Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6230731 times)
Offline heedpantsnow
  • Old enough to know better
« Reply #6250 on: Fri, 14 February 2014, 13:45:24 »
Yes, you should be able to reuse your parts. And yes, you should use the Poker layout because that's what the Poker PCB supports. The universal is better for the GH60 which has multiple layout options.
Thanks, I really appreciate the help.
I'm back.
Offline JPG
  • Model F is my new passion!
« Reply #6251 on: Fri, 14 February 2014, 14:57:47 »
Hey anyone know what switch is used in this keyboard (IBM POS keyboard)?
54465-0
« Reply #6252 on: Fri, 14 February 2014, 15:00:35 »
Parak tells me it's buckling rubber sleeve.
<CPTBadAss> IBM Heads: http://geekhack.org/index.php?topic=40501.msg1227923#msg1227923
<sadbot> Title: Simple Questions, Simple Answers (FAQ in the OP) (at geekhack.org)
<CPTBadAss> what switch is in this?
<Parak> buckling rubber sleeve
<CPTBadAss> thank you parak
« Reply #6253 on: Fri, 14 February 2014, 16:22:53 »
What do most people use for a spacebar (since cherry spacebars have offset center stems) when using white on black cherry double shots?
« Reply #6254 on: Fri, 14 February 2014, 16:41:56 »
SP DCS-profile.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #6255 on: Fri, 14 February 2014, 16:52:04 »
I didn't know that Cherry spacebars were off-center. Is there an image that shows the difference? Are there common fixes on e.g. modern custom PCB's?
Offline Zeal
    • Zeal Generation Inc.
« Reply #6256 on: Fri, 14 February 2014, 16:57:09 »
Here's a pretty obvious off-center space bar on a Cherry G80-3000 board:
Offline Pacifist
  • on hiatus
« Reply #6257 on: Fri, 14 February 2014, 17:13:04 »
Cherry off center spacing is weird. My 11900 has an off center 6x spacebar, and even when I found a 6x bar from a different board that had center and off center placings, it still didn't match up :-\
  • Cherry Peasant
  • keycult.com
« Reply #6258 on: Fri, 14 February 2014, 17:15:08 »
Are 7x Cherry spacebars similarly off-center?
« Reply #6259 on: Fri, 14 February 2014, 17:16:09 »
You can try stem modding it. I've also used the sticky tack used to hang posters to adjust spacebars. But that would mean that the stem that goes with the switch needs to be centered right.
I think so. Check this out (from the DT Wiki)
6.25 units space bar with mounts for Cherry and Filco. Below are the Cherry G80-3000 stabilisers.
So the Filco is centered and Cherry is off-centered it seems.
« Last Edit: Fri, 14 February 2014, 17:22:01 by CPTBadAss »
Offline Pacifist
  • on hiatus
« Reply #6260 on: Fri, 14 February 2014, 17:18:24 »
I read somewhere here that cherry 7x is centered
« Reply #6261 on: Fri, 14 February 2014, 18:57:53 »
7x Cherry is definitely centered.
Offline Pacifist
  • on hiatus
« Reply #6262 on: Sat, 15 February 2014, 01:04:46 »
Anybody know if this is a hall effect or no?
« Reply #6263 on: Sat, 15 February 2014, 02:55:53 »
It's hard to tell from that picture but hall effect isn't a bad guess in my opinion.
Offline yasuo
  • spanengan puyeng newbie
« Reply #6264 on: Sat, 15 February 2014, 06:13:49 »
what is shape DSA is distrub?especially modiefer like backspace looks vertical
Logitech MK220 Colemak DH
« Reply #6265 on: Sat, 15 February 2014, 07:04:01 »
Check out the pictures of the DSA caps in this review.
Offline Norz
« Reply #6266 on: Sat, 15 February 2014, 16:27:23 »
Is it hard to find Filco ISO 88 keys (TKL) with MX Red ?
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline Norz
« Reply #6268 on: Sat, 15 February 2014, 16:46:49 »
Keyboardco
http://www.keyboardco.com/keyboard/uk-filco-ninja-majestouch-2-tenkeyless-nkr-soft-linear-action-keyboard.asp
Ah interesting thank you !
2 questions
1) I'm still new at the fancy keyboards thing: No particular reason I couldn't use my WASD keyboard keycaps on this one right ?
2) Ive seen different amazing Filco on their JP website, can you get them in ISO 88 ? or is the one you linked all there is to get (easily) in Europe ?
- Edit
oh and 3) how do you think it scales quality wise vs WASD v2 keyboards ?
« Last Edit: Sat, 15 February 2014, 16:50:10 by Norz »
« Reply #6269 on: Sat, 15 February 2014, 17:25:41 »
1) Yes you can use WASD keycaps on your Filco as long as it's ISO.
2) I think keyboardco.com is the best place to get the ISO 88 layout. I think the Filco/Diatec site mainly sells JP layout.
3) Filco is my favorite stock keyboard. I prefer Filcos above all other stock keyboards. I've heard WASD v2's are nice though.
  • Cherry Peasant
  • keycult.com
« Reply #6270 on: Sun, 16 February 2014, 09:01:32 »
Is there any English documentation for the ps2avrU firmware? (Sprit's PCBs ship with this firmware.)
Okay! I've had some success with hardware key remapping of Sprit's FaceW 60% PCB. I haven't managed to reflash the firmware though, which means that certain clever stuff like arbitrary function layers and dual-action keys aren't possible (I don't think), but this is a huge step up from not being able to to type a backtick yesterday.
The following technique is taken from this page. It uses a plain-text buffer as a primitive command prompt.
Steps to remap keys at the hardware level on a FaceW PCB:
Step 0. Unplug the USB cable from keyboard you're remapping to your computer.
Step 1. Open Notepad (Windows) or TextEdit (OS X, click "New Document").
Step 2. On the keyboard you're remapping, hold down M and plug the USB cable back in. The following should be printed in your text buffer:
Code: [Select]
ps2avrU
select mode
1:Key Mapping
2:Macro
3:Exit
4:boot mapper
Input Command Number:
Step 3. We're only going to be dealing with Key Mapping (the only thing I've figured out), so enter the code for Key Mapping. (In my case, this was 1, but the site occasionally shows different numbers, so YMMV.) Something like the following will be displayed:
Code: [Select]
Key Mapper
1: Change Layer
2: Select Key - input keycode
3: Save and Exit
4: Exit without Saving
6: Back
9: Reset to Default (Current Layer)
A quick run down of the important options: 1 will change the function layer you're mapping (the default is the normal layer) and 2 will allow you to remap a key in your current layer. The rest are self-explanatory.
Step 4. Let's remap a key (CapsLock to L-Ctrl). Enter 2 and you'll be prompted to press the key you want to remap. Press CapsLock. You'll then be prompted to enter the 3-digit key code you want to remap it to. Using this spreadsheet, identify the correct 3-digit code. In our case, L-Ctrl is 103.
Step 5. You're now back in the menu from Step 3. Enter 3 to Save and Exit.
Step 6. Unplug your keyboard, plug it back it, and verify that the remapping was successful.
If you learn more about this process, please let me know and I'll add it to this post. Thanks!
Offline Rena
« Reply #6271 on: Sun, 16 February 2014, 09:59:44 »
How much would one pay for a leopold FC660M with MX clears? I'm looking at it on qtan and it's about $140 shipped, but that seems like an awful lot just for a minimal keyboard like that with Cherry switches. It has PBT keycaps at least, but the FC660C with topres is only slightly more than that (not that I need another topre board).
Also, does anyone know if those doubleshot PBT vortex keycaps that geek feng is selling on ebay (http://www.ebay.com/itm/Vortex-Green-Double-Shot-Thick-PBT-104-Keyset-Cherry-MX-Keycaps-/231099852343?&_trksid=p2056016.l4276) are worth it, or if they could fit in a filco MJ2?
Offline Pacifist
  • on hiatus
« Reply #6272 on: Sun, 16 February 2014, 13:10:10 »
Next time, please post in the Price Check thread: http://geekhack.org/index.php?topic=31779.0;topicseen
I've seen 660M with clears go for $105 before, but it was used. For new I'd say $120 is a good price. Those vortex ones should fit on filco no problems
Offline Norz
« Reply #6273 on: Sun, 16 February 2014, 13:27:22 »
Is there a consensus to say that as far as MX keyboards go, Filco Majestouch 2 are as good as it gets in the "pretty good but not ultra fancy either" category ?
« Reply #6274 on: Sun, 16 February 2014, 13:31:42 »
Nope.
A lot of people think Filcos are the best. A lot of people think there are other readily available MX keyboards that are better, like Duckies. A lot of people think older MX keyboards like the Cherry G80 series are better than any readily available keyboards. It really comes down to personal preference.
Offline Rena
« Reply #6275 on: Sun, 16 February 2014, 13:35:27 »
Oh okay, I'll use that thread next time.
On qtan the price is $120, but shipping included it ends up being $140. I'd rather not buy used either, so it seems like this is my only option because I haven't found any listings for this particular board with clears.
Offline Pacifist
  • on hiatus
« Reply #6276 on: Sun, 16 February 2014, 14:22:59 »
The M with Clears is a bit rare. Fengs prices are pretty fair
Offline Pacifist
  • on hiatus
« Last Edit: Sun, 16 February 2014, 14:58:28 by Pacifist »
« Reply #6278 on: Sun, 16 February 2014, 14:59:29 »
Anyone know if the caps are DS ABS or POM?
http://www.ebay.com/itm/Cherry-MY-7000-POS-Credit-Card-Swipe-Keyboard-Black-G81-7000LPDUS-2-/121258728548?pt=PCA_Mice_Trackballs&hash=item1c3b955c64
G81-7000LPDUS-2
Please don't double post.
And it should be Lasered POM. The L after 7000 means it's lasered. Then Dorkvader talked about this a couple of pages back; if it's a black keyboard, it's probably lasered POM. If white, it's probably lasered PBT.
Offline Euf0ria
« Reply #6279 on: Mon, 17 February 2014, 07:13:30 »
What is the maximum number of switches you can use in a keyboard build if you are using a Teensy 2.0 with no additional add on controllers and you want two leds for indication of layer/modifiers.
All your base are belong to us
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #6280 on: Mon, 17 February 2014, 07:17:12 »
There are 25 pins available, two for LED, leaves 23, 11*12 = 132 max.
Offline Norz
« Reply #6281 on: Mon, 17 February 2014, 13:08:23 »
Is there some sort of "ISO" group of people on this forum for things such as "Interest check" "group buys" etc ? or is all the forum about ANSI keyboards ?
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #6282 on: Mon, 17 February 2014, 13:10:23 »
Def not.  There is a lot of people here that use ISO layout among others.  However I believe this forum has a large amount of US users hence the bias toward ISO.  From my experience though www.deskthority.net seems to have a larger portion of users in Europe so I would believe there would be more supporters of ISO there.  However, I could also be very wrong here as well.
« Reply #6283 on: Mon, 17 February 2014, 13:11:03 »
Most of the GBs for keycaps on the forum in general have an ISO option.
I'd agree with this.
Offline Norz
« Reply #6284 on: Mon, 17 February 2014, 13:12:01 »
I see. And I didn't know about this site, nice.
Thanks
Offline gh_pp
« Reply #6285 on: Mon, 17 February 2014, 13:56:39 »
What's the easiest (no desoldering/soldering) or economic way (off the shelf) to obtain a lubed ergo-clear 87 TKL?
I've a WTB thread up but looking for any options that I might have missed.
I wouldn't mind the hassle if I can get a fully customized phantom, but it seems like I can get everything sourced except the WFD/Beast 1.25 plate. They are not being produced anymore and chance of getting one from classified isn't high.
Is there a solid quality (QFR quality is good enough for me) PCB mounted TKL?
From my research POKER I / POKER X is pcb mounted, but if I gone through all the trouble and ended up liking it (lubed ergo-clear) I'll be even more pressed to find a TKL. (Of course, if I don’t like it, I can just resell it like my other boards).
I have tried BS/black alps/peerless, mx green/blue/clear/brown/red/black, 45g/55g and have a variable type-s in the mail.
I think this will be the last switch type that I want to try (I like light, bouncy tactile switch and I'm not going to miss the other rare heavier switch like mx-white or grey)
QFR brown x2, Realforce 45G, Type-S, Keycool 22 blue
Previous keyboards: 55G, IBM Model M, Dell AT101W, Fujitsu FKB4725, G80-3000 clear, QFS green, QFS blue
[WTB] Custom keyboard build
Offline Pacifist
  • on hiatus
« Reply #6286 on: Mon, 17 February 2014, 13:59:26 »
You won't get off the shelf ergo clear soon. I am not aware of any PCB mounted TKL on the market right now, but you can get a phantom and just PCB mount the switches and have a case cut
« Reply #6287 on: Mon, 17 February 2014, 14:02:06 »
G80-1800 comes close. And Phantom PCB doesn't have holes for PCB-mounting the switches.
« Reply #6288 on: Mon, 17 February 2014, 14:02:58 »
I believe someone was having some plates made not sure what happened with that, I'm hoping mechanicalkeyboards.com will have some plates for phantoms eventually.
« Reply #6289 on: Mon, 17 February 2014, 14:19:51 »
Hm, did you know that some people will do mods for free? You could buy a standard TKL that you do like, for example a Filco or Ducky, and the needed switches/springs. Then send it to one of the modders. Kmiller8 does it for free. There might be some others as well.
I'm not sure about a quality PCB-mounted TKL. Check out Ivan's post for more info.
« Reply #6290 on: Mon, 17 February 2014, 14:20:55 »
I think kmiller decided he was charging now, the free thing was a trial run.
« Reply #6291 on: Mon, 17 February 2014, 14:31:18 »
Hm, did you know that some people will do mods for free?  Kmiller8 does it for free. There might be some others as well.
I didn't know that. I just found the post in his classifieds ad.
Offline Melvang
« Reply #6292 on: Mon, 17 February 2014, 14:43:46 »
As far as buying ergo-clears your best bet is buy some off the classifieds if you can find them.  The only other option is to buy stock clears and mod them yourself.  Cherry has stated they would do a run of ergo-clears but the MOQ was 10,000 switches if I remember correctly.  This was at least 6 months ago the last time I remember someone communicating with Cherry directly on something like this.
Offline Pacifist
  • on hiatus
« Reply #6293 on: Mon, 17 February 2014, 14:45:19 »
Wasn't the MOQ 750,000? Or am I mistaken?
« Reply #6294 on: Mon, 17 February 2014, 14:46:00 »
DT wiki says 750,000 for MOQ but perhaps that was due to stem color as well http://deskthority.net/wiki/Cherry_MX_Ergo_Clear
Offline Melvang
« Reply #6295 on: Mon, 17 February 2014, 14:48:24 »
I stand corrected.
« Reply #6296 on: Mon, 17 February 2014, 14:51:46 »
Ergo clears are nothing but hype. This is coming from someone who has tried them, and hated them. Everyone wants ergo clears because they are so glorified as the ultimate switch, probably because they AREN'T a "stock" switch, and take some effort to modify/acquire.
Stock Clears 2014
« Reply #6297 on: Mon, 17 February 2014, 14:52:32 »
Stock Clears 2014
^^ I concur, stock clears FTW!!
Offline Melvang
« Reply #6298 on: Mon, 17 February 2014, 15:00:42 »
And again another personal preference being marketed as the gospel.  There really is not best or worst switch with the possible exception to cheap rubber domes.  Try the stock clears, if you find them two stiff or would like to feel a bit more of the tactile bump then go ahead and mod them.
Offline gh_pp
« Reply #6299 on: Mon, 17 February 2014, 15:04:19 »
Thanks for all the replies, BTW CPTBadAss I got your PM thanks for the heads up.
jdcarpe is definitely right about the allure of non-standard switches (human nature wanting something you can't have, not easily obtainable :)
However what makes me want to try ergo-clear so bad is this video
It looks so smooth and it thocks like a topre but it also debounces fast like cherry!
I've tried stock clears but they're not 100% of what I'm looking for.
Maybe lubed mx-brown will be as good but there is really no easy way to find out.
So yes now that I know of another option I'll definitely pm those folks to see who can help me mod one.
Too bad WFD is swarmed with real-life [tm], his craftsmanship seems top notch from the videos I watched.
« Last Edit: Mon, 17 February 2014, 15:06:39 by gh_pp »
