Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6230227 times)
0 Members and 9 Guests are viewing this topic.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6500 on: Fri, 28 February 2014, 11:30:53 »
Does anyone know of a YouTube video where I can see someone typing on a Filco MJ2 in a Vortex aluminium case? If so, please pass me the link! :)
Not this one:
- Need a video of a Filco MJ2 in a Vortex aluminium case with plastic keys.
« Reply #6501 on: Fri, 28 February 2014, 14:28:39 »
Not this one:
I don't have a video for you, but I can tell you that if you don't have a clicky switch, the case will eat a lot of the sound. I typed on riotonthebay's spritboard with ergo clears, and the only noise it made was when it the switches actuated.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6502 on: Fri, 28 February 2014, 14:38:22 »
Not this one:
Thanks for the information, but I still would appreciate a video, hard to imagine how it will sound. :P Have you typed on an acrylic case before? Wondering if it will sound similar, or if it will be vastly different.
« Reply #6503 on: Fri, 28 February 2014, 16:56:44 »
Where can I get a filco cable? I need one because my camo is starting to die again.
Offline Pacifist
  • on hiatus
« Reply #6504 on: Fri, 28 February 2014, 17:13:31 »
pexon
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6505 on: Fri, 28 February 2014, 17:14:40 »
Here is one place:
http://pexonpcs.co.uk/Filco-Cable-_p_43.html
Pexon sells that Filco detachable mod as well, if you're interested. :)
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6506 on: Fri, 28 February 2014, 17:16:05 »
How do I define 'key chattering'? Is it when I gently tap on my stabilized keys and they make that metallic sound? Sorry if it's a stupid question, but I have no idea what it is. :P
Offline Pacifist
  • on hiatus
« Reply #6507 on: Fri, 28 February 2014, 17:17:09 »
its when the wrong keypresses are sent I think or when it double taps a key when u single hit
Offline Fullcream
« Reply #6508 on: Fri, 28 February 2014, 17:30:40 »
Why does my BTC 5100C actuate as if it is mechanical (halfway down the keystroke). I think it may be a conductive rubber dome? do all conductive rubber domes actuate without bottoming out? It is definitely not foam and foil. It is one of the newer/last produced ones.
« Reply #6509 on: Fri, 28 February 2014, 17:32:20 »
Since you're in the US, I highly recommend Mimic Cables.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6510 on: Fri, 28 February 2014, 17:33:52 »
Oh, I get it - thanks!
« Reply #6511 on: Fri, 28 February 2014, 17:37:22 »
To clarify/expand, it's what debounce solves.  It's when multiple keystrokes are sent to the computer for a single press of the key.  The "chattering" is on the switch/hardware side, and the "debounce" is on the firmware side to combat chattering.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6512 on: Fri, 28 February 2014, 18:18:24 »
I see. Thank you. :)
Offline HPE1000
  • Keycap Paparazzo
« Reply #6513 on: Fri, 28 February 2014, 18:38:32 »
Less keyboard related, more forum related. How in the world can I upload an avatar without it being horrible quality? There is always compression on the picture really bad, I don't see anyone else with these bad of problems with their avatars.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #6514 on: Fri, 28 February 2014, 18:41:11 »
I noticed this as well and haven't bothered to fix it yet myself, but I believe you can choose to link to a URL instead of uploading. This shouldn't result in any additional compression, just resizing.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6515 on: Fri, 28 February 2014, 18:54:34 »
Is there any way to disable the windows keys on a Filco MJ2? With some software perhaps?
« Reply #6516 on: Fri, 28 February 2014, 19:22:33 »
SP sells physical keylockers.
Offline stancato9
« Reply #6517 on: Fri, 28 February 2014, 23:53:38 »
How would the caps lock LED work on a pure / poker 2 if you were to desolder the original LED and add one to the switch. Would it always stay on?
Poker 2 - MX Red
« Reply #6518 on: Sat, 01 March 2014, 00:09:23 »
For a software solution, you could consider using autohotkey to reassign it to (nothing).  I've never tried that, but it might be worth trying.
« Reply #6519 on: Sat, 01 March 2014, 00:45:13 »
How would it work if you replaced the LED? It would work the same I think.
« Reply #6520 on: Sat, 01 March 2014, 00:46:53 »
Quick list of blue tooth mechs. And go!
« Reply #6522 on: Sat, 01 March 2014, 00:48:35 »
KBTalking Pro v1.1
« Reply #6523 on: Sat, 01 March 2014, 00:48:54 »
I think he's referring to the fact that the caps lock LED on the poker 2 is actually a round LED not seated into the switch but rather positioned to the right of the switch.  (so you could potentially keep the stock LED and add one to the switch)  So if you remove that and put one in the switch position, what happens?  I can't answer that as I don't know, but hopefully I've correctly interpreted the question.
« Reply #6524 on: Sat, 01 March 2014, 00:50:28 »
« Reply #6525 on: Sat, 01 March 2014, 00:56:26 »
Out the box bluetooth no modding 15 lb keyboards
« Reply #6526 on: Sat, 01 March 2014, 00:59:25 »
KBTalking Pro v1.1 superglued to a 12.5lb weight.
« Reply #6527 on: Sat, 01 March 2014, 01:01:05 »
Ewwww 104 keys
Offline stancato9
« Reply #6528 on: Sat, 01 March 2014, 01:01:17 »
Spot on. :thumb:
Poker 2 - MX Red
« Reply #6529 on: Sat, 01 March 2014, 01:09:57 »
Spot on. :thumb:
If you're willing to wait a couple days, I could throw an LED on my caps lock switch and see how it behaves (whether it's always on or behaves as the caps lock LED does).  I need to think about what color LED I want there though eventually, so I don't want to rush and do it right now.  :P
Of course it'd be ideal if anyone else has experience with this.  But if no one replies I'll try it out for you.  :)
Offline stancato9
« Reply #6530 on: Sat, 01 March 2014, 01:14:30 »
Spot on. :thumb:
Thanks a lot. I appreciate that :)
I would assume it would not function as a caps lock LED but I may be mistaken.
Maybe someone will chime in soon.
Poker 2 - MX Red
« Reply #6531 on: Sat, 01 March 2014, 01:19:27 »
After a brief inspection of the traces, it seems like it might actually behave like all the other add-on LEDs on the board (always on / controlled by fn+v).  But that's just a guess.
Offline stancato9
« Reply #6532 on: Sat, 01 March 2014, 01:22:53 »
Well that really sucks. Is there a possibility of somehow wiring that led to the original caps lock?
Poker 2 - MX Red
« Reply #6533 on: Sat, 01 March 2014, 01:25:43 »
If I'm right with that guess, then no, not without cutting traces and re-routing which would not be easy at all.  Best bet would probably be to swap out the stock caps lock LED and put the new one in its place, rather than in the switch position.
Offline stancato9
« Reply #6534 on: Sat, 01 March 2014, 01:27:23 »
Damn. I actually have to remove it completely because of the imsto plate I ordered not having the cutout.
Poker 2 - MX Red
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6535 on: Sat, 01 March 2014, 03:27:36 »
Kk, will check it out.  :thumb:
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6536 on: Sat, 01 March 2014, 03:49:54 »
AutoHotKey worked just fine! Thank you so much.
« Reply #6537 on: Sat, 01 March 2014, 03:52:50 »
Awesome!  I'm glad it worked out well for you.  :D
Offline stancato9
« Reply #6538 on: Sat, 01 March 2014, 10:22:03 »
Spot on. :thumb:
Posted this last night without a definitive answer. Does anyone know? :)
Thank you.
Poker 2 - MX Red
« Reply #6539 on: Sat, 01 March 2014, 10:35:20 »
Spot on. :thumb:
Thank you.
I'm almost 100% positive I've replaced the Caps Lock LED on a Pure with an in-switch LED and it worked just as you would expect.
« Reply #6540 on: Sat, 01 March 2014, 11:22:41 »
Spot on. :thumb:
Thank you.
Please don't bump your questions.
Offline stancato9
« Reply #6541 on: Sat, 01 March 2014, 11:59:08 »
Spot on. :thumb:
Thank you.
Sorry!
Could someone quickly tell me how to turn on and adjust LEDs on a pure. I can't find it.
Poker 2 - MX Red
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6542 on: Sat, 01 March 2014, 12:01:55 »
nvm ^^
« Last Edit: Sat, 01 March 2014, 12:39:29 by epzy »
Offline Emmiya
« Reply #6543 on: Sat, 01 March 2014, 12:18:12 »
On my pure it's:
Fn + B - activate (setting 1)
Fn + V - increase brightness
Fn + N - decrease brightness
Fn + B - again (setting 2) - Locked at that brightness
Fn + B - third time (disable)
« Last Edit: Sat, 01 March 2014, 12:22:19 by Emmiya »
« Reply #6544 on: Sat, 01 March 2014, 12:23:45 »
On my pure it's:
Doesn't the second Fn+B put it into breathing mode? I'm pretty sure that's what mine does.
Offline Emmiya
« Reply #6545 on: Sat, 01 March 2014, 12:26:22 »
Ah, that's exactly what it does.
My bad, I never use the back-lighting, so I just figured it was a preset-high setting.
Either way, here's the online manual : http://view.samurajdata.se/psview.php?id=8ae497aa&page=1
« Reply #6546 on: Sat, 01 March 2014, 21:37:45 »
If I have a non-backlit pure that I then add LEDs to, will I be able to control them or will they have to be on all the time?
Similar question about the poker II.
« Reply #6547 on: Sat, 01 March 2014, 21:45:46 »
It will work the same as a backlit Pure or Poker II. They ship with the same hardware and firmware, sans LEDs only.
Offline Slowdiving
« Reply #6548 on: Sat, 01 March 2014, 23:29:16 »
Can I use the Pexon filco mod on my RF87U?  Or am I better getting a USB mini extender, cutting/soldering it to a mobo header and attaching that to my PCB?
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #6549 on: Sat, 01 March 2014, 23:57:40 »
Which color way for caps was/is the Nathan set?
