Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6230704 times)
« Reply #7900 on: Tue, 20 May 2014, 00:48:56 »
Thought it must be, but you can't see the dye sublimation from the underside ... Pretty amazing how well thought out the M is ... A testimony to the old "built to last" mindset that has unfortunately faded over time and is almost non-existent now-days.
Dyesub is really a bad word for it. The process is more like a Dye Diffusion. The dye comes in on the top of the keycap, and only goes in less than a mm. You can't see it on the bottom at all.
I agree though. The M, despite being a huge cost cutting measure over the F is still built sturdily enough to work after decades. I sometimes wish that things were more expensive and repairable instead of cheaper and disposable, but that seems to be the way we are going.
Computer repair used to be a big thing, but soon, I expect they'll be more disposable. After that, vehicles will be disposable, then housing, then we'll make whole societies disposable.
To be clear, dye sublimation is still the "correct" industry term for the process.  There is technically no sublimation occurring, but it is still the term used to describe the process.
Offline juguerre
« Reply #7901 on: Tue, 20 May 2014, 01:06:06 »
Just thinking about topre "snappy' feeling...  How RF 55g  compares to other switches? Is there a difference between" old" Fc660c and the "new" one?
Realforce 105 variable (at work)     Ducky G2Pro ISO TKL Mx-Clear    Realforce 87 55g (home)
« Reply #7902 on: Tue, 20 May 2014, 02:28:54 »
RGB mods from Desko keyboards were not made by BSP, right? I.e., they do not have the banana-like right shift?
Sadly, they were made by BSP. They do have the banana-like right shift :'(
Offline intelli78
« Reply #7903 on: Tue, 20 May 2014, 02:37:34 »
D:
Did anyone else ever make winkeyless PBT RBG Cherry mods? Does a proper, non-banana set exist at all?
Offline BlueBär
« Reply #7904 on: Tue, 20 May 2014, 03:27:04 »
The bicolors.
The legends of the italic ones were pretty bad as they had varying thickness. The legends of the bicolors seem to be a lot better. You can find a review here (these are unicoloured but essentially the same): http://geekhack.org/index.php?topic=56399.msg1273075
1. How RF 55g  compares to other switches?
2. Is there a difference between" old" Fc660c and the "new" one?
1. People generally say that the closest MX switch to Topre are Ergo Clears. Topre has a big bump and smooth travel. Not a Topre expert though.
2. The only difference should be the keycaps.
Offline intelli78
« Reply #7905 on: Tue, 20 May 2014, 03:40:05 »
Is there a specific date/year that separates vintage MX switches from current ones? I'm mainly talking about browns.
« Reply #7906 on: Tue, 20 May 2014, 04:33:23 »
D:
GMK, SP. There are no 'proper' BSP/Cherry dyesubs ones that I know of.
You should ask sprit about this. He knows a lot about vintage switches + different switch ages
Offline juguerre
« Reply #7907 on: Tue, 20 May 2014, 06:46:59 »
The bicolors.
I mean how it compares with other topre switches (HHKB, fc660c, silent o not silent). I ask for this because I read people saying that 45g RF is not the same that 45g in other topre "flavors" (regarding "snappy" feeling).
Offline combataran
« Reply #7908 on: Tue, 20 May 2014, 07:35:51 »
The bicolors.
Looks good, thanks for the link.
Cherry G80-1000HFD | CM Storm Spawn | Keypuller.com - Key Caps News & Database
Offline codyeatworld
« Reply #7909 on: Tue, 20 May 2014, 07:56:33 »
Anybody know the size/type of KMAC screws?
I need to replace all of them.
Offline combataran
« Reply #7910 on: Tue, 20 May 2014, 09:02:53 »
Are there any advantages to using right angle mini connectors compared to straight ones, like different stress points, maybe?
Offline BlueBär
« Reply #7911 on: Tue, 20 May 2014, 10:29:41 »
I don't know their length but they're M2 and M3 screws. Also take a look at this topic: http://geekhack.org/index.php?topic=56065.0
Some people use them because they don't stick out as much (for example some people put their mechs on their laptops). I don't know if it makes much of a difference in terms of durability.
Offline Razor Lotus
« Reply #7912 on: Tue, 20 May 2014, 21:01:40 »
Can I just solder any LEDs to my keyboards with LED slots?
I read that you can't have LEDs with less than 3 forward voltage else they won't work.
Has anyone tried? Primarily red and orange LEDs
« Reply #7913 on: Tue, 20 May 2014, 21:07:02 »
I've never calculated any voltages for my LEDs, I've just done swaps. I haven't had issues so far. But check out this thread for some actual information and numbers.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #7914 on: Tue, 20 May 2014, 21:13:07 »
So I am thinking of making some diode leg bending tools for common widths, while I have the width for the in switch version for cherry.
Anyone know the width between pads for the Phantom?
Does the ergo dox use either of these widths?
Would like to use the 2 most common lengths, and these seem like to two most popular builds.
Offline Pacifist
  • on hiatus
« Reply #7915 on: Tue, 20 May 2014, 21:52:50 »
How easily does soft anodized alum scratch?
Such as when:
On wood desk
In backpack
Hitting hard carpet
Hitting wood doors/walls
Falling
Pens hit it
« Reply #7916 on: Tue, 20 May 2014, 21:57:56 »
Such as when:
On wood desk
In backpack
Hitting hard carpet
Falling
Pens hit it
What if you throw it on the ground?
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #7917 on: Tue, 20 May 2014, 21:58:25 »
Such as when:
On wood desk
In backpack
Hitting hard carpet
Falling
Pens hit it
Question: will you be throwing it onto a pile of pens or just onto hard carpet?
« Reply #7918 on: Tue, 20 May 2014, 22:01:54 »
Such as when:
On wood desk
In backpack
Hitting hard carpet
Falling
Pens hit it
I was leaning towards concrete or dirt.
« Reply #7919 on: Tue, 20 May 2014, 22:13:28 »
Such as when:
On wood desk
In backpack
Hitting hard carpet
Falling
Pens hit it
I'm not part of your system.
KMAC to the ground!
« Reply #7920 on: Tue, 20 May 2014, 22:15:17 »
Such as when:
On wood desk
In backpack
Hitting hard carpet
Falling
Pens hit it
KMAC to the ground!
See JD knows whats up.
And to be on topic I think the color of the anodizing along with metal type will change the answer.
Offline Dubsgalore
« Reply #7921 on: Tue, 20 May 2014, 22:16:34 »
 :))  :cool:
  • Cherry Peasant
  • keycult.com
« Reply #7922 on: Tue, 20 May 2014, 22:17:41 »
Such as when:
On wood desk
In backpack
Hitting hard carpet
Falling
Pens hit it
KMAC to the ground!
and furthermore, hitting your keyboard against doors and dropping it is never advised. A fair number of dinged cases pop up, so it must not be too hard to do...
« Reply #7923 on: Tue, 20 May 2014, 22:19:14 »
Such as when:
On wood desk
In backpack
Hitting hard carpet
Falling
Pens hit it
KMAC to the ground!
But most of those actually ding the case itself. Hard anodizing might help with scratches but its not going to stop a dent.
Also I may not make Amy sense I'm half asleep.
« Reply #7924 on: Tue, 20 May 2014, 22:23:47 »
My advice? Use your keyboard for whatever you want. If you need to smack someone in the mouth with it on your way out of the office after being fired, smack away. You'll probably lose a few keycaps, though.
For defense against zombie bites, I'd recommend a Model M, however. Especially the models with the channel openings in the case, which will allow the blood and bile to run right out from the barrel plate and not accumulate in the keyboard.
Offline combataran
« Reply #7925 on: Wed, 21 May 2014, 02:03:36 »
Which version PCB is compatible with a KMAC 1.2?
Offline Pacifist
  • on hiatus
« Reply #7926 on: Wed, 21 May 2014, 02:10:14 »
What PCB? KMAC PCB? Its standard TKL isn't it?
Offline combataran
« Reply #7927 on: Wed, 21 May 2014, 02:14:02 »
Theres the 1.2 and 1.4 kmac pcb. Im not sure which one to get as a backup.
« Reply #7928 on: Wed, 21 May 2014, 06:43:49 »
Look up a picture of which PCB the 1.2 had then get that one. I don't recall exactly which PCB it has.
« Reply #7929 on: Wed, 21 May 2014, 06:45:41 »
Both PCBs should fit the 1.2 case.
« Reply #7930 on: Wed, 21 May 2014, 06:52:17 »
For the record had this keyboard been soft anodized would it have been messed up?
Offline epzy
  • HHKB Fiend
  • ded
« Reply #7931 on: Wed, 21 May 2014, 06:57:14 »
Why did I watch that video over 15 times? :p
Offline combataran
« Reply #7932 on: Wed, 21 May 2014, 07:02:47 »
Where can I find a 1.4 pcb? Originative maybe?
« Reply #7933 on: Wed, 21 May 2014, 07:06:41 »
kbdmod.co.kr
Offline epzy
  • HHKB Fiend
  • ded
« Reply #7935 on: Wed, 21 May 2014, 07:48:20 »
Such as when:
On wood desk
In backpack
Hitting hard carpet
Falling
Pens hit it
I don't advise you to drop or throw your keyboard. And you should probably not drop it on anything. But if you really care to find out, here's a selection of articles on anodization that will answer questions for strength, corrosion resistance, and wear:
The bonding strength and corrosion resistance of aluminum alloy by anodizing treatment in a phosphoric acid modified boric acid/sulfuric acid bath
The Effect of Anodizing to Minimize Friction and
Wear of Aluminum Surfaces
Anodising of Aluminum
Book entitled "Handbook of Aluminum Bonding Technology and Data"
These are *not* my articles, the authors names are all listed in the documents. They're just being provided for you to learn. And I'm not doing a TL:DR.
That being said, anodization is used in the aerospace industry to protect parts but at work, we still have issues with scratches and dings everyday in the factory. Don't be stupid with your keyboard and treat it like you would your phone.
No I'm not drop testing my KMAC for you.
« Last Edit: Wed, 21 May 2014, 07:53:53 by CPTBadAss »
Offline Razor Lotus
« Reply #7936 on: Wed, 21 May 2014, 07:53:09 »
Did you change them to red or orange LEDs by any chance? They work fine right?
« Reply #7937 on: Wed, 21 May 2014, 07:56:04 »
No I didn't swap orange or red LEDs in. I swapped magenta ones in. But I did put an Orange LED in the techkeys business card without issue. Take an LED, put it into your keyboard, see if it works. If it doesn't then it's time to figure out different resistors.
As I already stated, I haven't swapped out any resistors and the swaps I've done have worked fine.
Offline BlueBär
« Reply #7938 on: Wed, 21 May 2014, 08:12:46 »
No need for that, just use your Kingsaver.
Offline combataran
Offline epzy
  • HHKB Fiend
  • ded
« Reply #7942 on: Wed, 21 May 2014, 08:32:13 »
Apparently you can email them and they'll help you order if you're outside of Korea. I don't know for sure though.
Offline combataran
« Reply #7943 on: Wed, 21 May 2014, 09:47:16 »
Oh? I'll shoot them an email then.
Offline domoaligato
« Reply #7944 on: Wed, 21 May 2014, 14:50:32 »
It's not done by default, especially because this wouldn't fit acrylic cases.
Sounds like it will collide with about every aluminium case as well. Added depth below the the top row?
The most protruding part of the module will be the header pins, which will stand 5.5mm out of the mainboard
Can anyone confirm if this will be a issue with the FMJ Design 1 from Round 1?
edit: incase you have no idea what I am talking about... the added width for the led module addition on the gh60 rev.c may cause the gh60 to not fit in some of the cases that people have purchased for there gh60's
Offline BlueBär
« Reply #7945 on: Wed, 21 May 2014, 15:00:04 »
It will not get wider but "thicker". Since we don't know exactly yet how much more space is needed this is impossible to say right now, you can only guess (well apart from if a Rev. C has already been built with the addon module, I only know that there was a prototype of the addon module made).
Offline domoaligato
« Reply #7946 on: Wed, 21 May 2014, 15:04:31 »
yeah I meant to say thickness. derp. anyways thanks for the info. I guess I will just have to wait and see.
Offline juguerre
« Reply #7947 on: Thu, 22 May 2014, 03:17:47 »
Are Realforce and Leopold related? Just watched an image with Leopold-realforce written on a keyboard!
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #7948 on: Thu, 22 May 2014, 03:20:51 »
I'm sure I will get more then one answer, but what is the best solder for soldering switches?
« Last Edit: Thu, 22 May 2014, 05:22:49 by CommonCurt »
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline phoenix1234
« Reply #7949 on: Thu, 22 May 2014, 03:52:29 »
I'm sure I will get more then one answer, but what is the best solder to use for switch replacement?
Yes, there are more than one answer but I can nominate two, Kester 44 0.6mm SN63Pb37 (core rosin) and Kester 245 0.6mm SN63Pb37 (no clean).
Leopold is just a Topre distributor, just like you can see Ducky in Taiwan is also a Topre distributor.
I like linear switches
