Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6017348 times)
0 Members and 9 Guests are viewing this topic.
« Reply #8050 on: Thu, 29 May 2014, 18:08:37 »
Why not get a black Pro 2 and a Type-S and swap the plungers. Then you could always sell the white "non-Type-S" haha
« Last Edit: Thu, 29 May 2014, 18:14:27 by jdcarpe »
Offline juguerre
« Reply #8051 on: Fri, 30 May 2014, 01:08:07 »
Because I have a thin desk at my home workspace I get a "clock-clock"  instead of "click - click" from my kb. I think it's due to some resonate think. This is not happening when I  type with the kb on my lap. So,  which could be the best cheap solution for that? A mouse pad or something like that?
Realforce 105 variable (at work)     Ducky G2Pro ISO TKL Mx-Clear    Realforce 87 55g (home)
« Reply #8052 on: Fri, 30 May 2014, 01:10:55 »
I use some drawer liner under mine.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #8053 on: Fri, 30 May 2014, 02:32:50 »
Drawer liner or a small towel are both popular choices.
« Reply #8054 on: Fri, 30 May 2014, 07:00:45 »
For people who don't want to buy my EPDM mats.
- Franklin Roosevelt 1933
Offline BlueBär
« Reply #8055 on: Fri, 30 May 2014, 10:20:13 »
Three questions:
1. Can you remove plate mounted Cherry stabs by desoldering just the one switch in the middle?
2. I assume that the sliders of plate and PCB mounted Cherry stabilizers are identical. Is this correct?
3. Does clipping stabilizers affect the feel of Cherry plate mounted stabs?
Offline Melvang
« Reply #8056 on: Fri, 30 May 2014, 10:23:01 »
Three questions:
1.  If there is a slot in the plate connecting all three then yes, if not no.
2.  Yes.
3.  Yes, in the same way as clipping PCB mount.
Offline BlueBär
« Reply #8057 on: Fri, 30 May 2014, 10:28:37 »
Thanks for the quick reply!
Offline Melvang
« Reply #8058 on: Fri, 30 May 2014, 10:30:53 »
Not a problem.  Though there might still be a difference between plate and pcb mount cherry stabs just due to the plate.
Offline asgeirtj
« Reply #8059 on: Fri, 30 May 2014, 16:36:39 »
Thanks for answers on the o-rings sp keycaps issue.  I have blue switches to clarify.  So as I understand it it's basically impossible to use o-rings on sp keycaps? So my question is then, are  soft landing pads compatible with sp keycaps?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
« Reply #8060 on: Fri, 30 May 2014, 16:40:24 »
So how blue switches work, you're already going to have a louder switch to begin with. It's not "impossible", you'll just need to stack more o-rings to have it work, as you've already figured out. Soft landing pads have the same issue with the SP keycaps. You can also try the myriad of suggestions that were posted earlier. I highly suggest you put drawer liner in your keyboard.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #8061 on: Fri, 30 May 2014, 16:48:04 »
So is the right shift on the Leopold FC660M the same size as the right?
Offline Razor Lotus
« Reply #8062 on: Fri, 30 May 2014, 16:57:50 »
When do you need to use a ferrite bead when making a DIY cable?
Cause looking at some of our artisans making their own DIY cables, how come they don't need a ferrite bead?
« Reply #8063 on: Fri, 30 May 2014, 17:19:31 »
Is the right shift same as the right shift? Yes  :))
Is the right shift same as the left shift? No. According to eyesmiles and rjrich, you'll need two 2.25x shift keys.
I believe that it's to help with EMF interference. But I don't think there's a lot of EMF interference in cables. It's just there for overkill. So when people make them, it's nice to have but not 100% necessary.
« Reply #8064 on: Fri, 30 May 2014, 17:26:30 »
I have wondered about this a lot. They seemed very common a decade or 2 ago, and quite rare now.
Would you consider the need to be equal in just about any cable, or would some keyboards/cables/connectors be more prone to accumulate capacitance or some other property than others?
« Reply #8065 on: Fri, 30 May 2014, 17:31:40 »
I'm definitely not an authority on this but I suspect that like ESD, EMF is a lesser concern now. But like I said, I'm just assuming. It might be better to ask a cable maker or someone who understands much better such as mkawa or dorkvader.
Offline ideus
  • Björkö.
« Reply #8066 on: Fri, 30 May 2014, 18:08:10 »
The Leo 660M's right shift is 2.25u, the same size as the left shift key on any standard ANSI keyboard. It takes two shift keys in the same 2.25u size.
Offline combataran
« Reply #8067 on: Sat, 31 May 2014, 10:18:11 »
What is the appeal of OTD boards that justify their celestial prices?
Cherry G80-1000HFD | CM Storm Spawn | Keypuller.com - Key Caps News & Database
Offline Dubsgalore
« Reply #8068 on: Sat, 31 May 2014, 10:23:13 »
They are the best built customs, the group buys are pretty exclusive to enter and require a certain number of 'points' on OTD to even enter, and even after that, usually no more then 100~+ of each model are made once and never again. the most common 356 is the DGE with about 200 units made. There are two types of 356 minis as well, V1 and V2, V1 came in red, black and gunmetal, and V2 was much more recent and only came in red.
Offline combataran
« Reply #8069 on: Sat, 31 May 2014, 10:26:04 »
There's a more recent mini huh? Now I'm interested. What's the going price for a Mini v2?
Offline Dubsgalore
« Reply #8070 on: Sat, 31 May 2014, 10:29:57 »
$400 unassembled, $500-550 for assembled
« Reply #8071 on: Sat, 31 May 2014, 10:41:30 »
I've seen them go higher assembled. Somewhere in the $650 range.
Offline Dubsgalore
« Reply #8072 on: Sat, 31 May 2014, 10:46:30 »
Just for an assembled 356mini? Profit on OTD is really, really, really a big NO NO, so super high priced 356 series boards are not seen very often. the reason why the 356 series is the most wanted and most expensive/rare series of keyboards on earth is because once people have them, they literally are not let go of, ever. Geekhack always seems to have users that get clacks/keyboards and just sell them and give them up after a few weeks of use, but most people who actually can get their hands on a 356 board keep them for life.
Offline combataran
« Reply #8073 on: Sat, 31 May 2014, 10:51:03 »
Oh my, that IS pricey. Welp, better start saving.  ;D
That being said, what are the other better aluminium 60% cases out there(preferably with brass weights and a cheaper price tag)?
@Dubsgalore I've seen a 356cl and 356dge go for 12000RMB and 10000RMB respectively in a chinese board forum. The scary part is that the boards were actually sold.
Offline Dubsgalore
« Reply #8074 on: Sat, 31 May 2014, 10:52:46 »
If all you want is an aluminum 60% case, maybe the 356 series ain't the easiest option :)) , why not check out mechanicalkeyboards.com? they have $100 aluminum 60% cases there I think.. :)
« Reply #8075 on: Sat, 31 May 2014, 10:55:06 »
Combataran, the 356CL and DGE are BY FAR the most wanted Korean customs. They're considered the absolute best, which is why they sold for such ridiculous prices. 356L and 356N are close.
The only 356 board that multiple members of GH own is the 356mini. The rest are just too rare, and never really leave OTD members hands. I mean.. Tsangan has a 356N MK2, but that doesn't come near the 356CL/DGE, 356L or 356N.
More info on the series can be found here : http://deskthority.net/keyboards-f2/the-korean-custom-keyboards-1-356-series-t255.html?hilit=356CL
Worth noting there are other, non-356 OTD customs. The 456GT and 360corsa.
« Last Edit: Sat, 31 May 2014, 10:56:53 by Photekq »
Offline combataran
« Reply #8076 on: Sat, 31 May 2014, 10:56:58 »
All I see are TEX cases for pokers(too low a profile) and those horrible vortex cases. Anything between $170 and $250?
Offline Dubsgalore
« Reply #8077 on: Sat, 31 May 2014, 11:04:12 »
Few other members here have MK2s, but those members are all active OTD members, so it doesn't really count. The 456 and 360 Series boards can be looked at like triple A series if the 356 series is major leagues
Offline Dubsgalore
« Reply #8078 on: Sat, 31 May 2014, 11:07:02 »
Yeah I don't like the low profile cases either. Duck Poker cases exist..and pop up on kbdmania often, I just sold my LZCE but you see them pop up on GH and kbdmania sometimes, the Duck V2 cases can be used with most 60% pcbs I believe as well, that one may be the best to look out for now
Offline combataran
« Reply #8079 on: Sat, 31 May 2014, 11:11:46 »
That's the one with the raiser block right? Yeah I've been keeping an eye out for those too but no luck. That, and the 356mini. What about the FMJ and Hammer cases? Do they belong in their own category?
Offline Dubsgalore
« Reply #8080 on: Sat, 31 May 2014, 11:14:23 »
Nah I forgot about those, those are about in the same price range, $200~
If you're looking for a 356mini on geekhack, you're are almost definitely not going to find it, you're probably going to have to venture over to kbdmania to find one :P
and yes the Duck V2 has the raiser block. There was a GB for it a while ago but I think that'd be a great option for you. that or the FMJ/Hammer
Offline combataran
« Reply #8081 on: Sat, 31 May 2014, 11:19:45 »
How tolerant are the kbdmania folks towards foreigners? Chinese forums are one thing, Korean forums are a totally different beast. And what about OTD?
I think I'll just keep my scopes on the duck mini v2 and the 356mini. Fmj cases look...different, and the Hammer, don't see thosaround anymore. Not since the GH60 days.
« Reply #8082 on: Sat, 31 May 2014, 11:26:21 »
Sales on OTD market for custom boards will usually say 'will not sell to foreigners'.
« Reply #8083 on: Sat, 31 May 2014, 12:11:21 »
They will proxy to you, though. You just have to find someone to proxy for you.
Offline combataran
« Reply #8084 on: Sat, 31 May 2014, 12:59:07 »
What about kbdmania then?
« Reply #8085 on: Sat, 31 May 2014, 13:03:19 »
356/456/360 series don't come up on kbdmania often at all.
Offline combataran
« Reply #8086 on: Sat, 31 May 2014, 13:30:04 »
That sucks major b*lls. Guess I'll go hide in a corner and wait for a duck mini to pop up then. Or a hammer. Or an fmj case. Not the premium edition though.
« Reply #8087 on: Sat, 31 May 2014, 13:38:30 »
They're cool and rare...like everything else  :)). I don't know about being "the best" Korean custom but they're certainly very nice. I definitely wouldn't say no to a pink 456GT. I feel like sometimes the OTD boards are put on this pedestal because of rarity when you can get a KMAC or 2TU or GON more easily. And they're *really* nice boards.
Please try not to ask for pricing here. Thanks. I know it was harmless though so no worries. :D
Should also say there's some really cool info in the last two pages about Korean customs that you don't see everyday ^__^
« Last Edit: Sat, 31 May 2014, 13:44:13 by CPTBadAss »
Offline Jixr
« Reply #8088 on: Sat, 31 May 2014, 14:41:25 »
best way to clean keycaps?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #8089 on: Sat, 31 May 2014, 14:43:04 »
Denture cleaning tablets always work well
« Reply #8090 on: Sat, 31 May 2014, 14:43:34 »
Here's the way I do it.. Get some hot water. Not boiling, but hot enough so that putting your hand in it would be uncomfortable after a few seconds. Put a few denture tablets in there, then put your keycaps in. Stir every 5-10 minutes until the water is cold. Then transfer them to some more hot water and stir it for a few minutes. Then dry.
Offline Jixr
« Reply #8091 on: Sat, 31 May 2014, 14:47:41 »
would denture tablets affect anything with keycaps wiht pad printed legends or anything like that?
I have a mix of abs/pbt with pad printing, dub shots, dye subs, etc. I would just like to get them all cleaned up.
« Reply #8092 on: Sat, 31 May 2014, 14:49:29 »
It has never effected pad printing for me. I don't know for sure though.
By the way, I use 2 or 3 tablets for 1 keyset, so you'll want to use a few if your cleaning lots of sets.
Offline Jixr
« Reply #8093 on: Sat, 31 May 2014, 14:52:25 »
yeah, I just hate when my keyboards start to feel greesey, and I have around 6 or 7 keysets I would like to clean up.
Offline Candyflip
« Reply #8094 on: Sat, 31 May 2014, 15:06:23 »
I go with 2 tabs for 1 set its pretty good you don't need more than that. It won't affect the pad printed caps what so ever.
« Reply #8095 on: Sat, 31 May 2014, 15:35:28 »
I've been cleaning all types of caps for over a year with denture tabs with no issues. Think about it, they're meant to clean something that goes in your mouth. It can't be *that* harsh. If you're really that paranoid, you can just wash them with dish soap.
Offline Jixr
« Reply #8096 on: Sat, 31 May 2014, 15:43:49 »
I'm not worried. I just wanted to make sure. I don't know anything about denture sets or whatever. I'll pick some up next time I'm at the store. I'm getting a new alum case in the mail Monday and want to get things cleaned up so when I put it together it's all ready to go
« Reply #8097 on: Sat, 31 May 2014, 15:45:20 »
I just don't get all this fancy stuff. I have cleaned thousands of keys squeaky clean without any further work on 99% of them by using a spoonful of powdered laundry detergent (I like Charlie's or 365) in a liter of hot water. 5-20 minutes is plenty of time. Adding half a spoon of Oxi or washing soda probably helps.
Rinse well about 3 times pouring back and forth between a bowl and a colander, and toss out on a T-shirt to dry for a little while.
All that other rigamarole is just a big waste of time, money, and energy.
If you shake the water out of each key and roll them over right-side-up on the T-shirt, the entire affair, including drying, hardly takes half an hour.
« Reply #8098 on: Sat, 31 May 2014, 15:48:28 »
I don't get powdered laundry detergent. I've never seen it before and I think it's fancy lol. Same thing with Oxi, I don't have Oxi in my home. I know most people have dish soap so I always suggest that in addition to denture tabs. If you have it and it works for you, that's great. I just don't think powdered laundry detergent is commonly used.
« Reply #8099 on: Sat, 31 May 2014, 16:09:29 »
I think that laundry detergent works better than dish soap and certainly rinses easier.
I gave up that syrupy liquid laundry detergent years ago and never looked back. I think that the powder works better and it is way cheaper. Just make sure that it is dissolving properly.
Oxi/Biz type products are very helpful cleaning aids, if a bit harsh on fabric. It only takes a little bit.
