Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6229045 times)
Offline SeeThruHead
« Reply #7300 on: Wed, 16 April 2014, 17:49:04 »
What options are available for someone who would like to build a 75% board. Like the choc mini with inline function keys. Would love to have a full aluminum case option.
 Painted QFR          Poker 2
Offline Pacifist
  • on hiatus
« Reply #7301 on: Wed, 16 April 2014, 17:51:18 »
full alum only the LZ Mini, and even still, the full metal case is almost impossible to find
Offline BlueBär
« Reply #7302 on: Wed, 16 April 2014, 17:53:54 »
As for aluminium cases only the MX Mini comes to my mind. If you are saying "build" I'm assuming you mean you want a custom keyboard? Sprit offers a 75% PCB and sooner or later there might be a GH75.
Offline SeeThruHead
« Reply #7303 on: Wed, 16 April 2014, 18:00:41 »
I didn't know sprit offered a custom 75% pcb thanks. The case can always come later..
 Painted QFR          Poker 2
Offline BlueBär
« Reply #7304 on: Wed, 16 April 2014, 18:08:55 »
Sprit might also offer metal cases for his 75% (if not he offers acrylic cases), but I'm not sure what the status of the metal cases is.
Offline Pacifist
  • on hiatus
« Reply #7305 on: Wed, 16 April 2014, 18:17:31 »
status of metal in general is really far off in the future, and it doesnt look like sprit likes 75%s
Offline SeeThruHead
« Reply #7306 on: Wed, 16 April 2014, 18:24:59 »
Is there a plate available?
 Painted QFR          Poker 2
Offline BlueBär
« Reply #7307 on: Wed, 16 April 2014, 18:27:09 »
There are pics of acrylic plates. Please ask Sprit himself about the details - he probably knows more about it than we do ;)
Offline Smasher816
  • HHKB Master
« Reply #7308 on: Wed, 16 April 2014, 18:41:52 »
What's the best way to get blank PBT caps for a realforce? (Similar to the blank HHKB versions).
« Reply #7309 on: Wed, 16 April 2014, 18:44:54 »
Classifieds I think at this point. I could be wrong though.
« Reply #7310 on: Wed, 16 April 2014, 19:02:06 »
That seems correct to me.
Offline intelli78
« Reply #7311 on: Thu, 17 April 2014, 12:50:01 »
What size is the right shift on this?
« Reply #7312 on: Thu, 17 April 2014, 12:51:38 »
That's a 2x shift from the CCnG Tsangan kit, also called an 1800 shift.
Offline intelli78
« Reply #7313 on: Thu, 17 April 2014, 12:52:54 »
Nice! Know of anywhere, off the top of your head, to find 2x shifts readily available for sale?
Offline Dubsgalore
« Reply #7314 on: Thu, 17 April 2014, 12:52:58 »
I think it's a 1.75x shift right? normal right shift is 2.75x, and because he has the 1x on the right, that means the short shift is 1.75x
Offline ideus
  • Björkö.
« Reply #7315 on: Thu, 17 April 2014, 13:28:09 »
Right shift in a Tsangan kit is 1.75 units.
« Reply #7316 on: Thu, 17 April 2014, 14:41:15 »
Yeah that makes sense. I always get it confused since I always call it an 1800, Tsangan, or "short right" shift
Just that shift? Not really easy to find on it's own. You'll need to find a Tsangan kit. SP might have one I don't know about though.
« Reply #7317 on: Thu, 17 April 2014, 14:52:57 »
I had some CCnG crap bag caps.....somewhere.....
Offline intelli78
« Reply #7318 on: Thu, 17 April 2014, 15:07:25 »
Thank you, guys!
I looked on the SP website and found a very limited selection of Row 4 1.75 PBT shifts:
302488 DCS - 1.75X ROW 4 - BLACK (NDY) PBT
210702 DCS - 1.75X ROW 4 - MEDIUM GRAY (GEC) PBT
These will tide me over for now.
« Reply #7319 on: Thu, 17 April 2014, 15:23:39 »
Man I'm really off my game. Forgot SP sells loose caps. I meant I wasn't sure pimp my keyboards had a set. Oh well, it worked out XD
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #7320 on: Thu, 17 April 2014, 15:40:39 »
If you had just taken apart a model M and found the barrel plate to be cracked half way down one of the ribs between the rows in the alpha numeric block, would you still bolt mod the broken plate, or wait until a replacement came in?
« Reply #7321 on: Thu, 17 April 2014, 16:12:49 »
Wait for a replacement.
Offline Melvang
« Reply #7322 on: Thu, 17 April 2014, 16:15:07 »
I was thinking of doing the mod anyway just so I know what I am doing with a new part when it comes in.  Would this be good practice?
« Reply #7323 on: Thu, 17 April 2014, 16:29:51 »
Good practice but I think you're making unnecessary work for yourself.
Offline intelli78
« Reply #7324 on: Thu, 17 April 2014, 16:31:42 »
When making ergo-clears from new switches, do you guys lube them right away or let them have a "break-in" period first? I imagine that any breaking-in would take a lot longer if they get lubed up right away.
Offline Melvang
« Reply #7325 on: Thu, 17 April 2014, 16:38:57 »
The ones I have made were from used switches but I would suggest using the clears with stock springs for a while before modding.  Adding the lube will greatly increase the breakin time on the sides of the slider but should have zero effect on the part that actually causes the tactile click which is also what causes the sticking.  I say go ahead and lube lightly only on the sides of the slider.
Offline laserpanda
« Reply #7326 on: Thu, 17 April 2014, 17:00:04 »
I'm trying to buy a 122 from Unicomp, but have no idea which version I should get.
They've got 6 separate versions now. PC, Terminal, and Emulator versions of both the 5250 and 3270.
What's the difference between them all?
Ideally I'd like a PS/2 version that allows me to use all the extra keys in W7 without having to jump through a bunch of hoops.
« Last Edit: Thu, 17 April 2014, 17:04:15 by laserpanda »
Offline Pacifist
  • on hiatus
« Reply #7327 on: Thu, 17 April 2014, 19:17:14 »
Swapped the spacebar on my keycool with costar stabs and blacks
the spacebar now has tactility :confused:
I reseated the bar and it still has tactility and is superlould
any suggestions? Would lube help?
could it be the extra mounting holes rubbing against something?
edit: wtf....lubed it, still like this.
edit2: ended up putting the stock bar back on
« Last Edit: Thu, 17 April 2014, 19:26:41 by Pacifist »
Offline BlueBär
« Reply #7328 on: Fri, 18 April 2014, 06:53:29 »
Check if the stabilizer wire hits the spacebar.
« Reply #7329 on: Fri, 18 April 2014, 08:10:23 »
There's only two 122 versions from Unicomp. One has USB and the other has PS/2. Neither has a windows key. I think to satisfy most of your wants, you'll want to check out the Classic 104 PS/2. If you look carefully, there's 101 and 104. 101 means its the classic Model M layout which has no winkey. 104 means it's got the windows key so you can use your Windows 7 setup with no issues.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #7330 on: Fri, 18 April 2014, 11:54:00 »
Where can I get replacement Topre springs? The kind that you put under the cloud of boobs, not the spacebar spring.
Offline intelli78
« Reply #7331 on: Fri, 18 April 2014, 13:41:24 »
As far as I know, there's no place to get spare parts. You have to use a donor board.
« Reply #7332 on: Fri, 18 April 2014, 14:11:45 »
Did you lose one? Sometimes they will nest in each other and you'll think it's one spring but two.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #7333 on: Fri, 18 April 2014, 14:14:03 »
I managed to ruin two of mine...
« Reply #7334 on: Fri, 18 April 2014, 14:15:14 »
Offline epzy
  • HHKB Fiend
  • ded
« Reply #7335 on: Fri, 18 April 2014, 14:40:39 »
Looks like I'm royally screwed then, have fun in my closet Mr. Realforce. :/
Offline intelli78
« Reply #7336 on: Fri, 18 April 2014, 14:41:57 »
Swap them with keys you'll never use, like Pause/Scroll Lock.
« Reply #7337 on: Fri, 18 April 2014, 14:43:13 »
Did you try emailing EK or Topre? Or putting up a WTB? A quick search yields this classifieds listing from norbauer who was selling Topre parts. Try PMing him to see if he's still got them even though the listing is old?
This too.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #7338 on: Fri, 18 April 2014, 14:46:13 »
I don't like having a incomplete board. I'll PM that guy CPT, thanks. I have put up a WTB, but I have not e-mailed EK / Topre / Keyboardco yet.
Offline intelli78
« Reply #7339 on: Fri, 18 April 2014, 16:06:42 »
What Cherry boards have an MX-compatible 7x PBT space bar?
Offline Pacifist
  • on hiatus
« Reply #7340 on: Fri, 18 April 2014, 16:09:52 »
11800
Offline intelli78
« Reply #7341 on: Fri, 18 April 2014, 16:12:26 »
11800
Thanks. Is that one board that has it, or the only one?
Offline Pacifist
  • on hiatus
« Reply #7342 on: Fri, 18 April 2014, 16:19:04 »
11800
one
« Reply #7343 on: Fri, 18 April 2014, 16:22:07 »
11800
That's one board. You can check this list but I think there might be more boards than that.
Offline intelli78
« Reply #7344 on: Fri, 18 April 2014, 16:25:09 »
Thanks guys. It doesn't look like that list mentions the spacebar material, only the size. Is there any way to know which of the 7x boards have PBT spacebar, aside from asking and Googling? I want to track one down, so the more model numbers I have, the better.
Offline Pacifist
  • on hiatus
« Reply #7345 on: Fri, 18 April 2014, 16:31:22 »
11800 is probally the easiest way to get one, as all the others are really rare and expensive
2nd would be a 3000
Offline intelli78
« Reply #7346 on: Fri, 18 April 2014, 16:34:54 »
2nd would be a 3000
Gotcha, that's helpful. Thanks.
Offline laserpanda
« Reply #7347 on: Fri, 18 April 2014, 17:12:02 »
There's 6 if you use the customiser, which I am, as I want the Swedish/Finnish layout.
There's clearly a windows key on the PC/122 at least.
https://s-media-cache-ec0.pinimg.com/736x/fd/4d/b9/fd4db9cc522a0341e54c3d1033c8ea65.jpg
bottom left
What I'm concerned with is that some models apparently just treat the extra function keys as Shift + F1-F12, rather than giving them unique scancodes, which I want to avoid.
« Last Edit: Fri, 18 April 2014, 17:19:45 by laserpanda »
« Reply #7348 on: Fri, 18 April 2014, 17:34:34 »
2nd would be a 3000
Are you sure? There were boards with PBT caps that had ABS spacebars. The spacebars were marked as PBT but they were still ABS. I should've clarified that earlier. Was mainly looking at the 7x length part.
bottom left
I don't know personally so I asked some of the IBMHeads in the IRC channel. Thanks dfj and daemonraccoon for the help.
dfj's thread: http://geekhack.org/index.php?topic=10985.msg212193#msg212193
<dfj> [22:19:09] so - if you get teh one, it is setup to go into the 'emulator' mode, so it generates shift+blah strokes for the extra keys, alternately, if you get the other it generates mode-3 unique scnacodes for each key... however this doesn't work with windows.
<dfj> [22:20:05] so - a soarer controller or similar will be needed to convert from teh pseudo-PS/2 of mode 3 to USB, at which point windows will see the f13-f24 and the rest of teh keys as whatever you set them to.
<dfj> [22:20:23] yeah - gh'ers actually got it added to linux. :p
<dfj> [22:20:57] morningsong, way back when.
<dfj> [22:21:37] for linux - mebbe - but for a windows machine, you want to use a 122 with a soarerverter, even if you purchase a unicomp.
<daemonraccoon> [22:20:00] AT mode-3 is not windows friendly, but loonix supports it if you know the magic kernel config
<CPTBadAss> [22:21:51] thank you dfj and daemonraccoon
Offline intelli78
« Reply #7349 on: Fri, 18 April 2014, 17:40:51 »
2nd would be a 3000
Hmm, well at the very least, are all (unmodified) 11800 boards guaranteed to have a PBT bar? There are quite a few on eBay.
