Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6201436 times)
« Reply #4050 on: Tue, 10 September 2013, 12:16:30 »
Yeah I know the site but I meant if there was a place IN europe where I can buy them, because I have to pay imports and I have to go to the customs and waste a lot of time until I take my keyboard out of bond.
I would have no idea about storefronts in Europe unfortunately. Hopefully some of our EU buddies can chime in.
Offline BlueBär
« Reply #4051 on: Tue, 10 September 2013, 12:17:51 »
I don't think there's a place in Europe where they sell Ducky or Keycool. Only european sellers I know are keyboardco, qwerkeys and kbtrace.com.
« Reply #4052 on: Tue, 10 September 2013, 12:23:07 »
the stl files on ergodox.org are created in inches or cm?
It's not a drawing so it shouldn't matter. Just change the units in your CAD program to whatever you're familiar with.
Offline Tarzan
  • formerly known as Greystoke
« Reply #4053 on: Tue, 10 September 2013, 12:25:20 »
Perhaps more Scandinavia than Europe, but Teraset.net (Finland) carries Ducky.
https://www.teraset.net/ducky.php
« Reply #4054 on: Tue, 10 September 2013, 12:32:33 »
My reading comprehension is apparently at an all time low :(
Offline LoNeWolF
« Reply #4055 on: Tue, 10 September 2013, 12:37:31 »
Thanks for the help guys, I appreciate all the responses. I found this:
http://geekhack.org/index.php?topic=42808.0
Seems like ducky-nordic.com is still under construction tho. I'll try to PM the guy. Thx again. :thumb:
Offline jonathanyu
« Reply #4056 on: Tue, 10 September 2013, 22:45:33 »
Where can I buy a wire for cherry stabilizer online?
Mouser, see the OP.
yeah I know, but i mean just the wire, not the whole stabilizer.  I can't find any hobby shop near my location have the right thickness.  So I want to try it online.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #4057 on: Wed, 11 September 2013, 02:02:00 »
Mouser, see the OP.
you could try music wire.  That stuff is stupid strong but difficult to bend.
« Reply #4058 on: Wed, 11 September 2013, 08:45:03 »
Hobby stores should carry it. I think HobbyLobby and Menards carry it; at least from what I heard. Can't hurt to check the usual Home Depot/Lowes/Hardware store closest to you.
Can also try this.
Offline yasuo
  • spanengan puyeng newbie
« Reply #4059 on: Wed, 11 September 2013, 11:07:15 »
i ask again :)
what keyboard other layout like QF TK?
Logitech MK220 Colemak DH
« Reply #4060 on: Wed, 11 September 2013, 11:16:00 »
i ask again :)
PLUM 96
« Reply #4061 on: Wed, 11 September 2013, 11:21:33 »
i ask again :)
PLUM 96
That board is the only one I still kind of wish I could get just to see if the wireless is worth it.
You can also do something similar with a phantom.
35025-0
« Reply #4062 on: Wed, 11 September 2013, 11:23:52 »
i ask again :)
PLUM 96
The plate on that Phantom doesn't look black...
« Reply #4063 on: Wed, 11 September 2013, 11:30:53 »
i ask again :)
PLUM 96
Evil office lighting + crappy phone camera.....
I just tried again to get a better pic didn't help.
« Reply #4064 on: Wed, 11 September 2013, 11:35:02 »
i ask again :)
PLUM 96
Ah, I thought you were cheating on me. ;D
It looks good! :thumb:
Offline Dreamre
    • kbdlife
« Reply #4065 on: Wed, 11 September 2013, 11:39:37 »
Has the stabilizers on the Ducky Shine 3 changed?
Offline jonathanyu
« Reply #4066 on: Wed, 11 September 2013, 19:54:36 »
Can also try this.
i have checked the home depot, those are too thick, maybe I will check the HobbyLobby
Found!
found it on the darehobby
« Last Edit: Wed, 11 September 2013, 19:59:43 by jonathanyu »
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #4067 on: Wed, 11 September 2013, 21:02:13 »
Does anyone have dimensions of The_Beast's poker plate? And the distance between the plate and pcb? I don't have a ruler and I couldn't find the answer through search.
Thanks to anyone who can help.
« Reply #4068 on: Wed, 11 September 2013, 21:04:29 »
Distance between top of the plate and top of the PCB -5mm
It'll be roughly between 285x95 and 300x100. Most likely closer to 285x95.
« Last Edit: Wed, 11 September 2013, 21:10:40 by Photekq »
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #4069 on: Wed, 11 September 2013, 21:08:04 »
It'll be roughly between 285x95 and 300x100. Most likely closer to 285.95.
Thanks dude. The second measurements are in mm right?
« Reply #4070 on: Wed, 11 September 2013, 21:09:01 »
Yes. 300 inches would be around 25 ft. Pretty sure that's not the size of a PCB.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #4071 on: Wed, 11 September 2013, 21:12:20 »
At first I thought it was in pixels.. then I realized that's ridiculous. Just making sure
« Reply #4072 on: Wed, 11 September 2013, 21:14:10 »
Yes it's mm :))
Offline missalaire
  • Great Finder of Great Finds
« Reply #4073 on: Wed, 11 September 2013, 21:16:31 »
WTS common sense
Offline whiskytango
  • Don't touch the trim
« Reply #4074 on: Thu, 12 September 2013, 00:46:20 »
Alright, time to bust out a what I fear might be a noob question: Will a G80-1800 PCB fit inside a G81-1800 case?
And a related question: If it does fit, does anyone know if the leeku PCB from the current group buy thread will also fit a G81-1800 case?
« Reply #4075 on: Thu, 12 September 2013, 06:17:40 »
1) Will a G80-1800 PCB fit inside a G81-1800 case?
2) And a related question: If it does fit, does anyone know if the leeku PCB from the current group buy thread will also fit a G81-1800 case?
1) At a glance? It looks like it should. But I'm just guessing. I'm not 100% sure
2) I know the PCB will to a G80-1800 case. I'm not sure if there are subtle differences between the G81-1800 and G80-1800 cases.
Hopefully inlikeflynn sees this. If not, I can PM him and ask.
« Reply #4076 on: Thu, 12 September 2013, 06:27:37 »
My G80-1819HEU pcb is in a G81-1800HQAUS case.
« Reply #4077 on: Thu, 12 September 2013, 06:30:43 »
Yeah I think the G80-1800 and G81-1800 cases are probably made from the same molds. Quite a few people find a nice, but well used G80, and swap it into a new G81 case.
Offline whiskytango
« Reply #4078 on: Thu, 12 September 2013, 06:56:38 »
Thanks! I didn't want to bother Flynn as I have pestered him enough lately with questions.
I have a G81-1800LAAUS that I will try to use as a case for the leeku pcb then.
Offline Grobalo
« Reply #4079 on: Thu, 12 September 2013, 11:57:33 »
Quick question about switches.
For a given cherry-MX color, are there different switches qualities? I mean, are some red switches better than other for example?
Thanks
« Reply #4080 on: Thu, 12 September 2013, 12:08:55 »
Yes, there may be differences between switches depending on the batch. They'll also feel different depending on the board and how its mounted (PCB vs Plate). For modern switches, it's a bit of a gamble. The quality control issues seem to mainly be with the clicky (Blue, Green, and White MX switches). For vintage or older switches, the QC seems to be better. Some people claim certain vintage switches feel different. YMMV.
Offline jonathanyu
« Reply #4081 on: Fri, 13 September 2013, 00:27:22 »
where can I get  LED stand-offs for filco-style LEDs?
« Reply #4082 on: Fri, 13 September 2013, 06:40:54 »
I never realized they had a standoff but i found a picture from Photoelectric. I bet you could just order some plastic bushings and cut it down to size from McMasterCarr or a hardware store. I don't know the diameter though. And I wonder if you actually need them or if you could just put a bit of insulation, like plastic, between the LED and plate.
« Reply #4083 on: Fri, 13 September 2013, 08:26:52 »
They are 5mm in diameter x 8mm in height. You can get 400 of them for $6.83 shipped, from Amazon.
Edit: I just ordered some, and I think they ship from China.
« Last Edit: Fri, 13 September 2013, 08:29:45 by jdcarpe »
« Reply #4084 on: Fri, 13 September 2013, 08:27:38 »
Thanks jdcarpe! :D
« Reply #4085 on: Fri, 13 September 2013, 08:29:43 »
someone tell mkawa he can buy a pack and add them to the geekhackers store ;)
« Reply #4086 on: Fri, 13 September 2013, 08:32:35 »
Hmmm, 2000 pcs is only $21.91 shipped, from Hong Kong. http://www.ebay.com/itm/310577934164
Offline stancato9
« Reply #4087 on: Fri, 13 September 2013, 13:45:09 »
Can someone please tell me what caps these are? Thanks :) Stole these pictures from somewhere on this forum. Credit where credit is due!
Poker 2 - MX Red
« Reply #4088 on: Fri, 13 September 2013, 13:48:16 »
Didn't I answer this before? They are 'Dolch' keycaps.
« Reply #4089 on: Fri, 13 September 2013, 13:48:28 »
Those are Dolch caps. Looks like they're the original caps with a proper moogle or tsangan kit on the modifer row. Second picture is MMB's or Bro Caps. Not sure who owns the first. More information on the Dolch PAC Keyboard here.
Offline stancato9
« Reply #4090 on: Fri, 13 September 2013, 13:51:37 »
Thanks, that's what I thought :)
What exactly is a moogle kit? I've seen that word around here but never figured out what it exactly is.
Poker 2 - MX Red
« Reply #4091 on: Fri, 13 September 2013, 13:52:57 »
Moogle kit - a kit with 1.25x mods and 6.25x spacebar for keycap sets that don't have them
Tsangan kit - a kit with 1.5x mods and 7x spacebar for keycap sets that don't have them
Original dolch only came with 1.5x mods, so you'll need a moogle kit for most keyboards. Alternatively buy the exact replica from originativeco (when he sells them) which comes with all keycaps for all layouts.
« Reply #4092 on: Fri, 13 September 2013, 13:54:51 »
Photekq wanna help me out? Hunt down a picture of both and add them to that post? Gonna add it to the OP.
Offline stancato9
« Reply #4093 on: Fri, 13 September 2013, 13:55:02 »
Oh ok. So is there a moogle kit for every keycap set? With the same legends / font / colour?
Poker 2 - MX Red
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #4094 on: Fri, 13 September 2013, 13:56:32 »
That depends on who organised the GB. Generally 1.25x mods with 6.25x spacebar are sold as standard mod set and a separate Tsangan set.
« Reply #4095 on: Fri, 13 September 2013, 13:58:07 »
No. For most modern sets, they'll come in ANSI 1.25x. If you harvest say a Cherry G81-7000 for the keycaps, you'll notice the bottom row isn't 1.25x mods with 6.25x spacebar. Hence you'd need a moogle. Older sets like a WYSE or Dolch from a Dolch PAC didn't have 1.25x mods/6.25x spacebar.
Offline stancato9
« Reply #4096 on: Fri, 13 September 2013, 13:58:25 »
Okay cool. Thanks!
Poker 2 - MX Red
« Reply #4097 on: Fri, 13 September 2013, 13:59:42 »
Most GBs here are ANSI 1.25x which are the 1.25x mods/6.25x spacebar. A Tsangan is 1.5x mods/7x spacebar.
« Last Edit: Fri, 13 September 2013, 15:14:08 by CPTBadAss »
Offline Dubsgalore
« Reply #4098 on: Fri, 13 September 2013, 14:59:29 »
that first photo looks more like dolch alphas with white on black mods (IMO)
« Reply #4099 on: Fri, 13 September 2013, 15:01:45 »
Isn't that what Dolch is? White on Grey Alphas with White on Black mods? Just called Dolch because that's the board the color scheme originally came from.
« Last Edit: Fri, 13 September 2013, 15:13:13 by CPTBadAss »
