Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 5740045 times)
0 Members and 10 Guests are viewing this topic.
« Reply #3750 on: Wed, 21 August 2013, 11:27:04 »
Inches!
'murica
Actually, those measurements are in inches because Litster's Phantom plate drawings were scaled in inches. Almost every plate drawing I make is scaled in mm, to the chagrin of local metals shops. Now you know. :)
Offline BlueBär
« Reply #3751 on: Wed, 21 August 2013, 18:13:11 »
Do all Tipro keyboards use Cherry switches? They sometimes have some weird stepped keys which make me wonder.
« Reply #3752 on: Wed, 21 August 2013, 18:22:50 »
Hmm. Maybe someone would know: I know there's a regular milk blue CC and a metallic milk blue CC, I've only seen the metallic in mx but am unsure about the regular. Was regular milk blue Topre only, or does that also exist in mx? I'm pretty positive regular comes in Topre and mx, but metallic is mx only. Also: gum colors(pink/purple) were Topre only runs?
« Reply #3753 on: Wed, 21 August 2013, 18:24:52 »
Think so. The caps are very odd on Tipros.
1) Was regular milk blue Topre only, or does that also exist in mx? I'm pretty positive regular comes in Topre and mx, but metallic is mx only.
2)gum colors(pink/purple) were Topre only runs?
1) I think you're right there.
2) No I dont think so. Pretty sure I saw some MX when I was at Keycon.
Offline esoomenona
  • Gnillort?
« Reply #3754 on: Wed, 21 August 2013, 18:28:17 »
What does TW mean?
« Reply #3755 on: Wed, 21 August 2013, 18:28:50 »
It means you're really new Moose. Now hush child.
Offline Photoelectric
« Reply #3756 on: Wed, 21 August 2013, 18:36:11 »
What does TW mean?
It's an abbreviation for Two Words.  Their meaning is obscure and changes once an hour.
« Reply #3757 on: Wed, 21 August 2013, 18:37:19 »
What does TW mean?
It means I know what something is worth, but want more.
« Reply #3758 on: Wed, 21 August 2013, 18:49:36 »
« Reply #3759 on: Wed, 21 August 2013, 19:05:22 »
« Reply #3760 on: Wed, 21 August 2013, 20:46:32 »
If I got my hands on a Filco TKL plate. Can I make cutouts in the corners like the custom plates so that I can open switch tops? That's how the custom plates work right? There's just extra circular cutouts in the corners of the switch holes?
« Reply #3761 on: Wed, 21 August 2013, 20:47:54 »
Are you trolling your own thread?
« Reply #3762 on: Wed, 21 August 2013, 20:57:31 »
What? No? This is a serious question wtf...
« Reply #3763 on: Wed, 21 August 2013, 21:06:40 »
With all the other crazy stuff in thought maybe it was like a parody.
There were measurements posted above for the switch openings, wouldn't that be what your looking for?
The circular part through me. All I've seen are small rectangular cutouts.
« Reply #3764 on: Wed, 21 August 2013, 21:18:05 »
I wasn't sure because I thought those were just the standard switch holes. I'm not sure though. Want someone to confirm one way or another.
« Reply #3765 on: Wed, 21 August 2013, 21:28:32 »
I've had four different phantom plates all with those notches.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #3766 on: Wed, 21 August 2013, 21:39:10 »
I don't see why it wouldn't work.  The extra cutouts just allow the 4 prongs on the top half of the switch cover to clear the plate.  My suggestions would be either small file or a dremel.  If the plate is aluminum be prepared to clean out the cutting tool often whoever method you choose.
Question for myself.  Does anyone know what the dimensions are for the stab locations on a 10u WYSE space bar?
« Reply #3767 on: Wed, 21 August 2013, 21:44:26 »
Universal TKL plate has wider rectangular switch openings--not really cut outs.
Although I imagine if you sand off protrusions for switch tabs, you would be able to open your switches.  But it'd be a lot of work, 4x "dips" per switch opening.
« Reply #3768 on: Wed, 21 August 2013, 21:55:22 »
Yeah WFD redesigned his plates here is an R1 potato
« Reply #3769 on: Wed, 21 August 2013, 22:04:08 »
Cool. I'm going to buy a cheapo Dremel and see how it goes then.
Offline domoaligato
« Reply #3770 on: Wed, 21 August 2013, 22:04:32 »
in a attempt to answer the question please correct me if I am wrong.
normal cherry switch holes are only square.
look at the corners of the squares above. they have a special pattern in each corner of every cutout.
this is what allows the switches topcover teeth to pass over the bottom housing while still attached to the plate.
If you buy any of the universal tkl plates from WFD/the_beast or have jdcarpe design one.... they all use this cutout pattern.
the one that photoelectric posted about has the cutout for the QFR/Filco controller and will also work with the phantoms.
it is from WFD's latest GB.
WFD has already posted somewhere else in this thread stating the locations that would need to be cutout of previous versions of the TKL plates to make them as "universal" as this one.
edit2: photoelectric's pic is R2. and spamrays is R1. I was right the first time. sorry.
« Last Edit: Wed, 21 August 2013, 22:19:24 by domoaligato »
Offline domoaligato
« Reply #3771 on: Wed, 21 August 2013, 22:05:53 »
This should work fine. just test every switch cutout with a spare switch as you go.
Offline domoaligato
« Reply #3772 on: Wed, 21 August 2013, 22:29:30 »
I have a question....
what nikkor AF-S lens are some of you using to take photos of keycaps?
I have a nikon D80 but need a macro lens to capture the detail of my caps..
Offline Melvang
« Reply #3773 on: Thu, 22 August 2013, 04:15:08 »
I see guys are connecting the two halves for an ergo dox via TRRS connectors.  Are they just using that plug as an alternative to a USB connector?  Also since there wouldn't be enough terminals on the connector for this to be for the matrix I would assume that it is just so the two Teensy controllers to communicate.  Would it be possible to go this route to connect just the right side of an ergo dox to a modified TKL layout board that also has the "F" keys removed with a Teensy 2.0 in the TKL or is there not enough pins for that?
« Reply #3774 on: Thu, 22 August 2013, 07:26:24 »
I discuss that here: http://geekhack.org/index.php?topic=41464.msg844651#msg844651 :)
The ErgoDox left half doesn't have a Teensy, the TRRS connector connects the two halves using an expander IC.
Offline Melvang
« Reply #3775 on: Thu, 22 August 2013, 07:59:29 »
Excellent info thanx JD.  I would assume then that the expander IC just wires into the Teensy that is in the right half then?  If it does would there be enough pins left after a TKL minus F row to plug just the left half into a Teensy 2.0?
Offline vivalarevolución
« Reply #3776 on: Thu, 22 August 2013, 10:34:41 »
Thought about starting a new thread, but I will post here.
Just looking for some opinions of spring weights for Ergo clears.  I have heard and experienced spring weighs that are so light they cause the slider to return very slowly or catch below the bump. If you know what I mean.  I want some lighter springs in my clear switches and I would to get others opinions on the stickiness of spring weights.
Offline esoomenona
  • Gnillort?
« Reply #3777 on: Thu, 22 August 2013, 10:37:33 »
I heard tell that the stickiness might have been caused by the lubrication being used as opposed to the light weight springs.
« Reply #3778 on: Thu, 22 August 2013, 10:39:08 »
I wrote about this in my review Prdlm2009 but I believe that anything under MX Black springs for ergo-clears has a bit of a sticky issue. Especially with the really light springs. i3oilermaker's QFR at Chicagoland/Gurnee was horribly sticky. Think those had 55g springs.
« Reply #3779 on: Thu, 22 August 2013, 10:41:52 »
The king of springs is here.
Yes, lube is known to cause stickiness if you're using a poor mixture (notably, too much grease)
For me personally, I think 60g (red/blue/brown spring) ergo clears is fine but requires lube. But with this set up it loses a bit of its tactility, and is instead a smooth bump. Unlubed, it's definitely noticeably sticky.
55g is a bit harder to do, but I know some people have it where it doesn't stick as much. Anything lighter I don't think would be good at all. Definitely requires proper application of lube.
62g silver is alright, it gets a little bit more crisp. Seems to be the most popular choice, that little added weight helps with the stickiness but doesn't change much from the good old ergo clear.
65g I hear is a bit too heavy for some people's taste, although completely relieves the switch of the sticky feeling. This and Panda Clears seems to be a good choice for people who like heavier switches but dislike stock clears.
62g gold, I always say, is absolutely perfect. I've described it as the "63.5g" spring, where it's just in between 62g silver and 65g. Lubed or unlubed, no stick at all, and good on the fingers.
Offline WhiteFireDragon
    • youtube
« Reply #3780 on: Thu, 22 August 2013, 10:46:24 »
Who designed the Round 1 Al plate for the Phantom?
I'm sure there was some combined effort but I know I've seen Litster's name mentioned.
Yes, it was Litster.
I just wanted to give credit where credit is due: it was bpiphany that designed the original phantom 1x switch holes, and the modifier cutouts were directly from cherry's design on their website. BiNiaRiS was the one that sourced a manufacturer to get them made, and litster tested the prototype made from bpiphany's design. All 3 of them had contributions of the original phantom plate.
« Reply #3781 on: Thu, 22 August 2013, 10:49:07 »
WFD thanks for clearing that up.
Hope your enjoying your vacation!!
    • youtube
« Reply #3782 on: Thu, 22 August 2013, 10:52:26 »
I'm going to save you the trouble and time by saying don't bother trying.
All stock mass-produced plates are steel, not softer aluminum. Have you tried to dremel out steel before? Each switch hole requires you to dremel out 4 slots, so that's 348 slots you'll have to shave out.
« Reply #3783 on: Thu, 22 August 2013, 10:52:48 »
Thanks WFD ^__^
« Reply #3784 on: Thu, 22 August 2013, 11:07:50 »
Lol, introduces himself as the king of springs.  Thanks guys.
Basically, I'm looking for as light as possible without consistent stickiness issues.
« Reply #3785 on: Thu, 22 August 2013, 11:08:27 »
62g silver
« Reply #3786 on: Thu, 22 August 2013, 11:14:53 »
62g silver
Thanks.  I might buy a couple different weights between 60g and 65g and play around with them.  I tried those 55g springs and definitely felt some issues.
Offline ouimeansyes
« Reply #3787 on: Thu, 22 August 2013, 14:29:29 »
Hi all,
I have been lurking on Geekhack for some time and have my heart set on a HHKB Pro 2. I have a quick question regarding it. Is it possible to type the € or £ symbols on a HHKB Pro 2? I need those symbols somewhat regularly and it would be nice to be able to use them relatively quickly. I believe you would be unable to produce those symbols using Alt+0128 and Alt+0163 respectively as they require either a numpad or a Fn equivalent. Do I understand correctly? Would it be a case of copying and pasting those symbols if I need to use them?
Perhaps I should spring for a Realforce 23U as well? Although that seems a touch extreme and more expense.
Thanks for your help.
ouimeansyes
« Reply #3788 on: Thu, 22 August 2013, 14:31:01 »
Hi all,
ouimeansyes
You can use a program called autohotkey to bind those keys to a key or key combination.
For example you could set it to tab+3.
Also, welcome to geekhack :)
Offline ouimeansyes
« Reply #3789 on: Thu, 22 August 2013, 14:47:29 »
Thanks for that. I never really thought about setting up some hotkeys. Certainly cheaper than a separate Realforce numpad.
« Reply #3790 on: Thu, 22 August 2013, 15:21:48 »
So, now that I decided that I want springs, where do I get them?  All I can find is Originative.
« Reply #3791 on: Thu, 22 August 2013, 15:22:53 »
It's really down to that and GBs. Also I also second 62g springs for Clears.
Hi all,
ouimeansyes
Welcome to GH!
« Reply #3792 on: Thu, 22 August 2013, 15:24:20 »
I'm still a bigger proponent of 65g and 67g springs, but to each their own.
Offline Xenderwind
« Reply #3793 on: Thu, 22 August 2013, 15:29:01 »
I'd just go ahead and buy both 65g and 62g springs then you can decide on your own.  I like both personally.  Not really sure which one I favor more.  I had 65g in until last night when I desoldered them all to lube with the krytox I got from mkawa and switched to 62g.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
« Reply #3794 on: Thu, 22 August 2013, 15:30:40 »
The 62g had just a little too much hang on the rebound for me.  The 65g gets rid of that and the 67g just feels good to me.  It's all personal preference though.
Offline findingthelimit
  • Rawr
« Reply #3795 on: Thu, 22 August 2013, 18:29:37 »
Does anyone know what profile the wasdkeyboard keycaps are? I'm looking at signature plastics' page for reference:
http://keycapsdirect.com/key-caps.php
I have parts of the raindrop set and lily set, and they are both lower profile than the wasdkeyboard's sets. this doesn't bother me too much, but i prefer the higher profile'd ones. I think the lily set is DCS, so does that mean the wasdkeyboard's caps are KT? they are the only "high profile" caps that aren't spherical.
thanks :]
Poker 2 reds, GH60 42g ergo clears
Offline esoomenona
  • Gnillort?
« Reply #3796 on: Thu, 22 August 2013, 18:30:44 »
OEM profile. They're taller than SPs DCS profile.
Offline ComradeSniper
  • HHKB Pro
« Reply #3797 on: Thu, 22 August 2013, 20:54:23 »
I agree, 62g felt just a bit sticky.
On a different topic, how do you guys usually ship a full size keyboard? so far I've been using the long rectangle ReadyPost boxes that you can get at the USPS store but I want to see if there's a more efficient way.
« Reply #3798 on: Thu, 22 August 2013, 21:00:21 »
USPS Game Board Box. I've had boards shipped to me in made up boxes (I.E they cut their box up and fit it around the keyboard), or huge boxes but that USPS box worked the best for me.
  • HHKB Pro
« Reply #3799 on: Thu, 22 August 2013, 21:01:23 »
Haven't tried that one, thanks.
