Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 5739346 times)
0 Members and 17 Guests are viewing this topic.
Offline Game Theory
... he's just a poor kid from the stupid ages.
Realforce 104UG | Realforce 91U | IBM SSK | IBM 5251 BeamSpring | IBM Model F XT |  IBM Model F AT | IBM SSK | Filco Majestouch 2 TKL (MX Blue) | KMAC LE (MX Green)| Northgate Omni Key 101 | Avant Stellar Prime
Offline ComradeSniper
  • HHKB Pro
Offline elton5354
« Reply #3802 on: Thu, 22 August 2013, 21:25:39 »
What kind of caps are on the Dell's AT101W?  Doesn't seem like pad printed as I can't feel the stickers on them.
« Reply #3803 on: Thu, 22 August 2013, 21:28:38 »
Pad-printed, or they should be.  Edit:  Actually, supposedly lasered according to the DT wiki.
« Last Edit: Thu, 22 August 2013, 21:35:10 by nubbinator »
« Reply #3804 on: Thu, 22 August 2013, 21:33:28 »
I believe it's dye-sub
Offline phx
« Reply #3805 on: Fri, 23 August 2013, 07:51:44 »
do all QFR w/ red switches have red plates? even the stealth versions?
does QFR work on a mac without installing additional software?
« Reply #3806 on: Fri, 23 August 2013, 07:57:29 »
If I got my hands on a Filco TKL plate. Can I make cutouts in the corners like the custom plates so that I can open switch tops? That's how the custom plates work right? There's just extra circular cutouts in the corners of the switch holes?
Cool. I'm going to buy a cheapo Dremel and see how it goes then.
I'm going to save you the trouble and time by saying don't bother trying.
All stock mass-produced plates are steel, not softer aluminum. Have you tried to dremel out steel before? Each switch hole requires you to dremel out 4 slots, so that's 348 slots you'll have to shave out.
Then cut me a plate man! :P Seriously though, I haven't dremeled steel.
1) do all QFR w/ red switches have red plates? even the stealth versions?
2) does QFR work on a mac without installing additional software?
1) Think it's just the Stealth and the newer unbranded QFRs that have the plate color match the switch. I have an older branded QFR which has just a black plate.
2) I think so but the command key will probably not work. You'll have to use the Mac equivalent of AutoHotKey.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #3807 on: Fri, 23 August 2013, 08:00:07 »
Steel cuts just fine with a dremel.  just get the reinforced cut off wheels.  Make sure they are not the heavy duty.  They just get used up very quick.
Offline phx
« Reply #3808 on: Fri, 23 August 2013, 08:00:58 »
yeah I dont need the command/apple keys to work, just the letters and stuff.
was thinking of giving a QFR to a not so techy mac user, so if it's plug and play compatible with mac it would be great
« Reply #3809 on: Fri, 23 August 2013, 08:16:51 »
You need some type of plate, bro? Y U NO ASK?!
« Reply #3810 on: Fri, 23 August 2013, 08:19:53 »
Hm? I just wanted one as a lube station so I can lube Black switches. Not like to use in a keyboard or anything.
Yeah it'll work if you don't care about the command and apple key stuff.
« Reply #3811 on: Fri, 23 August 2013, 08:24:32 »
Let's just get some 'real' lube stations!!
Offline yasuo
  • spanengan puyeng newbie
« Reply #3812 on: Fri, 23 August 2013, 08:34:27 »
What name key particulary(TAB,SHIFT,CTRL,ALT,CAPS) which are the most widely used and sequence?
1.
2.
3.
4.
Thanks All ;D
Logitech MK220 Colemak DH
« Reply #3813 on: Fri, 23 August 2013, 08:36:18 »
1.
2.
3.
4.
Thanks All ;D
Depends on the person and what they do with their computer/keyboards? Not a very simple question since it will vary per person.
« Reply #3814 on: Fri, 23 August 2013, 08:44:10 »
Like this?
« Reply #3815 on: Fri, 23 August 2013, 08:45:54 »
Like this?
now your just showing off......
BUT.....if something like that were to 'accidentally' find it's way in the box with my phantom I won't tell anybody ;)
Offline yasuo
« Reply #3816 on: Fri, 23 August 2013, 09:34:34 »
1.
2.
3.
4.
Thanks All ;D
Yes also true :D
I just know
CTRL usually often for Programmer
SHIFT usually often for Typist
but This,i don't know
ALT?
TAB?
« Reply #3817 on: Fri, 23 August 2013, 09:37:23 »
Yes also true :D
I just know
ALT?
TAB?
Again, it depends on the person and what programs they use...if you're using Excel a lot maybe you Tab a lot versus someone who just plays video games.
Offline yasuo
« Reply #3818 on: Fri, 23 August 2013, 10:05:12 »
Thanks, I already understand right now :D :thumb:
I just found out, if TAB usually be used excel :rolleyes:
how to ALT usually for?
Thanks Again
« Reply #3819 on: Fri, 23 August 2013, 10:09:12 »
I just use mine for media macro keys if the keyboard has it and other hotkey. Oh and alt-tabbing through windows.
Offline yicaoyimu
« Reply #3820 on: Fri, 23 August 2013, 10:13:34 »
GH keyboard experts, where can I get MX white switches? If none is available on the market, is it possible to order a box of white switches directly from Cherry? Thanks in advance!
« Reply #3821 on: Fri, 23 August 2013, 10:14:39 »
1) Where can I get MX white switches?
2) If none is available on the market, is it possible to order a box of white switches directly from Cherry?
1) Only sources are GBs like 7bit or harvesting from a board with MX whites
2) No. They have a very very very high MOQ.
Offline yicaoyimu
« Reply #3822 on: Fri, 23 August 2013, 10:18:30 »
That's too bad. :'(
I should have bought a KBT with white switches from mechanicalkeyboards.com several days ago. They are all gone now. White switches are the cure to my keyboard fever...
Thanks anyway.
« Reply #3823 on: Fri, 23 August 2013, 10:28:00 »
Doubtful. There is no known cure for keyboard fever. The closest thing to a remedy is to cancel your internet, move to a small tropical island, buy a bicycle and ride it all day, or similar.
Once you use MX switches more, you will probably find that you can use any of them interchangeably, with maybe some preference, but probably very little disdain for certain of the different types.
Offline yicaoyimu
« Reply #3824 on: Fri, 23 August 2013, 11:12:15 »
Of course, the white switch alone is not the cure. I want a sexy looking metal tenkeyless keyboard with full LED support to end my keyboard fever. White switch is my choice for switch because I want the feel of blue switch and the clean white color.
Offline yasuo
« Reply #3825 on: Sat, 24 August 2013, 03:13:04 »
« Reply #3826 on: Sat, 24 August 2013, 03:40:22 »
Yes QFR works fine on a Mac - I used one for a long time with no worries.
You can use System Preferences to swap Alt and Win around - works like Mac.
Also the function keys do Expose and media functions too :)
« Reply #3827 on: Sat, 24 August 2013, 08:02:17 »
I want this link but broken,what any new link?
http://geekhack.org/showwiki.php?title=Design+your+own+Teensy+keyboard+in+KiCAD+how-to+guide
Ok I think you're looking for this link here.
Can you please try searching for it yourself next time? I know it's a little daunting to find all this information but I literally don't know what you want since I can't read your mind. And I literally just typed the title in the URL into Google. I don't want to discourage questions but I'm also not here to Google search.
« Last Edit: Sat, 24 August 2013, 08:09:32 by CPTBadAss »
Offline yasuo
« Reply #3828 on: Sat, 24 August 2013, 08:25:05 »
Thanks CPT,
I'm just disappointed and found that a lot of broken links GH (not can opened) especially old thread
« Reply #3829 on: Sat, 24 August 2013, 08:25:53 »
The archived links are all broken due to rootworm wiping them out.
Offline yicaoyimu
« Reply #3830 on: Sat, 24 August 2013, 12:10:27 »
GH experts, another noob question. What would be the most common and appropiate shipping method if I wanna ship a keyboard within US? I was trying to sell my keyboard and this is my first time I ever do this. Thanks!
« Reply #3831 on: Sat, 24 August 2013, 12:12:41 »
This whole thread is to help out. No need to be ashamed with noob questions ^__^
If you're within the USA, I recommend USPS Flat Rate Game Board boxes. Cost to ship it is $16.85. Your USPS branch should have it but if it doesn't you can order packs on the USPS website and they'll deliver to you.
Offline Dubsgalore
« Reply #3832 on: Sat, 24 August 2013, 14:34:24 »
Like this?
x_____x gimmie gimmie
« Reply #3833 on: Sat, 24 August 2013, 15:03:04 »
I prefer to ship via a "normal" box by priority mail in the US. I find it saves some money over the game board flat rate box (for most weights), and I get boxes and cardboard from work. Oftentimes, I'll custom make up a box if I dont' have one the right size.
Last time I mailed something, priority was $0.03 more expensive than first class and included more features.
« Reply #3834 on: Sat, 24 August 2013, 23:44:59 »
Just did a major overhaul of the OP. Now it has anchors and a table of contents with the FAQ section. I think this will be way easier to navigate. Hopefully this makes the OP less daunting to read through and refer to. If you guys could let me know what you think, that would be great. Thanks!
Offline The_Beast
  • I like wood ಠ_๏
« Reply #3835 on: Sat, 24 August 2013, 23:48:33 »
Holy ****, that looks really nice!
« Reply #3836 on: Sat, 24 August 2013, 23:54:58 »
whoah... you just slightly got a bit older.
« Reply #3837 on: Sun, 25 August 2013, 00:42:33 »
Looks fantastic!
Q: Can CPTBadAss make this thread any more awesome?
Offline Melvang
« Reply #3838 on: Sun, 25 August 2013, 04:33:46 »
What are the pros and coins of hard wired matrix vs PCB for custom layouts with the exception of the price of a one off PCB?
« Reply #3839 on: Sun, 25 August 2013, 06:54:19 »
Not that it's a big deal but trying to use the links in tapatalk it wants to open in a web browser instead of jumping to the info.
Thanks for all the effort in keeping this thread going!
« Reply #3840 on: Sun, 25 August 2013, 08:54:01 »
Pros (of a hardwire matrix): Custom layout, more flexibility with the case and controller sizing/spacing, more customization in terms of LEDs and custom layouts, cheaper in terms of money, no need to learn KiCad
Cons: Much much much more work to layout and solder, hard to rework/tinker with later, probably requires a custom case unless you design for a currently available case, expensive in terms of time
I'm not how sure anchors are handled in Tapatalk but unfortunately, that's out of my control. I don't think I can change the back end to fix that issue. If it's a big enough issue, I can talk to rkinze.
Offline Melvang
« Reply #3841 on: Sun, 25 August 2013, 15:10:12 »
Awesome thanks for the info CPT.  And the OP looks great.
Offline thebeargentile
« Reply #3842 on: Sun, 25 August 2013, 16:05:03 »
I'm looking to edit the function layer on my KMAC Happy, but all the KMAC keybinding programs I have found only have templates for the regular KMAC and the Mini, not the Happy.  Can I just change, say, the KMAC Mini template to match the row/column layout of the Happy, or do I need to find the exact Happy template file?  Do all these boards use the same controller?
Offline Melvang
« Reply #3843 on: Sun, 25 August 2013, 18:38:30 »
Wish I could help you out there but I'm not sure on that one.
Offline meiosis
  • Time
« Reply #3844 on: Sun, 25 August 2013, 21:27:52 »
I think you should message GON about that, I believe it is somewhere on kbdmania but I don't have access to it.
Keyboards:
Aripeko TKL
Offline yasuo
« Reply #3845 on: Mon, 26 August 2013, 04:33:54 »
What is good or suitable cable to connect the two halves (left/right) for DIY Split keyboard keyboard handwired?
Thanks
« Last Edit: Mon, 26 August 2013, 05:44:43 by yasuo »
Offline BlueBär
« Reply #3846 on: Mon, 26 August 2013, 05:30:26 »
What is good or suitable cable to connect the two halves (left/right) DIY Split keyboard keyboard handwired?
Thanks
That depends on your design. If you need for example 3 wires to connect the halves you could use a normal 3,5mm stereo connector. The ErgoDox uses the extended 3,5mm plug with the 4-pole connector for example. If you need more poles, you could use a Cat 5 cable.
Offline yasuo
« Reply #3847 on: Mon, 26 August 2013, 06:06:00 »
Thanks, I want the detachable cable,
what name connector/ Extensions for cat 5?
or any other cable?
Offline BlueBär
« Reply #3848 on: Mon, 26 August 2013, 06:32:01 »
or any other cable?
As I said, it depends on how you do the matrix etc. how many poles you need. Do you have a plan how to wire the keyboard yet? If so, can you post it?
Cat 5 is the name of the connector, here you can get some female connectors, Cat 5 cables you can get in pretty much every electronics store.
Offline yasuo
« Reply #3849 on: Mon, 26 August 2013, 07:13:34 »
it seems 12 cable (6 right/6 left hand)
how to teensy,whether I need two?
