Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 5258015 times)
Offline Jocelyn
  • 조셀린
« Reply #2250 on: Mon, 03 June 2013, 19:22:16 »
R2 GB is for Imsto Thick PBT  :p
Link - http://geekhack.org/index.php?topic=43328.0
Oh THAT R2...hard to judge what R2 we're talking about. For all I know, it couldve been Beast's switch tools. :P
Can anyone give me their input on my dilemma?
I am wondering if I should get the Dolch ABS keycaps from originative or the thick PBT caps from the R2 GB. I know the differences between ABS and PBT however, I have tried neither as my first keyboard is in the mail. Any help would be appreciated.
Context & reading comprehension, I has it  :p
« Reply #2251 on: Mon, 03 June 2013, 19:34:08 »
What is this R4 dolch magic?
Who can give me an easy answer on the history of dolch?
Quickie history on Dolch boards. They made the Dolch 65 PAC board which is really nice. I tried one with vintage blues at the Chicago meetup.
R4 = Round 4. There has been 4 rounds of Dolch replica Group Buys. The last one was run by 7Bit. More info on R4 can be found here. Not sure what the difference between all the Rounds are.
I had no idea R4 had anything to do with dolch!
« Reply #2252 on: Mon, 03 June 2013, 19:39:00 »
English might be my main language now but it wasn't my first language. :P
R4 just shipped to typically when people say R4, they are referring to the Dolch replica set.
Offline Jocelyn
  • 조셀린
« Reply #2253 on: Mon, 03 June 2013, 19:40:16 »
Actually it's more related to memory, but I'm just messing with you anyway :)
« Reply #2254 on: Mon, 03 June 2013, 19:43:04 »
I know haha, I'm just kidding too ^__^
Offline SmallFry
« Reply #2255 on: Mon, 03 June 2013, 20:23:41 »
R4 included a lot more than just the Dolch themed set also. LOTS of novelties, and a few other base sets.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2256 on: Mon, 03 June 2013, 20:51:56 »
Eh, no. That would be IIPBTR2 sillyhead!
Offline Moomoo
« Reply #2257 on: Mon, 03 June 2013, 21:34:47 »
Can you change the PS/2 to USB connector on "The Cheat" without problem and What are phantom PCB (remove cherries without soldering/desolder?)
« Reply #2258 on: Mon, 03 June 2013, 21:37:43 »
1. Yes
2. Yes
« Reply #2259 on: Mon, 03 June 2013, 21:39:28 »
1) Can you change the PS/2 to USB connector on "The Cheat" without problem
2) What are phantom PCB (remove cherries without soldering/desolder?)
1) I don't see why you can't change the PS/2 connector. Just be careful? Or use an adapter.
2) I'm not quite sure what you're asking but there are cut-outs in the Phantom plate which allows you to remove Cherry switches without soldering or desoldering.
Offline Moomoo
« Reply #2260 on: Mon, 03 June 2013, 21:47:51 »
That's pretty sweet, GH communities are freaking geniuses. Just thought I'd ask the question seems legit especially if you want to try new switches without having to spend 19 million hours to switch cherries.
Offline Photoelectric
« Reply #2261 on: Mon, 03 June 2013, 23:23:27 »
Noob question: PCB-mounted switches can or cannot be mounted on boards with plates?  And the other way around, can plate-mounted switches be attached successfully to boards without a plate?
« Reply #2262 on: Mon, 03 June 2013, 23:24:17 »
You can put PCB mount switches onto a plate mounted board, given that the PCB has the holes to support the pins. If not, you can easily just break off the pins, which obviously isn't reversible.
Plate mounted switches cannot be attached to boards without plates.
Offline Jocelyn
  • 조셀린
« Reply #2263 on: Mon, 03 June 2013, 23:24:48 »
First question, yes assuming the PCB has the holes for the nubs. If not you can can cut the plastic nubs off.
Second question, no.
« Reply #2264 on: Mon, 03 June 2013, 23:27:12 »
Ok, so the reason I ask is for buying Clear switches.  If I get an older batch, it may be PCB-mounted kind.  So I'm okay.  But if I get a new kind, those seem to mostly be for plate-mounting, so I have to be careful which keyboards to look for on the cheap to be converted to clears.  This is all theoretical, as I'll probably just get a Ducky with Clears, but... I hate that it's not TKL, so I'm exploring my options.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #2265 on: Mon, 03 June 2013, 23:28:22 »
Well, plate mount switches CAN be mounted to a PCB without a plate. However, you have to alight the switches very carefully since you don't have the pins to use for alignment. If you don't alight them right, you could get binding issues, because the caps would be at an angle.
kmiller used plate mounts on his GH60 prototype, but the alignment was off and it looked terribad
When in doubt, buy PCB mount (Hey it rhymes kinda)
« Reply #2267 on: Mon, 03 June 2013, 23:32:30 »
For those who have done it,how much work/time is it to clip those legs off say ~100 switches??
Offline The_Beast
  • I like wood ಠ_๏
« Reply #2268 on: Mon, 03 June 2013, 23:34:51 »
Shouldn't take long.
Do you HAVE to clip off the legs? BTW, are the stems still in them or are them empty switches?
Offline linziyi
  • The one with many questions
« Reply #2269 on: Mon, 03 June 2013, 23:35:48 »
Just one related question.... Can I put a plate on the PCB mounted switches? That is, can I put a plate on a board already mounted with PCB mounted switches?
Ducky DK9008G2 Pro
"Much to learn you still have" --Yoda
« Reply #2270 on: Mon, 03 June 2013, 23:43:39 »
I got all those clears in the auction and wanted to use them in my phantom but the phantom needs plate mount switches...so yeah I hate to cut all those legs off....they are still in the bag they came in appear to be brand new pcb mount
not without desoldering and soldering back
« Reply #2271 on: Mon, 03 June 2013, 23:49:21 »
If this has been asked before, I apologize.  Are there any TKL keyboards that come stock with MX Clears?  Other than future CM QFRs?
Offline linziyi
« Reply #2272 on: Mon, 03 June 2013, 23:50:45 »
The PURE I think, I saw someone posting a picture of it eariler in this thread.
Ducky DK9008G2 Pro
« Reply #2273 on: Mon, 03 June 2013, 23:51:51 »
That's not TKL though.  I'm not ready for 60% and similar yet.
Offline calavera
« Reply #2274 on: Tue, 04 June 2013, 01:55:00 »
Whats a good taobao agent? Bhiner seems to be doing some fishy things lately, I could be wrong though.
« Reply #2275 on: Tue, 04 June 2013, 02:13:10 »
I too would like to know this after Bhiner majorly messed up my order and tried getting me to pay a ton in shipping to correct it.
Offline Jocelyn
  • 조셀린
« Reply #2276 on: Tue, 04 June 2013, 02:13:24 »
Agreed. I've personally never had a problem with them, but I know of at least two people (nubbinator and WFD) who had orders shipped in two separate packages when they could have shipped them together. No idea on other agents =/
Edit - The only reason I went with them in the first place, was due to someone raving about them in the "what did you get in the mail today thread" from awhile ago.
« Last Edit: Tue, 04 June 2013, 03:07:56 by Jocelyn »
Offline WhiteFireDragon
    • youtube
« Reply #2277 on: Tue, 04 June 2013, 03:01:00 »
That reminds me, they never even bothered to ship the second part of my order. The split order shouldn't have been a mistake in the first place  ::)
Offline Moomoo
« Reply #2278 on: Tue, 04 June 2013, 05:33:25 »
Has anyone tried panda clears? (Clear stems - non clicky with black springs) How do they feel?
« Reply #2279 on: Tue, 04 June 2013, 06:36:49 »
Took me less than 10 minutes to clip legs off of 30 switches. Its really not a big deal.
I think Leopold FC200Rs came in clears since I've seen a few floating around.
I think they'd feel like a heavier version of 62g or 65g (Korean spring) ergo-clears. It seems like the same concept as ergo-clears: Put a lighter spring into a switch with a clear stem. But I don't think I've tried them. Maybe the Universal Switch Tester had them but I don't recall what they felt like if they did.
« Reply #2280 on: Tue, 04 June 2013, 06:40:01 »
I'm still trying out Bhiner, seems odd I ordered something, a week later nothing so I messaged them and then the next day the item was ready for second payment....so I'm not sure if it was coincidence or what.
Also I have been trying out MisterTao with the intent of writing up a review on my TaoBao buying experience but right now I'm very unhappy with them, they left out ~$22 worth of stuff out of my order and basically told me, too bad.
« Reply #2281 on: Tue, 04 June 2013, 08:29:26 »
I don't care for clears much. It's been awhile since I tried them, but I do remember thinking with black springs were the least terrible. Stock was way too heavy, and I seemed to notice reset issues with lighter springs that put me off. Black springs clears with stock clear on the spacebar I thought was the sweetspot.
« Reply #2282 on: Tue, 04 June 2013, 08:51:16 »
The lighter spring (like 55g) ergo-clears board I tried also had reset issues and the modifiers would stick. I've been told lubing helps but I was also put off as well. I think the Black Spring Panda-clears might be nice.
Offline fateswarm
« Reply #2283 on: Tue, 04 June 2013, 12:02:05 »
No, LED stops the top from coming off. You will have to desolder it first.
I guess only the insane would disassemble them then just to lube them periodically.
Dropping the oil above it will have to do I guess.  :rolleyes:
« Reply #2284 on: Tue, 04 June 2013, 12:12:29 »
That scared to mod your board? Soldering and desoldering comes with the hobby :D
« Reply #2285 on: Tue, 04 June 2013, 12:15:22 »
I'm pretty sure that I saw you say that you didn't even have a soldering iron  :)) I might be wrong though.
« Reply #2286 on: Tue, 04 June 2013, 12:26:00 »
Just bought a Hakko and I've been taking apart boards to build my TKL Alps board. I'm extremely confident in my soldering skills too thank you very much :P
« Reply #2287 on: Tue, 04 June 2013, 12:42:51 »
Nice get! ;D What's this TKL alps board?  :eek:
« Reply #2288 on: Tue, 04 June 2013, 12:44:18 »
My Wiki has some details but I'm making my own TKL Alps board. Naming it the Tofu101. Check it out in my signature. :D
Offline domoaligato
« Reply #2289 on: Tue, 04 June 2013, 12:45:45 »
does anyone know someone that can make custom alps plates?
« Reply #2290 on: Tue, 04 June 2013, 12:46:36 »
How the hell did I miss this!? I look forward to seeing it! At a later date I think I'm going make myself a plate that supports alps for the TEK-80 and do a direct wiring teensy job.
« Last Edit: Tue, 04 June 2013, 12:48:16 by Photekq »
« Reply #2291 on: Tue, 04 June 2013, 12:50:57 »
Thanks! I've been keeping it on the DL since I'm not at a place in the project where I'm comfortable with showing off what I've done. I will post a build log when I progress a little more. I will admit the teensy is a bit intimidating since I'm so bad with coding so I avoiding that route. I hope to learn enough at a later point to learn to code a teensy.
The_Beast might be willing to cut you the plate if you can design/draw/model the plate in CAD.
Offline take
  • 87U / G500
    • front & follow
« Reply #2292 on: Tue, 04 June 2013, 12:53:08 »
is there any place besides EK to get keysets for my 87U?
REΛLFORCE 87U 55g  ||  Logitech G500
Offline SeriouSSpotS
  • 60% is love, 60% is life
« Reply #2293 on: Tue, 04 June 2013, 12:58:44 »
Does any company offer thick-PBT ISO enter keys?
Offline domoaligato
« Reply #2294 on: Tue, 04 June 2013, 12:59:08 »
I already asked him via PM a while back and he said he was only doing cherry plates.
« Reply #2295 on: Tue, 04 June 2013, 13:03:18 »
« Reply #2296 on: Tue, 04 June 2013, 13:08:20 »
Don't think so. But I'm not 100% sure.
You double posted this question and I don't think so. I've never seen a thick-PBT ISO enter. But maybe IvanIvanovitch's R2 Thick PBT buy has an ISO option? That might be your best bet.
He won't cut you a plate if you gave him a drawing? I think what he meant was he was only designing Cherry plate. If you gave him a CAD file/drawing, I'm sure he'd help you cut a plate. I don't think he has a personal vendetta against Alps boards.
Offline domoaligato
« Reply #2297 on: Tue, 04 June 2013, 13:34:55 »
i will get it in CAD and ask him when it is done.
« Reply #2298 on: Tue, 04 June 2013, 14:12:11 »
Quote from: CPTBadAss
Thanks for the reply, sorry didn't mean to double post. Tried to delete but couldn't figure out how :P.
« Reply #2299 on: Tue, 04 June 2013, 23:31:57 »
Vintage MX Clear vs "modern" : any noticeable difference, like the smoothness and lightness of vintage MX Black vs recent batches?
