Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6230964 times)
« Reply #7950 on: Thu, 22 May 2014, 07:23:16 »
I'm sure I will get more then one answer, but what is the best solder for soldering switches?
I use Kester 44 .031" diameter. I think mkawa is still selling it.
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #7951 on: Thu, 22 May 2014, 07:40:56 »
Okay.   Thanks CPT.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
« Reply #7952 on: Thu, 22 May 2014, 11:56:47 »
according to the description on geekhackers.org mkawa sells Kester 44 63/37 Sn/Pb RA 0.02" Solder
http://www.geekhackers.org/collections/soldering-tools-and-supplies/products/activate-rosin-core-fine-pitch-eutectic-leaded-solder
unless he is selling other solder not listed.
« Reply #7953 on: Thu, 22 May 2014, 11:57:49 »
Then apparently I'm using .020" diameter lol.
Offline intelli78
« Reply #7954 on: Thu, 22 May 2014, 12:37:04 »
Is that Kester solder considered no-clean?
« Reply #7955 on: Thu, 22 May 2014, 12:38:42 »
* CPTBadAss shrugs
I don't ever clean my PCBs after soldering. Never had an issue.
Offline Pacifist
  • on hiatus
« Reply #7956 on: Thu, 22 May 2014, 12:39:56 »
* CPTBadAss shrugs
I tried cleaning my PCBs after soldering but I never got anything off.
« Reply #7957 on: Thu, 22 May 2014, 12:40:45 »
it's technically no-clean, but i like to clean RA flux first, because it's sticky and annoying, and only gets more sticky and annoying as it dries out, but also because even though it's no-clean in an industrial sense, it still leaves a very mildly active residue and you will get the best results if you clean it up.
Offline intelli78
« Reply #7958 on: Thu, 22 May 2014, 12:48:05 »
Thanks  :thumb:
Offline Lain1911
  • God of the Wired
« Reply #7959 on: Thu, 22 May 2014, 14:25:11 »
Do metal keycaps such as zinc and aluminum pretty much last forever?
« Reply #7960 on: Thu, 22 May 2014, 14:28:21 »
I can't find the picture or thread right this second but there's a disgusting picture of zinc keycaps reacting with someone's finger oils or something. They looked horrible. I dont think zinc keycaps are very durable.
I don't know much about aluminum keycaps. I suppose I could put one of my aluminum novelties on a daily driver and see what happens.
Offline Lain1911
  • God of the Wired
« Reply #7961 on: Thu, 22 May 2014, 14:35:57 »
Ah the oils, good point.
Offline Jixr
« Reply #7962 on: Thu, 22 May 2014, 20:27:57 »
How do you turn on PokerX's LEDs?
Offline Pacifist
  • on hiatus
« Reply #7963 on: Thu, 22 May 2014, 20:53:00 »
poker x doesn't have LEDs, or I'm not aware of them
Offline phoenix1234
« Reply #7964 on: Thu, 22 May 2014, 21:17:25 »
No, it does have leds on some positions (esc, spacebar) .
These leds were designed for changing mode.
To turn those led on, we need to press : Fn+Q or Fn+Spacebar
Plus, as you can see in the Poker X that I just modded the plate yesterday, it also has led holes so we can mode the leds with additional wiring. Indeed, this non-trivial task, but we know they are there once we need  ;D.
I like linear switches
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #7965 on: Thu, 22 May 2014, 22:39:27 »
What would you clean it with?   Isopropyl Alcohol?
WTB/WTS/WTT ---->
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #7966 on: Thu, 22 May 2014, 22:45:48 »
Yes, as high of percentage as you can find.  Highest I have available locally is 91%.
Speaking of which, anyone know where I can find hydrogen peroxide higher than a 4% concentration for doing retro brite work?
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #7967 on: Thu, 22 May 2014, 22:47:57 »
Okay.  Thanks Melvang.
WTB/WTS/WTT ---->
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #7968 on: Thu, 22 May 2014, 23:00:11 »
http://www.purehealthdiscounts.com/h2o2.htm
you gotta scroll down near the bottom to find the actual product
Offline SpikeBolt
  • √(4) != -2
« Reply #7969 on: Fri, 23 May 2014, 14:06:26 »
Undecided in which keyboard to buy: Ducky Shine 3 TLK or Filco MJ2 Ninja TKL.
The backlighting is a non-factor for me. Which has the better build quality?
Offline Melvang
« Reply #7970 on: Fri, 23 May 2014, 14:10:39 »
Build quality is very good on both.  The ducky has a removable cable with cherry stabilizers, while the filxo has a fixed cable and costar stabilizers.
Offline SpikeBolt
  • √(4) != -2
« Reply #7971 on: Fri, 23 May 2014, 14:14:16 »
I don't mind the cable being fixed but I don't know the difference in feel between the stabilizers. Which keyboard do you prefer?
Offline studybreak
« Reply #7972 on: Fri, 23 May 2014, 14:15:17 »
Would this connector (http://www.amazon.com/SF-Cable-Keyboard-Adapter-MiniDin6/dp/B0016RTO1M/ref=pd_bxgy_e_text_y be ) be likely to allow using a 5-pin 122 key Model M on a modern computer without dead keys?
Offline Melvang
« Reply #7973 on: Fri, 23 May 2014, 14:19:42 »
I personally prefer costar or cherry if they are clipped.  Cherry stabs that are not clipped feel very mushy at the bottom of the keystroke.  Some people like that some don't.
« Reply #7974 on: Fri, 23 May 2014, 14:30:12 »
I *think* so? I can't remember if you can just use a converter on a terminal board though.
If I had to pick between the two? Filco. But I'm a Filco fanboy.
« Reply #7975 on: Fri, 23 May 2014, 14:50:58 »
I own both,, I like my Filcos more. The ducky has a lot of strange issues with my VOIP softwares.
Offline SpikeBolt
  • √(4) != -2
« Reply #7976 on: Fri, 23 May 2014, 15:02:10 »
I'm already pretty sold on the Filco, but you elaborate on why you prefer it? (other than the voip software thing which seems awkward)
« Reply #7977 on: Sat, 24 May 2014, 11:58:13 »
The Filco is lighter, which is nice when I want to keep my keyboard in my lap (which is often). The LEDs in the Ducky's spacebar shine in my face when I lean back, which is really annoying, and leads me to keep them off 100% of the time. My USB-A to mini-B cable has some problems, but since the Filco has a non-detachable cable, these issues are not present. Filco does not twist as much as the Ducky in the "Twist test" but my black MJ2 makes some nasty creaking. Filco has more custom case options. Ducky's QC has been known to be lacking in some parts, mainly LED testing.
I could go on, but I just woke up and this post probably reads like crap.
Offline domoaligato
« Reply #7978 on: Sat, 24 May 2014, 13:01:28 »
Filco's are built like tanks. they have the best build quality of pretty much every out of the box cherry keyboard (some actual cherry brand keyboards are better). I would choose a cm storm qfr before a ducky also.
Filco > QFR > Ducky as long as led's are not important.
Eventually you might move past all this TKL and move to a 60%, in which case the search begins again :)
Offline epzy
  • HHKB Fiend
  • ded
« Reply #7979 on: Sat, 24 May 2014, 13:10:49 »
I'd go with the Ducky just because I think it feels much better to type on than my Filco's.
Offline domoaligato
« Reply #7980 on: Sat, 24 May 2014, 13:28:48 »
it all comes back to personal preference. :)
I have a model f and I love it more then any of my cherry mx boards, but it is too loud to use at home(wife hates it) or at work(coworkers hate it).
So it sits in a closet until one day that either my wife leaves me or I change jobs. lol.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #7981 on: Sat, 24 May 2014, 14:25:03 »
Random question: who would I talk to to get the Geekhack logo in AI so I can print it off large in quality?
Offline domoaligato
« Reply #7982 on: Sat, 24 May 2014, 14:28:02 »
Which logo? There are a few... oh wait there is only nostalgia ^_^
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #7983 on: Sat, 24 May 2014, 16:11:10 »
Just the Geekhack text.
« Reply #7984 on: Sat, 24 May 2014, 17:16:38 »
Depends on the board.
Some, especially terminal emulator M122's will work on PS/2 with either no problem or with no problem once a jumper is set.
Some work more like the F122's and "barely" work on PS/2.
« Reply #7985 on: Sun, 25 May 2014, 11:27:56 »
So you can check out this Wiki entry which should have the logo. mkawa and Krogenar should have the logo files. The "Geekhack" font is also called Special Elite. An example of what this font looks like can be found in bunnylake's sale thread. Look at the little card with the text on it.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #7986 on: Sun, 25 May 2014, 16:31:22 »
Thx Cpt'n
« Reply #7987 on: Sun, 25 May 2014, 16:48:10 »
Isn't that an ordinary AT-to-PS/2 type adapter? I have never seen an M-122 with that plug.
The early ones that I have had my hands on had the 240-degree connection, and the later ones were RJ-45-ish or PS/2.
- D Trump 2026-10-24
Offline Lain1911
  • God of the Wired
« Reply #7988 on: Sun, 25 May 2014, 19:36:36 »
Is it rare to see a Poker II on Massdrop or on sale? Rare as in 2-3 times a year or none at all?
Offline Pacifist
  • on hiatus
« Reply #7989 on: Sun, 25 May 2014, 19:37:57 »
like a month ago there were p2's on md
Offline Lain1911
  • God of the Wired
« Reply #7990 on: Sun, 25 May 2014, 19:40:30 »
Mixed emotions of happy and sad :\
thanks tho heh
Offline epzy
  • HHKB Fiend
  • ded
« Reply #7991 on: Sun, 25 May 2014, 19:49:37 »
thanks tho heh
They offer MX Clear Poker 2's now, which is unique.
« Reply #7992 on: Sun, 25 May 2014, 20:47:56 »
thanks tho heh
Seriously? I've never noticed those. Interesting.
Offline combataran
« Reply #7993 on: Sun, 25 May 2014, 21:31:36 »
What's the difference between the layouts of the Duck Mini v2 and the Duck Eagle?
Cherry G80-1000HFD | CM Storm Spawn | Keypuller.com - Key Caps News & Database
« Reply #7994 on: Sun, 25 May 2014, 21:50:52 »
I thought both were 60% boards with different cases. Also I think the Eagle is MX only and the Mini can take both MX and Alps. Same layout iirc.
Offline combataran
« Reply #7995 on: Sun, 25 May 2014, 23:33:39 »
Guess that explains the lower price point then.
Offline Melvang
« Reply #7996 on: Mon, 26 May 2014, 03:02:46 »
Anyone know what the radius of curve in Model M's steel back plate is?
Offline asgeirtj
« Reply #7997 on: Mon, 26 May 2014, 13:20:42 »
I was wondering about the availability of tenkeypads with red switches.  So far i've found these
http://www.ebay.com/itm/Leopold-FC210TP-Mechanical-Tenkeypad-Cherry-MX-Red-Switches-21-Key-PBT-Black-/281342246330
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=435
Was wondering if there were more options with red switches?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Offline BlueBär
« Reply #7998 on: Mon, 26 May 2014, 13:48:16 »
Filco also offers a numpad, but I can't find one with reds, so apart from custom numpads I don't think there is one.
« Reply #7999 on: Mon, 26 May 2014, 14:07:42 »
I think Keycool has some numpads with Reds but I'm not 100% sure. I like the Filco numpad so maybe you can just find one you like and the swap in new switches?
