Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6214171 times)
« Reply #2500 on: Wed, 12 June 2013, 12:32:00 »
Unsure if pump would be that good. I'd prefer a braid for that personally.
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
« Reply #2501 on: Wed, 12 June 2013, 12:41:57 »
I have a desoldering pump but how well would it work on that mountain?
I don't know, never used one, but a wick will remove most of the excess solder while still leaving enough to keep the connection if you're lucky, however if your solder joint breaks after using the wick, you'll obviously need either more solder or flux to get it back together.
Offline Lastpilot
  • Power stance
« Reply #2502 on: Wed, 12 June 2013, 13:36:13 »
Any pictures of LEDs behind some SP ABS doubleshots? White please? Raindrop if you got it?
I looked through so many google image pages, couldn't find any. I KNOW there are some pictures somewhere though.
« Reply #2503 on: Wed, 12 June 2013, 14:03:54 »
Use a google search on this thread and type in "remind me to post a picture". I took pictures already earlier in this thread. Jocelyn did as well.
« Reply #2504 on: Wed, 12 June 2013, 14:08:46 »
http://geekhack.org/index.php?topic=40501.msg895963#msg895963
Offline Lastpilot
  • Power stance
« Reply #2505 on: Wed, 12 June 2013, 15:30:22 »
Thank you! Lol I feel bad, it was in this thread the whole time. D'oh.
One last question from me today! Where can I find a high-res or vector copy of 7bit legends?
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #2506 on: Wed, 12 June 2013, 15:32:53 »
nevermind
« Last Edit: Wed, 12 June 2013, 15:53:37 by kenmai9 »
Offline BlueBär
« Reply #2507 on: Wed, 12 June 2013, 15:53:21 »
I'm really confused with springs right now. So basically what I want is a Ergo-Clear variant, however without lubing them. I want to buy the springs from Originative, and I want the same spring strenght all over the keyboard. Which spring strength form Originative would be close to the original MX Clear strength or close enough to not stick? How can I compare them? Which one would you recommend (without lube)? How can I compare them to the values given at the DT wiki?
« Last Edit: Wed, 12 June 2013, 15:55:15 by BlueBär »
« Reply #2508 on: Wed, 12 June 2013, 16:16:29 »
There is a ton of info in these threads that should help
http://geekhack.org/index.php?topic=44100.0
http://geekhack.org/index.php?topic=43374.0
http://geekhack.org/index.php?topic=44478.0
« Reply #2509 on: Wed, 12 June 2013, 16:17:48 »
65g won't stick unlubed.  62g may or may not have issues, but will be fine on most.  From my understanding, 80g is the closest to the Clear spring (supposedly lighter still), but I could be wrong there.
Any reason you won't be lubing them?
Since the Korean springs are measured at bottom out and MX at actuation, it does make things more interesting.
Offline BlueBär
« Reply #2510 on: Wed, 12 June 2013, 16:32:26 »
I've seen these threads, however most people seem to lube their Ergo Clears so I wasn't sure. Thanks anyways :)
More work (well I will be stickering them so not really a valid point) + more material needed + some people say it might lose it's characteristic feeling if you overdo it... I don't know, I'm just concerned that if I would do something wrong it's a lot of work to revert it. I also don't mind the "scratchyness" at all.
I might do it at a later point, so I'll get 62g and 65g springs. Thanks for the help!
Offline linziyi
  • The one with many questions
« Reply #2511 on: Wed, 12 June 2013, 20:10:28 »
Does GH60 stands for GeekHack 60%?
Ducky DK9008G2 Pro
"Much to learn you still have" --Yoda
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #2512 on: Wed, 12 June 2013, 20:20:33 »
Yeah
« Reply #2513 on: Wed, 12 June 2013, 20:26:10 »
Yes
Offline Jocelyn
  • 조셀린
« Reply #2514 on: Wed, 12 June 2013, 20:28:00 »
Yes
You know it's funny, because I think americans hijacked 60% meaning. It makes sense being that 61-62 keys is ~60% of 104, but I've been told the original meaning had to do with weight. This is why Poker is 40% and not 60%
« Reply #2515 on: Wed, 12 June 2013, 20:34:07 »
Speaking of %s. I want to settle something. I asked ages ago what the percentage size of a TKL would be and it was decided 80% = TKL.
However, 87 = about 83.5% of 104.
The question is.. 80% or 85%?
Offline Dubsgalore
« Reply #2516 on: Wed, 12 June 2013, 20:38:58 »
80%
« Reply #2517 on: Wed, 12 June 2013, 20:43:06 »
Pretty sure the convention is 80% :D
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #2518 on: Thu, 13 June 2013, 01:42:42 »
Never mind. Found the answer
« Last Edit: Thu, 13 June 2013, 01:44:29 by kenmai9 »
« Reply #2519 on: Thu, 13 June 2013, 04:13:14 »
80%
Good. TEK-80 remains then.
Offline Jocelyn
  • 조셀린
« Reply #2520 on: Thu, 13 June 2013, 04:14:33 »
80%
lol I think it's funny you conclude this after I posted what I did, though I am in agreement.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #2521 on: Thu, 13 June 2013, 04:49:35 »
Does anyone know if you can successfully put a clear coat over the top of a "blued" finish like what you typically see on firearms?
Offline linziyi
« Reply #2522 on: Thu, 13 June 2013, 09:22:49 »
Would using PBT keycaps decrease the actuation force of the switches because of the weight of the keycaps?
Ducky DK9008G2 Pro
« Reply #2523 on: Thu, 13 June 2013, 09:26:11 »
LOL, technically yes, but they do not weigh that much more..
Offline therecorder
« Reply #2524 on: Thu, 13 June 2013, 09:29:53 »
Also, because of the change in feel and sound (bottoming out), they may cause one to conclude that they are heavier.
« Reply #2525 on: Thu, 13 June 2013, 09:49:56 »
It doesn't feel like the actuation force changes that much. I have both PBT and ABS caps on my boards.
80%
Whether or not your statement is correct, the convention still stands. That's how we seem to use the percentages here so that's what I'm running with. I'm not frequently on DT or any of the Korean sites so I can't tell you how things are done there or even if they're the same. And FWIW, I've never heard that it was based on weight.
Offline Melvang
« Reply #2526 on: Thu, 13 June 2013, 09:54:11 »
Can Alps switch internals be swapped out without changing the housing like you can with Cherry MX switches?
Edit so as not to double post but came up with a couple more questions.
Has anyone ever used  this stuff?
If so what size would be a good fit for doing 22ga hook up wire?
« Last Edit: Thu, 13 June 2013, 13:03:30 by Melvang »
Offline Melvang
« Reply #2527 on: Thu, 13 June 2013, 21:03:37 »
Wow 10 hours with no posts in this thread, did I scare everyone away?
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #2528 on: Fri, 14 June 2013, 05:57:56 »
It varies. Simplified to Simplified and Complicated to Complicated, in a nutshell. There's probably some other ways, but that's the rule I know.
Yes, I have. For 22ga hookup wire, I don't know. The guys at FrozenCPU will know the right size for 22ga though. I've been pleasantly surprised by it - looks very nice, very sturdy, and it is flame retarding. (Don't ask.)
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
« Reply #2529 on: Fri, 14 June 2013, 06:06:25 »
I plan on working on my Alps board this weekend. When I have switches to play with, I'll take them apart and see. Maybe post some pics.
Offline linziyi
« Reply #2530 on: Fri, 14 June 2013, 08:21:39 »
Conventional keycap sets won't fit ErgoDox will it?
Ducky DK9008G2 Pro
« Reply #2531 on: Fri, 14 June 2013, 08:24:42 »
Pretty sure it will but the Ergodox has a lot of extra caps that most sets won't have. I'd like someone to double check my answer though.
Offline CommunistWitchDr
  • >implying keyboards
« Reply #2532 on: Fri, 14 June 2013, 08:43:16 »
Only if your set had like 4 left shift keys and a bunch of tabs.
So cap'n is right.
Offline Melvang
« Reply #2533 on: Fri, 14 June 2013, 10:30:57 »
thanks for the info CPTBadAss and rootwyrm.  Now where was that thread about building up a keyboard using just a plate full of switches and the teensy?
« Reply #2534 on: Fri, 14 June 2013, 10:32:06 »
In my signature :)
Offline Melvang
« Reply #2535 on: Fri, 14 June 2013, 10:33:24 »
Thanks JD i did just find it though.
« Reply #2536 on: Fri, 14 June 2013, 10:34:16 »
I figured it was a somewhat rhetorical question, but I like to provide answers when I can. :)
Offline domoaligato
« Reply #2537 on: Fri, 14 June 2013, 11:18:51 »
I would suggest this thread also for discussions on Hasu's TMK keyboard firmware.
http://geekhack.org/index.php?topic=41989.0
Offline Masterchief79
« Reply #2538 on: Fri, 14 June 2013, 11:32:30 »
What's this?
Taiwanese Fake-Model F with MX black copies (1984) | Apple Keyboard (salmon Alps 1987) | G80-1000HDD vintage blacks (1987) | G80-1000HFD vintage blues | G80-1800HFD | QPad MK50 browns | AEK II
« Reply #2539 on: Fri, 14 June 2013, 11:34:39 »
Looks like a plunger over rubber dome board at a quick glance.
Offline Melvang
« Reply #2540 on: Fri, 14 June 2013, 11:35:59 »
Thank domo. Now how does the direct wiring method feel to type on?  I am considering this method for reasons that will remain under Classified status until complete.  And how does does this affect the sound of the keystrokes?
« Reply #2541 on: Fri, 14 June 2013, 11:36:23 »
Yep, with a spring! For some unknown reason... I doubt if it adds more than 5cN resistance.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2542 on: Fri, 14 June 2013, 11:44:43 »
Looks like Fujitsu Peerless. They are more similar to buckling springs in how they work, but totally linear.
« Reply #2543 on: Fri, 14 June 2013, 11:46:19 »
Should feel the same to type on but the overall weight should be lighter since you don't have a PCB. I've never actually tried a direct wired board though. Ask TheFlyingRaccoon or Matt30. They've very recently made direct wired boards.
Offline unnatural
« Reply #2544 on: Fri, 14 June 2013, 15:42:35 »
Kinda a newbie here, is it possible to change the spring and oil a plate mounted cherry switch without desoldering/soldering?
« Reply #2545 on: Fri, 14 June 2013, 15:45:05 »
Please read the OP
Offline unnatural
« Reply #2546 on: Fri, 14 June 2013, 15:50:20 »
Please read the OP
Thanks, I missed the first read through  :)
Offline remedyhalopc
« Reply #2547 on: Fri, 14 June 2013, 23:39:16 »
I found this at the volunteer organization I've been working for to clean up Moore. It's an old church's gym and it Had an oooold Internet cafe that we cleared out.
It stuck out to me because of the ISO layout with short right shift and the fact that it felt better than a membrane. Initially thought it was because the back was all metal so I figured the plate was making it sturdy. Just got home to check it out and pulled a cap off. To my surprise...AND the caps are MX compatible. It's a Packard Bell 5131C.
« Reply #2548 on: Fri, 14 June 2013, 23:42:38 »
Not sure if that's a question, but it's a rubber dome
« Reply #2549 on: Fri, 14 June 2013, 23:48:25 »
Is there a question here that I'm missing remodyhalopc?
