Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6228205 times)
Offline Pacifist
  • on hiatus
« Reply #7250 on: Sat, 12 April 2014, 14:02:52 »
Where can I buy a LZ MX Mini?
 unassembled and with a full metal case like dans:  http://dangwang.wordpress.com/2012/11/16/420-reviews-lz-mx-mini-by-lifezone/
« Last Edit: Sat, 12 April 2014, 14:08:07 by Pacifist »
Offline Zeal
    • Zeal Generation Inc.
Offline Pacifist
  • on hiatus
« Reply #7253 on: Sat, 12 April 2014, 14:22:31 »
http://geekhack.org/index.php?topic=33128.0
I should clarify
Where can I get one unassembled and with a full metal case like dans:  http://dangwang.wordpress.com/2012/11/16/420-reviews-lz-mx-mini-by-lifezone/
AFAIK, there isnt one for sale in any of the classifieds at the moment. Since it was made by Redline/Lifezone, you could try contacting one of them through PMs, email, or on their website.
Offline elton5354
« Reply #7254 on: Sat, 12 April 2014, 18:12:27 »
Where can I find legends to print to fit perfectly on relegendable key caps?
Offline ajx
« Reply #7255 on: Sun, 13 April 2014, 01:23:42 »
How do you find about KBT Pure pro layout?
I am thinking buying it because i cannot use my Poker 2 anymore, not dedicated arrows make me sick lol
But Pure pro has very strange layout to me:
- small shift keys
- small backspace
- small spacebar
last question: my former Pure backlit keyboard had wearing off keys issue
on some keys, keys coating is wearing off
did Vortex change anything with KBT Pure Pro?
Offline BlueBär
« Reply #7256 on: Sun, 13 April 2014, 05:08:59 »
Would giving you the dimensions help you?
1. How do you find about KBT Pure pro layout?
- small shift keys
- small backspace
- small spacebar
2. last question: my former Pure backlit keyboard had wearing off keys issue
1. I think the Pure Pro layout is terrible, but that is just my personal opinion. It has just too many non-standard sized keys and feels cramped to me. Some people like it though.
2. I don't think they changed anything in terms of keycaps.
Offline combataran
« Reply #7257 on: Sun, 13 April 2014, 11:30:14 »
How do I properly remove the space bar from my RF87U without breaking anything? Is there a video that I can use for reference?
Cherry G80-1000HFD | CM Storm Spawn | Keypuller.com - Key Caps News & Database
« Reply #7258 on: Sun, 13 April 2014, 11:32:25 »
Pull straight up on both sides of the spacebar. It's scary but I think that's how you do it.
Offline ajx
« Reply #7259 on: Sun, 13 April 2014, 11:59:02 »
- small shift keys
- small backspace
- small spacebar
Thanks me neither i dont really like layout according the described picture...
I am stuck, Poker 2 is pain in the ass to use as well with no real dedicated arrows and i find PBT keycaps quite rough as feeling, definitely i dislike
The other 60% are even worse (HHKB yes it could be interesting but too expensive imo, TEX also too expensive, Pure not pro isnt produced anymore
The only one that caught my eyes its Ducky Mini but Nordic layout LOL
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #7260 on: Sun, 13 April 2014, 12:00:18 »
Have you discounted a Leopold FC660M/C?
Offline epzy
  • HHKB Fiend
  • ded
« Reply #7261 on: Sun, 13 April 2014, 12:05:53 »
- small shift keys
- small backspace
- small spacebar
You know Ducky Mini = Poker 2, right? What do you mean by "I find PBT keycaps quite rough as feeling"? If you mean the texture, there are both smooth and rough textured PBT keycaps.
Offline combataran
« Reply #7262 on: Sun, 13 April 2014, 12:32:23 »
How long did it take for your Gas Mask keycaps to arrive from Hong Kong?
Offline Pacifist
  • on hiatus
« Reply #7263 on: Sun, 13 April 2014, 12:34:58 »
1-2 weeks usually
Offline Photoelectric
« Reply #7264 on: Sun, 13 April 2014, 21:06:41 »
Tried searching, but no luck :(  Does anyone know the default combination for a Winkeyless KMAC PCB (1.4) to swap between different LED modes?  I've seen that the Winkey board probably uses Menu + Esc, but the PCB I have is the WKL version with stock firmware--there has to be something that works for it without reprogramming.  I've tried many different combinations so far, unsuccessfully.
Offline zig_ziglar
« Reply #7265 on: Sun, 13 April 2014, 23:14:42 »
Kinesis Advantage: what switches are under those F keys?
Offline combataran
« Reply #7266 on: Sun, 13 April 2014, 23:30:15 »
My RF87U flexes, creaks and squeaks when I apply pressure directly on the marked spot. Is that a defect I should be expecting? I did get it from another GHer after all.
Offline intelli78
« Reply #7267 on: Mon, 14 April 2014, 00:01:53 »
It's normal. I have owned several 87Us and they all had the same problem.
Offline combataran
« Reply #7268 on: Mon, 14 April 2014, 00:07:07 »
And what made you settle with a FC660C?
Offline intelli78
« Reply #7269 on: Mon, 14 April 2014, 00:11:05 »
1. Form factor
2. Build quality
3. Portability
The FC660C is a great keyboard. I still have a 87u-55g, and I use it from time to time, but of all my keyboards, the Leo is my favorite. No one who owns a Leo is settling. :thumb:
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #7270 on: Mon, 14 April 2014, 00:12:56 »
1. Form factor
2. Build quality
3. Portability
Except for aftermarket spacebars.  Hehe just kidding.  I haven't had the priviledge of owning a Leo yet but the layout of the 660 has had me intrigued me for a long time.
Offline combataran
« Reply #7271 on: Mon, 14 April 2014, 00:17:00 »
1. Form factor
2. Build quality
3. Portability
Hmm...I might consider trading my RF for a LeoC, but I still am sceptic all about it's issues with the mini USB connector. Have you had any problems with your LeoC so far?
Offline intelli78
« Reply #7272 on: Mon, 14 April 2014, 00:19:26 »
I have not.
The FC660C is compatible with RF/HHKB spacebars, actually. It is the FC660M that is non-standard. However, the Leo's right shift and modifiers are different than HHKB/RF.
Offline BlueBär
« Reply #7273 on: Mon, 14 April 2014, 04:06:54 »
Looks non-mechanical to me.
Offline Dreamre
    • kbdlife
« Reply #7274 on: Mon, 14 April 2014, 07:59:26 »
Would like to know also D:...
« Reply #7275 on: Mon, 14 April 2014, 11:57:14 »
1. Form factor
2. Build quality
3. Portability
There has been issues w the Leo's mini USB???? I hope not.
Best keyboard ever like he said the form, build, layout, everything.
« Reply #7276 on: Mon, 14 April 2014, 13:38:49 »
1. Form factor
2. Build quality
3. Portability
There are currently issues with the USB. Very similar to the issues with the old RK9Ks.
Offline Bucake
« Reply #7277 on: Mon, 14 April 2014, 16:03:03 »
damn. what kind of usb issues are we talking about? because i've been thinking about getting a FC660C..
and is it possible to swap all keycaps (including the spacebar)? i've read the FC660C uses pad-printed (thin) pbts and i'd rather swap them for sturdier dye-subbed pbts..
Offline Pacifist
  • on hiatus
« Reply #7278 on: Mon, 14 April 2014, 16:06:08 »
the r shift is different
« Reply #7279 on: Mon, 14 April 2014, 16:35:23 »
It fails after a frustratingly small number of plug/unplugs
« Reply #7280 on: Mon, 14 April 2014, 17:05:00 »
Can you direct us to some further information on this?  I've been plugging and unplugging my fc660c near weekly since I got it and it's fine, but I'm curious to hear more about the issue you're talking about.
« Reply #7281 on: Mon, 14 April 2014, 18:23:23 »
I've seen a few people mentioning it, but not recently, so it may be fixed now. I seem to remember a lot of complaining about it on the keyboard's initial release, though. I wouldn't be surprised if it's fixed.
Offline taylordcraig
« Reply #7282 on: Mon, 14 April 2014, 21:19:50 »
Does everyone agree that the Filco is better than the WASD V2?
I'm a little late, but I own both and can say that the build quality is comparable. I honestly have no preference between the two as keyboards.
I can't stand the brown switches on my Filco, though. It sure does look nice on my wall with it's Miami caps and custom cable.
Has anyone installed LED's in a WASD V2? Thinking about adding some flare to the board, if there is a guide or something I missed, I apologize, I only did a brief search and didn't find anything specific on this board.
Snag up a Code keyboard and sell your wasd. ^.~
Offline TBone
« Reply #7283 on: Mon, 14 April 2014, 21:23:06 »
Is there a 60% with exactly the same layout as a Poker II but with Costar stabs?  And is there one with the Windows Key and Menu Key instead of the FN and PN keys?
Offline BlueBär
« Reply #7284 on: Tue, 15 April 2014, 03:38:41 »
Apart from customs (GH60, sprit's PCB), not that I know of.
« Reply #7285 on: Tue, 15 April 2014, 09:52:26 »
If you like the feel of costar stabilizers, you can clip Cherry stabilizers to get a similar feel. I've done this and I think it works.
« Reply #7286 on: Tue, 15 April 2014, 12:46:14 »
What do you mean by "clip"?
What is there to clip on cherry stabs?
Offline BlueBär
« Reply #7287 on: Tue, 15 April 2014, 12:50:01 »
Check my modding guide in my signature.
Offline combataran
« Reply #7288 on: Wed, 16 April 2014, 03:43:09 »
Has anyone's Realforce spacebar stabilizer stems snapped off before?
« Last Edit: Wed, 16 April 2014, 04:18:58 by combataran »
« Reply #7289 on: Wed, 16 April 2014, 06:39:59 »
Ouch, sorry for the progression there lol. Ripster has a bit of help here regarding the spacebar. If you did snap it off, I think Matt3o and others have a model for the Topre stabilizer stems. You can always get one printed up from Shapeways or another company that will do 3D printing and fix it like that.
Offline combataran
« Reply #7290 on: Wed, 16 April 2014, 07:38:41 »
Nah, I didn't break it. I was flipping the spacebar just now, heard an uncomfortably loud snap when I was putting it back in, thought I broke something.
This was when I was planning to remove the caps to do some cleaning. just worried about the spacebar.
« Reply #7291 on: Wed, 16 April 2014, 13:30:51 »
According to metalliqaz, you just need to hit pause if using the stock firmware.
Offline ajx
« Reply #7292 on: Wed, 16 April 2014, 15:53:18 »
I have a doubt about Pure keycaps
http://geekhack.org/index.php?topic=57056.0
There is several versions of Pure on the market:
- Backlit ABS keycaps
- PBT keycaps
- Non backlit ABS keycaps
Fortunately, Amazon sells a Pure that comes with non backlit ABS
I wonder if it comes with standard ABS or just those special backlit ABS
We can add leds on non backlit Pure through modding but i am afraid about the result of backliting on non ABS keycaps
Hope it will just light the lettering
Offline BlueBär
« Reply #7293 on: Wed, 16 April 2014, 15:55:39 »
Non-backlit ABS keycaps should have white letters that will not light up like backlit keycaps.
Offline ajx
« Reply #7294 on: Wed, 16 April 2014, 17:02:32 »
Then adding leds on standard black ABS keycaps with white lettering is useless?
« Reply #7295 on: Wed, 16 April 2014, 17:04:03 »
It won't shine through just the legend, it will light up the cap if its the standard thin ABS. Some pictures can be found in the OP.
Offline Melvang
« Reply #7296 on: Wed, 16 April 2014, 17:09:57 »
And even if there is zero light penetrating the cap, you will still get an underglow effect which I find the most pleasing.
« Reply #7297 on: Wed, 16 April 2014, 17:10:18 »
Yup, I love the underglow as well :D
Offline Pacifist
  • on hiatus
« Reply #7298 on: Wed, 16 April 2014, 17:21:57 »
+1
holy **** underglow is sexy
« Reply #7299 on: Wed, 16 April 2014, 17:40:29 »
4th vote for underglow
it's like underboob but keyboard
