Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6274543 times)
Offline domoaligato
« Reply #3250 on: Sun, 28 July 2013, 05:02:20 »
brown switch tenkeyless keycool 87's
http://mechanicalkeyboards.com/search.php?keyword=&switch_id=2&size=Tenkeyless&man=ALL&key_plastic=ALL&backlit=ALL&interface=ALL&cord_length=ALL&usb_kro=ALL&ps2_kro=ALL&x=33&y=10&in_stock=on
for white led keycaps post a WTB thread in the classifieds for white ducky shine keycap set.
they are sold out on mechanicalkeyboards.com and a few other places I checked.
a youtube video showing what that would look like...
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #3251 on: Sun, 28 July 2013, 05:07:17 »
Problem with posting in the Classifieds section is he doesn't have the required number of posts to start a thread there.
Offline klaxhu
« Reply #3252 on: Sun, 28 July 2013, 07:04:36 »
@domoaligato - that is not a bad idea. i will have a look at that option!
@melvang indeed :( - but it's not too bad. by the time i am familiarized with what i will need after probably spending some time here i think i will have the necessary no of posts.
« Last Edit: Sun, 28 July 2013, 07:13:59 by klaxhu »
Offline Lastpilot
  • Power stance
« Reply #3253 on: Sun, 28 July 2013, 13:57:22 »
What is this switch?29726-0
Offline BlueBär
« Reply #3254 on: Sun, 28 July 2013, 14:09:15 »
Can you get some more light on the inside of that black ring? I don't really see how it's mounted. Are you sure that it's mechanical and not a rubberdome with slider?
Offline Lastpilot
  • Power stance
« Reply #3255 on: Sun, 28 July 2013, 14:13:54 »
Never mind it must be rubber dome. Feels like rubber some I have just never seen a slider before. XD
« Reply #3256 on: Sun, 28 July 2013, 14:13:59 »
I also thought it was just a slider over rubberdome but I'm not sure.
Offline MJ45
  • HHKB Pro
« Reply #3257 on: Sun, 28 July 2013, 17:02:20 »
I just finished building my Phantom and looking for a case. I know that Filco and PLU will fit. Will a CM QFR case work?
Offline BlueBär
« Reply #3258 on: Sun, 28 July 2013, 17:06:47 »
http://geekhack.org/index.php?topic=38441.msg753747#msg753747
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #3259 on: Sun, 28 July 2013, 19:13:14 »
Does anyone know if I can put a Poker X/Poker pcb in my Poker 2 case? I want to be able to mod my Poker to clears.
Offline lcs
  • Lover of Grape Drank
  • はやく
« Reply #3260 on: Mon, 29 July 2013, 15:04:05 »
I would like to know which 60 or 75% keyboards have a white case and if any of them have white, clears or greens.
Also, if there is someone that could mod a regular one for me!s
« Reply #3261 on: Mon, 29 July 2013, 15:10:20 »
I think they are the same case, but do you not have a case for your poker x?
The first half, I don't think so, possibly a leopold that is somewhat rare, someone else probably knows better
The second half there is a directory of people who mod boards here
http://geekhack.org/index.php?topic=45886.0
Offline Narcix
« Reply #3262 on: Mon, 29 July 2013, 15:28:29 »
Does the poker 2 come with any leds installed?
Keycool 87 Grey PBT with mx blues
« Reply #3263 on: Mon, 29 July 2013, 15:37:35 »
yes
capslock and 2 on spacebar possibly others can't remember and cant find pic i took
« Last Edit: Mon, 29 July 2013, 15:39:42 by SpAmRaY »
Offline Narcix
« Reply #3264 on: Mon, 29 July 2013, 15:46:05 »
yes
kewl! what color?
also, to install leds on the poker 2, you just have to remove the solder from the led holes and solder 'em in right?
« Reply #3265 on: Mon, 29 July 2013, 15:47:15 »
yes
kewl! what color?
white-ish, I haven't actually plugged mine in yet
yes, more info here http://geekhack.org/index.php?topic=35152.msg976734#msg976734
« Last Edit: Mon, 29 July 2013, 15:48:51 by SpAmRaY »
Offline Narcix
« Reply #3266 on: Mon, 29 July 2013, 15:52:44 »
yes
kewl! what color?
thanks!  ;D
Offline BlueBär
« Reply #3267 on: Mon, 29 July 2013, 15:56:46 »
There was a KBT Race in white but that had issues with the paint chipping off. The Noppoo Choc Mini and the Keycool 84 are available in white, too. I don't think there's a 60% in white. None of those come with the switches you want though I think.
Left win has also one.
Offline lcs
  • はやく
« Reply #3268 on: Mon, 29 July 2013, 15:59:23 »
Yes, I saw it. I want heavier switches though :( I think I'll buy one of those (or maybe a Filco white TKL) and change the switches. Would that be expensive?
Offline Narcix
« Reply #3269 on: Mon, 29 July 2013, 16:10:10 »
If i installed leds on a poker 2, would they be always turned on?
« Reply #3270 on: Mon, 29 July 2013, 16:16:47 »
Yes I remember that now, because I saw it and was thinking, 'what the heck?'
Offline BlueBär
« Reply #3271 on: Mon, 29 July 2013, 16:48:31 »
You can get some different springs from the classifieds or Originative and make some ghetto greens for example. Or you can buy some switches which will be more expensive though (price for 100 springs should be under 10$, Originative sells 100 80g springs for 8$, a new switch costs around 0.50-0.60$ per piece). Maybe check 7bit's MX group buy on deskthority.
I think you can turn them off if you want to but that is more of a guess. Since it will be the same PCB as the backlit version I am pretty sure they included that feature. Probably dimming as well.
Edit: Just looked it up in the manual, you can dim the backlight and turn it completly off as well.
« Last Edit: Mon, 29 July 2013, 16:53:08 by BlueBär »
Offline lcs
  • はやく
« Reply #3272 on: Mon, 29 July 2013, 20:00:19 »
Humm, more help them please :)
If I bought the switches from MX, I wouldn't know if I need the pins or not. The options are the filco and a noppoo choc. Also, is it easy to change them? Thanks for the replies so far guys!
Offline BlueBär
« Reply #3273 on: Mon, 29 July 2013, 20:25:24 »
Both the Noppoo and the Filco are plate mounted boards, so you don't need the pins. However, if you misordered or something, you can simply cut the pins off, it doesn't really make a difference.
Changing the switches or the springs is a bit of work as you will have to desolder the switches on plate mounted boards. This will take some time, you will also have to resolder them when reassembling the keyboard.
If you just buy different springs you will also have to open each switch, but with The_Beast's switch tools for example (currently available for pre-order, I would really recommend them if you want to get into keyboard modding) it's really easy and just takes a few seconds for each switch, opening - swapping the spring - closing takes about a minute for each switch, depending on how fast you are.
You won't have to open the the switches if you simply replace them with new switches of course, so that would a bit faster.
« Last Edit: Mon, 29 July 2013, 20:28:08 by BlueBär »
« Reply #3274 on: Mon, 29 July 2013, 20:32:45 »
Anyone know roughly how much a 456GT weighs?
Offline lcs
  • はやく
« Reply #3275 on: Mon, 29 July 2013, 20:42:14 »
Thanks! I think I'll try swapping the springs them! Seems easier for starting :) I'll buy some switches to practice first :)
Thanks again for the replies!
Offline BlueBär
« Reply #3276 on: Mon, 29 July 2013, 20:48:02 »
Could be that you misunderstood me there: For swapping the switches themselves you will have to desolder them all, and resolder again. When swapping only the springs you will have to additionally open the swiches, so really just changing switches is easier, but more expensive as well.
Offline lcs
  • はやく
« Reply #3277 on: Mon, 29 July 2013, 20:58:08 »
Ok, I get it. Indeed I misunderstood.
So, to desolder and resolder, that'd be too hard for a total idiot on these things?
Offline BlueBär
« Reply #3278 on: Mon, 29 July 2013, 21:08:47 »
Not too hard, but you need some soldering equipment of course and enough time and patience. To get an idea of how much work it is, heres a video from WhiteFireDragon swapping the switches of a Filco to Ergo Clears:
If you don't want to do that, here you can find some people who will do it for you: Professional Services Directory.
Offline lcs
  • はやく
« Reply #3279 on: Mon, 29 July 2013, 21:20:33 »
I think I'll try it myself! There is tj's thread to help as well.
Thanks so much BlueBär!
Offline BlueBär
« Reply #3280 on: Mon, 29 July 2013, 21:27:32 »
Glad to help! I think tomorrrow I'm gonna write a beginner's modding guide, but now I gotta go to sleep :)
Offline domoaligato
« Reply #3281 on: Mon, 29 July 2013, 22:56:41 »
I asked alaricljs and he says about 7lb 2oz without the cable
Offline Narcix
« Reply #3282 on: Tue, 30 July 2013, 05:57:27 »
I think i read somewhere that soon every qfr will have the blak case. is that true?
« Reply #3283 on: Tue, 30 July 2013, 06:16:09 »
The regular QFRs should be unbranded and black now.
The QFR Stealths already have the black cases. I think they have matching plate colors as well. So red switches have red plates, blue switches have blue plates, etc.
Offline Xenderwind
« Reply #3284 on: Tue, 30 July 2013, 06:18:15 »
http://geekhack.org/index.php?topic=46341.msg977953#msg977953
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline phx
« Reply #3285 on: Tue, 30 July 2013, 09:35:08 »
so the brown is 45 cN and the clear is 55, is there a 50 spring?
also, is there a lighter spring than the 45?
edit: sticker sheet, worth?
« Reply #3286 on: Tue, 30 July 2013, 09:39:49 »
1) is there a 50 spring?
2) is there a lighter spring than the 45?
3) sticker sheet, worth?
1) I think so? I'm not sure. There might be a custom Korean one.
2) I've seen a 35g mod but I'm not sure how he did it. I didn't look at the article I saw.
3) Read the OP. This isn't the Price Check Thread. There are vendors who sell stickers so check those out for an idea.
Offline phx
« Reply #3287 on: Tue, 30 July 2013, 09:42:42 »
3. meant to say "is it worth getting?" Does it make a noticeable difference?
« Reply #3288 on: Tue, 30 July 2013, 09:45:15 »
Answer is in the OP as well.
Offline phx
« Reply #3289 on: Tue, 30 July 2013, 09:48:19 »
great, thanks!
(didn't notice the OP has a list of FAQs now)
Offline BlueBär
« Reply #3290 on: Tue, 30 July 2013, 09:49:15 »
If you take the Korean measurements (by bottom out force), the brown springs bottom out around 60g (correct me if I'm wrong here!). You can get 62g, 65g, 67g or 80g springs pretty easily (Originative for example), 80g should be close to the original black springs. Lighter springs sometimes show up in the classifieds, i.e. 45g or 55g springs. Be aware that with a less strong spring, the tactility of a switch will increase (can make it sticky feeling though), but with a stronger spring it will decrease.
« Reply #3291 on: Tue, 30 July 2013, 10:04:42 »
67g is probably closest to MX blacks. 80g is definitely heavier than Blacks based on my own research.
Offline BlueBär
« Reply #3292 on: Tue, 30 July 2013, 10:11:13 »
I don't have any 80g 67g springs to compare, this was just compiled from waht I read on the forum, so I guess you're right. Kind of a simple question: I made this beginner guide to modding, should I rather put it in the keyboard section or in the making stuff together section?
« Reply #3293 on: Tue, 30 July 2013, 10:35:39 »
Making Stuff Together
« Reply #3294 on: Tue, 30 July 2013, 10:38:26 »
Is there anything currently any mechanicals available  to purchase smaller than 60%?
I know there are a few 'in the works' pre-group buy/planning stuffs.
Offline WhiteFireDragon
    • youtube
« Reply #3295 on: Tue, 30 July 2013, 10:46:08 »
Not commercially available.
Offline dndlmx
« Reply #3296 on: Tue, 30 July 2013, 18:44:42 »
How much smaller can you get? Link to said designs?
HHKB could be considered less than "60%" as it's missing some corner buttons.   ^-^
« Reply #3297 on: Tue, 30 July 2013, 18:49:55 »
Welcome to the world of 40% boards.
jdcarpe, he actually built his. I've seen prototypes.
Hypermicro from DT and 7bit.
kmiller8's 40% design thread
Offline dndlmx
« Reply #3298 on: Tue, 30 July 2013, 19:16:27 »
« Reply #3299 on: Tue, 30 July 2013, 19:24:54 »
No memes in this thread please.
