Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6230214 times)
0 Members and 9 Guests are viewing this topic.
« Reply #7750 on: Mon, 12 May 2014, 20:20:10 »
What are all the different types of KMAC's and what are the difference, (KMAC2, KMAC1.2 etc.), and what does LE stand for like KMAC LE?
I'm pretty sure KMAC 1, 1.2, and LE were all the same but there were supposed issues with the anodization. I guess the LE has different anodization on the top and bottom halves. But I own and LE and I can't spot the difference. LE I would imagine is limited edition.
My question is, WHY are there two types of switches?  Is there any benefit to have PCB mounted VS Plate mounted, or visa versa?
Depends on the PCB and the PCB manufacturer I guess. As seen above, there's PCBs that can accept PCB mount and some that can only take Plate mount. Customer requirements. Also I agree with what BlueBar said earlier.
2. Plate mounted switches feel more solid. If you PCB mount switches your board can tend to flex a bit depending on how the PCB is supported by the case.
Offline ajx
« Reply #7751 on: Tue, 13 May 2014, 12:53:47 »
any cleaning stuff to remove mark of grease on keys?
Too bad that my fingers are naturally greasy
I use wipe on it and keys become eventually more greasy lol
« Reply #7752 on: Tue, 13 May 2014, 12:56:33 »
I like using alcohol wipes/moist towelettes or a cloth with isopropyl alchohol for quick cleans. If you want to do a proper clean, pull all the caps off, then put them in warm water. You can add dish soap or denture cleaning tablets (what I like using). Shake and let sit for 15 minutes. Rinse with water, then dry with a towel. Caps are clean again and if you use denture tabs, they smell minty :D
« Last Edit: Tue, 13 May 2014, 13:03:47 by CPTBadAss »
Offline juguerre
« Reply #7753 on: Tue, 13 May 2014, 14:31:23 »
Hi! Now that  EK's RF 55g is out of stock ... Is there any other store selling RF 55g? I just can't find nothing out there ...
Realforce 105 variable (at work)     Ducky G2Pro ISO TKL Mx-Clear    Realforce 87 55g (home)
Offline BlueBär
« Reply #7754 on: Tue, 13 May 2014, 14:44:22 »
There are some Amazon.co.jp listings that say "30/45/55g" but I don't see where you would select your desired weight (not that I know Japanese).
http://www.amazon.co.jp/s/...
Offline juguerre
« Reply #7755 on: Tue, 13 May 2014, 15:06:52 »
I think that "30/45/55g" stands for variable weighted keyboards that have all those switches....  :rolleyes:
Offline BlueBär
« Reply #7756 on: Tue, 13 May 2014, 15:16:56 »
Oh right, I forgot about the 55g Esc. Sorry I don't know any other source then :(
Offline juguerre
« Reply #7757 on: Tue, 13 May 2014, 15:27:06 »
Thanks any way!  ;D ... so ... I have to wait  :'(
Offline Pacifist
  • on hiatus
« Reply #7758 on: Tue, 13 May 2014, 18:05:28 »
What TKL boards are there that allow
1. Reflashing new firmware
and
2. Backlighting
and
3. 1.5 1 1.5 7 1.5 1 1.5 bottom row and 1.75 right shift
Only one I know is KMAC, but that only fits 1 and 2, not 3.
« Reply #7759 on: Tue, 13 May 2014, 18:16:39 »
Organic solvents (eg "citrus oil" cleaners) work well on oils but can be damaging to some plastics.
"wax on - wax off" quickly and you should be OK
Soaking in hot soapy water is better, but much harder.
- D Trump 2026-10-24
Offline divito
« Reply #7760 on: Wed, 14 May 2014, 01:39:36 »
One of my sisters is a Korean fanatic. Showed her someone's keyboard with English and Hangul caps, she seemed quite interested. What's the easiest way to get caps, and where?
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
« Reply #7761 on: Wed, 14 May 2014, 06:56:05 »
http://imsto.cn/index.php?route=product/product&path=62&product_id=62
« Reply #7762 on: Wed, 14 May 2014, 07:17:41 »
and
2. Backlighting
and
The Cheat, the LZ customs, Orion.
Offline colomb
« Reply #7763 on: Wed, 14 May 2014, 10:39:49 »
What TKL keyboards are there with:
1. 45g (or 55g) uniform topre silent switches
2. Dip switches to remap ctrl & caps-lock
« Reply #7764 on: Wed, 14 May 2014, 12:10:12 »
Not sure a keyboard like this exists In a stock form tbh. I'm definitely the wrong person to ask about Topre boards though so hopefully someone chimes in.
Offline intelli78
« Reply #7765 on: Wed, 14 May 2014, 13:00:08 »
edit: there are none with silent and uniform switches.
« Reply #7766 on: Wed, 14 May 2014, 13:00:57 »
Just the silent Realforce TKLs. Check EliteKeyboards.
Realforces have a dipswitch to swap those Ctrl and Caps Lock?
Offline intelli78
« Reply #7767 on: Wed, 14 May 2014, 13:02:20 »
Yeah, they do, but my answer was wrong because he wants uniform and silent switches. AFAIK,  silent switches are only available on the variable weighted models.
« Reply #7768 on: Wed, 14 May 2014, 13:04:06 »
Yeah, they do
That's good to know.
But my answer was wrong because he wants uniform and silent switches. AFAIK,  silent switches are only available on the variable weighted models.
Yeah I thought the only way to get a silent TKL Topre board was to do the dental band or o-ring mod. And perhaps swap in domes/bands from another Type S board. But I could easily be mistaken.
Like I said, I'm sorely lacking in Topre knowledge.
Offline intelli78
« Reply #7769 on: Wed, 14 May 2014, 13:05:22 »
Yeah, they do
Yes, unless you are OK with variable weighting, then you can buy one of the stock silent models on ek.
Offline maxtortheone
« Reply #7770 on: Wed, 14 May 2014, 16:40:56 »
I'm curious on the dimensions of my soon to arrive Model M 122 key. And weight.
Keyboards: IBM Model M 122 Key Terminal Board;  Logitech G710+; Focus FK-2001 w/ Complicated ALPS
Offline Pacifist
  • on hiatus
« Reply #7771 on: Wed, 14 May 2014, 16:55:07 »
1. Big
2. Heavy
Offline Eszett
« Reply #7772 on: Wed, 14 May 2014, 17:06:39 »
How many times can I flash a programable keyboard controller? Does it “wear off”?
Offline Pacifist
  • on hiatus
« Reply #7773 on: Wed, 14 May 2014, 17:07:45 »
1. Infinite
2. no......
Offline zig_ziglar
« Reply #7774 on: Wed, 14 May 2014, 17:10:04 »
I have acquired a vintage keyboard that has a 5 pin metal plug. What adapter do I need? (Forum search for "5 pin" does not succeed.)
Offline Pacifist
  • on hiatus
« Reply #7775 on: Wed, 14 May 2014, 17:12:37 »
Pic? Lots of 5 pin plugs
Offline intelli78
« Reply #7776 on: Wed, 14 May 2014, 17:14:39 »
It is probably an AT/XT connector. If the keyboard uses the AT protocol, you need an AT --> PS2 and a PS2 --> USB. If it uses XT, you need a Soarer's converter or similar, and it will probably be more effort than you want to put in, unless you really love that kb.
Offline BlueBär
« Reply #7777 on: Wed, 14 May 2014, 17:19:24 »
I have a Cherry G80-2100 here which should be about the same size, it's ~51cm long and ~21cm wide.
Offline Eszett
« Reply #7778 on: Wed, 14 May 2014, 17:31:34 »
@Pacifist thanks and peace!
Offline zig_ziglar
« Reply #7779 on: Wed, 14 May 2014, 17:38:59 »
Thanks for the reply. The keryboard has an AT to XT switch, so you can select the "mode", I guess. So best path fowards is to procure an AT -> PS2 adaptor? Excuse my ignorance, but what is AT and XT? Cheers
Offline Pacifist
  • on hiatus
« Reply #7780 on: Wed, 14 May 2014, 17:41:25 »
Different types of scancodes
« Reply #7781 on: Wed, 14 May 2014, 17:58:39 »
In addition to what intelli78 mentioned, you can buy a AT/DIN5 to PS2 adaptor. I have that adapter and then a PS/2 to USB adapter to hook up my Minitouch to my computer.
I can't find the dimensions for sure but ClickyKeyboards says that packed, the dimensions are as follows:
The shipping weight of these keyboards is approximately 6-7 pounds (2.7 kg). A cardboard box with the minimum dimensions of 24" x 10" x 4"
But what is AT and XT?
They were two types of IBM computer systems, XT and AT, which seem to use different connectors in terms of keyboards. The difference between the systems can be found in a chart I found in what appears to be a report on IBM computers. Link is here. I can't find the original report or link to the report unfortunately.
More information can be found here on XT and here on AT.
1. Big
2. Heavy
Do you really think answers like these are helping people? If you don't know, just leave it alone instead of spamming this thread with ridiculous answers.
« Last Edit: Wed, 14 May 2014, 18:13:33 by CPTBadAss »
Offline zig_ziglar
« Reply #7782 on: Wed, 14 May 2014, 18:15:43 »
1. Big
2. Heavy
Thanks for that, mate. I found a $2 female AT to male PS2 on eBay :) Then I can just use one of those dual PS2 (mouse+kb) plugs to USB male to complete the chain.
Offline intelli78
« Reply #7783 on: Wed, 14 May 2014, 18:18:52 »
Probably; but not all PS2 to USB adapters are created equal. The Ziotec blue cube is good, and mkawa also has another good one for sale. Both of those have wide compatibility. Your particular unit may or may not work with your particular keyboard. Try it and see.
Also, it's always appreciated to pare down your quoted text to the essentials  ;)
« Reply #7784 on: Wed, 14 May 2014, 18:21:58 »
Probably; but not all PS2 to USB adapters are created equal. Mkawa also has another good one for sale. Both of those have wide compatibility.
Agreed, I vouch for the one that mkawa and Geekhackers is selling.
Offline zig_ziglar
« Reply #7785 on: Wed, 14 May 2014, 18:32:52 »
Not a problem!
Thanks for the link. I guess 5 times the price is worth the savings on frustration and time. I can't find any AT to ps2 adaptors locally, so I'll have to import one from the UK I think.
« Reply #7786 on: Wed, 14 May 2014, 18:34:27 »
IBM F AT Personal Computer keyboard
Can any of you please give me the quick dimensions of the footprint of the F AT?
Mine is packed and stored deep, and I can't seem to find the dimensions online.
Offline zig_ziglar
« Reply #7787 on: Wed, 14 May 2014, 18:35:14 »
Actually, I can't tell from the photo - is the GH ps2-usb a female or male ps2?
« Reply #7789 on: Wed, 14 May 2014, 18:40:05 »
I'm trying to get the dimensions now. Weight seems to be 6.2 lbs, according to Clickykeyboards.
Female PS/2
« Reply #7790 on: Wed, 14 May 2014, 18:51:37 »
Thanks, I just need to cut a rubber mat for somebody.
It is always hard with that one, because "IBM AT keyboard" turns up thousands of hits. Mine hasn't seen the light of day in a year or 2, although I keep meaning to bring it out and do a full ANSI mod on it.
Selling custom-cut keyboard mats has made me aware of how very different they all are!
« Reply #7791 on: Wed, 14 May 2014, 19:03:25 »
Dimensions as measured by ninjadoc.
Width (think 1 to Backspace): 20.5 inches (about 18.5 without the leg adjusters)
Height (think Escape to Left Control): 8.5 inches
Thickness (bottom of the keyboard to the top half): 1.5 inches
« Last Edit: Wed, 14 May 2014, 19:17:59 by CPTBadAss »
Offline zig_ziglar
« Reply #7792 on: Wed, 14 May 2014, 19:07:17 »
I have checked out via Paypal and there are no shipping charges applied. Do they ship internationally for free?!
« Reply #7793 on: Wed, 14 May 2014, 19:11:52 »
I have no idea how Geekhackers.org's shipping works because it's new. If there's an issue or question, feel free to ask here and/or PM mkawa.
« Reply #7794 on: Wed, 14 May 2014, 19:15:40 »
Width (think Escape to F12): 20.5 inches (about 18.5 without the leg adjusters)
Huh? The F AT does not have F12 and Escape is in the numpad area.
Those dimensions seem awfully large, are we talking about the 84-key Model F AT?
« Reply #7795 on: Wed, 14 May 2014, 19:17:47 »
I'm sorry, think across from 1 to backspace. I just put those in so you can visualize which direction I'm talking about. And yes, the 84 key Model F AT.
« Last Edit: Wed, 14 May 2014, 19:20:34 by CPTBadAss »
Offline zig_ziglar
« Reply #7796 on: Wed, 14 May 2014, 19:18:37 »
It looks like a bug that really needs to be fixed asap, as I had to sign up and add an address to my account and then check-out NOT using Paypal before it applied International Shipping. This in itself is not a problem, however, I could have checked out for $12 only instead of $22.
« Reply #7797 on: Wed, 14 May 2014, 19:19:35 »
So comment in that thread?
Offline zig_ziglar
« Reply #7798 on: Wed, 14 May 2014, 19:38:11 »
Have done so now :)
« Reply #7799 on: Wed, 14 May 2014, 19:38:53 »
Have done so now :)
Great! Here's to hoping you get your adapter soon :D
