Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6228211 times)
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #6850 on: Thu, 20 March 2014, 06:35:44 »
What alu TKL cases are there?
|||My other keyboards :
x
Offline BlueBär
« Reply #6851 on: Thu, 20 March 2014, 07:01:07 »
Including or excluding Korean customs?
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #6852 on: Thu, 20 March 2014, 07:09:27 »
I'm guessing the Korean Customs will skyrocket that number. :P
Mostly looking for models that include win-keys.
x
Offline BlueBär
« Reply #6853 on: Thu, 20 March 2014, 07:25:24 »
MKC made one, there also is the Skeldon TKL and the Vortex case that is available on mechanicalkeyboards.com.
« Reply #6854 on: Thu, 20 March 2014, 07:28:31 »
Are there any mass produced TKL aluminum cases besides for the Vortex cases? I can't think of any. Some Korean customs that have aluminum TKL cases include:
- KMAC series
- LZ-GH
- LZ-S
- LZ-F
- Orion TKL
BlueBär's post also has some good suggestions.
Stock QFR caps are laser engraved and filled, correct? Not etched?
I think you're right.
Edit: The DT wiki says that the caps are laser etched and infilled ABS.
« Last Edit: Thu, 20 March 2014, 07:40:16 by CPTBadAss »
Offline BlueBär
« Reply #6855 on: Thu, 20 March 2014, 07:38:37 »
I don't think so either.
Question: Can somebody give me some measurements of Costar stabilizer inserts?
58080-0
Offline lightsout714
« Reply #6856 on: Thu, 20 March 2014, 09:08:58 »
Do all cherry doubleshots (white on black) with 1.25 mods have a messed up bottom row? (off center stems) Or is this only when you harvest from a G81 (MY)
Would the mods from a G80 be compatible with a filco?
Offline BlueBär
« Reply #6857 on: Thu, 20 March 2014, 09:12:47 »
No
Yes
Yes, if the mods have the correct size
« Reply #6858 on: Thu, 20 March 2014, 09:15:45 »
I think an MY3000 and G80-3000 would work for you other than the Caps Lock which has an off centered stem placement.
Offline BlueBär
« Reply #6859 on: Thu, 20 March 2014, 09:18:57 »
Nope, MY3000/G81-3000 does have off center stems. I have one sitting right behind me and just double checked.
« Reply #6860 on: Thu, 20 March 2014, 09:20:52 »
Ok thanks guys. Appreciate it.
« Reply #6861 on: Thu, 20 March 2014, 09:40:55 »
Just a heads up, please check out this post for up to date information on the GH60 buy in case you haven't been following the GH60 thread. Doing my best to post the relevant updates in that post. A link can also be found in the OP.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #6862 on: Thu, 20 March 2014, 10:59:21 »
- KMAC series
- LZ-GH
- LZ-S
- LZ-F
- Orion TKL
Thanks, both of you. Guess I will have to pony up some cash for a custom then.
x
Offline Pacifist
  • on hiatus
« Reply #6863 on: Thu, 20 March 2014, 17:11:36 »
Are there any keyboards with cutouts for two AA batteries?
I plan to make a wireless mech with my ****ty logitech wave RD controller that I spent $60 on......only problem is room for the new (****ty 2kro) controller and the two AA batteries it uses
« Reply #6864 on: Thu, 20 March 2014, 17:23:45 »
I've never heard of a mechanical keyboard with a cutout especially made for batteries. Both in the past or coming up.
Offline Pacifist
  • on hiatus
« Reply #6865 on: Thu, 20 March 2014, 17:29:39 »
Guess I'll do an open air direct solder configuration for this project then
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #6866 on: Thu, 20 March 2014, 19:26:51 »
Anyone know the dimensions between the bottom of the stem and the bottom half of the housing on an MX switch?  Looking for these dimensions at rest, actuation, and bottom.  I was going to email Cherry but their website link just opens your installed email client, which I don't have.
« Reply #6867 on: Thu, 20 March 2014, 19:40:27 »
They are using a "mailto:" type link. Just right click and copy email address, and paste in your web-based mail program or whatever you use to get your email.
All the modifiers on a G80-8113 or G80-8200 will work on a filco (the only noncompatible key is the spacebar and sometimes the enter key / pipe key) Keep in mind, though, that the windows keys and menu key are not doubleshot.
Offline BlueBär
« Reply #6868 on: Thu, 20 March 2014, 19:43:09 »
The bottom of the stem hits the bottom of the housing iirc. Total travel is 4mm and actuation is around 2mm, exact actuation point depends on the switch type.
« Reply #6869 on: Thu, 20 March 2014, 19:51:24 »
http://www.wireless-computing.com/products/mechanical-keyboard/
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=260
Offline Pacifist
  • on hiatus
« Reply #6870 on: Thu, 20 March 2014, 19:59:06 »
Ugh full size. That almost negates a major purpose of wireless: to be portable
« Reply #6871 on: Thu, 20 March 2014, 20:01:07 »
You asked for keyboards with cutouts for AA :p
BUT there was one or two of the older models a plum and maybe a noppo I think the plum may have used AA's and one of the noppo models wasn't wireless but had a door for a battery with nothing inside.
Offline Pacifist
  • on hiatus
« Reply #6872 on: Thu, 20 March 2014, 20:08:12 »
Thanks for the help! I'll check those out and see if I can just get the case. Otherwise an open air direct solder setup is what I'll have to stick with :p
« Reply #6873 on: Thu, 20 March 2014, 20:47:03 »
Whats a guy gotta do to get a nice set of white/beige doubleshots for a filco/qfr?
Anyone know what keyboards have all the right keys (besides caps)
Not having much luck in the classifieds.
Offline Melvang
« Reply #6874 on: Thu, 20 March 2014, 20:53:17 »
Thanks BlueBar.  I was thinking for some reason that the stem bottomed out on something other than the bottom of the housing.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #6875 on: Thu, 20 March 2014, 20:55:27 »
Keep looking :). If you want something nice, look for Originative's GMK white/beige set. It should have the kits you need for a Filco/QFR. It'll run you about $100 and you'll have to be quick on the draw, but you'll love 'em.
Offline zig_ziglar
« Reply #6876 on: Thu, 20 March 2014, 21:23:06 »
What's the name of that keyboard click sound emulation program that some people use with linear switches for audible feedback?
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6877 on: Thu, 20 March 2014, 21:27:44 »
This?
http://www.colorpilot.com/soundpilot.html
Or: https://www.grc.com/freeware/clickey.htm
« Last Edit: Thu, 20 March 2014, 21:30:50 by epzy »
Offline zig_ziglar
« Reply #6878 on: Thu, 20 March 2014, 21:43:18 »
This?
Thanks, mate.  ;D
Offline combataran
« Reply #6879 on: Thu, 20 March 2014, 21:55:15 »
I like Reds and Browns, dislike the Blacks and Blues. Should I go with a 45 or 55 uniform RF 87?
Cherry G80-1000HFD | CM Storm Spawn | Keypuller.com - Key Caps News & Database
Offline Pacifist
  • on hiatus
« Reply #6880 on: Thu, 20 March 2014, 21:57:26 »
There's really no comparison between mx and topre. Some may claim so, but rubber is much different from plastic
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6881 on: Thu, 20 March 2014, 22:06:01 »
Seems to be appropriate, since you like the 45g actuation MX switches. Topre may be a bit heavier; but smoother. There's no way to tell if you would like 55g or 45g better though, sorry.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #6882 on: Thu, 20 March 2014, 22:14:05 »
What size of LEDs would one use for backlighting?
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6883 on: Thu, 20 March 2014, 22:15:19 »
2x3x4mm
« Reply #6884 on: Thu, 20 March 2014, 22:17:04 »
Filco Minila Air might work for you as well. I didn't realize you were asking for keyboard that used AA batteries.
« Last Edit: Thu, 20 March 2014, 22:24:26 by CPTBadAss »
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #6885 on: Thu, 20 March 2014, 22:17:14 »
2x3x4mm
Much appreciated
« Reply #6886 on: Thu, 20 March 2014, 22:23:07 »
I'm not sure I see the correlation since I don't think that it's as easy as saying "Oh I like light switches so I'll like light MX and light Topre". I think the different switch types (Alps, Topre, MX, Buckling Spring, etc) are unique and it's going to be hard to judge by comparing from one type to another. I would suggest you try both to judge it. Plus, none of us know exactly what you're looking for in a switch. It's personal preference more than anything.
^This. Be patient and keep looking. Dorkvader and I suggested some Cherry boards that would fit your needs. Hunt eBay and the classifieds.
Offline yasuo
  • spanengan puyeng newbie
Logitech MK220 Colemak DH
Offline BlueBär
« Reply #6890 on: Fri, 21 March 2014, 09:25:42 »
Comparing the pics from the BTC switches to the Futabas, I also change my guess to BTC  ;)
(BlueBär so smart)
Offline BlueBär
« Reply #6891 on: Fri, 21 March 2014, 09:27:52 »
(BlueBär so smart)
Had a good teacher :-*
« Reply #6892 on: Fri, 21 March 2014, 09:29:15 »
(BlueBär so smart)
Yup, it definitely is BTC.  I scored one of those boards cheap a long time ago for the caps.  They feel like disappointment.
« Reply #6893 on: Fri, 21 March 2014, 09:30:04 »
LOL. That made me laugh for no reason. That's how I'm describing switches I don't like from now on.
Offline lcs
  • Lover of Grape Drank
  • はやく
« Reply #6894 on: Fri, 21 March 2014, 09:31:17 »
CPTBadAss feels like disappointment.
Offline intelli78
« Reply #6895 on: Fri, 21 March 2014, 14:38:33 »
Is there any place with 62g springs in stock right now?
« Reply #6896 on: Fri, 21 March 2014, 14:39:58 »
Originative has them but I'm not sure if those orders are being fulfilled right now. Other than that...in stock *right now*? I can't think of anyone...maybe GON's site has some? Or imsto? Not 100% on their stocks.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #6897 on: Fri, 21 March 2014, 14:40:30 »
There is a GB happening.
Offline intelli78
« Reply #6898 on: Fri, 21 March 2014, 14:56:14 »
Thanks guys. Looks like no springs on Imsto or Gon's sites, and Originative is sold out. Placed an order in the GB.
Offline Pacifist
  • on hiatus
« Reply #6899 on: Fri, 21 March 2014, 20:37:01 »
Is there/how easy is it to get 7x Plate mounted stabs, preferably cherry but also costar can work
