Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 5259060 times)
0 Members and 8 Guests are viewing this topic.
Offline esoomenona
  • Gnillort?
« Reply #2150 on: Fri, 31 May 2013, 08:21:38 »
When did you buy that Rosewill? Three months ago? Is that all it takes to call them vintage these days... :p
« Reply #2151 on: Fri, 31 May 2013, 08:23:45 »
ahem....it came with 'vintage blacks' dutifully installed and modded by sir whiskytango ;)
and while it seems like three months ago it was only one month ago (i've only been here for two) 8)
« Last Edit: Fri, 31 May 2013, 08:25:25 by ray4jc »
Offline SmallFry
« Reply #2152 on: Fri, 31 May 2013, 08:24:58 »
You know what they say about assuming...
« Reply #2153 on: Fri, 31 May 2013, 08:26:15 »
small fry needs something for getting to 6000 posts....what would be a proper prize?
« Reply #2154 on: Fri, 31 May 2013, 08:27:12 »
If I'm right, it was originally mine. I gave whiskeytango a Rosewill that I had harvested of switches. He took some vintage blacks from an old WYSE terminal board, and soldered them in. WT used the board for a while, then sold it for basically the cost of the switches, since he had received the rest of the parts for free. Hopefully if ray4jc ever gets tired of the board, he will pass on the good will. :D
Offline esoomenona
  • Gnillort?
« Reply #2155 on: Fri, 31 May 2013, 08:28:24 »
Feeling a bit bitter?
Offline SmallFry
« Reply #2156 on: Fri, 31 May 2013, 08:29:12 »
People to get of my ass all ****ing day long. Home, online, everywhere.
Offline esoomenona
  • Gnillort?
« Reply #2157 on: Fri, 31 May 2013, 08:29:46 »
My word, you guys... I was joking about the state of "vintage" these days!
« Last Edit: Fri, 31 May 2013, 08:31:30 by esoomenona »
Offline SmallFry
« Reply #2158 on: Fri, 31 May 2013, 08:30:34 »
Not just you, moose...not just you.
Offline Tym
« Reply #2159 on: Fri, 31 May 2013, 08:35:57 »
But your avatar; he is so happy...
Offline The_Beast
  • I like wood ಠ_๏
« Reply #2160 on: Fri, 31 May 2013, 08:36:34 »
My MX Black Filco TKL makes a "ping" noise on key release, my Choc Mini with MX Reds never did this. How can I prevent this noise? Both boards have O-rings already.
More than likely because one is plate mount (filco) and the other is PCB mount
I'd like to mention that this was incorrect advice and I ended up wasting $70+ on Clear PCB switches because of it. Not saying it's his fault... but it was the reason I made the purchase.
All Noppoo Choc Minis are plate mounted and all Filcos are plate mounted (obviously).
Wait, what the ****?
I simply told you that the Filco has a plate and the Choc Mini didn't. I never told you to buy $70 on switches or even hinted that you would need new switches to fix the pinging issues you have.
So, I guess, don't blame me for your mistake
« Reply #2161 on: Fri, 31 May 2013, 08:56:11 »
hopefully I will find some actual 'vintage' IBM boards when I go visit my parents in a month or so
bro I wasn't bashing or anything I just wanted to send you a gift for getting to 6000 posts  :'(
yes I actually already offered it to someone for a little less than i paid just the other day but then i decided i better keep it since its the only other full size board i have at the moment...but yes it will go for a good price IF I ever sell it. But now that I now it was once owned by jdcarpe I want $400 j/k :p
Offline SmallFry
« Reply #2162 on: Fri, 31 May 2013, 09:09:18 »
I understand, sorry. I am just rather sick of people at the moment.
Offline Lastpilot
  • Power stance
« Reply #2163 on: Fri, 31 May 2013, 09:31:28 »
I know that SP makes keys in high gloss and matte finishes. Has there ever been a set made in high-gloss finish to avoid uneven shine over time?
« Reply #2164 on: Fri, 31 May 2013, 09:35:04 »
I wasnt aware that SP made caps in different finishes. I've only ever seen caps in what I'm assuming is the matte finish. This is an interesting idea though.
« Reply #2165 on: Fri, 31 May 2013, 09:37:25 »
I believe SP's SA-profile sphericals have smooth tops with no texture.
Offline Lastpilot
  • Power stance
« Reply #2166 on: Fri, 31 May 2013, 09:42:34 »
Yes I was reading about it here: http://keycapsdirect.com/key-caps.php
I am guessing any finish can apply to any profile. And yes, the sphercials do look smooth with no texture, but I'm not sure if that is considered high gloss or just a side-effect of the manufacturing process. From what I've seen they just don't look shiny enough.
Touch area finishes are typically semi-glossy
Offline esoomenona
  • Gnillort?
« Reply #2167 on: Fri, 31 May 2013, 10:42:08 »
« Reply #2168 on: Fri, 31 May 2013, 10:43:31 »
Has there ever been/Is there a thread where people posted there ages? Or perhaps their occupations? Or are we all to anonemoose for that?
Offline SmallFry
« Reply #2169 on: Fri, 31 May 2013, 10:46:25 »
I've seen one in the past, I don't recall where though.
Offline Dubsgalore
« Reply #2170 on: Fri, 31 May 2013, 10:50:12 »
there should be another :3
« Reply #2171 on: Fri, 31 May 2013, 10:50:46 »
There are two kinda current threads. I found a one from 2009 but decided I didn't want to encourage the necro-threads :P
What do you do?
Dayjobs
And if you work in the union skilled trades, there's a post that was started by melvang.
« Reply #2172 on: Fri, 31 May 2013, 10:52:43 »
I think we need an age range poll thread....
Offline esoomenona
  • Gnillort?
« Reply #2173 on: Fri, 31 May 2013, 10:53:25 »
What does it matter how old people are? Curious as to your thought process.
Offline SmallFry
« Reply #2174 on: Fri, 31 May 2013, 10:53:28 »
There was one of those too.
Likely just curious. Becoming part of community often makes people interested in their surroundings.
Offline Dubsgalore
« Reply #2175 on: Fri, 31 May 2013, 10:57:13 »
curiosity
i wanna know how old some people are as well
Offline dadgh
« Reply #2177 on: Fri, 31 May 2013, 10:59:41 »
Here, how bout this. Pay shipping for the board to me and back, and I'll swap the clears (or ergo-clears depending on what you like) for free.
Depending on where you live I could probably drop it off at your house (I'm in WI too). I'll PM you about it later.
Offline esoomenona
  • Gnillort?
« Reply #2178 on: Fri, 31 May 2013, 11:00:37 »
« Reply #2179 on: Fri, 31 May 2013, 11:02:11 »
Seriously. I'm tired of posting this. Stop trading/bartering/handling business in this thread. Please use PMs. I don't want this thread circumventing the 60 post rule and I don't want there being precedents saying that others did it so they can do it here too.
Offline Tarzan
  • formerly known as Greystoke
« Reply #2180 on: Fri, 31 May 2013, 11:07:03 »
How do I get this thread to not show up when I click on the "Show new replies to your posts." link?
Offline SmallFry
« Reply #2181 on: Fri, 31 May 2013, 11:17:23 »
Yup, I've been made into an ass lately. **** it.
CPTBadAss, sorry. I didn't mean to, I meant more to offer to fix the mistake than anything.
Offline Dubsgalore
« Reply #2182 on: Fri, 31 May 2013, 11:19:27 »
6000 get
Offline The_Beast
  • I like wood ಠ_๏
« Reply #2183 on: Fri, 31 May 2013, 11:19:32 »
I just got my Hakko 888, anyone else come with a already wet sponge?
I think it's hilarious that they ship it with a wet sponge
Offline therecorder
« Reply #2184 on: Fri, 31 May 2013, 11:20:54 »
Just unsubscribe when you get the next notice in your email.  Or, you can unsubscribe in your Profile area.
Click on your name/id, mouse over "Modify Profile",  click on "Notifications, check the box on the right side of the thread that you want to unnotify, and scroll down to the bottom of the page and click on "Unnotify".
« Last Edit: Fri, 31 May 2013, 11:27:29 by therecorder »
Offline SmallFry
« Reply #2185 on: Fri, 31 May 2013, 11:21:41 »
« Reply #2186 on: Fri, 31 May 2013, 11:23:28 »
It's all right.
6000 get
Woo... :/ feels good...
Congrats on 6K SmallFry!
Offline Dubsgalore
« Reply #2187 on: Fri, 31 May 2013, 11:29:21 »
6000 get
i believe this was the 6000th post
congrats small!  :D
« Reply #2188 on: Fri, 31 May 2013, 11:32:14 »
pure demographic curiosity  :-*
and I hate to say this but sometimes having an idea of someones age helps understand where they are coming from  ???
Offline esoomenona
  • Gnillort?
« Reply #2189 on: Fri, 31 May 2013, 11:33:44 »
I think people would use the knowledge to dismiss people more than anything.
« Reply #2190 on: Fri, 31 May 2013, 11:36:26 »
Actually, I would like to know a member's age before entering into any buy/sale/contractual agreement. Excepting a few trusted members, I'm going to make it a policy not to transact business with anyone under 18. Especially when sending money to someone.
« Reply #2191 on: Fri, 31 May 2013, 11:40:11 »
I don't know I've ran across some really smart 15 year olds and some hard to understand 50 years olds but I get the idea.
^^ I didn't want to say it like that but if I'm selling something to a kid who got the money out of his mom's purse then yeah that could be an issue :o
« Reply #2192 on: Fri, 31 May 2013, 11:48:31 »
Sounds like this should be taken to a new off topic thread ^__^
« Reply #2193 on: Fri, 31 May 2013, 12:06:28 »
http://geekhack.org/index.php?topic=44177.0
done :p
before long people are just going to say, should I just start a new thread about ________?  ;D
Offline Tarzan
« Reply #2194 on: Fri, 31 May 2013, 12:13:30 »
There are two links under the "Hello Greystoke" text in the upper left corner of the forum view; "Show unread posts since last visit." and "Show new replies to your posts."
Clicking on the second link brings up unread posts for every single topic thread I have ever posted in.  These are not threads I have opted to get Notifications for, these are just ones where I have posted.
Is there any way to remove threads/topics from this category?  Or are we forced to switch over to the "Watched/Unwatched" options in order to effect the same result?
Or is this not a "Simple Question?"  In that case, where should I post my question?
Offline SmallFry
« Reply #2195 on: Fri, 31 May 2013, 12:56:21 »
Using the Watched feature will allow you to 'unwatch' a topic. Transfering to Watches is recommended by Rknize.
Offline WhiteFireDragon
    • youtube
« Reply #2196 on: Fri, 31 May 2013, 15:26:12 »
For pictures on this forum, how do I put a SMALL thumbnail and when clicked on, it expands out to full size? I use either photobucket or imgur and they do not have this option, neither does this forum. The thumbnails are always too big.
But I think I've seen someone (jdcarpe?) resize a thumbnail, and when clicked on, it's full size.
« Reply #2197 on: Fri, 31 May 2013, 15:29:35 »
Use WIDTH and/or HEIGHT size tags with the IMG tag.
Code: [Select]
[img width=80]http://i.imgur.com/jVmZwNE.png[/img]
If you only use one or the other, the system will adjust the missing size tag based upon the image's aspect ratio.
Offline hypercrush
« Reply #2198 on: Fri, 31 May 2013, 15:37:07 »
I just took delivery of a TKL MJ2 Filco w/ Browns an hour ago and while I like it, I don't LOVE it as much as I thought I was going to.
I'm used to typing on a Razer Tarantula and the keystroke travel was almost non existent after the activation point.
Would adding o-rings help minimize the post activation travel and the 'bottoming out' sound?
If so, which o-rings should I try? What's the best place to get them? I see WASD has them for $17.99, but that seems kind of pricey for what it is.
Thanks in advance.
« Reply #2199 on: Fri, 31 May 2013, 15:40:21 »
Code: [Select]
Thats some handy info JD, I did not realize we could use size in the img tag here.
I think there should be a posting guide that covers these things as well as useful codes. But at the least this could go in the OP!
