Author Topic: Post your Topre Keyboard  (Read 4663346 times)
Offline Ngt
Re: Post your Topre Keyboard
« Reply #4800 on: Thu, 02 April 2015, 17:32:39 »
I've heard people saying the type-s is a lot better than the regular version, Is it really that much different than a silenced regular HHKB?
Are you talking about the dental band modded normal HHKB? If yes, I would assume that the mod would reduce the key travel of your HHKB which is different from the Type-S as its plungers have a thinner base than the normal, allowing for the presence of the foam pads hence no modification of the key travel.
The dental band mod does reduce travel on the HHKB.  Some have said it is negligible, others say its very bad.
Perhaps one could do the same as for the Type-S plunge and sand down the normal plunger but I guess it would be quite time consuming. I wonder if you can buy Type-S plungers at retails, my first guess would be no as there would be no point anymore in buying a Type-S.
I saw someone mention that before, but I think it would be much more work than it's worth.  I believe people have swapped the silent sliders out of the 87U though.  I think that would be much easier to do than trying to source them outright.  You could swap out all of the modifiers from a silent 87U and keep the alphas silent.  You would have enough sliders for an HHKB, and should be able to recoup most of your cost on the RF through selling it used.
Actually that's something I haven't thought of but I wonder there would be a buyer for such an hybrid board. I wonder as well how much the silent 87U prices at.
Offline ghostjuggernaut
« Reply #4801 on: Thu, 02 April 2015, 17:33:40 »
I've said it a handful of times. Don't pay for the type-s when you can get the same effect with the o2dazone mod for $20
If I ever end up in a situation that requires my HHKB to be silenced, this is the route I will take.  I just can't justify the cost of the Type-S, when his mod is so cheap and effective (from what I have read).
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #4802 on: Thu, 02 April 2015, 17:37:33 »
I'm planning on the ironed landing pad method, is o2dazone's method much different than the regular dental bands?
Offline Ngt
« Reply #4803 on: Thu, 02 April 2015, 17:40:33 »
I have used such technique on my Novatouch. I did notice a little difference between the stock and the silenced keys though (I kept 2 stock keys as a matter of comparison). However the sound is definitely better and I still have a tactile feedback. It was time consuming though, especially since I did mistakes several times. I used Spicebar's method.
Here is the link in case you wonder: https://geekhack.org/index.php?topic=65853.msg1540901#msg1540901
« Reply #4804 on: Thu, 02 April 2015, 17:47:40 »
Here you go.
https://geekhack.org/index.php?topic=40582.0
Offline Xowie
  • On Sabbatical
« Reply #4805 on: Thu, 02 April 2015, 17:52:33 »
Unfortunately I am not too sure.
Meh, I feel like if I use the type S as much as my other HHKBs, the price difference is negligible in the long run. Also type S does not void EK's warranty ([/my price justification]  :p)
RETIRED
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #4806 on: Thu, 02 April 2015, 18:44:08 »
i've been using the hhkb a lot more often now after i got hasu's BT controller.
Offline exitfire401
  • The Force is Re/\l
« Reply #4807 on: Thu, 02 April 2015, 18:55:37 »
Fair enough, imho, it's just that the Type-S is fairly mushy compared to the non type-s. It's not that I don't enjoy my type-s, it's just that I would rather use the o2dazone and void ek's warranty to have the improved feeling over paying the extra cash haha. I'm very happy with the board, and that's my only gripe (well, that, and the fact that there's no alu case, but that's a problem that will be resolved in the near future).
Offline Sygaldry
  • Edema Ruh
« Reply #4808 on: Thu, 02 April 2015, 19:23:57 »
Why buy a non-Type-S for 255 in the US when you can import a Type-S directly from PFU (at times when Tenso has a shipping promotion going on) from Japan for about 257 (without the shipping promotion, you'd pay maybe 275)?
null
« Reply #4809 on: Thu, 02 April 2015, 19:48:48 »
Enviro, ooh
I have a controller but I've been too lazy to program it to Dvorak.   :-[
Offline byker
  • Literally Canada
« Reply #4810 on: Thu, 02 April 2015, 19:52:03 »
Nice board naasfu! Didn;t know you had an enviro.. :) Excited to get my Bluetooth controller in the mail!
Offline Air tree
« Reply #4811 on: Thu, 02 April 2015, 19:55:16 »
What kind of battery life do you get with your HHKB?
I'm on the fence about ordering a blue tooth version because of the aluminium case that's coming up, I'm going to see if there is going to be room for the battery. I hope there is, because a blue tooth, aluminium HHKB with 55g domes, silenced & lubed would be the best HHKB in existence...
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #4812 on: Thu, 02 April 2015, 21:50:35 »
Yeah, I really love hasu's controller. :)  I haven't really had time to experiment with keymappings other than the SpaceFN layout which was included with the firmware zip.  So I'm pretty much using the default HHKB layout, except that I'm still having trouble hitting Home/End when I need them.
For Bluetooth, I'm using a Sparkfun battery that hasu recommended.  Battery life has been pretty good so far, although I haven't really been keeping tabs since I use my laptop for a couple of hours at a time here and there.  hasu mentioned about 8 hours, I think, but it seems to be longer than that?
I would love an alu case, but my main usage for an HHKB is plunking it down on top of a laptop, and an alu case would probably be too unwieldy and might scratch up my laptop.  Also, I don't know about Bluetooth's limitations, but I remember GON added BT support to his boards, but he mentioned BT would only work with his plastic cases and not the metal ones.
Enviro is one of my favorites. :)  I should be getting an Eyeland T soon to go with this one. :)
Offline Belfong
« Reply #4813 on: Fri, 03 April 2015, 02:43:24 »
I finally put the orange blanks on. It made my HHKB feel and look super bad ass! It's very nice actually!
Offline byker
  • Literally Canada
« Reply #4814 on: Fri, 03 April 2015, 03:03:21 »
Looks really nice Belfong. You have so many matching clacks too!  :)
Offline Belfong
« Reply #4815 on: Fri, 03 April 2015, 03:19:26 »
Thanks byker. My potato pix sucked though. I thought putting it near the window with the afternoon soon here would make it look good but the caps became too washed out.
Here's another one where I reduce the white balance (I am just using iPhone so it's a software adjustment). At least this is better.
Offline byker
  • Literally Canada
« Reply #4816 on: Fri, 03 April 2015, 03:44:48 »
So bright! :O
Offline Sed8op8
  • Keyboard Padawan
« Reply #4817 on: Fri, 03 April 2015, 06:02:55 »
OMFG those look gorgeous!!. I still can't post in the classifieds but I'm trying hard to find an orange/green/blue set! Anyways grats and everything looks so tight !!!!!
Offline MAR82
  • Keyboard Addict
« Reply #4818 on: Fri, 03 April 2015, 06:42:40 »
Well it's a Topre wannabe, but I still wanted to share it
Here is my Noppoo EC108Pro with Matt3o's Granite set
96155-0
(Sorry for the phone quality picture)
« Reply #4819 on: Fri, 03 April 2015, 09:10:19 »
That's a nice match.
Paging Mr. Dustin!
Offline Ngt
« Reply #4820 on: Fri, 03 April 2015, 10:18:28 »
This board has Topre MX compatible stem as the Novatouch, hasn't it?
Offline MAR82
  • Keyboard Addict
« Reply #4821 on: Fri, 03 April 2015, 10:38:33 »
Yeah it does, but I don't think they are the same stems (color aside) nor do they use the same cups
Offline ideus
  • Björkö.
« Reply #4822 on: Fri, 03 April 2015, 10:42:00 »
Those characters look awesome. What characters are they?
« Reply #4823 on: Fri, 03 April 2015, 11:22:49 »
Great shots belfong. I'm digging the orange blanks.
« Reply #4824 on: Fri, 03 April 2015, 12:48:28 »
Edit: Inspiration credit to clacktalk.
« Last Edit: Fri, 03 April 2015, 15:33:40 by ghostjuggernaut »
Offline exitfire401
« Reply #4825 on: Fri, 03 April 2015, 12:54:43 »
Offline Xowie
  • On Sabbatical
« Reply #4826 on: Fri, 03 April 2015, 13:57:19 »
:eek:  :eek: All very nice!
RETIRED
Offline Ngt
« Reply #4827 on: Fri, 03 April 2015, 14:07:20 »
Hebrew perhaps?
« Reply #4828 on: Fri, 03 April 2015, 14:15:39 »
Wow, that's awesome.   :thumb:   Shame about the Caps Lock Right Shift though.   :-/
« Reply #4829 on: Fri, 03 April 2015, 14:29:53 »
Thanks Hoff.  The shift is the absolute only downside to the set.  I can deal though. :thumb:
Offline MJ45
  • HHKB Pro
« Reply #4830 on: Fri, 03 April 2015, 14:30:34 »
Hebrew perhaps?
I think those are Japanese, if not maybe Klingon?
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #4831 on: Fri, 03 April 2015, 15:25:07 »
woo, congrats on finally getting your orange setup complete. :)  that orange looks so vibrant.
really beautiful, man.  love the pink and black together.
Hebrew perhaps?
japanese.  really cool legends!  how are the profiles for those caps?
« Reply #4832 on: Fri, 03 April 2015, 15:26:31 »
Hebrew perhaps?
The ones on the board all match.
Offline Air tree
« Reply #4833 on: Fri, 03 April 2015, 15:36:58 »
The caps lock nipple adds character.  :p
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #4834 on: Fri, 03 April 2015, 16:00:50 »
Offline Ngt
« Reply #4835 on: Fri, 03 April 2015, 16:14:43 »
Offline trizkut
« Reply #4836 on: Fri, 03 April 2015, 16:35:16 »
Clean board.  Looks like you're not using that ugly stump... I'll gladly take that abomination off your hands!   :p
« Reply #4837 on: Fri, 03 April 2015, 17:07:52 »
I'm digging the look. The white printed set looks really great, mixed with blanks. Whether alphas and mods, or vice versa.
Offline Kinaesthetic
« Reply #4838 on: Fri, 03 April 2015, 23:16:01 »
Finally tracked down a green RF printed set to finish off the design that I wanted to do in the first place!
Offline Belfong
« Reply #4839 on: Fri, 03 April 2015, 23:18:31 »
Very nice!!!!
I didn't know there is a Topre Dolly!!! My eyes zoomed in to that spot in your photo.
« Reply #4840 on: Fri, 03 April 2015, 23:41:59 »
Very nice!!!!
Yep. He threw it in with the last sale as a freebie in my package. I was quite surprised. According to him, that single color dolly is one of the earlier ones that he made. It isn't perfect though, since the stem has a small defect. But it still sits very firmly on the Topre switch stem, so in all honesty, that small defect makes absolutely no difference.
THere just seem to be so few of the Topre dollys out there. I believe Joey Quinn also has one (multichromatic), but don't quote me on that. Don't know who else has one.
« Reply #4841 on: Sat, 04 April 2015, 02:37:07 »
Verrry nice indeed!
Sorry about your space bar though :p
« Reply #4842 on: Sat, 04 April 2015, 09:33:21 »
Verrry nice indeed!
Lol, thanks rowdy. I thought I'd give it a try, with everyone raving about it all the time. I'll give it a few days and see if I like it.
« Reply #4843 on: Sat, 04 April 2015, 10:15:11 »
Very nice!!!!
I also have one.  :)
Since I don't have photos of it on a board ( :O ), I'll link you to the post I made just now in the Nubs media thread.  ;)
Offline Belfong
« Reply #4844 on: Sat, 04 April 2015, 10:25:56 »
Very nice!!!!
I also have one.  :)
Purple Dolly! Of all the colour! Ha ha! Well played, Hoff! well played!
Offline oscillik
    • music podcasts
« Reply #4845 on: Sat, 04 April 2015, 10:42:37 »
I no longer have a potato for taking pictures! got a FujiFilm X100T finally
Keymacs A620N-Rev.A with Alps SKCM Salmon switches
Offline ideus
  • Björkö.
« Reply #4846 on: Sat, 04 April 2015, 12:10:03 »
Nice picture. Congratulations on your new Fuji.
« Reply #4847 on: Sat, 04 April 2015, 14:49:57 »
Very nice!!!!
I also have one.  :)
Hehehe, that one is just for you, Belfong!!  :))
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #4848 on: Sat, 04 April 2015, 15:35:39 »
WA WA WEE WA!!!
You really have some awesome orange loot, my love...So much beautiful orange! I love it!!!
Changin' it up, eh~ Lookin' good, mane.
That is so damn clean and fresh, dood... FU- I really like the Slush and Bro Trans Fn ~ ... who am I kidding.. I love the purples too :'(
Glad you were able to track down the green, dood!!! We really don't have enough people posting fullsize in here. I love, dood. Looks so bright and happy~  Definitely my style.
OH mane, oh mang... finally showing us your beauty in high res!!!
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #4849 on: Sat, 04 April 2015, 15:36:29 »
It gon' happen...
