Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6154657 times)
0 Members and 6 Guests are viewing this topic.
« Reply #6750 on: Sun, 16 March 2014, 11:26:57 »
For the older DSA caps with really tight stems, could you make it looser by warming it up with a hairdryer and then while its soft put it on a switch and let it cool to a bigger size?
I'm gonna say no.
Plastic shrinks as it cools, so I'd even go as far to say it could make it worse.
Offline Pacifist
  • on hiatus
« Reply #6751 on: Sun, 16 March 2014, 13:00:57 »
I'm gonna say no.
Aww that sucks. This DSA retro GH key is stubborn af
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #6752 on: Sun, 16 March 2014, 16:06:53 »
Is making your own EVA/Nylon molded keyboard carrying case possible, or does this process need expensive machinery.
|||My other keyboards :
x
« Reply #6753 on: Sun, 16 March 2014, 16:12:43 »
I think you could do it. Buy some codura cloth. Put sandwich cardboard or a heavy cardstock between it. Then form a case. Sew on a zipper. Done. My sister made me a case and it wasn't *too* bad.
Offline lightsout714
« Reply #6754 on: Sun, 16 March 2014, 16:21:33 »
I live in the US. Whats the fastest and most affordable way to get a poker 2? I was going to go with Qtan but wondering if there is a better option.
I see mechanicalkeyboards.com has them too but I don't want backlighting, just MX brown or red.
Also is there anywhere that sells the cherry GMK sets like originative used to sell? White and Beige?
« Last Edit: Sun, 16 March 2014, 16:44:14 by lightsout714 »
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #6755 on: Sun, 16 March 2014, 17:20:56 »
Most people I know of got them from qtan.
It looks like kbdmod.com sells them, but they're out of stock and you'd probably need a Korean proxy. I don't know of any other stores that have them regularly in stock.
« Reply #6756 on: Sun, 16 March 2014, 17:30:28 »
Thanks. Out of stock thats a bummer. I guess the classifieds is my best shot.
Offline Dubsgalore
« Reply #6757 on: Sun, 16 March 2014, 18:19:49 »
My 3700 is giving me a lot of trouble and is pretty uneven
when I press on the right side, it makes a noise and wobbles, but the left side (top and bottom) are both ok. its just the top right side
extremely aggravating, not sure what to do really. opened it up and everything is ok inside with the PCB placement and whatnot
heres what the back looks like (everythings ok)
heres a video (ready soon) of what it looks like
should i try and weight one side? :////////
« Reply #6758 on: Sun, 16 March 2014, 18:35:55 »
MechanicalKeyboards.com seems to have plenty in stock.
Offline Pacifist
  • on hiatus
« Reply #6759 on: Sun, 16 March 2014, 18:36:48 »
« Reply #6760 on: Sun, 16 March 2014, 18:44:53 »
Yeah don't want backlighting. How about a cheap brown QFR. Newegg is sold out. Missed it.
« Reply #6761 on: Mon, 17 March 2014, 03:57:51 »
I will happily desolder the LEDs out of it for you.
Offline RESPRiT
  • HHKB = ❤
« Reply #6762 on: Mon, 17 March 2014, 04:25:02 »
The backlit Pokers have ABS instead of PBT, so I think that's the issue.
« Reply #6763 on: Mon, 17 March 2014, 08:47:40 »
Thanks guys. I'm leaning towards just getting a qfr and some caps instead. Not sure if 60% is for me.
« Reply #6764 on: Mon, 17 March 2014, 16:02:29 »
60% is a hard layout to get used to for a lot of people. I don't blame you.
Personally, I recommend Filco as a brand. The stock keycaps are kinda crummy, I grant you, but they'll last long enough for you to get a nice thick PBT set.
« Reply #6765 on: Mon, 17 March 2014, 16:10:23 »
Nothing wrong with QFR (or QFS), plus they re cheaper than Filco and will leave you more money afterwards for a good PBT set (he said, typing on his QFS with PBT dyesub set).
Offline lcs
  • Lover of Grape Drank
  • はやく
« Reply #6766 on: Mon, 17 March 2014, 17:26:25 »
So, stupid question time!
I got my gf a A87ps2avr. I plugged it using a mini usb to usb cable and the leds worked out fine, but I can't type it. Can someone enlighten me? Do I need a miniusb to ps2 cable? How do I configure this thing?
tks!
« Reply #6767 on: Mon, 17 March 2014, 17:31:40 »
Yes, you need a mini-USB to PS2 cable. Info from Sifo.
Offline lcs
  • はやく
« Reply #6768 on: Mon, 17 March 2014, 17:36:51 »
O Captain! My Captain! our fearful question is done;
The ship has weather'd every rack, the answer we sought is won
« Reply #6769 on: Mon, 17 March 2014, 19:10:36 »
Thanks, I do prefer filco. Had a few, but at almost twice the price I'm not sure its worth it. Just picked up another QFR. Wish I could find a nice set of Cherry beige DS's.
Offline RESPRiT
  • HHKB = ❤
« Reply #6770 on: Mon, 17 March 2014, 19:15:46 »
tks!
You can also get a ps2avr-ext if that can be more convenient for you.
« Reply #6771 on: Mon, 17 March 2014, 19:24:33 »
Simple USB to PS2 converter works too, or should.
Offline lcs
  • はやく
« Reply #6772 on: Mon, 17 March 2014, 19:36:24 »
tks!
What is that?
Offline Lain1911
  • God of the Wired
« Reply #6773 on: Mon, 17 March 2014, 19:40:39 »
Does the Ducky Zero Shine come in a TKL? I could not find one.
Offline BlueBär
« Reply #6774 on: Mon, 17 March 2014, 19:47:47 »
The Ducky Zero DK2087 and the Shine 2 DK9087 are TKL. There is no Ducky Zero Shine.
Offline RESPRiT
  • HHKB = ❤
« Reply #6775 on: Mon, 17 March 2014, 19:53:16 »
tks!
What is that?
It's a simple converter that converts a USB cable into a ps/2 cable without ever needing a ps/2 cable, if that makes sense. Basically, it lets you use a USB cable as a ps/2 cable.
Offline lcs
  • はやく
« Reply #6776 on: Mon, 17 March 2014, 19:54:32 »
tks!
What is that?
Ah, I see. I think it would be harder to get one of those than a ps2 cable XD
« Reply #6777 on: Mon, 17 March 2014, 19:59:30 »
DK2108S - Ducky Zero Shine - is only available full size.
http://www.duckychannel.com.tw/en/ZERO_DK2108S.html
Offline BlueBär
« Reply #6778 on: Mon, 17 March 2014, 20:01:45 »
Although it has backlighting it is not part of the Shine series ;)
Offline RESPRiT
  • HHKB = ❤
« Reply #6779 on: Mon, 17 March 2014, 20:04:53 »
tks!
What is that?
When I got my ps2avr, it just came with one :P
Offline lcs
  • はやく
« Reply #6780 on: Mon, 17 March 2014, 20:19:48 »
tks!
What is that?
Mine didn't :'( :'(
It's ok, got a ps2 cable :)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #6781 on: Mon, 17 March 2014, 22:36:16 »
Anyone know switch hole dimensions for an Alps switch?
« Reply #6782 on: Mon, 17 March 2014, 22:37:41 »
There are diagrams of Alps switches with measurements here:
http://deskthority.net/workshop-f7/deskthority-alps-keyboard-project-t4651.html
Edit: Sorry, that was for Matias, but supposed to be the same as Alps?
Offline Melvang
« Reply #6783 on: Mon, 17 March 2014, 22:42:40 »
Awesome, thanks Rowdy.
« Reply #6784 on: Mon, 17 March 2014, 22:48:30 »
How many GB's have there been with the cherry replicas? Just the orange ones and toxic?
Is there a classic cherry in the works? (White/beige)
I guess everyone is tired of those?
Offline Pacifist
  • on hiatus
« Reply #6785 on: Mon, 17 March 2014, 22:50:41 »
there was raindrop too
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #6786 on: Mon, 17 March 2014, 22:52:34 »
I would love to get a classic Beige/White with cherry legends. I wouldn't mind it being DCS if it were PBT.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
« Reply #6787 on: Mon, 17 March 2014, 23:01:33 »
So would I, hard to find.
Oh the beautiful raindrop, didn't realize they were cherry. I've been away too long.
EDIT** Just glanced at some pics in the raindrop GB those look like standard SP WYSE font.
« Last Edit: Mon, 17 March 2014, 23:03:40 by lightsout714 »
« Reply #6788 on: Mon, 17 March 2014, 23:14:28 »
Raindrop R2 is currently in production. It is a CtrlAlt GB. And it uses Cherry replica legends.
Anyone wishing upon a star for a full set of double shot PBT caps can just keep right on dreaming. We have already been told by SP that the shrinkage rate problem makes it near impossible to do a full set of DS from PBT. And if they were somehow able to do it, it would be so cost prohibitive that no one could buy them.
Best bet for classic Cherry beige is to wait for someone to run a GB for them through GMK. The reason to keep doing sets from SP is that they can do colors and legends that GMK just can't/won't. But if it's a true replica set, of existing colors that GMK has, there's no reason not to go the GMK route.
I believe Bunnylake has said that Toxic will be the last CtrlAlt GB with SP for a while. I think he has plans to do some cool stuff with GMK. And perhaps some classic replicas are in those plans. We shall see. :)
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #6789 on: Mon, 17 March 2014, 23:32:03 »
Anyone know where to get LEDs?
Offline Melvang
« Reply #6791 on: Mon, 17 March 2014, 23:39:48 »
Thanks for the correction and info.
Offline Pacifist
  • on hiatus
« Reply #6792 on: Mon, 17 March 2014, 23:43:23 »
Aw that sucks. My march GH key looks and feels sweet, but I do see how shrinkage will be a major issue...stem is a bit tight
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #6793 on: Mon, 17 March 2014, 23:55:19 »
I was talking a about a classic beige/white dye-sub DCS set, but yes I can't wait for Bunny to start the GMK group buys :)
WTB/WTS/WTT ---->
Offline ideus
  • Björkö.
« Reply #6794 on: Tue, 18 March 2014, 01:03:32 »
They should call Vortex. Or send in a spy... ;)
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #6795 on: Tue, 18 March 2014, 11:49:03 »
Has anyone installed LED's in a WASD V2? Thinking about adding some flare to the board, if there is a guide or something I missed, I apologize, I only did a brief search and didn't find anything specific on this board.
  • Cherry Peasant
  • keycult.com
« Reply #6796 on: Tue, 18 March 2014, 11:53:04 »
If the PCB supports LED's already (I don't know about this), it should be as simple as soldering them in. You can find information about polarity in the OP of this thread, and Photoelectric has a nice mini-review and description of various LED types.
Offline digi
  • elite af tbh
« Reply #6797 on: Tue, 18 March 2014, 11:54:01 »
Thanks Riot, I'll check that out.
« Reply #6798 on: Tue, 18 March 2014, 15:15:09 »
AFAIK the WASD V2 doesn't have LED support on the PCB.
Offline Pacifist
  • on hiatus
« Reply #6799 on: Tue, 18 March 2014, 16:09:59 »
What kro does the minila air have as its wireless?
also what 75% metal cases have been made?
« Last Edit: Tue, 18 March 2014, 17:49:03 by Pacifist »
