Author Topic: Post your Topre Keyboard  (Read 2660784 times)
Offline Sup
Re: Post your Topre Keyboard
« Reply #10450 on: Tue, 31 August 2021, 07:05:00 »
Bought this old gen 1 Realforce 91 NE0100 from 2004 for 70 Euros from Japan. I restored it since it didn't feel right.
Looks cleanable  :) - tested the keyboard it fully works
:'( Rust
Cleaned the housing
OOF  :blank:
It has some sticky brown stuff on the rubber and the PCB. I guess it must have been soda or something.
Cleaned the PCB and the rubber
Lubed the sliders and the stabelizers. The plate was hard to clean since removing the housing was a bit dangerous since the plastic was pretty old and brittle so i couldn't remove them to clean the plate fully. Housing/sliders also got a nice wash.
End result a very nice 91u with aged variable domes that are pretty nice to type on. :thumb:
« Last Edit: Tue, 31 August 2021, 07:26:56 by Sup »
current
Coming soon
Offline nmur
  • ಠ_ಠ
« Reply #10451 on: Tue, 31 August 2021, 09:32:29 »
:'( Rust
Cleaned the housing
OOF  :blank:
nice pickup mate, good price too
if you're willing, it is possible to restore the plate, however your plate's rust is significantly worse than what I encountered, so the pitting could be quite deep
Offline _rubik
« Reply #10452 on: Tue, 31 August 2021, 10:42:19 »
:'( Rust
Cleaned the housing
OOF  :blank:
I recently sanded down and repainted my 87u plate. The rust situation wasn't nearly as bad, but I saw a little bit creeping up in the corners where paint had rubbed away during manu.
Very happy with the final results. Pulling the slide housings off the plate was a pain, but I'd recommend it!
Offline Sup
« Reply #10453 on: Tue, 31 August 2021, 10:50:52 »
Thanks for the replies but, I haven't found any video on how to properly remove the housing from the plate with out snapping the tabs. I tried a bit with one but it felt like the tabs would break since the plastic feels pretty brittle.
current
Coming soon
Offline _rubik
« Reply #10454 on: Tue, 31 August 2021, 11:30:19 »
I used the end of a cap puller (soft plastic no ticker than a guitar pick) and gentle pressure to push down one side of the housing. Slight pressure on the other side and bobs your uncle.
I didn't shave off any tabs, but I'm sure some aren't as pristine as before.
« Last Edit: Tue, 31 August 2021, 11:33:36 by _rubik »
Offline btctopre
« Reply #10455 on: Wed, 29 September 2021, 21:51:31 »
blue gray evija w/ polycarb plate, rev. a purple housings + sliders, white/beige realforce hangul keycaps.
« Last Edit: Thu, 30 September 2021, 06:28:14 by btctopre »
    • Gray Designs
« Reply #10456 on: Wed, 29 September 2021, 22:57:44 »
:'( Rust
Cleaned the housing
OOF  :blank:
Soooo beautiful!
Offline nmur
  • ಠ_ಠ
« Reply #10457 on: Thu, 30 September 2021, 01:59:55 »
blue gray evija w/ pom plate, rev. a purple housings + sliders, white/beige realforce hangul keycaps.
nice, that looks great. I hope it feels good to use as well
I wish I managed to order one of these, especially the poly one. I think I have the spare parts lying around as well
Offline Auxo
  • Formerly CJD_Anthony
« Reply #10458 on: Thu, 30 September 2021, 21:02:08 »
Got this in today ;)
« Last Edit: Thu, 30 September 2021, 21:04:43 by Auxo »
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #10459 on: Thu, 30 September 2021, 21:03:13 »
Wew lad nice KBDMOD case! All those colored caps tho, PLUS the white set!
Offline PadawanGeek
« Reply #10460 on: Fri, 08 October 2021, 21:45:52 »
No modding for me, other than just simply changing keycaps. Love pics of that restoration work done by Sup. :thumb:
My collection of Topre KBs I'd collected over the years, recently took this pic for another forum, I have a total of seven Topre KBs:
I'd forgotten about the Type Heaven, after keeping most of the rest, so I took a pic of it with the RealForce 103UB 55G...
Offline kekstee
« Reply #10461 on: Fri, 05 November 2021, 04:27:55 »
278066-0
My BT board got much newer and whiter last week. :)
Is 6 HHKBs enough?
« Last Edit: Fri, 05 November 2021, 10:25:57 by kekstee »
Offline kekstee
« Reply #10462 on: Fri, 05 November 2021, 04:58:26 »
rip this topic
found two NIB CDS G5-CSKB earlier this month
forgive the noisy grainy images as always
I need this topic and pictures like that in my life. Even if I'm a couple months late.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #10463 on: Fri, 05 November 2021, 08:51:44 »
My BT board got a lot newer and whiter last week. :)
Is 6 HHKBs enough?
Jelly of that white one...! I really need to get ahold of the white blanks...
Offline bl1978
« Reply #10464 on: Fri, 10 December 2021, 02:54:41 »
realforce 103
Topre Realforce 103
The only keyboard in the world
4 Color scheme
Red,White,grey,black  PBT key cap
2009年12周生產
Sublimation printing does not erase the characters on the key top and PBT material that does not easily wear the surface
Chinese keycap only sold in Taiwan
Topre Realforce 103 (PBT Keycap)
Topre Realforce HiPro
KBC Poker 60% (PBT Keycap)
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #10465 on: Fri, 10 December 2021, 12:32:07 »
By no means are my boards perfect, but these have accompanied me well over the years =) I decided to document them while I was feeling very sick from the booster shot (I fortunately have now recovered):
Offline kekstee
« Reply #10466 on: Fri, 10 December 2021, 13:57:43 »
Damn, how is that white pro1 not a banana :D
How did you do that btw? Got two RF plates with some rust spots waiting for some love.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #10467 on: Fri, 10 December 2021, 13:59:31 »
It's not very hard actually - if you look closely at the RF slider housings, they are held by small clips. Just compress carefully and wiggle them out. They'll come off.
Offline kekstee
« Reply #10468 on: Sun, 12 December 2021, 17:05:25 »
Oh somehow thought he was talking about the brass inserts for the screws. Which would also get in the way of sanding and painting the plate quite a bit.
Offline E3E
« Reply #10469 on: Sun, 12 December 2021, 18:00:55 »
I don't post much anymore, but here's a dump of funpre:
Offline Auxo
« Reply #10470 on: Sun, 12 December 2021, 18:29:59 »
Whoa what an neat collection, thank you for sharing!
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #10471 on: Sun, 12 December 2021, 18:40:55 »
Jeebus christ
Damn that's all so nice.
Offline Auxo
« Reply #10472 on: Wed, 29 December 2021, 20:36:38 »
Wanted to try something different tonight
280489-0
Offline phinix
« Reply #10473 on: Thu, 30 December 2021, 03:01:43 »
Where did you get those stoppers/WKL blocks?
9100 | 3070 | 8TB SSD + 2x 1TB SSD | Z390 Aorus Pro ITX | 16GB RAM | SFX 600W | Sentry 2.0 | Ruark Audio MR1 Mark II | LG OLED 48CX
Realforce 87u55 | CM QuickFire Rapid MX Blacks | NCR-80 87g Gateron Oil Kings | Drop CSTM80 | Logitech Pro Superlight
SA: Retro Petscii, 7bit Round6 'Symbiosis', Filco, Carbon Bone Cherry: GMK Laser, OG double shot caps, CRP APL GSA: Retro High-light HSA: Hyperfuse
Offline nmur
  • ಠ_ಠ
« Reply #10474 on: Thu, 30 December 2021, 07:30:16 »
They're part of the case
Offline phinix
« Reply #10475 on: Thu, 30 December 2021, 08:00:13 »
I see, interesting.
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #10476 on: Thu, 30 December 2021, 11:19:45 »
Couldn't pass on the HHKB Yuki Edition. I managed to grab one of the 25 keycap units that were made available in EU to boot.
I'll probably add some color if I can find something decent later on.
Offline Auxo
« Reply #10477 on: Thu, 30 December 2021, 12:03:23 »
I see, interesting.
Check out the 89u! Its from the JIS layout specifically. When japan released their realforce r1, it came in 89u and 91u
Offline Helminth
« Reply #10478 on: Thu, 30 December 2021, 23:13:54 »
Figure I would show off my board  :thumb: (pardon the dings on the wrist rest)
280530-0
Offline pancake
    • instagram
« Reply #10479 on: Fri, 31 December 2021, 18:28:54 »
tenso took all my money
SA Bisoromi | GMK Gregory
HHKB Snow | HHKB Snow 25th | Kafka 87 | Realforce R3TL BT | RS | RS60 | RS65 | TGR Jane v2 CE | VSPO!GEAR 橘ひなのEdition
Offline nmur
  • ಠ_ಠ
« Reply #10480 on: Fri, 31 December 2021, 22:57:29 »
so nice
I really wish I was clued up about this snow edition + blanks when it was announced
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #10481 on: Thu, 20 January 2022, 08:05:59 »
so nice
Yes! I wonder how fast all were taken when the sale started? Was the press release long time before visible? How many went to Japan, Europe, et cetera.
I ordered 2 days ago a new black variable weight Realforce 87UB, and will do I think a stormtrooper version with my beige 87UW. Or I just wanted to get a black 87U when they are still available. A problem I have: I lost the 'Back Space' keycap on my 87UW :confused: or better my son >:D Getting a fullsize 104UW would be the only option now I guess to get that cap again? Wow, then it would be like an artisan keycap. I also wrote PFU, but they told me:
"Leider vertreibt Fujitsu keine Ersatztastenkappen für Realforce Tastaturen. Wir bitten Sie sich diesbezüglich an einen Drittanbieter wie zum Beispiel Aliexpress zu wenden.
 https://www.aliexpress.com"
Which reads like "we do not have replacement keycaps, go to Aliexpress." :D
My daily driver with new caps:
« Last Edit: Thu, 20 January 2022, 08:08:30 by madhias »
Offline btctopre
« Reply #10482 on: Fri, 21 January 2022, 13:55:56 »
i want to be a gr8 collector
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #10483 on: Fri, 21 January 2022, 15:37:01 »
That's sick - what model is this? Do the caps look more grey overall compared to the usual, stock ivory/white caps?
Offline btctopre
« Reply #10484 on: Fri, 21 January 2022, 16:22:53 »
2013ish 104UB-DK (XF11R0). and yeah they're a light gray color- basically the equivalent of the beige mods but gray instead of beige.
white - dk gray - anni/pro gray
spacebar was starting to yellow a bit on my current set of alphas so finally just ponied up and bought a new one
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #10485 on: Fri, 21 January 2022, 16:27:12 »
It's like the NCR grey version for Realforce. That's really nice. I should try finding one. Thanks for the comparison!
Offline Auxo
« Reply #10486 on: Fri, 21 January 2022, 17:01:21 »
so nice
Very nice photo & build. Looks super clean
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #10487 on: Thu, 10 February 2022, 00:56:06 »
I am looking for a Yuki version (no branding) HHKB Hybrid myself, but I had the exquisite pleasure to tune one for someone in the community. Figured I should share, because it's just so clean nonetheless.
and some typing:
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #10488 on: Thu, 10 February 2022, 10:01:58 »
Dope. I tried the new hybrid type S and it was just a mushy mess to me. I'd have to unsilence it haha.
Wish you luck, friend!
Offline vladimir108
« Reply #10489 on: Thu, 10 February 2022, 14:35:23 »
... Yuki version (no branding) HHKB Hybrid ...
Guys, I couldn't find why is non branded show model called "Yuki". Is it based on some YT influencer please?
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #10490 on: Thu, 10 February 2022, 17:26:10 »
Yuki is snow in Japanese lol
Offline TheIcyKoala
« Reply #10491 on: Thu, 10 February 2022, 20:42:45 »
my steadfast topper
i gots the bke redux ultralight v1 domes and kdbfans silence x rings  ;D
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #10492 on: Mon, 21 February 2022, 04:09:04 »
THOCK THOCK THOOOOOCK! Sanded and painted my rusty RF87 plate, and added Deskeys #3 silencing rings. I think the kid between a Realforce 55g with its metal plate and HHKB with its layout would be the hottest kid in town. I didn't lube anything though, maybe with this model it is not needed, it is a butter thocky awesome sound and feeling.
Offline ejewell89
  • 4ever Smol
« Reply #10493 on: Wed, 06 April 2022, 22:31:49 »
you are a buttery sound and feeling
Offline shnizlon
« Reply #10494 on: Mon, 18 April 2022, 06:00:53 »
Offline phinix
« Reply #10495 on: Mon, 18 April 2022, 18:10:20 »
My first hhkb :)
285192-0
Offline ejewell89
  • 4ever Smol
« Reply #10496 on: Thu, 21 April 2022, 11:08:21 »
My first hhkb :)
topre gang. the most expensive keyboards we keep looking stock
Offline phinix
« Reply #10497 on: Tue, 26 April 2022, 04:02:11 »
My first hhkb :)
Yeah, so many hhkb users - how do you guys handle arrow cluster position - it drove me nuts, couldn't get used to.
Offline E3E
« Reply #10498 on: Tue, 26 April 2022, 04:14:30 »
I prefer RF over HHKB (shots fired)
but I actually really liked the diamond arrow cluster orientation with the HHKB's FN layer.  I used to program my 60s with my own arrow placement but started replicating the HHKB function layer layout after I got mine.
I will always prefer dedicated arrows, but I do find it very usable
Oh yeah, and I bought this thing to essentially give me all the keys the HHKB lacks in a dedicated cluster. I take these two around when I travel.
Decked it out with hipro to match even if the legends make it look ridiculous
« Last Edit: Tue, 26 April 2022, 04:39:50 by E3E »
Offline phinix
« Reply #10499 on: Tue, 26 April 2022, 04:58:16 »
Wow, that BFK looks sick :)
I also prefer RF (trying to buy 87u now), but I loved hhkb so much that I think I will have to go back to it in the future.
