Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6201154 times)
Offline Pacifist
  • on hiatus
« Reply #4250 on: Tue, 24 September 2013, 21:17:39 »
Straight up cheapest mechanical board?
Cheapest MX board I've seen was a Monoprice full size for $45 shipped.
Cheapest Alps I've bought was an FK-2001 for $20. Ninjadoc has been buying them for $1 at e-waste recyclers. Dell AT101Ws can be super cheap too.
Cheapest ML board I've seen was a G84-4100 for $17, which I bought.
Cheapest Topre I've seen was a Type Heaven for $170 new and I've seen it used for as low as $120.
Also the Type Heaven is priced at $150 now for a new one.
How good is the quality of the type heaven compared to regular mechanicals?
I'm really on the fence for a board, and topres seem like the fit all solution
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4251 on: Tue, 24 September 2013, 21:17:48 »
Can't seem to find the tidbit of information... can someone tell me what size/value whatever of diode that fits inside the MX switch?
« Reply #4252 on: Tue, 24 September 2013, 21:33:52 »
Obviously its no realforce but I didn't think it was all that bad. I'm sure the key cap legends could be an issue eventually.
If you want budget topre its great.
« Reply #4253 on: Wed, 25 September 2013, 00:29:25 »
I think everyone uses a standard 1N4148, DO-35 should fit, but I'm not 100% sure on the physical size.
Here's a chart of diode sizes if you have a cherry switch handy, and want to measure between the two diode stanchions
http://www.topline.tv/DO.html
Offline gunmetal
« Reply #4254 on: Wed, 25 September 2013, 14:00:10 »
Does an aluminum case affect typing feel or sound and if so, how so?
« Reply #4255 on: Wed, 25 September 2013, 14:05:00 »
1)feel
2)sound
Yes to both, in my opinion.
1) It feels more solid and weighty, like the keyboard is planted firmly in place.
2) The clicky switches aren't as loud since the sound doesn't resonate as much through the case. Check out the last video in mashby's review of an AT F
Offline Fragil1ty
  • Abre los ojos.
« Reply #4256 on: Thu, 26 September 2013, 11:29:35 »
Does anyone know the expected delivery time on the Expedited Shipping option that Qtan uses on his website?
e.g. 5-7 days, 7-14 days and so on? I couldn't see anything about it on my order form and I just want to know the 'typical' shipping time before I get anxious about it not being here and what not.
你搞砸了
« Reply #4257 on: Thu, 26 September 2013, 11:34:08 »
I've never ordered anything from qtan but I will say that the items that Shadovved has sent me from Singapore has come in ten days.
Offline PhineasRex
« Reply #4258 on: Thu, 26 September 2013, 21:49:48 »
Is there a list somewhere of keyboards that have a correctly-placed control key (where the caps lock key is on most boards) or can switch control and caps lock via DIP switch?
« Reply #4259 on: Thu, 26 September 2013, 21:53:11 »
HHKB and KMAC Happy off the top of my head. Any programmable board like an LZ, KMAC, or a GON should let you program a layout however you want.
Offline whiskytango
  • Don't touch the trim
« Reply #4260 on: Thu, 26 September 2013, 21:58:46 »
Ducky 9008G2 Pro does it. Maybe other Duckys do too?
Source: http://geekhack.org/index.php?topic=45051.msg938640#msg938640
« Reply #4261 on: Thu, 26 September 2013, 22:46:02 »
HHKB, Realforce, KMAC2, The ducky pro mentioned above, Leopold FC700R, Any fully programmable board.  This is an incomplete list.
« Reply #4262 on: Thu, 26 September 2013, 23:34:08 »
KMAC is programmable, and features a working capslock LED on the bottom rightmost switch, phantom is programmable as well.
I believe poker and poker2 have dipswitches for that functionality. Possibly the PURE as well (I'll have to go get my manual again.)
WYSE and SUN keyboard too ofcourse.
Offline goobus
  • HHKB Elite
« Reply #4263 on: Fri, 27 September 2013, 05:25:27 »
My new Filco TKL with blues is very scratchy and gives off an inconsistent click between different keys.  Is this something you guys have experienced before?  I know for sure my friend's blackwidow didn't feel this scratchy!
How do I fix this?
« Reply #4264 on: Fri, 27 September 2013, 05:45:31 »
How do I fix this?
Did you *just* get it? Give it some time to break in. If it really bothers you, just change out the switches.
Offline goobus
  • HHKB Elite
« Reply #4265 on: Fri, 27 September 2013, 05:58:05 »
How do I fix this?
Yep, completely brand new!  I'm just a little disappointed because the blackwidow I tried in stores feels much smoother (but maybe because they are older and broken in).  Thanks for the reply.
« Reply #4266 on: Fri, 27 September 2013, 06:07:06 »
My experience with brand new keyboards is that they all feel a little off at first. Maybe the stems still have mold marks or flash from the factory or the springs are just really stiff still. Type on it for like a week and see how it feels then. If it's still terrible, definitely try and return it or swap out the switches.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #4267 on: Fri, 27 September 2013, 08:18:52 »
is there a way in autohotkey to set up a macro to toggle the right mouse click?  When I am playing WoW almost 99% of the time I am in combat (raiding mostly) I have the right mouse button held down for circle strafing.  I want to be able to hit say Ctrl+right mouse click and toggle it on until I hit that key combo again or just a reg mouse click to turn it off.  Is this beyond the realm of what AHK can do?
Or should I make a new thread for this?
Offline goobus
  • HHKB Elite
« Reply #4268 on: Fri, 27 September 2013, 09:04:15 »
Thanks. I'll try to be patient with my Filco.
« Reply #4269 on: Fri, 27 September 2013, 09:06:00 »
I don't have a clue how AHK cans or its capabilities. Hang out here, it seems like an easy question: How to toggle right click in AHK?
Offline Larken
« Reply #4270 on: Fri, 27 September 2013, 09:23:50 »
I haven't played WoW for over a year, but try this.
^RButton::
   hold:= Not hold   ; toggle hold flag
   If hold
       Click down    ; presses the right button
       ToolTip Toggle ON
   else
       Click up      ; releases the right button
       ToolTip Toggle OFF
   return
| Ergodox #1 | Ergodox #2 |
Offline Melvang
« Reply #4271 on: Fri, 27 September 2013, 10:35:55 »
^RButton::
   If hold
       ToolTip Toggle ON
   else
       ToolTip Toggle OFF
   return
will give that a shot
also quick question how do I get rid of the [/color] and get the last link in my signature to show the same color as the rest of my signature  here is what I have in that field
[color =#5CC3FF]Costar Das, Razer Orbweaver modded to clears and reds with blue LEDs, and Razer Naga Epic.  [url =http://geekhack.org/index.php?topic=49067.0]My meat and cheese smoking guide[/url]
[url =http://geekhack.org/index.php?topic=43241.0][color =#5CC3FF]HD LED on my Das III
[ur l=http://geekhack.org/index.php?topic=49028.0]Brushed Behemoth build log[/url]
[/color]
Added spaces in the coding to show the coding.  Do I just need to add the color one after the last [ hr]
« Last Edit: Fri, 27 September 2013, 10:38:53 by Melvang »
Offline esoomenona
  • Gnillort?
« Reply #4272 on: Fri, 27 September 2013, 10:41:37 »
If you want to put an LED on a board that doesn't have traces for it, it can be done but would be a huge pain for an entire board.  See the bottom link in my signature for how i did it to my costar Das.
wow the harddrive led is friken AWESOME!
the modification I had in mind is a lot simpler
You can't just turn switches around all willy nilly as you please. I see what you're saying with your image, but not only does the PCB have holes for the LED in a certain place, but the contacts for the switch itself are set on one side of the switch. So you're talking about having four different wires criss-crossing under this switch (two for the LED, and two for the switch itself).
« Reply #4273 on: Fri, 27 September 2013, 10:42:04 »
[color =#5CC3FF][/b]Costar Das, Razer Orbweaver modded to clears and reds with blue LEDs, and Razer Naga Epic.  [url =http://geekhack.org/index.php?topic=49067.0]My meat and cheese smoking guide[/url]
[url =http://geekhack.org/index.php?topic=43241.0][color =#5CC3FF][/size]HD LED on my Das III
[/color][/b]
You have an open color and no closed color. So each [color] needs a matching [/color]. Either elminate one of the color codes or add another [/color]
« Last Edit: Fri, 27 September 2013, 10:58:26 by CPTBadAss »
Offline esoomenona
  • Gnillort?
« Reply #4274 on: Fri, 27 September 2013, 10:46:51 »
Code: [Select]
[color=#5CC3FF]Costar Das, Razer Orbweaver modded to clears and reds with blue LEDs, and Razer Naga Epic.[/color][hr][color=#5CC3FF][url=http://geekhack.org/index.php?topic=49067.0]My meat and cheese smoking guide[/url][/color][hr][color=#5CC3FF][url=http://geekhack.org/index.php?topic=43241.0]HD LED on my Das III[/url][/color][hr][color=#5CC3FF][url=http://geekhack.org/index.php?topic=49028.0]Brushed Behemoth build log[/url][/color]
Offline Melvang
« Reply #4275 on: Fri, 27 September 2013, 10:56:15 »
Code: [Select]
Excellent thanks guys
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #4276 on: Fri, 27 September 2013, 13:41:51 »
Are there any black on yellow or any color on yellow key sets besides the Tai Hao and Turtle set?
« Reply #4277 on: Fri, 27 September 2013, 13:44:04 »
Bumblebee from Keypop
« Reply #4278 on: Fri, 27 September 2013, 13:51:05 »
school bus?
Offline MOZ
  • Busy making stuff
« Reply #4279 on: Fri, 27 September 2013, 14:47:20 »
Any other? Or anyplace I can buy a plain black on yellow keyset (Pref with tsangan) just not pad printed please.
school bus?
You smart-ass  :P
« Reply #4280 on: Fri, 27 September 2013, 14:49:56 »
Only set that springs to mind is the ones at EK which are pad printed and no Tsangan. You can always try looking at these vendors or searching Taobao. Or you can see what blank caps SP has for sale.
Offline MOZ
  • Busy making stuff
« Reply #4281 on: Fri, 27 September 2013, 14:51:04 »
I knew you'd say taht is why I added the pad printing comment. :P
« Reply #4282 on: Fri, 27 September 2013, 14:51:52 »
If I knew more I wouldve said so before. That's all I got. Maybe someone else knows but I haven't seen many yellow themed sets besides TaiHao and Bumblebee.
« Reply #4283 on: Fri, 27 September 2013, 14:54:37 »
school bus?
You smart-ass  :p
I thought you wanted matching keys for the acrylic top your working on or something :p
And I don't know of any other sets with those colors that have been done either.
« Reply #4284 on: Sat, 28 September 2013, 00:13:55 »
There is a Filco set that is black on yellow.  Didn't know they exsisted until right now. Stock Filco caps so OEM profile and their font. Don't know where you can get them now. The ones Im holding were from the classifieds.
« Reply #4285 on: Sat, 28 September 2013, 01:58:46 »
There was a place that was selling just the keycaps - someone sent me the link a year or so ago when I was searching for a set.
The only other way is buy a board and salvage the key caps (and maybe on-sell the board if anyone wants a keycap-less Filco).
Offline e4stw00t
« Reply #4286 on: Sat, 28 September 2013, 05:37:18 »
Did run in a odd thing today. PC booted twice before actually making it to Windows. Thereafter my Filco didn't work anymore using the PS/2 port. It works instantly when I switch to USB though. I am aware that PS/2 isn't hot plugged but whenever I switch to the port the LEDs on my keyboard flash for a second or two, but still it's not working no matter what I tried so far (uninstalling the USB keyboard, rebooting connected to the PS/2 port). I can't get Windows to reinstall the PS/2 drivers from the device manager and it also doesn't work automatically after reboot. Kind of lost on that one.
Offline goobus
  • HHKB Elite
« Reply #4287 on: Sat, 28 September 2013, 22:16:57 »
Has anyone ever modified Cherry stabilizers to feel slightly less mushy?  Per this video:
How safe is this?  Is there any other way to do it?
« Reply #4288 on: Sat, 28 September 2013, 22:26:23 »
Works great for me. Have it on my KMAC. Love how it feels. No other way to do it and its honestly very simple.
« Reply #4289 on: Sat, 28 September 2013, 22:26:52 »
Where can I find the lubing topre thread?
Offline goobus
  • HHKB Elite
« Reply #4290 on: Sat, 28 September 2013, 22:42:24 »
Very reassuring words ^^ can't wait to do it on my FC700R and KMAC!!! Thank you!!
« Reply #4292 on: Sun, 29 September 2013, 03:01:16 »
« Reply #4293 on: Sun, 29 September 2013, 10:12:08 »
What kind of wire should I use for direct wiring?
« Reply #4294 on: Sun, 29 September 2013, 10:57:25 »
I always use telecom cross connect wire, because I have a 1000' spool of it. It's basically just 24AWG solid copper wire.
« Reply #4295 on: Sun, 29 September 2013, 18:41:42 »
like this
http://www.ebay.com/itm/NEW-1000-ROLL-1-PAIR-2-WIRE-CROSS-CONNECT-CABLE-24-AWG-SOLID-COPPER-GREEN-WHITE-/360408809251
« Reply #4296 on: Sun, 29 September 2013, 19:39:46 »
like this
Yes, that's the stuff. You actually get 2000' of wire, since it's twisted pair. :)
« Reply #4297 on: Sun, 29 September 2013, 19:43:38 »
like this
I wonder if anyone else would want some I could buy a spool and split it up.
Offline esoomenona
  • Gnillort?
« Reply #4298 on: Mon, 30 September 2013, 08:42:15 »
How do you turn on Num Lock on a SSK?
« Reply #4299 on: Mon, 30 September 2013, 08:43:17 »
Shift-ScrLk
