Author Topic: Looking for keyboard suggestions  (Read 3430 times)
Offline Niceboy2801
« on: Sat, 23 February 2013, 21:49:23 »
Hello, I am looking for a mechanical keyboard that is tenkeyless and quiet with no macro's since im gaming. HybridCore has sent me to these fourms from the teksyndacate fourms (Shoutout to him/her)
Thanks for the suggestions,
Ncieboy2801
Offline laffindude
Re: Looking for keyboard suggestions
« Reply #1 on: Sat, 23 February 2013, 22:33:13 »
http://matias.ca/miniquietpro/pc/ No other choice for quiet.
Offline aviphysics
« Reply #2 on: Sat, 23 February 2013, 23:21:10 »
Would a Quickfire Rapid with Red switches and o-ring dampeners from WASD be quiet enough for him? Don't honestly know how that would compare to Matias, but it would be a little cheaper.
edit: Not that the Matias board would be a bad choice.
« Reply #3 on: Sat, 23 February 2013, 23:33:20 »
Not true.
Anyway, I think you're probably looking for a CM Storm QuickFire Rapid.  Probably either black or brown switches.  How loud they are depend entirely on how hard you hit the keys.  The Filco Majestouch is more expensive and hardly any different than the QFR, but also a good choice.  Ducky is also an interesting choice, for example the Shine II is full LED.  There's also Leopold but they are minimal in the flair department.
I challenge anyone to disagree that he would be best served by a QFR.
Offline aviphysics
« Reply #4 on: Sat, 23 February 2013, 23:46:54 »
Not true.
Why Black or Brown but not Red?
« Reply #5 on: Sat, 23 February 2013, 23:54:05 »
It's really up to everyone to figure out what works for them, but I feel that reds are too light for gaming.  The reason is that in-game I am usually have my left hand resting on WASD or other keys and I find that I can accidentally activate the light switches.  Reds are still great, though.  As a matter of fact I don't like blacks at all.
Offline Saturn
« Reply #6 on: Sun, 24 February 2013, 00:03:32 »
ymmv in this, as in everything.  I find reds spectacular for gaming, being smooth and light enough that it's almost as if the keyboard responds to your thoughts rather than your keypresses.  On the other hand I find them quite terrible to type on.
You do have to have a pretty delicate touch, though, to avoid accidentally actuating a cherry red switch.
Offline aviphysics
« Reply #7 on: Sun, 24 February 2013, 00:06:35 »
My advice to the OP is to go out and find some keys to try out or order the sampler from WASD.
I haven't tried blacks, but I find reds provide me with sufficient support. I don't really know why you would have to be careful to not accidentally press a key.
« Last Edit: Sun, 24 February 2013, 00:10:12 by aviphysics »
Offline laffindude
« Reply #8 on: Sun, 24 February 2013, 01:18:26 »
Not true.
He said mechanical. There is nothing mechanical about Topre.
Offline monday
    • Days of Game
« Reply #9 on: Sun, 24 February 2013, 03:53:49 »
hehe did not mean to post here
« Last Edit: Sun, 24 February 2013, 04:14:33 by monday »
Offline Deekin
« Reply #10 on: Sun, 24 February 2013, 06:26:10 »
Yeah, the black, browns and reds get significantly quiter with o-rings as it dampens the "CLACK" when they bottom out but they dont work so great with blues cause the most part of the sound comes from the "CLICK" in that switch.
So o-rings with reds could be a option yeah, though its that "CLACK" sound that the keys make that makes reds so wonderful. In my personal opinion ofc ;)
Offline hasu
  • @tmk
« Reply #11 on: Sun, 24 February 2013, 18:02:11 »
AEKII also is available.
Offline Niceboy2801
« Reply #12 on: Sun, 24 February 2013, 19:45:17 »
Thanks for all of the suggestions, Keep 'em comin!
Offline Hyde
  • White Tofu Extraordinaire
« Reply #13 on: Sun, 24 February 2013, 21:55:34 »
Typically I don't like o-ring because I find they kill the mechanical feel.
However brown, red and black are not too loud I guess.  I have to admit black is the quietest since it has the stiffest spring so you don't bottom out hard.  But at the same time I don't like using black since it's too heavy.
In terms of quietness from loud to quiet:  blue > brown > red > black.
I find red really nice to type and game on, so I'd suggest you get a red.
Otherwise go Matias Quiet Pro like laffindude said.
Offline monday
    • Days of Game
« Reply #14 on: Tue, 26 February 2013, 01:57:01 »
thanks this is all helping a lot. I am not thinking the mx greens are not for me. :D so thanks
Offline Niceboy2801
« Reply #15 on: Tue, 12 March 2013, 22:39:18 »
I bottom out.
