17:18:56 »
I made a video of this a while back
https://vine.co/v/b9LxtemdmQF
Offline Jocelyn
  • 조셀린
« Reply #2697 on: Sat, 22 June 2013, 17:20:04 »
lol holy ****!!!
Offline BlueBär
« Reply #2698 on: Sat, 22 June 2013, 17:27:40 »
You have a weird typing style.
Offline Melvang
« Reply #2699 on: Sat, 22 June 2013, 17:54:21 »
I have noticed that caps seem to hold to the stem a lot firmer to my clear stems than any other stems I have.  Which would be blues, browns, and reds.  But I noticed this with both ABS and PBT caps.  But I haven't pulled any switch housings apart and my clears are PCB mount.
