Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6003126 times)
« Reply #4000 on: Fri, 06 September 2013, 12:28:30 »
What size screws does the LZ-GH use?
« Reply #4001 on: Fri, 06 September 2013, 14:04:33 »
Maybe PM the Team Red-Line members? One or more or them would certainly have this info.
« Reply #4002 on: Fri, 06 September 2013, 14:25:44 »
I need a micro-usb breakout board but can't find any with the measurements I want so I'm gonna have one made for myself.
I understand there's SMD receptacles and I think through-hole but which type of mounting is the most solid & secure?
« Reply #4003 on: Fri, 06 September 2013, 14:33:07 »
What about the TRiKy? It uses Micro USB.
http://red-line.kr
« Reply #4004 on: Fri, 06 September 2013, 14:36:15 »
Like this?
https://www.sparkfun.com/products/9614
« Reply #4005 on: Fri, 06 September 2013, 15:26:29 »
Like this?
Pretty much like that, but as I've said I need my own custom measurements. Just wondering what kind of receptacle is best to use.
http://red-line.kr
By breakout board I simply meant a small PCB with a micro-usb port on it and pinouts to the 'vcc', 'd-' etc. like the link ray posted :)
Offline CalmB4tehPwn
  • Demon of the Fall
« Reply #4006 on: Sat, 07 September 2013, 00:16:56 »
What are the practical differences between white and clear stems, aside from a subdued click?
I am very interested by clears, but I do love the click.
"I seek a great warrior" - Luke Skywalker
"Great Warrior, Hmm? War does not make one great." - Master Jedi Yoda
« Reply #4007 on: Sat, 07 September 2013, 00:18:52 »
That's about it. Bump vs click. To me, they feel equally heavy. If you want a proper force readout, check the OP for rkinze's measurements.
« Reply #4008 on: Sat, 07 September 2013, 00:19:46 »
MX white : http://i.imgur.com/WeXMC43.jpg
MX clear : http://i.imgur.com/KCsOv0W.jpg
They are very different.
« Reply #4009 on: Sat, 07 September 2013, 00:28:50 »
Right, the click is accomplished with the 2 part slider vs the clear's single stem. I just meant in terms of how the switches felt :3.
Offline yasuo
  • spanengan puyeng newbie
« Reply #4010 on: Sat, 07 September 2013, 02:03:42 »
How much, MAX spacing switch?
Logitech MK220 Colemak DH
« Reply #4011 on: Sat, 07 September 2013, 02:14:42 »
If you're asking what the spacing is between each switch, that's in the OP.
Offline yasuo
« Reply #4012 on: Sat, 07 September 2013, 02:24:18 »
Not,i mean spacing or distance each holes on plate but The MAX?
« Reply #4013 on: Sat, 07 September 2013, 02:30:22 »
What do you mean: the max. I'm not understanding what you're asking as usual. On the MAX keyboard? The maximum width? What?
Offline yasuo
« Reply #4014 on: Sat, 07 September 2013, 02:36:26 »
the maximum :D
« Reply #4015 on: Sat, 07 September 2013, 02:37:09 »
Yes I know max = maximum. What maximum are you asking about?
Offline yasuo
« Reply #4016 on: Sat, 07 September 2013, 02:46:59 »
distance each holes(switch) on plate
« Reply #4017 on: Sat, 07 September 2013, 02:49:18 »
Are you asking for the size of the plate itself? Because I literally just told you the distance between the switch holes in the plate. That information (distance from the center of each hole in a plate) is in the OP.
http://geekhack.org/index.php?topic=40501.0#post_ZZ
« Last Edit: Sat, 07 September 2013, 02:51:11 by CPTBadAss »
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #4018 on: Sat, 07 September 2013, 04:48:56 »
ok so i just got a set of the geekhack.org function keys from pckeyboard.com and have a question for you guys.  On the actual switch cap with the legends on them the "F1" key doesn't seem to have the little catches on it that the other ones do so you can just pull it straight off with zero effort.  Has anyone else seen this and have any idea on how easy to deal with the parent web site it is with something of this nature??
Melvang
PS After typing on MX switches this chicklet keyboard on this new Asus laptop can suck my hairy *#&!@$^.
Offline yasuo
« Reply #4019 on: Sat, 07 September 2013, 06:51:46 »
Any someone can make design plate?
« Reply #4020 on: Sat, 07 September 2013, 09:49:15 »
Can you take a picture please? I'm not quite sure I follow.
http://geekhack.org/index.php?topic=40501.0#post_AA
While you're there, you should read the rest of it so I don't have to keep yelling at you to read the OP.
Offline Melvang
« Reply #4021 on: Sat, 07 September 2013, 21:56:51 »
I will try and get a pic posted in the morning for you Cpt.
« Reply #4022 on: Sun, 08 September 2013, 13:05:41 »
Are there any Alps keyboards that have the G80-1800 layout?
Offline jonathanyu
« Reply #4023 on: Sun, 08 September 2013, 22:32:29 »
Where can I buy a wire for cherry stabilizer online?
Offline BlueBär
« Reply #4024 on: Mon, 09 September 2013, 03:33:34 »
Mouser, see the OP.
Offline frogamic
« Reply #4025 on: Mon, 09 September 2013, 04:42:52 »
Are the novelty doubleshot key caps by techkeys/keypop SP DCS profile?
Filco TKL | Filco ISO105 | Acer 6311-K71
« Reply #4026 on: Mon, 09 September 2013, 07:43:43 »
Yes, you're correct.
Offline csmith1991
« Reply #4027 on: Mon, 09 September 2013, 12:03:19 »
I've only recently found out about GH, during my search for info about 60% keyboards. The HHKB keyboard has the layout that I think I'd really like, but for its price it just isn't for me :(. I missed the group buy it would seem, so my question is this: When would GH60 keyboards start showing up in the classifieds, and anyone got an idea how prices would work for that?
« Last Edit: Mon, 09 September 2013, 12:05:25 by csmith1991 »
Offline Melvang
« Reply #4028 on: Mon, 09 September 2013, 12:07:21 »
My guess would be around next year.  But that is just a shot in the dark there.
Question of my own.  Are all the keys on the unicomp buckling spring boards a 2 piece cap?
« Reply #4029 on: Mon, 09 September 2013, 12:14:49 »
« Reply #4030 on: Mon, 09 September 2013, 13:05:45 »
Pretty sure they are, yes.
Probably go for the same price as the GB. I've seen a few orders for sale already. More will come once people have them in hand. Probably sometime late this year or early 2014. In the future, don't ask about pricing here though. There's already a thread for that.
Yup
http://geekhack.org/index.php?topic=35672.msg1034865#msg1034865
Besides that one?
Offline Melvang
« Reply #4031 on: Mon, 09 September 2013, 13:07:07 »
Thanks CPT.  Also I emailed pckeyboard.com and told them about the issue with the top half of the cap and i got a reply back saying they would mail me a replacement within 3 minutes.
« Reply #4032 on: Mon, 09 September 2013, 13:10:25 »
That worked itself out nicely then :D
Offline phx
« Reply #4033 on: Mon, 09 September 2013, 13:57:17 »
anyone bought a QFR Red from newegg recently? is it branded? about about the plate's color? (still red?)
« Reply #4034 on: Mon, 09 September 2013, 14:00:17 »
Check this out. Plate should be red.
Offline ComradeSniper
  • HHKB Pro
« Reply #4035 on: Mon, 09 September 2013, 21:16:32 »
Do any Korean custom boards allow the use of Costar stabs? I really don't understand the appeal of PCB mount cherry stabs like the KMACs use.
« Reply #4036 on: Mon, 09 September 2013, 21:41:51 »
1) Do any Korean custom boards allow the use of Costar stabs?
2) I really don't understand the appeal of PCB mount cherry stabs like the KMACs use.
1) My boy Sifo says no
2) If you don't like the feel of PCB mount Cherry stabilizers, you can try clipping them
  • HHKB Pro
« Reply #4037 on: Mon, 09 September 2013, 21:48:16 »
Thanks, will try that.
Offline MKULTRA
  • telling it how it is
« Reply #4038 on: Mon, 09 September 2013, 21:51:32 »
PCB mounted stabs feel fine to me.
  • HHKB Pro
« Reply #4039 on: Mon, 09 September 2013, 21:52:59 »
They feel mushy to me. Costar stabs don't seem to affect the feel of the switch at all, but bottoming out on a Cherry stab feels like a rubber dome.
« Last Edit: Mon, 09 September 2013, 22:04:04 by ComradeSniper »
« Reply #4040 on: Mon, 09 September 2013, 21:54:32 »
clip em clip em clip em
pcb mount normal - meh
plate mount normal - meh
costar - good
pcb clipped - AMAZING
« Reply #4041 on: Mon, 09 September 2013, 21:55:15 »
They feel mushy to me. Costar stabs don't seem to effect the feel of the switch at all, but bottoming out on a Cherry stab feels like a rubber dome.
Yup, I have the same opinion ComradeSniper. Check this out. I did it on my KMAC and I highly recommend it.
Offline jonathanyu
« Reply #4042 on: Mon, 09 September 2013, 22:28:15 »
the stl files on ergodox.org are created in inches or cm?
Offline Melvang
« Reply #4043 on: Mon, 09 September 2013, 22:38:10 »
anyone know if you can dim CCFL with a resistor before the invertor?  I am thinking no but wanted to check before I bought parts
Offline LoNeWolF
« Reply #4044 on: Tue, 10 September 2013, 11:55:53 »
I checked out the FAQ but didn't find and answer to my question (which is incredibly basic). I've been looking for my first mechanical keyboard and the one I liked most was the fully backlit keycool 84. Is there a place in Europe where I can buy it without importing? Brown/Blue switches. Tried eBay and Amazon to no avail.
And if not, what about Ducky Shine III? We don't have a place selling a lot of mechanical keyboard brands here. Just the more popular ones like Razer, SS and CM. So if you can show me some links to shops that ship to EU I'll be very grateful. Thanks.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #4045 on: Tue, 10 September 2013, 12:00:51 »
http://stores.ebay.com/E-sports-Gaming-equipments/Mechanical-Gaming-keyboard-/_i.html?_fsub=2504364013&_sid=1011272153&_trksid=p4634.c0.m322
Qtan is awesome. He ships from China, but it only takes like 1 week to get to the US. I don't know about EU shipping, but I'm sure it wouldn't be a problem.
Edit: He sells his stuff cheaper on his site: http://www.vendio.com/stores/E-sports-Gaming-equipments/
« Reply #4046 on: Tue, 10 September 2013, 12:06:13 »
I checked out the FAQ but didn't find and answer to my question (which is incredibly basic). Is there a place in Europe where I can buy it without importing?
I haven't research different vendors in different locales simply because I'm lazy and that task is a bit daunting to me. If you want to do so, let me know what you find.
« Reply #4047 on: Tue, 10 September 2013, 12:08:38 »
You can get Filcos in the EU at The Keyboard Company. Bruce is a member here.
I'm not sure where you might get a Keycool or Ducky.
Offline Xenderwind
« Reply #4048 on: Tue, 10 September 2013, 12:11:22 »
I don't think the problem is the time it takes.  It's the extra cost because its an import.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline LoNeWolF
« Reply #4049 on: Tue, 10 September 2013, 12:14:20 »
Yeah I know the site but I meant if there was a place IN europe where I can buy them, because I have to pay imports and I have to go to the customs and waste a lot of time until I take my keyboard out of bond.
