Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6230262 times)
0 Members and 9 Guests are viewing this topic.
Offline Pacifist
  • on hiatus
« Reply #6400 on: Sun, 23 February 2014, 21:28:31 »
GL on the vortex. I've been waiting for it too and Vortex seems to have stopped doing it for some reason...
Offline yasuo
  • spanengan puyeng newbie
« Reply #6401 on: Mon, 24 February 2014, 05:32:23 »
what is name  fn on AHK? :)  i've tried fn or function not work
Logitech MK220 Colemak DH
Offline BlueBär
« Reply #6402 on: Mon, 24 February 2014, 05:55:28 »
The function key has no keycode and can therefore not be simulated. If you press the function key on your keyboard, no signal gets sent to your PC, only if you press a key combination with the function key.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #6403 on: Mon, 24 February 2014, 10:11:18 »
yup because the function key is handled at the keyboard firmware level.  I wonder if it would be possible to create function layer inside AHK?
Offline BlueBär
« Reply #6404 on: Mon, 24 February 2014, 10:17:34 »
If you would use for example one of the Windows keys as the FN key, absolutely.
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #6405 on: Mon, 24 February 2014, 11:28:15 »
Who ran the original SoWare set GB? Was it Sherry?
« Reply #6406 on: Mon, 24 February 2014, 11:29:29 »
It was a Korean GB, to go along with The Cheat keyboard.
Offline digi
  • elite af tbh
« Reply #6407 on: Mon, 24 February 2014, 11:30:18 »
Ok thanks JD
Offline Dreamre
    • kbdlife
Offline laqq3
« Reply #6409 on: Mon, 24 February 2014, 19:43:44 »
One of the keys on my 1-year old Unicomp keyboard is no longer as clicky as the others; probably the spring has worn down.
Is there a way that I can fix this myself?
« Reply #6410 on: Mon, 24 February 2014, 20:02:04 »
« Reply #6411 on: Mon, 24 February 2014, 20:38:43 »
Try reseating the cap first. If not, you can order replacement parts from Unicomp.
Offline Dreamre
    • kbdlife
Offline yasuo
« Reply #6413 on: Mon, 24 February 2014, 21:36:34 »
How to get rid of printed PBT i want make blank?
Offline Pacifist
  • on hiatus
« Reply #6414 on: Mon, 24 February 2014, 21:37:57 »
Sandpaper?
But for dyesub and doubleshot, that would take forever
Offline Melvang
« Reply #6415 on: Mon, 24 February 2014, 21:56:57 »
Sandpaper?
Dye sub it would not be possible since the legend goes all the way through the cap.  Think plated through hole on a dual sided PCB.  for dyesub you might be able to use acetone but make 100% sure it is PBT and not ABS.  That or sandpaper.  But I would rather use some pretty fine stuff.  And do this by hand.  But personally I would either buy a new set or see if you can trade someone.
Offline yasuo
« Reply #6416 on: Mon, 24 February 2014, 22:01:41 »
actually the keycap is keycool PBT not dyesub just printed regular,
so better uses acetone or Sandpaper(I'm afraid of damaging the surface)though..
Offline Melvang
« Reply #6417 on: Mon, 24 February 2014, 22:09:41 »
if you are 100% sure it is PBT then acetone shouldn't damage them.  There was a test done on a youtube clip (i think it was for PBT dye sub back light friendly caps) where they applied acetone to the caps and it did nothing to the cap aside from the legend on the dye subs.
« Reply #6418 on: Mon, 24 February 2014, 22:13:11 »
acetone might or might not damage the printing. I would recommend trying it.
Acetone does not affect the base PBT at all. I have used it several times on the underside of PBT keycaps.
Offline LechnerDE
« Reply #6419 on: Tue, 25 February 2014, 02:03:55 »
Please report back after you tried the tipps from this thread.
I also want to remove the legends from the Stock Poker II PBT keys without affecting the base keycap.
If Acetone is really the answer, I'll try it too :)
Offline Rena
« Reply #6420 on: Tue, 25 February 2014, 07:24:41 »
So pertaining to the message I sent the eBay seller from my alps thread, he responded saying he would remove a keycap but he's not sure how. Honestly I don't have much experience myself removing keycaps without the proper tools so basically
What advice can I give this guy on removing an alps keycap by hand? (I thought this question was more appropriate here)
« Reply #6421 on: Tue, 25 February 2014, 07:56:54 »
Get a wire keypuller, I find those work best for Alps keycaps. You can use other tools, as shown in the OP, but the wire keypuller is the best. Rock the keycap back and forth from corner to corner. Check out this guide. It will be hard to pull off, Alps caps are hard to remove.
« Last Edit: Tue, 25 February 2014, 08:36:23 by CPTBadAss »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #6422 on: Tue, 25 February 2014, 08:15:40 »
Is there anywhere to find MX green switches? I've only ever seen them on QFR's , does CM have some kind of exclusive deal w/ Cherry?
« Reply #6423 on: Tue, 25 February 2014, 08:20:23 »
1) Is there anywhere to find MX green switches?
2) Does CM have some kind of exclusive deal w/ Cherry?
1) 7bit's Group Buy on Deskthority. Not sure if there's other sources right now. You could also try Ghetto Greens.
2) No. Ducky has MX Green boards as well.
Offline Rena
« Reply #6424 on: Tue, 25 February 2014, 08:33:55 »
Alright, sent the message to the seller with your advice and included some pics from that guide on imgur
there's this: http://www.vendio.com/stores/E-sports-Gaming-equipments/item/shop-mechanical-keyboard-by-sw/leopold-fc660m-mechanical-keyb/lid=36574115
Offline stancato9
« Reply #6425 on: Tue, 25 February 2014, 13:47:11 »
Could someone quickly tell me the ideal wattage you would want in a soldering iron for working on PCBs.  Thanks.
Poker 2 - MX Red
« Reply #6426 on: Tue, 25 February 2014, 13:49:07 »
Hakko 888D runs at 65 Watts. Is there a reason you need wattage? Normally people ask about temperature.
Offline stancato9
« Reply #6427 on: Tue, 25 February 2014, 14:12:58 »
The cheap ones I'm looking at at the source are only displaying the wattage.
Poker 2 - MX Red
« Reply #6428 on: Tue, 25 February 2014, 14:14:18 »
Ah I see. Well I know people have soldered with a Radio Shack 15W iron so it really depends on what kind of iron you want.
Offline stancato9
« Reply #6429 on: Tue, 25 February 2014, 14:17:45 »
Yeah thanks. Ill probably pick up the 60 watt one. Any recommendations on solder? Just for a switch change.
http://www.thesource.ca/estore/category.aspx?language=en-CA&catalog=Online&category=Soldering+Tools&sort=1&pagenum=1
Poker 2 - MX Red
« Reply #6430 on: Tue, 25 February 2014, 14:20:45 »
If you're asking to pick something from the link you gave, I think this will be fine. You know there's a soldering thread you can look through for help too right? Just FYI.
Offline Dreamre
    • kbdlife
« Reply #6431 on: Tue, 25 February 2014, 14:25:31 »
I wouldn't get a 60w soldering iron as it might get too hot for the PCB. You should be okay with 25W/35W/40W irons.
I'd also get an iron that has replaceable tips that can be easily found (Weller, for example).
« Last Edit: Tue, 25 February 2014, 14:27:04 by Dreamre »
Offline Melvang
« Reply #6432 on: Tue, 25 February 2014, 14:26:00 »
Here is a link the the soldering thread
« Reply #6433 on: Tue, 25 February 2014, 14:27:53 »
If it's a fixed temperature soldering iron, I'm not sure how the wattage plays a factor in temperature. I think dreamre might be right since mkawa's learn to solder kit has an iron that only goes up to 30W. But again, I'm not 100% sure.
Offline Dreamre
    • kbdlife
« Reply #6434 on: Tue, 25 February 2014, 14:31:02 »
Depending on the iron you get, some irons regulate temperature while some don't.
Offline Rena
« Reply #6435 on: Tue, 25 February 2014, 18:15:46 »
Is it there a place to obtain these keycaps:
Without buying the keyboard? I thought for sure there are people who bought these caps separately some how. Really interested in getting them for the filco MJ2.
« Reply #6436 on: Tue, 25 February 2014, 18:18:39 »
I thought MK.com had them at one point. Maybe Ducky has them directly on their site? I'm not sure off the top of my head where to get those though. You can try finding an Imsto PBT set that is similar to that color scheme though.
Offline Rena
« Reply #6437 on: Tue, 25 February 2014, 18:22:52 »
MK.com has all the boards with those keycaps but not the caps alone, and neither does ducky's site. Imsto only has 4 listings for whole sets right now and while there is both an entire blue and dark grey set, they aren't the combination with the ducky unfortunately.
« Last Edit: Tue, 25 February 2014, 18:27:15 by Rena »
Offline Melvang
« Reply #6438 on: Tue, 25 February 2014, 21:47:20 »
Relating to plate manufacturing would .100" be enough space between holes?  Or would this warp real bad?
« Reply #6439 on: Tue, 25 February 2014, 23:36:50 »
Thickness of plate/type of hole (round, square, keyswitch, stabilizer)/plate material ?
Offline Melvang
« Reply #6440 on: Tue, 25 February 2014, 23:49:35 »
modified keyswitch hole 304 stainless standard thickness.
Offline intelli78
« Reply #6441 on: Wed, 26 February 2014, 01:29:35 »
Do these come with non-duck replacements for the win keys?
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=699
« Reply #6442 on: Wed, 26 February 2014, 06:50:56 »
I'm pretty sure what you see is what you get.  I don't recall any recent ducky boards with any extra keys for the win keys.
« Reply #6443 on: Wed, 26 February 2014, 08:13:43 »
A Keycool vendor just posted this which might interest you Rena.
I would agree with Ray. The OMG board that I just opened didn't have replacement keys.
Offline Rena
« Reply #6444 on: Wed, 26 February 2014, 08:59:05 »
oh yeah, I think I'll definitely be getting these. Is this something I'd have to buy through a proxy or will it be made available by an English retailer soon?
I don't have much experience buying keycaps.
« Reply #6445 on: Wed, 26 February 2014, 09:03:23 »
I'm honestly not sure where they're going to be available. Best way to find out is to ask in the thread.
Offline nkzt
  • DIY dye-sub explorer
    • Keycap DIY
« Reply #6446 on: Wed, 26 February 2014, 09:43:22 »
I'm going to buy keycaps from SP.
Are SP's row 5 keycaps suitable for common Cherry MX keyboards, like Filco?
Many manufacturers use row 1 keycaps for function keys. I'm afraid that the row 5 keycaps are not compatible with such keyboards.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #6447 on: Wed, 26 February 2014, 10:05:28 »
I'm not totally sure what you mean. If the keycaps have Cherry MX stems, they're compatible with Cherry MX keyboards (Filco included). Could you link to the exact keycaps you're planning to buy?
Offline nkzt
    • Keycap DIY
« Reply #6448 on: Wed, 26 February 2014, 10:13:56 »
Thanks riotonthebay.
I'm going to buy blank keycaps. http://keycapsdirect.com/pdfs/DCSFamily.pdf
Row 5 is taller than row 1 and the sides' slopes are different. I'm afraid that those differences may cause some problem what I don't know yet.
  • Cherry Peasant
  • keycult.com
« Reply #6449 on: Wed, 26 February 2014, 10:16:43 »
There won't be any issues adding them to your board, but I don't think that kind of uniform profile will be comfortable to type on. This page shows the usual row configuration for DCS-profile keycaps.
