Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6228217 times)
Offline Pacifist
  • on hiatus
« Reply #7000 on: Wed, 26 March 2014, 14:15:06 »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #7001 on: Wed, 26 March 2014, 14:16:10 »
What are mandolin crystals?
It's an inside joke. There was a user named Mandolin who was trying to sell Model M keyboards with what he called "rare crystals" in them. He was advertising his eBay auctions are ridiculous markups since he had these crystals in.
Everything makes more sense now
« Reply #7002 on: Wed, 26 March 2014, 14:41:52 »
How do I flip the spacebar on a Realforce 87U?
« Reply #7003 on: Wed, 26 March 2014, 14:44:15 »
very carefully :P
« Reply #7004 on: Wed, 26 March 2014, 14:55:04 »
Is it not the same as the MX spacebars? Pull it off then flip it around and push it back in place?
« Reply #7005 on: Wed, 26 March 2014, 14:56:03 »
According to retspiR, it's more complex than that.
« Reply #7006 on: Wed, 26 March 2014, 14:59:21 »
According to Ripster's imgur (found from this post), you just support both sides of the spacebar and pull it off. Then flip it around. I don't see anything else that would make it more difficult than that.
« Reply #7007 on: Wed, 26 March 2014, 15:13:08 »
that was surprisingly easy.
well then
Offline epzy
  • HHKB Fiend
  • ded
« Reply #7008 on: Wed, 26 March 2014, 15:37:33 »
What's wrong? I have a pretty good idea, but want to make sure. Perhaps someone else has had this happen before.
« Last Edit: Wed, 26 March 2014, 15:39:11 by epzy »
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #7009 on: Wed, 26 March 2014, 15:59:05 »
I did some analysis, and I think I've isolated the issue:
Offline epzy
  • HHKB Fiend
  • ded
« Reply #7010 on: Wed, 26 March 2014, 16:02:22 »
:P
I wanna know why it's stuck. I think it's not perfectly lined up under there, so will open it up tomorrow.
Offline BlueBär
« Reply #7011 on: Wed, 26 March 2014, 16:02:39 »
Wow! Revolutionary!
Is the dome underneath correctly seated?
Offline epzy
  • HHKB Fiend
  • ded
« Reply #7012 on: Wed, 26 March 2014, 16:04:34 »
Wow! Revolutionary!
Should be, but it might have moved a little while I was fastening the screws. Will try again tomorrow, but this time I'll hold the plate/pcb real tight while fastening the screws so there's zero chance of movement.
When I just fiddle with the sliders alone though, I feel like they get stuck a lot as well. It's weird...
« Reply #7013 on: Wed, 26 March 2014, 16:06:03 »
Wow! Revolutionary!
Sounds like something in the stack of parts isn't aligned correctly. Try reseating everything.
« Reply #7014 on: Wed, 26 March 2014, 16:07:27 »
Is it normal behaviour to be searching on eBay for the term "key caps" at times I care not to mention (very AM people).
Around here - yes ;)
Offline Lastpilot
  • Power stance
« Reply #7015 on: Wed, 26 March 2014, 16:08:47 »
Yep. I actually just use "mx cherry" as my regular search term.
« Reply #7016 on: Wed, 26 March 2014, 16:09:25 »
Wow! Revolutionary!
Can't say I've ever had that problem. What I do is support the plate/case top and put the domes/springs in it and then screw the PCB to it.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #7017 on: Wed, 26 March 2014, 16:09:54 »
Wow! Revolutionary!
Yes, sir. :)
Offline ajx
« Reply #7018 on: Wed, 26 March 2014, 16:14:45 »
Where can i find KBT Pure backlit?
Preferably with white led and mx-red
It seems to be out of stock everywhere
« Reply #7019 on: Wed, 26 March 2014, 16:16:00 »
It seems to be out of stock anywhere
Not the switch or color but you can find a couple for sale in this thread http://geekhack.org/index.php?topic=48727.0
Offline Lastpilot
  • Power stance
« Reply #7020 on: Wed, 26 March 2014, 16:18:01 »
BTW, the KBT Pure was never sold from factory with white LED's.
Offline hcry4
  • HHKB Hoarder
« Reply #7021 on: Wed, 26 March 2014, 16:28:15 »
Really? I got this one before it was sold out.
Offline Lastpilot
  • Power stance
« Reply #7022 on: Wed, 26 March 2014, 16:29:25 »
LOL WAT?! Wow, consider me corrected. I am still very new here. Never seen that model ever, nice catch! :thumb:
Offline ajx
« Reply #7023 on: Wed, 26 March 2014, 17:04:53 »
i sold mine lol and regret it now
There is Pure Pro in white led but some downsides to me
small spacebar and backspace
Offline hudson0804
« Reply #7024 on: Thu, 27 March 2014, 03:32:21 »
I have purchased some O rings for my mx brown ducky.
do you guys just do the alphanumeric keys or the whole board?
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #7025 on: Thu, 27 March 2014, 03:45:05 »
I put mine on all the keys to keep things uniform.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #7026 on: Thu, 27 March 2014, 03:45:49 »
I have never seen someone do just the alphas, or just the mods, but that'd be up to you. Personally I  have always gone for o-rings across the whole board. I like a uniform feel. :P
Offline hudson0804
« Reply #7027 on: Thu, 27 March 2014, 04:44:26 »
I think this is probably more laziness than anything.. 108 keys seems a lot.
I shall do the lot.
thanks
Offline epzy
  • HHKB Fiend
  • ded
« Reply #7028 on: Thu, 27 March 2014, 04:58:22 »
Hence why you should get a 60%. ;)
But in all seriousness; installing o-rings isn't too much work, at least compared to other mods like stickering, lubing, soldering, desoldering etc.
Offline kaz
« Reply #7029 on: Thu, 27 March 2014, 07:27:11 »
I've got a couple hundred spare Cherry Black switches lying around. Are there any DIY kits including PCB/case I could drop them into?
Cherry G80-11800 (Workhorse) | Cherry G80-11900 | \'93 IBM Model M | Apple M0116
Offline Candyflip
« Reply #7030 on: Thu, 27 March 2014, 07:29:22 »
You can drop them in my mail :p
In other news a Phantom project sounds good but at additional cost sadly.
Offline BlueBär
« Reply #7031 on: Thu, 27 March 2014, 07:30:18 »
Sprit's GB has nice PCBs and cases. There's also the Phantom PCB which you can get from mechanicalkeyboards.com, but that doesn't include a case. You can also get a GH60 (also PCB only) in the classifieds when the GB is finished.
Offline kaz
« Reply #7032 on: Thu, 27 March 2014, 07:42:37 »
Cheers, I'll check them out.
« Reply #7033 on: Thu, 27 March 2014, 07:48:42 »
I think MK.com is your best shot besides the Classifieds. You can try using their incoming stock page to see when they'll restock more Pures.
Offline BlueBär
« Reply #7034 on: Thu, 27 March 2014, 07:51:55 »
I don't think the KBT Pure is in production anymore.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #7035 on: Thu, 27 March 2014, 10:24:09 »
To all the people who make custom cables.
If you use Paracord.  I am assuming you are using the 550 Paracord Type III with 7 or 9 internal strands and 550lbs break strength.  In your experience does the 7 or 9 strand work better for cable sheathing?  I have heard that it can be hit and miss with Paracord being big enough in some cases.
I will be using a 28/24 USB cable (so it might be slightly bigger than standard USB cable).  Does anyone have recommendations for the right Paracord to buy?
« Reply #7036 on: Thu, 27 March 2014, 10:27:35 »
Thought it was only the Poker X that was getting phased out.
Offline BlueBär
« Reply #7037 on: Thu, 27 March 2014, 10:42:27 »
I guess the 9 strand might work better than the 7 strand one, since it is probably a bit thicker. I would also recommend rather using a thinner than usual USB cable.
There recently was a post with somebody saying that people asked for a KBT Pure Replica from Vortex (basically a KBT Pure with PN layer and a plate I guess) because they were not happy with the Pure Pro, and they're out of stock pretty much everywhere now, which makes me conclude that they stopped producing them as soon as the Pure Pro came out or even earlier. Same for Poker X and Poker II.
Offline hudson0804
« Reply #7038 on: Thu, 27 March 2014, 10:45:05 »
I have a new hoddy.  I need to embrace my new found hobby.
I'd like to build my own keyboard (not from scratch you understand) but want something I can say.. yes I assembled/built that.
Are there any kits/vendors that you can advise on.
I am quite handy with a soldering iron.
Any suggestions?
« Reply #7039 on: Thu, 27 March 2014, 10:50:44 »
Any suggestions?
Easiest PCBs to get right now are the Phantom (from MK.com), Ergodox (from Massdrop), and Sprit (from the GB sub-forum) ones. You might also be able to get a GH60 when that comes out. Korean boards such as the KMAC and LZ boards are also options.
You can also buy a stock board and modify it with switch swaps, spring swapping, or LED changes. For example making lubed ergo-clears or Jailhouse Blues.
I recommend you take a drive through Making Stuff Together to see what's out there in terms of custom stuff.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #7040 on: Thu, 27 March 2014, 10:56:53 »
Thanks for the answer.  That is also what I was thinking...  I want to use the 28/24 instead of the 28/28 because I will not be creating cables only for keyboards.  If you try to use 28/28 as a power cable for newer devices like phones, tablets, etc, you will find that they do not charge correctly.  These new devices require the extra power draw that the 24 gauge wire provides.
I know that MDPC-X is an alternative to Paracord, but it is much harder to get my hands on, so I have not gone that route yet...
Offline Zeal
    • Zeal Generation Inc.
« Reply #7041 on: Thu, 27 March 2014, 11:03:10 »
I haven't tried many varieties of 550lb Paracord, but the few ones I have with 7 internal strands are a snug fit on 28/28 AWG USB Cables. The ID of paracord can vary from manufacture to manufacture.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #7042 on: Thu, 27 March 2014, 11:06:26 »
Thank you, that is very helpful.  :)
Offline BlueBär
« Reply #7043 on: Thu, 27 March 2014, 11:09:32 »
I doubt that it really is that much a of a problem as USB should only provide 5V anyways. For example, the cable from my Nexus 4 is a lot thinner in comparison to the cable that came with my Pure. If a device doesn't charge correctly on a certain cable, something is wrong with the cable and it's probably not its thickness.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #7044 on: Thu, 27 March 2014, 11:15:48 »
In doing research on the topic, this is what I have found.  I have not had the chance to test the two side by side, but I found a few examples where people were having problems with this.  If I remember correctly, I think the Nexus 7 requires a 28/24 cable to charge correctly.  I believe it just charges VERY slowly without it.
Offline BlueBär
« Reply #7045 on: Thu, 27 March 2014, 11:19:22 »
Interesting. Well if you've done some research on it I'll believe you :)
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #7046 on: Thu, 27 March 2014, 11:26:06 »
Ya, it is not obvious at all.  Here is an example.  If you google stuff like "Nexus 7 USB cable type" you will find all sorts of stuff about people having problems using cables other than the one that came with the device.
Offline Zeal
« Reply #7047 on: Thu, 27 March 2014, 12:08:39 »
Yep, it's the amperage that determines how fast a smart phone/tablet can charge.
Here's a helpful tip from L-Com. You also have to take into consideration cable length & the added resistance.
« Reply #7048 on: Thu, 27 March 2014, 18:13:04 »
Were Skidata keyboard (the big blue ones with orange on charcoal keycaps) available in ANSI layout?
I have only ever seen ISO ones on GH, and a Google image search only seems to show ISO too.
Offline BlueBär
« Reply #7049 on: Thu, 27 March 2014, 18:16:22 »
I'm pretty sure I saw a ANSI one once.
