Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 4992434 times)
Offline domoaligato
« Reply #3300 on: Tue, 30 July 2013, 23:28:31 »
this is another very cool design as well
http://geekhack.org/index.php?topic=45389.0
Offline elton5354
« Reply #3301 on: Wed, 31 July 2013, 05:48:24 »
Where do you put an LED in an Alp switch?
Offline WhiteFireDragon
    • youtube
« Reply #3302 on: Wed, 31 July 2013, 06:00:11 »
If the switches doesn't already come with an LED, then the housing won't have holes that you can insert the LED. ALPS switches that come with LEDs have slightly different housing than the ones that don't have LEDs, unlike MX cherry switches where housings are all the same.
Offline elton5354
« Reply #3303 on: Wed, 31 July 2013, 06:13:41 »
How did these get their LEDs? They look like Matias Alp switches
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #3304 on: Wed, 31 July 2013, 06:18:51 »
Totally guessing here but but I would think the LEDs are probably SMD on the PCB directly to the side of the switch.
« Reply #3305 on: Wed, 31 July 2013, 06:27:16 »
I can't seem to find that thread where you pulled that image, as I'm only on a mobile platform right now with no access to a real PC. However, your answer is right there in one of the next images. They are lit from underneath, through the hole in the PCB designed for the Cherry switch mount.
« Reply #3306 on: Wed, 31 July 2013, 06:33:16 »
That image is from the Duck Mini2 thread with Matias switches installed.
Offline CalmB4tehPwn
  • Demon of the Fall
« Reply #3307 on: Wed, 31 July 2013, 10:14:58 »
Okay, so I've got a couple questions. As it hasn't really had any effect on my keyboarding, I haven't spent too much time worrying about keycaps, but I'm curious about where I can get some more information on the different types of plastic, and some benefits of the different types. Also, I'd love to see a pic or two illustrating thin vs med vs thick PBT, just so I have a reference. What are generally considered more preferable, and are there any quantifiable reasons?
"I seek a great warrior" - Luke Skywalker
"Great Warrior, Hmm? War does not make one great." - Master Jedi Yoda
« Reply #3308 on: Wed, 31 July 2013, 10:22:24 »
I found the thread and blog post where the images reside: http://duck0113.tistory.com/35
« Reply #3309 on: Wed, 31 July 2013, 10:25:59 »
1) I'm curious about where I can get some more information on the different types of plastic, and some benefits of the different types.
2) Also, I'd love to see a pic or two illustrating thin vs med vs thick PBT, just so I have a reference.
3) What are generally considered more preferable, and are there any quantifiable reasons?
1) There's a bit of info that can be found here and here. Regardless, common types of keycap plastics are ABS, PBT, and POM.
2) If you don't get a picture by 1800 EST today, PM me and I'll post a picture here for you. I believe I still have pictures of PBT caps but if not, I can show you the ABS caps I have in thick and thin.
3) Thick PBT and ABS seem to be the most popular. Thick ABS are generally found from Cherry/GMK. Thick PBT are usually from imsto. It's all personal preference. Some people swear by thick PBT. I just sold my set off because I love thick ABS. The thicker caps feel nicer and more solid versus say SP ABS caps or Vortex Thin PBT caps.
« Reply #3310 on: Wed, 31 July 2013, 10:37:20 »
This used to be in the OP... *grumble, grumble*
which is better? thick pbt or abs gmk?
That's like asking which is better, Ferrari or Lamborghini? :P
They're both awesome.
« Reply #3311 on: Wed, 31 July 2013, 13:07:25 »
Whoops, I'll fix that jdcarpe. Accidently deleted it.
« Last Edit: Wed, 31 July 2013, 13:11:16 by CPTBadAss »
« Reply #3312 on: Wed, 31 July 2013, 13:10:00 »
Is there anyway to figure out what spring is what if I've accidentally went and mixed up springs from red, black, brown, blue and white switches?
« Reply #3313 on: Wed, 31 July 2013, 13:13:00 »
Red, brown, and blue switches all use the same spring.
The black should be in the middle of the weights.
The white should be heaviest.
I don't actually know if the springs look different since I didn't look at them that hard but they might have different coil counts.
Offline Dubsgalore
« Reply #3314 on: Wed, 31 July 2013, 13:14:44 »
I know there is a picture someone with all the springs side by side, and some you can tell by just looking at them which are which
im going to go try and find it
« Reply #3315 on: Wed, 31 July 2013, 13:22:14 »
From this thread, I found this:
Offline esoomenona
  • Gnillort?
« Reply #3316 on: Wed, 31 July 2013, 13:23:27 »
He's thinking of ripster's guide.
« Reply #3317 on: Wed, 31 July 2013, 13:24:04 »
Doh! I didn't think to look for one of those pics with the springs side by side....I think the one I want is deleted possibly :(
^^ This might help  8)
^^ Oh yeah...that was it  :-[
Offline Dubsgalore
« Reply #3318 on: Wed, 31 July 2013, 14:00:17 »
It's like 8 or 9 springs, horizontally side by side, including kbd and gold ones (i think)
might be ripsters
I know i can tell a stock clear spring apart from others
« Reply #3319 on: Wed, 31 July 2013, 14:01:22 »
might be ripsters
Yeah I was thinking of that one to....was it in sherry's spring thread that got deleted?
« Reply #3320 on: Wed, 31 July 2013, 14:02:12 »
Edit: I can't link direct to the image. Just use the album link.
Album is here.
« Last Edit: Wed, 31 July 2013, 14:15:25 by CPTBadAss »
Offline Dubsgalore
« Reply #3321 on: Wed, 31 July 2013, 14:02:34 »
might be ripsters
I can't remember honestly, i know i've seen it again recently, and i know it's here somewhere, i'll go digging
« Reply #3322 on: Wed, 31 July 2013, 14:05:09 »
Album is here.
Thanks for the link!
Offline Dubsgalore
« Reply #3323 on: Wed, 31 July 2013, 14:07:13 »
I swear, there is a different pic. i know because it's only one photo, and each spring has it's weight under it, in a black font
« Reply #3324 on: Wed, 31 July 2013, 14:15:55 »
Are you confusing that one I linked with the Korean spring comparison photo?
« Reply #3325 on: Wed, 31 July 2013, 14:22:04 »
Wasn't there one in that fashion except with more springs?
Offline Dubsgalore
« Reply #3326 on: Wed, 31 July 2013, 14:24:33 »
nope, im still looking for it
« Reply #3327 on: Wed, 31 July 2013, 14:24:50 »
Tired of chasing your rumors. Find pictures or tell me the sources. This is the one I was referring to.
From calavera's GB thread and my review.
Offline Dubsgalore
« Reply #3328 on: Wed, 31 July 2013, 14:25:28 »
implying i was withholding the picture  :)) :)) :))
thats the one
« Reply #3329 on: Wed, 31 July 2013, 14:29:51 »
Nope just implying that I have no idea what picture you're looking for and I was tired of Googling.
Offline Dubsgalore
« Reply #3330 on: Wed, 31 July 2013, 14:31:11 »
ok well i was looking for it too, but you beat me too it. that is the one i was talking about..
« Reply #3331 on: Wed, 31 July 2013, 14:33:19 »
No worries. I found that Ripster album which was pretty cool so it paid off. Wasn't sure if you had seen something else is all.
« Reply #3332 on: Wed, 31 July 2013, 14:35:13 »
Yeah, I think the one he's referring to is from Calavera's Korean spring GB.
Offline Dubsgalore
« Reply #3333 on: Wed, 31 July 2013, 14:35:43 »
It was actually good to post the Ripster one, he had stock cherry springs, Calavera's had korean springs.
still, i can personally poke out a stock clear spring  :p
Offline lcs
  • Lover of Grape Drank
  • はやく
« Reply #3334 on: Wed, 31 July 2013, 17:29:33 »
I recently bough a model M.
Some keys are really hard to push, and sometimes they take a while to return up.
Is there some guide / known way to fix this?
« Reply #3335 on: Wed, 31 July 2013, 17:31:12 »
You'll want to look for fohat.dig's guide on bolt modding. He explains how to clean the board and if you want, how to bolt mod the board. It just sounds dirty.
Offline lcs
  • はやく
« Reply #3336 on: Wed, 31 July 2013, 17:33:25 »
Yes, I read that one in the wiki, but I got the impression that it was for a different problem! I'll try reading it again.
« Reply #3337 on: Wed, 31 July 2013, 17:34:12 »
No fohat.dig's guide isnt the one in the Wiki...
Offline lcs
  • はやく
« Reply #3338 on: Wed, 31 July 2013, 17:35:28 »
Oh, okay. I'll search for that one then. Tks!
Offline Tarzan
  • formerly known as Greystoke
« Reply #3339 on: Wed, 31 July 2013, 17:35:58 »
Could also be because a previous owner removed some of the key guides under the double-size keys, and re-inserted them incorrectly.  Do you have single-space keys sticking, or only the Return, Backspace, and Enter keys?
Offline lcs
  • はやく
« Reply #3340 on: Wed, 31 July 2013, 17:41:50 »
Only in some single-space keys.
Offline Tarzan
« Reply #3341 on: Wed, 31 July 2013, 17:54:23 »
Sounds like it's beyond the scope of a "simple answer."   :-\
Best approach would be a thorough Model M cleaning, then figure out if you need to pursue the bolt mod option.  I've done one, it's not tough, but time-consuming.
Offline lcs
  • はやく
« Reply #3342 on: Wed, 31 July 2013, 17:57:25 »
Oh well. I'll clean it then. Thanks for the help!
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #3343 on: Wed, 31 July 2013, 18:31:42 »
I'm thinking about having these modded onto my board: http://www.ebay.com/itm/100pcs-2x3x4mm-2x3x4-mm-Rectangle-White-Diffused-LED-Leds-Lamp-Free-Resistors-/321161076422?pt=LH_DefaultDomain_0&hash=item4ac6b11ec6
It says: "This is for 100pcs 2x3x4mm Rectangle White Diffused LED Leds Bulb Light Lamp + 100pcs 1/4W 470ohm Resistors"
Will those resistors work for our keyboards? Poker 2
Quote from another thread. Thought id ask here too for more exposure. Thanks
« Reply #3344 on: Wed, 31 July 2013, 18:42:43 »
Doesnt the Poker 2 already have SMD resistors for the PCB since there is a backlit version? Doesnt make sense to make 2 diff PCBs. I dont think you'll need the resistors.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #3345 on: Wed, 31 July 2013, 18:47:09 »
Okay so I can just buy LEDs and install them? :o
« Reply #3346 on: Wed, 31 July 2013, 18:49:30 »
Definitely check or take a pic of the PCB so we can verify but no, I don't think so. DOUBLE CHECK THOUGH. I'm not responsible if you dont verify yourself and break something.
« Reply #3347 on: Wed, 31 July 2013, 19:08:44 »
I will be taking apart my massdrop poker II when it arrives.
I couldn't find a picture of a poker II pcb on my quick search, but it was not an in depth search at all.
I'm pretty sure my nonbacklit pure I'm using does not have resistors, but I can doublesheck if anyone is interested.
    • youtube
« Reply #3348 on: Wed, 31 July 2013, 19:09:46 »
There are already SMD resistors, although I haven't checked the value of them. Ideally you'd want to match resistor value with the LED voltage, but I think most color and voltages should be ok.
You need to remove solder from the holes first (the small circle and square holes), install LED, clip excess leads, then solder. Pay attention to polarity. Here is a pic of poker2 PCB from my review thread:
http://geekhack.org/index.php?topic=44118.0
« Reply #3349 on: Wed, 31 July 2013, 19:56:24 »
Is it wrong for me to say I love you WhiteFireDragon? Thank you for the knowledge
