Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6003133 times)
Offline BlueBär
« Reply #3850 on: Mon, 26 August 2013, 08:31:21 »
it seems 12 cable (6 right/6 left hand)
how to teensy,whether I need two?
So you just need six cables to connect the two? Then Cat 5 should be good. I would recommend looking into how the ErgoDox works, it's completly open source afaik.
Offline domoaligato
« Reply #3851 on: Mon, 26 August 2013, 08:48:08 »
this should be in a new thread for modding the ergodox to use a cat5 cable instead of the one provided with the kit.
Offline esoomenona
  • Gnillort?
« Reply #3852 on: Mon, 26 August 2013, 09:21:52 »
D: Anchors are a thing here? This thread just gets better and better.
Offline BlueBär
« Reply #3853 on: Mon, 26 August 2013, 10:00:15 »
He wants to build his own keyboard using hardwiring, so his question is not about modding the ErgoDox. But yes, yasua you should make a new thread in the "Making stuff together" section if you need help with that project.
Offline esoomenona
  • Gnillort?
« Reply #3854 on: Mon, 26 August 2013, 15:16:10 »
Does anyone know if it's possible to get the media controls of a Mac keyboard to work in Windows? I found this video, but I'm not sure how I feel about installing random keyboard drivers from a youtube video.
Offline domoaligato
« Reply #3855 on: Mon, 26 August 2013, 15:24:33 »
do you mind using autohotkey?
also what mac keyboard is it exactly?
Offline esoomenona
  • Gnillort?
« Reply #3856 on: Mon, 26 August 2013, 15:27:28 »
I don't at all. It's an HHKB. The problem is they don't seem to return anything for AHK to pick up. The Eject key returns F20, but Vol_Up, Vol_Dn, and Mute don't seem to return anything. Also, aquakey picks up some signal from Eject as well, but nothing from the others.
Offline domoaligato
« Reply #3857 on: Mon, 26 August 2013, 15:30:03 »
the og hhkb or the pro or pro 2?
Offline esoomenona
  • Gnillort?
« Reply #3858 on: Mon, 26 August 2013, 15:34:44 »
Pro 2
Offline domoaligato
« Reply #3859 on: Mon, 26 August 2013, 15:34:54 »
basically hasu is your man for the hhkb/pro/pro2/etc
check this thread out.
he should be able to answer any questions you might have about what your trying to achieve.
http://geekhack.org/index.php?topic=12047.0
https://github.com/tmk/tmk_keyboard/tree/master/keyboard/hhkb
Offline domoaligato
« Reply #3860 on: Mon, 26 August 2013, 17:35:44 »
For users that do not want to mod there keyboard and might be looking for a easy way to remap keys in windows...
http://www.randyrants.com/2006/07/sharpkeys_211.html
to finish the info about the hhkb.
from what I have been reading the only special buttons on the mac hhkb that can be remapped in windows is  eject and it equals F20.
sharpkeys can help you change F20 to whatever you want in windows if you want to do just that.
Offline MJ45
  • HHKB Pro
« Reply #3861 on: Mon, 26 August 2013, 17:45:40 »
[/quote
The media features (vol-up, dn, mute) are Mac only features. You will have to use Autohotkey or other keyboard utility.
Offline esoomenona
  • Gnillort?
« Reply #3862 on: Mon, 26 August 2013, 19:37:51 »
I know that. But I was just wondering, what with the amount of people who use Windows and the ingenuity of some of those people, that someone might have come up with a way to build a hook into Windows to receive those signals. It's no big deal to me if it's impossible. I won't go out of my way to use them. I just figured if they were there, why not.
« Reply #3863 on: Mon, 26 August 2013, 19:56:31 »
Yeah they're a thing. I've been using them for a little while in my reviews but I think this has been my best usage of it so far. You know how they work right?
« Last Edit: Mon, 26 August 2013, 23:58:49 by CPTBadAss »
Offline esoomenona
  • Gnillort?
« Reply #3864 on: Mon, 26 August 2013, 20:04:04 »
Yeah they're a thing. I've been using them for a little while in my reviews but I think this has been my best implication of it so far. You know how they work right?
Of course, son.
Offline lcs
  • Lover of Grape Drank
  • はやく
« Reply #3865 on: Tue, 27 August 2013, 10:51:44 »
Can someone tell me the size of a KMAC Happy please?
« Reply #3866 on: Tue, 27 August 2013, 11:30:54 »
Judging from the picture that Calavera posted from KBD:
It looks to be the same size as my KMAC LE without the navigation/arrow cluster. I will be taking measurements from my KMAC LE then since that's what is in front of me.
So if I measure the width from the left edge to the keyboard to the right edge where F12 is I get: 11.5 inches.
The right bezel between the F12 to the navigation cluster isnt' the same size as the left bezel so we'll just measure the left bezel and then add that to the first measuremeant: 0.5 inches
So total width is 12 inches. And height (from bezel below left ctrl to bezel above escape) is 5.5 inches.
Offline lcs
  • はやく
« Reply #3867 on: Tue, 27 August 2013, 11:31:44 »
Thank you so much :)
Offline esoomenona
  • Gnillort?
« Reply #3868 on: Tue, 27 August 2013, 11:34:22 »
5.5 inches is too much. I measure my HHKB and only get 4.25". I'd say that thing looks a little bit wider, but not that much more.
Offline lcs
  • はやく
« Reply #3869 on: Tue, 27 August 2013, 11:36:49 »
What about the height? :)
Offline esoomenona
  • Gnillort?
« Reply #3870 on: Tue, 27 August 2013, 11:42:33 »
My HHKB is .75" front, 1.25" back. I only offer these numbers being that it seems they were looking to emulate it in some regard. I know you want measurements of the Happy in particular, so someone else would have to measure that for you.
Offline lcs
  • はやく
« Reply #3871 on: Tue, 27 August 2013, 11:44:53 »
I think it is a fine estimate :)
Thanks moose :)
« Reply #3872 on: Tue, 27 August 2013, 11:48:01 »
I'm going to call this thickness because I already used the word height. The thickness of my KMAC LE is 13/16 inch.
Like I said before, I'm *assuming* that the KMAC LE and Happy are similar based on the picture and when I tried the Happy in real life at Chicago. As always, I might be wrong.
I'm looking to edit the function layer on my KMAC Happy, but all the KMAC keybinding programs I have found only have templates for the regular KMAC and the Mini, not the Happy.  Can I just change, say, the KMAC Mini template to match the row/column layout of the Happy, or do I need to find the exact Happy template file?  Do all these boards use the same controller?
You can reprogram the KMAC Happy using the KMAC2 .exe. I confirmed this with jcrouse.
The controller on the KMAC is a ATMega16, as shown here.
« Last Edit: Tue, 27 August 2013, 11:51:27 by CPTBadAss »
Offline lcs
  • はやく
« Reply #3873 on: Tue, 27 August 2013, 11:51:59 »
Don't worry, for what I want I don't need too much precision :)
Thanks for the replies, as usual!
Offline yasuo
  • spanengan puyeng newbie
« Reply #3874 on: Tue, 27 August 2013, 12:06:46 »
What good plate for handwired, i want make plate own any suggestion for plate but easy for making holes?
Thanks
Logitech MK220 Colemak DH
Offline domoaligato
« Reply #3875 on: Tue, 27 August 2013, 12:06:54 »
KMAC2 .exe is supposed to support all Kmac devices even the kmac tenkey pad
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #3876 on: Tue, 27 August 2013, 22:32:37 »
Snip
« Last Edit: Tue, 27 August 2013, 22:34:39 by MOZ »
Offline BlueBär
« Reply #3877 on: Wed, 28 August 2013, 09:40:14 »
Thanks
Search for somebody who does laser cutting (theres also some people in the professional services directory), aluminium is a common material for plates and they can get you one made.
Offline GeeGee
  • ㅈ ㅈ
« Reply #3878 on: Wed, 28 August 2013, 14:28:28 »
Where can you get an LZSE?
Ducky Shine 2 with Blues
Poker 2 with Reds
KMAC Korean Custom with Clears
ReΛlforce 87u 55g
456GT
« Reply #3879 on: Wed, 28 August 2013, 14:29:22 »
From people who own one.
Offline GeeGee
  • ㅈ ㅈ
« Reply #3880 on: Wed, 28 August 2013, 14:31:25 »
Are you serious :O
I so didn't think of that.
Poker 2 with Reds
ReΛlforce 87u 55g
456GT
Offline esoomenona
  • Gnillort?
« Reply #3881 on: Wed, 28 August 2013, 14:36:25 »
Yes, he is serious. They were a limited run. Only those who have one and are willing to let it go will have what you seek.
Offline GeeGee
  • ㅈ ㅈ
« Reply #3882 on: Wed, 28 August 2013, 14:41:42 »
Sarcasm.
I knew that. What I wanted to know is if anyone is 'know' for selling them or willing to let it go.
Poker 2 with Reds
ReΛlforce 87u 55g
456GT
Offline esoomenona
  • Gnillort?
« Reply #3883 on: Wed, 28 August 2013, 15:04:45 »
Your best bet in that case is to start a WTB thread in the Classifieds.
Offline GeeGee
  • ㅈ ㅈ
« Reply #3884 on: Wed, 28 August 2013, 15:14:18 »
Yeah I will do that in a couple of days.
Thanks for your help guys :)!
Poker 2 with Reds
ReΛlforce 87u 55g
456GT
Offline CalmB4tehPwn
  • Demon of the Fall
« Reply #3885 on: Wed, 28 August 2013, 16:05:08 »
What is Cherry's MOQ for switches? I keep hearing it's stupid crazy high, but how many is stupid crazy? I'd be curious enough to see if there's a demand for something like Clears or Greens to set up a GB for it, but if it's like 2 millions switches, then we can just.. not do that.
"I seek a great warrior" - Luke Skywalker
"Great Warrior, Hmm? War does not make one great." - Master Jedi Yoda
« Reply #3886 on: Wed, 28 August 2013, 16:07:03 »
Well there's already a constantly running switch GB on deskthority, not sure about the MOQ though.
Offline Dubsgalore
« Reply #3887 on: Wed, 28 August 2013, 16:07:47 »
pretty sure it's 100k+
« Reply #3888 on: Wed, 28 August 2013, 16:37:45 »
5000
Offline Topre
« Reply #3889 on: Wed, 28 August 2013, 16:40:30 »
It depends on your supplier. There one supplier that has a MOQ of 800, for 24.51¢ United States cents each.
Offline domoaligato
« Reply #3890 on: Wed, 28 August 2013, 16:59:17 »
here is a example at mouser
http://www.mouser.com/ProductDetail/Cherry-Electrical/MX1A-11NW/?qs=sGAEpiMZZMsqIr59i2oRck%252brJF20sIm2GQvQAXuvA88%3d
moq is 1 but the more you order the cheaper it gets... i.e. groupbuy
        1:   $0.98
    50:   $0.75
    100:   $0.641
    250:   $0.497
    500:   $0.468
the confusion based on the very high number is because of this page.
http://deskthority.net/wiki/Cherry_MX_Ergo_Clear
"On request, Cherry has stated that they would actually produce Ergo Clears in a slider-colour of choice, provided that they get an order of at least 750,000 switches. Among keyboard enthusiasts there is a controversy, whether such switches should be called "beiges", "pinks" or "violets"."
edit: the above prices change based on switch color and mount type.
« Reply #3891 on: Wed, 28 August 2013, 17:00:19 »
For which switch type and what kind of lead time? $0.24/switch is a steal.
Offline domoaligato
« Reply #3892 on: Wed, 28 August 2013, 17:01:17 »
Or is he saying $24.51 each :D
Offline Topre
« Reply #3893 on: Wed, 28 August 2013, 17:12:54 »
Cherry MX Blacks and Blues, plate mounted. 800 MOQ, $0.2541 USD per switch.
It drops down to about $0.15 each when you order 100,000. These prices are still not directly from Cherry. I believe the normal MOQ is 8000.
Offline domoaligato
« Reply #3894 on: Wed, 28 August 2013, 17:31:19 »
again the question is where are you seeing this price?
Offline Topre
« Reply #3895 on: Wed, 28 August 2013, 17:42:27 »
From a catalog that I will not post. Look around and you should be able to find a similar or the same price. There are other switches available, but it doesn't seem like the MOQ is as low as 800.
Offline domoaligato
« Reply #3896 on: Wed, 28 August 2013, 18:15:31 »
$0.49 is the cheapest before shipping @ 1000 ordered for plate mounted mx blacks.
http://www.eciaauthorized.com/search?pn=MX1A-11NN
$0.46 is the cheapest before shipping @ 1000 ordered for pcb mounted mx blacks.
http://www.eciaauthorized.com/search?pn=MX1A-11NW
If you can get prices that low then please arrange a groupbuy to compete with 7bit
7bit wants .65 euro each
  • Demon of the Fall
« Reply #3897 on: Wed, 28 August 2013, 18:25:41 »
So you're saying Cherry's MOQ is 8,000? Because that's not so bad. I can see why they would want upwards of a million to make a new stem/spring mix, but the demand is clearly there so they'll probably make it on their own anyways, eventually.
I am very very interested now that I'm actually starting to desolder. I have a mighty need for clears.
  • Demon of the Fall
« Reply #3898 on: Wed, 28 August 2013, 18:38:02 »
Okay, another question. Sorry for spamming this thread.
Mouser has clears listed here
http://www.mouser.com/ProductDetail/Cherry-Electrical/MX1A-C1NN/?qs=sGAEpiMZZMt3hSNP33T8%2fE6DQc5dkbQB7kwsFyn%2feDc%3d
But is says termination type "lug" as opposed to "solder" which some of the others have listed. Is this saying they're made to be used with a wired board, as opposed to PCB? Can we still solder lug terminations? Or am I completely off base?
Also, that page says 83 cents at 500 units but their catalog says differently. I figure we'd probably get significantly more than 500 sold in a GB anyways, so I'd ask for an updated extended pricing.
TL:DR
these things I linked. Those things for purchase? Or I want other things?
« Last Edit: Wed, 28 August 2013, 18:47:38 by CalmB4tehPwn »
Offline Topre
« Reply #3899 on: Wed, 28 August 2013, 18:43:42 »
You are looking at redistributors, which will cost more because they themselves want to make a profit. The redistributors get their switches from a supplier or from Cherry.
I am also currently not interested in hosting a groupbuy or competing with 7bit because I may not have the time for it.
I am not sure on the MOQ directly from Cherry, but I assume it's around 8000 because that's what most suppliers seem to be requesting.
