Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6201090 times)
Offline esoomenona
  • Gnillort?
« Reply #4300 on: Mon, 30 September 2013, 08:46:52 »
Yeah... that doesn't seem to be working for me. :(
« Reply #4301 on: Mon, 30 September 2013, 14:09:27 »
How do you turn on Num Lock on a SSK?
Shift-ScrLk
Maybe it's Alt + Scroll Lock? That's Dorkvader's suggestion at least.
Offline esoomenona
  • Gnillort?
« Reply #4302 on: Mon, 30 September 2013, 14:12:53 »
I tried Alt, Ctrl, and Shift. I tried Caps+Num. I tried Esc+Num. Nothing. I'll take the keyboard home and try it on another computer. Everything else works perfectly except for that. I thought turning on Num with another keyboard would work, but it didn't.
« Reply #4303 on: Mon, 30 September 2013, 14:14:16 »
I was guessing from memory. My brief search on it suggests that it should be right shift + scroll lock
http://geekhack.org/index.php?topic=41977.msg842647#msg842647 (samwisekoi commenting on tenkeys)
http://geekhack.org/index.php?topic=48823.msg1050118#msg1050118 (cgbuen asking about the numpad layer)
Are you quite sure it's an SSK controller PCB?
« Reply #4304 on: Mon, 30 September 2013, 14:14:54 »
Pretty sure that's what I did on my SSK, I used a different keyboard to toggle num lock. But my memory might be a little fuzzy.
Let me know if it works for you, otherwise I'll keep hunting for an answer.
Offline esoomenona
  • Gnillort?
« Reply #4305 on: Mon, 30 September 2013, 14:16:06 »
I'm not sure at all. I purchased a "SSK", so I should hope so...
« Reply #4306 on: Mon, 30 September 2013, 16:33:18 »
There is a chance it's a "normal" model M controller. I'm not too familiar with the visual differences, but If you can open up the KB and post a picture of yours, I'm happy to compare to the SSK controller I'm currently working on. I'll post a picture of it as well, provided the owner gives their permission.
« Reply #4307 on: Mon, 30 September 2013, 16:37:19 »
If you're referring to my SSK dorkvader, I don't mind you taking pictures. If it was a Model M controller, how would you enable num lock? Obviously the SSK doesn't have the switch to press like a Model M but maybe there's a layered command (ALT + M for example) that would enable it? I know moose tried a ton of other combos before.
Offline BlackWidowMan777
« Reply #4308 on: Tue, 01 October 2013, 02:35:49 »
I just received two Aron 106 Alps keyboards from China, but the two keys on either side of the spacebar are printed in Korean.
Does anybody know what these two keys do or can anybody who can read Korean tell me what they say?
Considering the extremely cheap price, they feel surprisingly good to type on and are quite solid feeling (especially the non-tactile one, which is silky smooth).
Offline yasuo
  • spanengan puyeng newbie
« Reply #4309 on: Tue, 01 October 2013, 06:42:09 »
i ask again ;D
This
http://imgur.com/ynhSQLU
http://i.imgur.com/cxOqUvo.png?1
in here, i ask
1.what dimesion holes square(white)
2.how much spacing (Red)
3.how to size screw regulary?
4.any idea place for teensy particular
Thanks very much
Logitech MK220 Colemak DH
« Reply #4310 on: Tue, 01 October 2013, 06:53:50 »
i ask again ;D
This
in here, i ask
Thanks very much
1) Information is in the original/first post and in the CAD resources thread in Making Stuff Together.
2) Information is in the original/first post and in the CAD resources thread in Making Stuff Together.
3) I'm actually not sure about this. Forget the KMAC screw size but the LZ-GH used M3 6MM screws. Those were too small for use in my KMAC>
4) You could make a standoff like melvang did, buy a small housing for it and attach it to the cable, or hide it inside your case. You can check the teensy/adapter thread Soarer has for ideas. It's a stickied thread in Making Stuff Together.
Offline yasuo
« Reply #4311 on: Tue, 01 October 2013, 07:39:04 »
1.I want square regular like matte3o plate
This
https://www.dropbox.com/s/7818xtw054jrhue/MXSwitchCuouts.png
For width 0.6140 or 0.5500 fit cherry mx not easily loose :))
Thanks
« Reply #4312 on: Tue, 01 October 2013, 07:53:33 »
This
Thanks
You can figure out the square from that picture...
Offline gameaholic
« Reply #4313 on: Tue, 01 October 2013, 08:46:39 »
I'm ordering an aluminum case in black.  How would I go about re-anodizing it in the future if I want it in titanium or silver?  And just wondering what about gold plating?
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
« Reply #4314 on: Tue, 01 October 2013, 08:47:30 »
You'd have to find a shop to do anodization. Most likely have to do the same thing for gold plating.
Edit: There are home kits for anodization but they're expensive and deal with very nasty chemicals. Apparently the gold plating isn't as hard but I'm not as well versed on that.
« Last Edit: Tue, 01 October 2013, 08:50:51 by CPTBadAss »
Offline esoomenona
  • Gnillort?
« Reply #4315 on: Tue, 01 October 2013, 09:29:44 »
Could a SDL cable make the difference between Num Lock working and not? The person who sold me the SSK said that the Num Lock worked, and I'm leaning towards believing him. But I took it home yesterday and plugged it into another computer, and nothing...
« Reply #4316 on: Tue, 01 October 2013, 10:17:40 »
Couldn't hurt to swap in a new one....wish I had my SSK to help test out.
Offline esoomenona
  • Gnillort?
« Reply #4317 on: Tue, 01 October 2013, 10:18:59 »
The one I bought was brand new. But I'm wondering if maybe the cable from an SSK is necessary for it to work as an SSK? Maybe the cable I bought is for a regular Model M?
But then, people have purchased Orihalcon's cable for both, and they don't differentiate between SSK or regular M...
« Reply #4318 on: Tue, 01 October 2013, 10:22:01 »
Ah, I meant maybe you should try another cable. I know for a fact I used the same cable for my SSK as I did a Model AT F and M.
Offline esoomenona
  • Gnillort?
« Reply #4319 on: Tue, 01 October 2013, 10:29:59 »
I'm going to try to remember today to run it through my PS/2 to USB converter, and see if there is any difference, then I might pick up a cable from Orihalcon and see what's up there.
« Reply #4320 on: Tue, 01 October 2013, 11:04:36 »
I know I've seen it posted and am pretty sure of the answer but I'll ask anyways.
I've got a coolermaster board and it has costar stabs and I hate those little white inserts so is my only solution to completely desolder and install cherry stabs?
Or can a stock coolermaster plate even take cherry stabs?
Offline esoomenona
  • Gnillort?
« Reply #4321 on: Tue, 01 October 2013, 11:06:44 »
It can't accept Cherry stabs. You'd have to find a Universal TKL plate if you wanted to use them.
« Reply #4322 on: Tue, 01 October 2013, 11:08:28 »
Ah ok and it's not a TKL either its the XT :( boooooo
Offline Kampeki
« Reply #4323 on: Tue, 01 October 2013, 13:02:56 »
I'd like to know a few keyboards, TKL or Fullsize ( TKL would be better ) that have a larger Ctrl key size, I believe that means 1.5x modifiers, like the BWU, could someone point some to me?
Offline esoomenona
  • Gnillort?
« Reply #4324 on: Tue, 01 October 2013, 13:05:12 »
http://www.ttesports.com/productPage.aspx?p=19&g=ftr
Big enough for you?
« Reply #4325 on: Tue, 01 October 2013, 13:07:03 »
Big enough for you?
Thermaltake always pushing the boundaries..
« Last Edit: Tue, 01 October 2013, 13:09:17 by Photekq »
« Reply #4326 on: Tue, 01 October 2013, 13:07:24 »
The Korean custom boards like The Cheat, KMAC, and LZ-GH will have these as well.
Offline Kampeki
« Reply #4327 on: Tue, 01 October 2013, 13:24:57 »
I meant more like these ones, that Tt Meka is too much for me :P, unfortunately Korean customs are a little out of my budget, thank you everyone though.
Offline esoomenona
  • Gnillort?
« Reply #4328 on: Tue, 01 October 2013, 13:27:41 »
You could probably put together a Phantom for cheaper.
« Reply #4329 on: Tue, 01 October 2013, 13:31:11 »
Very true...I keep forgetting a Phantom PCB can be bought easily and is very cheap now.
« Reply #4330 on: Tue, 01 October 2013, 13:34:29 »
PCB's area easy to get, plates not so much.
Offline esoomenona
  • Gnillort?
« Reply #4331 on: Tue, 01 October 2013, 13:39:23 »
I would wager if you started a WTB for a popular layout plate like ANSI150, you'd find it relatively easy.
« Reply #4332 on: Tue, 01 October 2013, 13:53:07 »
Many WYSE boards also have large Ctrl keys, but you would most likely have to make a converter for use with a PC.
« Reply #4333 on: Tue, 01 October 2013, 18:07:00 »
HHKB Pro 2?
Offline Kampeki
« Reply #4334 on: Wed, 02 October 2013, 06:57:51 »
HHKB is too compact for me.
Thank you everyone who replied, I think my best bet is to build a Phantom, although it will be a bit hard to get the plate and switches, besides the fact that it will be my second keyboard, after my BWU. But I believe it would be worth it.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #4335 on: Wed, 02 October 2013, 07:01:36 »
www.mouser.com and www.digikey.com both sell Cherry switches.  If you want to check part numbers for the specific cherry stem colors head to www.cherrycorp.com and navigate to "Keyswitches" on the left hand column and from there select MX switch line.
« Reply #4336 on: Wed, 02 October 2013, 07:25:00 »
What kind of switches are you wanting?
There are cheap new blue switches in the classifieds right now. There are also frequent sales of cheap used black switches.
You can also order switches from a groupbuy at deskthority from user 7bit.
Offline Melvang
« Reply #4337 on: Wed, 02 October 2013, 07:40:17 »
When hardwiring LEDs on all switches on a keyboard that doesn't support full LED lighting for whatever reason are they wired in series or parallel?
« Reply #4338 on: Wed, 02 October 2013, 07:42:55 »
The Deskthority wiki also has part numbers.
« Reply #4339 on: Wed, 02 October 2013, 07:54:57 »
Cherry Switch part numbers
Plate Mount
    MXBLUE    MX1A-E1NN
    MXBROWN   MX1A-G1NN
    MXCLEAR   MX1A-C1NN
    MXGREEN   MX1A-F1NN
    MXGREY    MX1A-D1NN
    MXRED     MX1A-L1NN
    MXWHITE   MX1A-A1NN
PCB mount
    MXBLACK   MX1A-11NW
    MXBLUE   MX1A-E1NW
    MXBROWN   MX1A-G1NW
    MXCLEAR   NWMX1A-C1NW
    MXGREEN   MX1A-F1NW
    MXGREY    MX1A-D1NW
    MXRED     MX1A-L1NW
    MXWHITE   MX1A-A1NW
dt wiki link
http://deskthority.net/wiki/Category:Cherry_MX
« Last Edit: Wed, 02 October 2013, 08:01:58 by SpAmRaY »
« Reply #4340 on: Wed, 02 October 2013, 08:25:02 »
What kind of wire should I use for direct wiring?
I always use telecom cross connect wire, because I have a 1000' spool of it. It's basically just 24AWG solid copper wire.
Cheers! Got some 24AWG now, it's perfect.
Offline Kampeki
« Reply #4341 on: Wed, 02 October 2013, 08:45:34 »
I'm looking for browns, perhaps a few clears, but brown are my priority.
Offline sharkbyte
« Reply #4342 on: Wed, 02 October 2013, 09:43:30 »
can I transfer switches from a PCB mount to a plate mount KB easily?
« Reply #4343 on: Wed, 02 October 2013, 09:44:29 »
Yes, chop off the two smaller plastic pins on the bottom of the switches with some nail clippers or a similar tool.
Offline sharkbyte
« Reply #4344 on: Wed, 02 October 2013, 11:21:03 »
Do I have to solder for this transfer, or can ijust switch the inner components?
« Reply #4345 on: Wed, 02 October 2013, 11:23:24 »
PCB mount can be opened up and you can remove the stem and spring however unless the plate has been designed to allow for switch top removal you will have to desolder the plate mount
« Reply #4346 on: Wed, 02 October 2013, 11:23:41 »
You can open the switches on a PCB-mounted board without desoldering, but on a plate mounted board (unless it uses a custom plate, which i'm guessing yours does not) you cannot, so you need to desolder them to access their internals.
Offline Melvang
« Reply #4347 on: Wed, 02 October 2013, 14:54:35 »
Also note that you can not swap switch internals on PCB mount without desoldering if the switch has an LED
Offline Photoelectric
« Reply #4348 on: Wed, 02 October 2013, 15:09:05 »
I'm sorry if this has been asked before, but I'm trying to make sure that a Phantom PCB is compatible with a standard Filco TKL plate (for a Filco-style layout, of course).  If anyone knows otherwise, please let me know.
Thanks in advance!
« Reply #4349 on: Wed, 02 October 2013, 15:18:11 »
Thanks in advance!
That's what it was designed for!!
