Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6011043 times)
Offline Tarzan
  • formerly known as Greystoke
« Reply #2350 on: Thu, 06 June 2013, 12:50:19 »
Any chance of this being a mechanical?
Yes.
 :p
Okay, I'll stop being a smartass.  It looks very much like a Cherry G80-1500.  If so, these were usually MX Black switches, if it's an older model they could have that "vintage Black" feel that is pretty nice.  I'm typing on one right now.
But, it would really help to see the label on the keyboard.
Offline Masterchief79
« Reply #2351 on: Thu, 06 June 2013, 12:54:32 »
Well thanks, just saying the font doesn't look like Cherry at all. Also, the transparent cutouts for Num, Capslock and "Rollen" were of another style, rather rectangular. Would be very astonished if this were a Cherry keyboard. The font style rather looks Model-M-ish to me, though the caps obviously don't. I'm really not sure at this one. I', actually hoping for some kind of maybe blue or green ALPS, that'd be nice^^
Unfortunately, there are no other fotos. I will maybe just buy it (hope to get it for <10€ incl. shipping).
« Last Edit: Thu, 06 June 2013, 12:57:02 by Masterchief79 »
Taiwanese Fake-Model F with MX black copies (1984) | Apple Keyboard (salmon Alps 1987) | G80-1000HDD vintage blacks (1987) | G80-1000HFD vintage blues | G80-1800HFD | QPad MK50 browns | AEK II
« Reply #2352 on: Thu, 06 June 2013, 14:01:01 »
(PS: Didn't get it, went for 15€+).
Offline Tarzan
« Reply #2353 on: Thu, 06 June 2013, 14:11:49 »
I got the G80=1501HAD I'm using right now for €10.00 plus €5.90 shipping.  Cost a bit more to get it to the US, but I think that was a decent price for the quality and MX Blacks.  I think it was a wise move to stick to €10 as your top bid.   :D
Offline domoaligato
« Reply #2354 on: Thu, 06 June 2013, 16:58:00 »
...Quite expensive as 85 USD just for switches... I think I should work on my wallet more and stick with stock keyboards for a while
you could just buy a QFR w/greens for a little bit more :D
http://www.cmstore-usa.com/quickfire-rapid-mechanical-gaming-keyboard-green-switch/
Offline domoaligato
« Reply #2355 on: Thu, 06 June 2013, 18:22:43 »
where could I find windowed cherry mx blank keys?
I saw this in zenuty's photo thread.
« Last Edit: Thu, 06 June 2013, 18:25:06 by domoaligato »
Offline Tarzan
« Reply #2356 on: Thu, 06 June 2013, 18:37:15 »
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #2357 on: Thu, 06 June 2013, 20:28:29 »
What was the name of the old port for PC's that used the flip up wire retainer clips?
« Reply #2358 on: Thu, 06 June 2013, 21:29:47 »
parallel?
Offline Melvang
« Reply #2359 on: Fri, 07 June 2013, 04:38:26 »
That's the one.  More specifically the one I want uses the centronics 36 connector with bail latch.  Just needed that seed.
Offline Lbeuol
« Reply #2360 on: Fri, 07 June 2013, 12:01:05 »
You can buy those from Taobao (pretty sure that's is where zenuty got his)
« Reply #2361 on: Fri, 07 June 2013, 17:03:10 »
Those are probably from a WEY keyboard.
http://www.ebay.co.uk/itm/WEY-Banking-Double-Shot-Keytop-Cherry-MX-Mechanical-Switch-Keyboard-HK2000B-/321116677022?_trksid=p2047675.l2557&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D15010%26meid%3D7446503786930103391%26pid%3D100011%26prg%3D1121%26rk%3D1%26sd%3D161016541694%26&nma=true&si=aq96MfHMvXAPG26kzDt1zuZw5rk%253D&orig_cvip=true&rt=nc
These windowed keycaps are in demand, you can sometimes find sets of just the blanks for sale on Taobao.  Pricey, though.
Wow, despite extra keycaps and everything, that keybord itself is a dream... Just to be clear, he sells the whole thing there? Not just caps? And what would you need to get it connected to a Win8 PC, he's speaking of a controller box there...
« Last Edit: Fri, 07 June 2013, 17:05:02 by Masterchief79 »
« Reply #2362 on: Fri, 07 June 2013, 17:06:52 »
You'd probably need to teensy it. And yes, it's the whole board.
Offline calavera
« Reply #2363 on: Fri, 07 June 2013, 17:33:22 »
Don't understand why SP row 4 doesn't match profile with the cherry SHIFT key. wtf? Can anyone explain?
Cherry key caps are from a 1800 board.
« Reply #2364 on: Fri, 07 June 2013, 17:35:03 »
I thought that the DCS profile was *CLOSE* to the Cherry profile but not exact.
Offline Jagriff
« Reply #2365 on: Fri, 07 June 2013, 17:45:21 »
What's the best way to remove the tops of PCB (or mo-friendly plate) mounted switches without using Beast's tool?
« Reply #2366 on: Fri, 07 June 2013, 17:45:59 »
Very small flathead screwdriver.
« Reply #2367 on: Fri, 07 June 2013, 17:48:41 »
Please read the OP, I've provided some alternatives there :D
Offline Jagriff
« Reply #2368 on: Fri, 07 June 2013, 21:04:00 »
Thanks! That binder clip looks very interesting.
« Reply #2369 on: Fri, 07 June 2013, 21:34:18 »
Binder method never worked for me. I think I may have bought binders that were too thick since they literally wouldn't fit in the holes. Even tried hammering them but still wouldn't work.
Offline Melvang
« Reply #2370 on: Fri, 07 June 2013, 22:29:05 »
a small file fixes that problem.  The thread that I saw with them and how he made them said that he had to file down the ends to fit in the holes.  Gotta remember it is a round peg in a square hole.
Offline Dubsgalore
« Reply #2371 on: Fri, 07 June 2013, 22:34:40 »
page 80 though
Offline SmallFry
« Reply #2372 on: Fri, 07 June 2013, 22:35:19 »
So... I didn't see this in the OP, but can I sell stuff here? :P
Offline raKeto
« Reply #2373 on: Sat, 08 June 2013, 02:26:54 »
Why are Filco Keyboards known to be the Best? Most people say the processing is so good. What makes them so Special?
« Reply #2374 on: Sat, 08 June 2013, 02:28:42 »
They are pretty good, but not nearly as good as Black Widow Ultimates.
« Reply #2375 on: Sat, 08 June 2013, 02:30:02 »
They're not the best, it's just personal opinion. If they were clearly superior, everyone would have that over everything else. The PCB is apparently very easy to mod. And you have one so you must like it already.
« Last Edit: Sat, 08 June 2013, 02:32:33 by CPTBadAss »
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #2376 on: Sat, 08 June 2013, 02:36:36 »
DAE game?
Offline raKeto
« Reply #2377 on: Sat, 08 June 2013, 02:38:07 »
If there would be a qotw topic i would defintly post it there :p As you noticed i have a Blackwidow as well, but i know why these Keyboard is bad atleast... Software is a piece of Crap.
I love it. Just need a justification for my GF on spending so much money on a mechanical keyboard. What is a PCB btw?  :p
« Reply #2378 on: Sat, 08 June 2013, 02:52:49 »
What is a PCB btw?
Check this out for more info on PCBs.
Offline Lupizza
  • Kung av Sverige!
« Reply #2379 on: Sat, 08 June 2013, 07:01:27 »
Uh, how do you make a keyboard signature picture? Like the one raKeto has? ;D And will I always have to do the captcha and antispam thingy when posting or will that disappear after a certain amount of posts?
Left geekhack 2013-08-24, because of rude and arbitrary moderators.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2380 on: Sat, 08 June 2013, 08:19:19 »
Filco was kind of special if you go back in time some years. Back then they were a cut above most choices in build quality. Now not so much. There are many other choice that is just as good really. Filco is mostly just riding on the reputation these days in my opinion.
Captchas go away after I think post 10.
« Reply #2381 on: Sat, 08 June 2013, 09:25:19 »
How do you make a keyboard signature picture? Like the one raKeto has?
You can find keyboard pixel art in this thread.
Offline Rule16
  • R.I.P. SmallFry
« Reply #2382 on: Sat, 08 June 2013, 14:11:01 »
Anyone know where I can find the Poker II other than MechanicalKeyboards.com?? (Its sold out there)
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline Lupizza
  • Kung av Sverige!
« Reply #2383 on: Sat, 08 June 2013, 14:12:56 »
Thanks alot! :)
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #2384 on: Sat, 08 June 2013, 14:50:54 »
Qtan's vendio store.
http://www.vendio.com/stores/E-sports-Gaming-equipments/product/__template=iphone/lid=35050923
« Reply #2385 on: Sat, 08 June 2013, 15:04:15 »
It will also be sold through TechKeys.us sometime soon.
Offline Rule16
  • R.I.P. SmallFry
« Reply #2386 on: Sat, 08 June 2013, 16:10:49 »
Sweet, thanks guys.
Dvorak Only Zone
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #2387 on: Sat, 08 June 2013, 16:17:15 »
Q.
What do you usually do when you buy another KB knowing your significant other half will be pissed beyond godlike?
(I just get prepared to spend double, so $xxx.xx for the KB, and $xxx.xx for the hu$h) lol
This is from page 1.. but I love this question hahaha. I face silent judgment whenever I get a new package.. but its just.. so addicting.. dem endorphins.
My SO doesn't need a keyboard.. but one day I'm gonna buy her one, and customise it for her. She won't want it.. but she'll hopefully use it and love it and will join me on this keyboard adventure. Probably not though. Lol.
« Reply #2388 on: Sat, 08 June 2013, 17:45:17 »
Funny, my girlfriend really asked me for one yesterday... She knows I'm addicted to collecting KBs and now I have to find pink doubleshots somewhere^^ She's the one eh :D
Offline UniClown
« Reply #2389 on: Sat, 08 June 2013, 21:31:00 »
How in the hell did someone come up with the lube combination of GPL103 + GPL205? I mean, who decided that using lube commonly used for Liquid Oxygen pumps would be so amazing in a keyboard?
Offline Lastpilot
  • Power stance
« Reply #2390 on: Sun, 09 June 2013, 00:10:24 »
Can we please put a proper definition for 'tenkeyless' on the OP? Recently a lot of newcomers have been using this to cover the 60% category. It's really happening wayyy too much than it should lol.
« Reply #2391 on: Sun, 09 June 2013, 00:12:58 »
Trial and error? And testing a lot of types of lubes?
I thought it was pretty self explanatory as well.
« Reply #2392 on: Sun, 09 June 2013, 00:20:43 »
WFD has an excellent summary here: http://geekhack.org/index.php?topic=44525.msg922756#msg922756
Offline SmallFry
« Reply #2393 on: Sun, 09 June 2013, 02:40:37 »
FREEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEDDDDDDDDDDDDDOOOOOOOOOMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM!
« Reply #2394 on: Sun, 09 June 2013, 02:42:31 »
The thread was locked but I didn't lock it. There was no unlock button before but it reappeared. I've unlocked the thread. Sorry for the scare everyone. :D
Offline Lupizza
  • Kung av Sverige!
« Reply #2395 on: Sun, 09 June 2013, 08:33:30 »
what is this i dont even... 7
« Reply #2396 on: Sun, 09 June 2013, 16:09:44 »
Yo,   the ergodox fasteners, they are M2.5 - 0.5 x 22 ???
my eyes no good
Offline dndlmx
« Reply #2397 on: Sun, 09 June 2013, 21:14:48 »
Say you want something between MX Red and MX Black. Good way to approach this?
What springs to use, where to get them?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #2398 on: Sun, 09 June 2013, 21:17:22 »
You'll more than likely have to find Korean springs
« Reply #2399 on: Sun, 09 June 2013, 21:17:59 »
62g and 65g Korean springs are inbetween MX Reds and Black. You can get them in various groupbuys (Calavera just held one) and Sherry has some for sale in his classifieds board.
