Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6213865 times)
Offline BlueBär
« Reply #3550 on: Thu, 08 August 2013, 11:02:04 »
Thanks for the advice guys, I will use PCB mounted switches then, can't hurt.
« Reply #3551 on: Thu, 08 August 2013, 11:03:41 »
WFD said in one of his videos to use PCB mounted with a plate whenever you can for increased rigidity.
IF the PCB has holes for the PCB mount pins...not all do.
Hence the "whenever you can" sir. More physical locking connections can't hurt.
I don't always completely read before I post, if I did I might not post as much. ;)
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #3552 on: Thu, 08 August 2013, 11:04:56 »
Dont worry ray, we wouldn't want you any other way :-*
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline Dubsgalore
« Reply #3553 on: Thu, 08 August 2013, 20:52:21 »
does anyone here know if the gh60 plates are going to be the magical type where you can remove the switch top without desoldering?
i've had a 'i think so but i'm not 100% sure' confirmation from the captain, but can anyone else give me the thumbs up?
Offline domoaligato
« Reply #3554 on: Thu, 08 August 2013, 20:55:47 »
Yes
Offline Narcix
« Reply #3555 on: Fri, 09 August 2013, 11:05:33 »
Can i use pictures made by users of this forum for a small guide im making on an italian forum?
Keycool 87 Grey PBT with mx blues
Offline Dubsgalore
« Reply #3556 on: Fri, 09 August 2013, 11:06:00 »
Yes
awesome :D
Offline BlueBär
« Reply #3557 on: Fri, 09 August 2013, 11:09:51 »
That depends on the user.
« Reply #3558 on: Fri, 09 August 2013, 11:11:19 »
Best thing to do is PM the user and ask.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #3559 on: Fri, 09 August 2013, 11:26:22 »
Before I post my incredible findings from driving down to pick up what I won on Ebay i have one question?  Is there an easy way to tell the difference between modern and vintage blacks?
« Reply #3560 on: Fri, 09 August 2013, 11:27:53 »
Hahaha. Yes, there is. The "CHERRY" logo on the top housing of the switches is visibly larger on "vintage" switches than on modern Cherry switches.
Offline Melvang
« Reply #3561 on: Fri, 09 August 2013, 11:28:28 »
Excellent thank you for the quick response JD
Edit I just looked at my find and the word Cherry doesn't seem to be any larger but there is a lot more detail in the emblem next to the word.  And they feel butter smooth considering the condition of the outside of the case.
« Last Edit: Fri, 09 August 2013, 11:32:08 by Melvang »
« Reply #3562 on: Fri, 09 August 2013, 12:09:37 »
You should ask the user. And then you should also credit the picture you use to the person who took the picture.
Offline Melvang
« Reply #3563 on: Fri, 09 August 2013, 12:10:29 »
Would a 1983 date on a pcb from a terminal board be old enough for a black switch to be considered "vintage"
Offline BlueBär
« Reply #3564 on: Fri, 09 August 2013, 12:14:27 »
Definately.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #3565 on: Fri, 09 August 2013, 12:14:35 »
I think you can check the switches to see if its vintage.
http://geekhack.org/index.php?topic=38921.0#quickreply
Offline esoomenona
  • Gnillort?
« Reply #3566 on: Fri, 09 August 2013, 12:20:41 »
Anything older than 2013 is. lrn2vintage.
Offline Melvang
« Reply #3567 on: Fri, 09 August 2013, 12:34:37 »
Well according to the pic the vintage housing the word cherry was the same size as the logo but the newer ones the word was smaller than the logo.  But apparently there was also a transition period.  Will try and get some macro shots of a stem and the housing and try and figure out this one.
« Reply #3568 on: Fri, 09 August 2013, 12:39:12 »
Isn't "Vintage" just a term the community came up with? There's a set date that we all said "this is vintage?"
Offline BlueBär
« Reply #3569 on: Fri, 09 August 2013, 12:42:37 »
They changed the Logo around 1991 and around that time (a bit later) they changed the plastic or the mold for the sliders as well, which results in a more scratchy feel.
If it is from 1983 you can be 100% sure that these switches are vintage and as you said they feel butter smooth.
« Reply #3570 on: Fri, 09 August 2013, 12:45:55 »
Sure they're not just butter smooth from years of wear and usage? All the usage rubbing away the stems' friction points.
Offline BlueBär
« Reply #3571 on: Fri, 09 August 2013, 12:55:20 »
I thought the same first, but according to Ivan NIBs feel that smooth as well.
« Reply #3572 on: Fri, 09 August 2013, 12:56:52 »
Link to that please?
Offline esoomenona
  • Gnillort?
« Reply #3573 on: Fri, 09 August 2013, 12:59:11 »
#VINTAGEPLACEBO
Offline BlueBär
« Reply #3574 on: Fri, 09 August 2013, 13:00:25 »
I have had few NIB MX boards with earlier production years black and blue switch, and they still feel different in a better way. Also don't forget the discontinued switch like linear white which are super amazing.
Those are probably 2 of the most overpriced G80 on the internet.
He has said that multiple times but this the first post that I could find.
#VINTAGEPLACEBO
Cmon moose, remember what happened to your last troll attempt?
Offline esoomenona
  • Gnillort?
« Reply #3575 on: Fri, 09 August 2013, 13:03:01 »
I'm not quite sure I follow.
Offline Melvang
« Reply #3576 on: Fri, 09 August 2013, 13:05:42 »
Thanks for the knowledge bomb there BlueBar.
Offline esoomenona
  • Gnillort?
« Reply #3577 on: Fri, 09 August 2013, 13:09:48 »
Did you guys ever stop to think that maybe the people who say "vintage" switches are "thebestthebestthebest" are messing with you? Sounds similar to something someone was doing with MY switches. Bunch of jokesters.
Offline BlueBär
« Reply #3578 on: Fri, 09 August 2013, 13:11:00 »
I have some. They are smoother. I can send you a few if you pay postage.
Offline Melvang
« Reply #3579 on: Fri, 09 August 2013, 13:11:20 »
I didn't because this board was the first time I have felt a black switch and I had no idea what the vintage of the switches was.  But in my opinion they are smoother than the reds in my orbweaver.
Edit:  Can anyone confirm either way on if Model M, F, or SSK spacebars are PBT?
« Last Edit: Fri, 09 August 2013, 14:18:15 by Melvang »
« Reply #3580 on: Fri, 09 August 2013, 14:27:02 »
I'm 90% sure all IBM boards have PBT caps. That should include the spacebar.
Offline Melvang
« Reply #3581 on: Fri, 09 August 2013, 14:38:37 »
Thanks CPT.  Any idea how well PBT takes to dye, either RIT or vinyl?  Also on that topic how well do home dyed caps stand up to the test of time and use?
« Reply #3582 on: Fri, 09 August 2013, 14:41:17 »
1) Any idea how well PBT takes to dye, either RIT or vinyl?
2) Also on that topic how well do home dyed caps stand up to the test of time and use?
1) meeba does RIT dye-ing on his meebcaps. They look amazing.
2) meebcaps seem like they have a good quality. I saw Smallfry's Aircraft Carrier M with red dyed caps which looked good too.
Offline remedyhalopc
« Reply #3583 on: Fri, 09 August 2013, 20:01:20 »
Does anyone know if GMK produces the colored doubleshots that EK is selling on their sites or are they closer to SP double shots?
« Reply #3584 on: Fri, 09 August 2013, 20:02:09 »
GMK..
Offline Thimplum
  • Master of all Ponies
« Reply #3585 on: Fri, 09 August 2013, 20:06:45 »
GMK..
TP4 FOR ADMIN 2013
« Reply #3586 on: Fri, 09 August 2013, 20:07:23 »
Thanks. On my phone in spotty reception so I couldn't look it up.
« Reply #3587 on: Fri, 09 August 2013, 20:07:40 »
GMK..
« Reply #3588 on: Fri, 09 August 2013, 20:07:56 »
GMK..
He was answering the question.
Offline Melvang
« Reply #3589 on: Fri, 09 August 2013, 20:08:19 »
When posting a question in this thread I often com up with another question before the question gets answered.  In this case is it better to make a new post or modify the existing post?
« Reply #3590 on: Fri, 09 August 2013, 20:09:28 »
CPT always encourages modifying.. but I always think people who've already seen my question will miss the one I added, so I usually make another post.
« Reply #3591 on: Fri, 09 August 2013, 20:10:00 »
I normally edit.
« Reply #3592 on: Fri, 09 August 2013, 20:23:09 »
What type of ALPS does this apple design KB use? It's sort-of an offwhite.
« Reply #3593 on: Fri, 09 August 2013, 20:42:34 »
Dorkvader, post pictures please. I believe it's Cream Alps
I encourage edits like people have said.
« Reply #3594 on: Fri, 09 August 2013, 21:13:32 »
GMK..
I think he's confused by the extra ".."
Offline Melvang
« Reply #3595 on: Sat, 10 August 2013, 16:25:21 »
Anyone here ever ate at a place called Zombie Burger?
« Reply #3596 on: Sat, 10 August 2013, 16:32:16 »
No but please keep this keyboard related :3
Offline Dubsgalore
« Reply #3597 on: Sat, 10 August 2013, 18:42:24 »
question for ducky fans:
my little brother has a ducky 9087g2, and i want to add some green LEDs from my pure. my pure is being disassembled for parts tomorrow, so i thought he could add some LEDs to his ducky, but does that pcb support LEDs beyond the locks and the wasd switches?
thanks doods
Offline Melvang
« Reply #3598 on: Sat, 10 August 2013, 23:21:25 »
1) Any suggestions for cleaning the plate on a terminal board that spent is full of dust dirt and God knows what else?
2) What is the prefered method for cleaning really dirty non yellowed caps?
3) Is there any way to tell ABS from PBT without destroying the cap?
« Reply #3599 on: Sat, 10 August 2013, 23:23:47 »
1) Rubbing or isopropyl alcohol, as pure as you can get it.
2) Get some denture cleaning tabs. Put the caps in warm water, put the tabs in, and then wait 20 minutes. Take them out and then dry them.
3) Feel of the cap?
