Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6018603 times)
Offline Dreamre
    • kbdlife
« Reply #6600 on: Fri, 07 March 2014, 22:21:35 »
Where do you guys get your angled tweezers for stickering and such?
Thank you in advance!
Amazon, eBay, Frys, Mouser, Digikey, Newark, so on and so forth.
Any particular one you like :D?
« Reply #6601 on: Fri, 07 March 2014, 22:25:16 »
Whichever one is decently made and cheapest.  Personally, I love Mouser and Amazon.  Amazon because if it's crap, it's no big deal to return, and Mouser because they're cheap and customer service is amazing.
Offline Dreamre
    • kbdlife
« Reply #6602 on: Fri, 07 March 2014, 22:26:22 »
Ah, I see. Thanks for providing your insight :).
Offline do_Og@n
« Reply #6603 on: Fri, 07 March 2014, 22:29:37 »
Does anyone here know someone who can convert my old NMB Black Space Invader keyboard cable from a coiled, off-white AT plug to a braided, colored USB plug?
Offline yasuo
  • spanengan puyeng newbie
« Reply #6604 on: Sat, 08 March 2014, 00:33:29 »
On SP Keycap Vertical numpad (+),include row?    on WASD/OEM is R3
thanks
Logitech MK220 Colemak DH
« Reply #6605 on: Sat, 08 March 2014, 10:27:26 »
yes
« Reply #6607 on: Sat, 08 March 2014, 10:53:47 »
Yes it had blacks and is not backlit.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6608 on: Sat, 08 March 2014, 13:34:48 »
Which one of these switches feels heavier: Completely new RF 55g vs completely new stock MX Clears? Which one is easiest to bottom out with?
« Reply #6609 on: Sat, 08 March 2014, 13:42:30 »
Stock clear is 80g. Topre is basically linear, so the topre will bottom out easier.
Offline gh_pp
« Reply #6610 on: Sat, 08 March 2014, 13:47:26 »
IMO stock clear is easier to actuate but harder to bottom out compared to 55g topre.
QFR brown x2, Realforce 45G, Type-S, Keycool 22 blue
Previous keyboards: 55G, IBM Model M, Dell AT101W, Fujitsu FKB4725, G80-3000 clear, QFS green, QFS blue
[WTB] Custom keyboard build
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #6611 on: Sat, 08 March 2014, 13:47:59 »
What models are there with QWERTY and Hindi legends? Just keycaps is fine too.
|||My other keyboards :
x
« Reply #6612 on: Sat, 08 March 2014, 14:07:40 »
I've never seen a board in Hindi legends. At least not mechanical.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #6613 on: Sat, 08 March 2014, 14:41:45 »
It's for my girlfriend she is studying Hindi and would like one.
Even a simple rubber dome seems to be rare too.
EDIT: What do you know, a Mech keyboard with Hindi legends; TVS-E BHARAT GOLD BILINGUAL. Guess that settles that.
Let's see if we can get out hands on that.
« Last Edit: Sat, 08 March 2014, 14:55:20 by JaccoW »
x
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6614 on: Sat, 08 March 2014, 15:37:53 »
Which Korean spring is closest to stock mx reds in terms of force? 55g?
Offline BlueBär
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6616 on: Sat, 08 March 2014, 16:03:05 »
Ty. :) Yeah, 62g korean springs seems to be pretty close to stock reds. And damn, 62g ergo clears must be suuuuper light compared to stock clears then. :eek:
Offline Flyersfan1
  • Hi!
« Reply #6617 on: Sat, 08 March 2014, 19:41:19 »
Can pcb mounted cherry stabilizers from gon's website be mounted on an ansi125 universal tkl plate?
Quote from: Photekq
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #6618 on: Sat, 08 March 2014, 20:33:48 »
No.  But it woudn't take much to open the holes up enough for them to work.  At least to my knowledge
Offline Flyersfan1
  • Hi!
« Reply #6619 on: Sat, 08 March 2014, 20:37:30 »
Thanks Melvang!  :)
Quote from: Photekq
Offline tribade
« Reply #6620 on: Sun, 09 March 2014, 14:04:33 »
I'm trying to put my RF into a digil0g case, but goddamnit I can't get the screw off the ground on the usb cable.  This is the one here: (that's the bottom of the board, the top is a phillips head screw, about 3mm I believe.
Do they put some kind of lock tight on it now?  Any tips or hints?
KMAC mini w/ blacks | Realforce 87uw 55g w/ Digil0g case | KMAC w/ blacks | Duck Viper w/ clears
"Te occidere possunt sed te edere non possunt nefas est."
« Reply #6621 on: Sun, 09 March 2014, 14:10:14 »
By definition, PCB mount stabilizers mount only to a PCB, not to a plate. The uTKL plate will work just fine with PCB mounted stabilizers, which are mounted to a PCB which supports them. In order to mount stabilizers to the actual plate, you want either Cherry PLATE mount stabilizers, or Costar stabilizers (either will work with that plate). You can find Cherry plate mount stabilizers on Mouser, Digi-Key, Online Components, etc. Part numbers are in the OP of this thread. You can get Costar stabilizers from WASDkeyboards.
Offline Pacifist
  • on hiatus
« Reply #6622 on: Sun, 09 March 2014, 14:44:14 »
How many custom 60% PCBs allow 1.5x Ctrl Alt, 1x Win key, and 7x spacebar?
Offline BlueBär
« Reply #6623 on: Sun, 09 March 2014, 14:49:20 »
I think four.
« Reply #6624 on: Sun, 09 March 2014, 14:56:51 »
GH60 and Sprit, I believe are the only ones.
Offline BlueBär
« Reply #6625 on: Sun, 09 March 2014, 15:01:06 »
356mini and I think Duck made another one? And I'm not sure about the Kmac Happy, but I think it can have that layout too.
« Reply #6626 on: Sun, 09 March 2014, 15:02:27 »
Ah, I forgot about 356 mini and KMAC Happy. Duck was the 38GT, right? Which doesn't do that, unless there is another PCB for v2.
Offline BlueBär
« Reply #6627 on: Sun, 09 March 2014, 15:07:24 »
Duck Mini V2:
I think it uses a special PCB, not the 38GT.
Offline Pacifist
  • on hiatus
« Reply #6628 on: Sun, 09 March 2014, 15:09:27 »
Thanks for the help!
I'll probably go with the GH60 for my 60% pcb mounted clears needs, whenever I can get my hands on one
Offline Dreamre
    • kbdlife
« Reply #6629 on: Mon, 10 March 2014, 11:05:55 »
My friend lubed his QFR (MX red) with the thin mixture from Originative. It seems that one of his keys sometimes double presses (press once and it would press it twice). Is there any remedy to fixing this? Can cleaning inside the switch with rubbing alcohol fix this issue? Or is there a way to reposition the metal stem to fix the actuation point? He is too cheap to get replacement switches.
Thanks in advance!
Offline BlueBär
« Reply #6630 on: Mon, 10 March 2014, 11:26:58 »
Yes cleaning should help. Double check that the contact leafs are clean and relube it.
Offline Candyflip
« Reply #6631 on: Mon, 10 March 2014, 11:28:52 »
Thanks in advance!
Be a real friend hook him with some replacement switches... Other than that with alcohol I think he can remove the lube but not sure if they are already ruined.
Offline Dreamre
    • kbdlife
« Reply #6632 on: Mon, 10 March 2014, 11:36:01 »
I will let him know! Thanks BlueBar!
Thanks in advance!
He's away for University and won't be back for another month and so  :p. How do switches become ruined with too much lube :eek:?
« Last Edit: Mon, 10 March 2014, 11:40:02 by Dreamre »
Offline BlueBär
« Reply #6633 on: Mon, 10 March 2014, 11:37:53 »
I think he used too much or lubed on the wrong spots.
Offline Melvang
« Reply #6634 on: Mon, 10 March 2014, 11:39:19 »
Thanks in advance!
Are there any PCB manufacturers that are on par with OshPark as far as quality vs cost?  Would like them to accept gerber files for online ordering.
Offline Dreamre
    • kbdlife
« Reply #6635 on: Mon, 10 March 2014, 11:40:59 »
I will let him know and will report back once he tries this. Thanks again both of you :D.
Offline BlueBär
« Reply #6636 on: Mon, 10 March 2014, 13:00:35 »
What PCBs (apart from original Cherry) fit G80-3000 cases?
« Reply #6637 on: Mon, 10 March 2014, 13:20:53 »
I think the only one is Leeku's 3000 PCB.
Offline BlueBär
« Reply #6638 on: Mon, 10 March 2014, 15:30:45 »
Is that still obtainable somehwere? I guess in the Korean forums? I only heard about the 1800 PCBs.
Offline note
« Reply #6639 on: Mon, 10 March 2014, 15:32:32 »
Any of you guys know where could I get a CCnG key set? Or I just have to wait in classifieds for one to pop up?
Offline Pacifist
  • on hiatus
« Reply #6640 on: Mon, 10 March 2014, 15:34:29 »
classifieds
the gb starter had some extras but sold them all
Offline BlueBär
« Reply #6641 on: Mon, 10 March 2014, 15:34:43 »
Yes. There was one quite recently, not sure if it's still available.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6642 on: Mon, 10 March 2014, 15:37:44 »
ANSI? ISO? PBT? ABS? Profile?
Ducky are releasing ISO, OEM profile, thick PBT, CCnG sets in the near future. Send an e-mail showing interest to: ducky@teraset.net
I think they will come in both dyesub and blank variants, perhaps even engraved.
Offline note
« Reply #6643 on: Mon, 10 March 2014, 15:44:16 »
Its gonna be an ANSI profile.
Wow, I really thought I'm out of luck. I've been lurking the classifieds for a while now, but those things doesn't seem to pop up at all.
Offline Pacifist
  • on hiatus
« Reply #6644 on: Mon, 10 March 2014, 16:24:54 »
What's the easiest way to solder wires to this?
Offline BlueBär
« Reply #6645 on: Mon, 10 March 2014, 16:30:46 »
Bend little hooks with the wire.
Offline Pacifist
  • on hiatus
« Reply #6646 on: Mon, 10 March 2014, 16:32:09 »
So just be careful to not touch them together?
« Reply #6647 on: Mon, 10 March 2014, 18:08:56 »
And use heat shrink tubing.
Offline Pacifist
  • on hiatus
« Reply #6648 on: Mon, 10 March 2014, 18:52:35 »
What size would be ideal?
Offline BlueBär
« Reply #6649 on: Mon, 10 March 2014, 18:53:50 »
One that isn't too big and still fits :rolleyes:
They often come in packages with multiple sizes.
