Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6274544 times)
« Reply #3200 on: Fri, 26 July 2013, 01:49:48 »
Clears and Browns have different stems. I've been noticing people thinking otherwise around the forums lately.
Offline naokira
  • The King in the North
« Reply #3201 on: Fri, 26 July 2013, 07:30:00 »
Do leds shine through a thick pbt keycap if its white? Mines do :( don't know if the led is just too strong or what.
Though the stock pbt of poker II doesn't shine through.
FaceW in LZ-CE
« Reply #3202 on: Fri, 26 July 2013, 07:36:43 »
I think that's normal. There have neem some pictures posted in this thread that show that.
« Reply #3203 on: Fri, 26 July 2013, 07:38:46 »
From here.
Offline naokira
« Reply #3204 on: Fri, 26 July 2013, 08:14:59 »
Thanks for the info. I think they don't shine with darker colors, provided that its a thick pbt.
FaceW in LZ-CE
« Reply #3205 on: Fri, 26 July 2013, 12:44:27 »
Is there anywhere I can buy round LEDs that don't require shaving? I just don't like the look of the square ones..
« Reply #3206 on: Fri, 26 July 2013, 13:46:24 »
Just buy regular 3mm (T1) LEDs. Sometimes you will have a problem with really thick keycaps, though.
Offline Dubsgalore
« Reply #3207 on: Fri, 26 July 2013, 15:17:39 »
If someone where to be using GMK/Cherry caps, would T1 LEDs be a problem?
Offline WhiteFireDragon
    • youtube
« Reply #3208 on: Fri, 26 July 2013, 15:54:05 »
Majority of round LEDs (even T1 and 3mm) will have that small lip on the bottom. If you don't file down that nub sticking out, it won't be seated in the switch housing correctly. This will be a problem for ALL thick caps, including cherry/GMK ABS and imsto PBT.
Looking at datasheet is the best bet to see if those nubs are present. If you're buying those generic T1 LEDs from China that has no datasheet, then nearly all of them will have that bump you'll have to file.
« Last Edit: Fri, 26 July 2013, 15:55:44 by WhiteFireDragon »
« Reply #3209 on: Fri, 26 July 2013, 15:56:16 »
Are there any available that don't require filing down that you know of?
« Reply #3210 on: Fri, 26 July 2013, 16:00:58 »
2x3x4 rectangular ;D
Offline blueasjim
« Reply #3211 on: Fri, 26 July 2013, 16:01:04 »
Is the Tsangan kit not the right fit for the Vortex Pure? That shift key looks too small.
Vortex KBT PURE [MX Red] | CM Storm [MX Blue] | CM Storm [MX Red]
« Reply #3212 on: Fri, 26 July 2013, 16:02:09 »
Tsangan compatibility kit includes "1800" shift, or 1.75-unit shift, same as on the Vortex KBT Pure.
Offline blueasjim
« Reply #3213 on: Fri, 26 July 2013, 16:03:12 »
Thank you, jd.
Offline nathairtras
« Reply #3214 on: Fri, 26 July 2013, 18:44:22 »
Where can I buy a Pure with whites shipping CONUS?
Only store I have found is i kbtrace.com but that is in EU.  It will ship here, but wondering if I have other options or if that is it.  ANSI layout.
Sent from my iPhone using Tapatalk 2
CM QFR Green
« Reply #3215 on: Fri, 26 July 2013, 18:59:49 »
Did you try MechanicalKeyboards.com?
« Reply #3216 on: Fri, 26 July 2013, 19:01:07 »
They're out and they don't have any incoming stock.  They have a Race with Whites though.
Odds are if you can't find it there, you won't find it in the US though.
Offline Lastpilot
  • Power stance
« Reply #3217 on: Sat, 27 July 2013, 12:31:18 »
Which KMACs come hard anodized?
Offline Dubsgalore
« Reply #3218 on: Sat, 27 July 2013, 12:43:39 »
are those the rectangulars on my poker?
    • youtube
« Reply #3219 on: Sat, 27 July 2013, 14:00:58 »
The most recent one, KMAC 2. All other kmacs (and kpad) I believe are standard Type II anodized.
« Reply #3220 on: Sat, 27 July 2013, 14:05:05 »
Take a picture of it for us and we'll ID it. It's very easy to tell though. Are the LEDs square or round?
Offline Dubsgalore
« Reply #3221 on: Sat, 27 July 2013, 14:09:08 »
Only asking JD because he's the one who gave them to me! :p
I believe they are 2x3x4 rectangular ones though
Offline Lastpilot
  • Power stance
« Reply #3222 on: Sat, 27 July 2013, 14:16:52 »
Ah okay, thank you!
Offline Dubsgalore
« Reply #3223 on: Sat, 27 July 2013, 14:18:34 »
I'll drop another question i've been thinking about;
Do FN MX Julysicles exist alongside the FN Topre julysicles?
« Reply #3224 on: Sat, 27 July 2013, 14:20:06 »
I've never seen a 1.5x Clack mod. If the 1x July mod exists, I've never seen it. I don't think it does.
Offline Dubsgalore
« Reply #3225 on: Sat, 27 July 2013, 14:23:35 »
I don't think 1.5x Clack Mods exist at all, but i know 1x 'fn' Topre Julysicles do, i think we'll all seen a picture of one of those. but does it exist in MX?
« Reply #3226 on: Sat, 27 July 2013, 14:24:20 »
I missed the word "MX".
I've never seen a 1x mod July MX and I don't think they exist.
Offline FlagrantWolf
« Reply #3227 on: Sat, 27 July 2013, 14:39:27 »
Where is the best place to buy and then return mechanical keyboards in order to test different switches (specifically brown and clear)?
« Last Edit: Sat, 27 July 2013, 14:47:22 by FlagrantWolf »
« Reply #3228 on: Sat, 27 July 2013, 14:48:21 »
Um that's kinda crappy to do to a company but Amazon and MechnicalKeyboards.com have good return policies. Why not do a meetup or go to a storefront?
« Reply #3229 on: Sat, 27 July 2013, 14:50:50 »
Why not but a sample pack of switches from WASD?
Offline calavera
« Reply #3230 on: Sat, 27 July 2013, 14:51:15 »
amazon has a good return policy.
Offline Rule16
  • R.I.P. SmallFry
« Reply #3231 on: Sat, 27 July 2013, 14:53:05 »
Anyone know if there's full sets of just deep-dished dsa caps? I recently ordered the blank PBT dsa caps from SP and the deep dished ones (f and j) is the best part IMO.
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
« Reply #3232 on: Sat, 27 July 2013, 14:53:32 »
You can't tell from just trying a single switch.
I would recommend amazon. Returns are super-simple with them, and since they're so large I don't feel bad about returning stuff to them for no reason.
« Reply #3233 on: Sat, 27 July 2013, 14:58:59 »
Normally I would never do this, but my city really sucks and there are no stores that carry any higher quality keyboards, much less mechanical keyboards. There is also not much of a computer community here so I could not find any type of meetup. While the switch pack is a nice idea I want to feel what it's like to type on a full keyboard before spending $150-200 on a customized keyboard with that type of switch.
Thanks guys, I'll give amazon a try.
« Reply #3234 on: Sat, 27 July 2013, 15:02:29 »
I've never seen a board with clears on Amazon.
« Reply #3235 on: Sat, 27 July 2013, 15:08:57 »
I guess I can try brown and black then and see if I like the light or heavy. If I like heavier better I'll order the clears on my custom board.
    • youtube
« Reply #3236 on: Sat, 27 July 2013, 15:10:48 »
There should be plenty of keyboards with browns, but very limited boards with clears. Amazon or newegg won't have any boards with clear switches. Mechanicalkeyboards.com should have some Duckies with clear switches.
But they are a small business, so buying with intentions to return will hurt them. Then they'll have to deal with trying to sell the used board. If you really want to try out a switch, you should worry about reselling it youself.
Pressing on a single sample switch does not feel the same as typing on the keys from a complete keyboard.
« Reply #3237 on: Sat, 27 July 2013, 15:18:17 »
Better than nothing though.
Offline nathairtras
« Reply #3238 on: Sat, 27 July 2013, 15:29:25 »
Thanks, that's what I was afraid of but nice to be sure.
$175... Might be hard to justify over a QFR green...
CM QFR Green
« Reply #3239 on: Sat, 27 July 2013, 15:31:00 »
I feel bad enough buying and returning with Amazon. I'd never do that to a small business. I'll just try the browns and maybe the blacks from amazon.
« Reply #3240 on: Sat, 27 July 2013, 15:33:40 »
What? Most I've seen for a used QFR green was $120. Usually they sell in the classifieds for $75-100...
Anyways, this is NOT the thread to talk about prices.
« Reply #3241 on: Sat, 27 July 2013, 22:56:42 »
Yes, Dubs, they are the 2x3x4 rectangular variety. :)
To the person wanting to try different switches: I recommend starting with MX Browns, as they are a good all-around choice and always my recommendation for someone just starting out. When you buy your second mechanical, get clears, reds, blues, or blacks. If you ever get a switch you don't like after trying it for a while, you can usually sell the board here for about 90% of retail. I really just like all MX switches now, after using most of them for a while. You could probably even sit me in front of a keyboard with blues, and I could use it without complaint. :)
Offline klaxhu
« Reply #3242 on: Sun, 28 July 2013, 04:15:05 »
Hi all,
I really like how the CM Storm Limited Edition White Quickfire TK looks, everything except the layout. Would love a keyboard with everything this one has (color combination, backlit, price, etc) but with the layout of the CM Storm Quickfire Rapid or the K65 (basically, tenkeyless) - I have seen a few backlit tenkeyless but none with this color combination...
Also, I am currently building my water-cooled system and need something to match the black & white theme.
Thank you for any small info that could help me find one!
    • youtube
« Reply #3243 on: Sun, 28 July 2013, 04:20:47 »
^ You didn't ask a single question, but thanks for sharing  ^-^ . Also, welcome to GH.
Offline klaxhu
« Reply #3244 on: Sun, 28 July 2013, 04:28:12 »
Hi all,
@WFD - you are right! i am so stupid :)
Do you guys know a keyboard that:
1. tenkeyless
2. backlit
3. ideally - brown sw
4. white & black color combination by default without replacing caps ?
« Last Edit: Sun, 28 July 2013, 04:34:34 by klaxhu »
Offline domoaligato
« Reply #3245 on: Sun, 28 July 2013, 04:33:42 »
Hi all,
1. tenkeyless
2. backlit
3. white & black color combination by default without replacing caps ?
no... sorry I do not know of any without changing caps.
    • youtube
« Reply #3246 on: Sun, 28 July 2013, 04:39:10 »
Ducky shine satisfies the first 3 requirements, you'll have to buy additional caps for #4. But don't worry, you'll get over the price shock after you've been on here for a while  ;)
Offline klaxhu
« Reply #3247 on: Sun, 28 July 2013, 04:39:14 »
thanks!
that Storm LE ticks most boxes, i just don't like that layout and don't know if i can get used to using it ...
i use arrows/insert/delete/home/end a lot in total commander :-(
in SC2 it won't be a problem as i would rarely touch that side
and about the high $ £ € - i know and i don't mind :D
« Last Edit: Sun, 28 July 2013, 04:44:37 by klaxhu »
Offline domoaligato
« Reply #3248 on: Sun, 28 July 2013, 04:41:45 »
can you do a black keyboard with white key caps? if so a ducky like wfd said with a different set of caps would be easy to find on mechanicalkeyboards.com
edit: what switches?
Offline klaxhu
« Reply #3249 on: Sun, 28 July 2013, 04:45:15 »
ideally, brown
