Author Topic: Post your Topre Keyboard  (Read 4663337 times)
Offline VesperSAINT
  • vpsert
  • #CustomKorean
Re: Post your Topre Keyboard
« Reply #5050 on: Wed, 22 April 2015, 16:24:18 »
Added the gamer set today. I also swapped 55g domes in and am loving it.
but... da pics. where r dey?
edit: just realized you image tagged an link, but the wrong one, son ~ Good lookin' kid you got there.
« Last Edit: Wed, 22 April 2015, 16:26:09 by VesperSAINT »
Offline ghostjuggernaut
« Reply #5051 on: Wed, 22 April 2015, 16:29:00 »
Not sure what happened, but I fixed it now.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #5052 on: Wed, 22 April 2015, 21:00:01 »
Classy lookin' board, yo. LIKE!
Offline Sygaldry
  • Edema Ruh
« Reply #5053 on: Wed, 22 April 2015, 21:16:26 »
All of you and your 55g HHKBs....
Why you do dis to me?
Tempting me to rip apart my beautiful RF87.....
wuwuwuwu   :'( :'( :'(
DOU****E!?
null
Offline Tigermelon
« Reply #5054 on: Thu, 23 April 2015, 15:31:00 »
Managed to pick up a blank type-s with blank pink arrow cluster/esc for 300usd. Too hyped, had to post, pics will be up once it arrives. Finally joining the oneness.
Offline Ngt
« Reply #5055 on: Thu, 23 April 2015, 15:41:46 »
Is it me or the purple Fn is darker than the other one?
« Reply #5056 on: Thu, 23 April 2015, 15:51:38 »
They are the same color IRL. The lighting was bad, and it was hard to photograph.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #5057 on: Thu, 23 April 2015, 17:44:39 »
DOU****E!?
Offline illitirit
« Reply #5058 on: Thu, 23 April 2015, 23:22:43 »
Does anyone know where to get 10th anniversary RF 87u keycap sets?
I love the look but I havnt been able to find anything near it.
« Reply #5059 on: Thu, 23 April 2015, 23:23:22 »
You'd have to buy the keyboard. Widebasket has a couple on eBay for ~$400.
Offline Flyersfan1
  • Hi!
« Reply #5060 on: Thu, 23 April 2015, 23:26:47 »
Are those being made especially for Leopold or something? At first I thought they had unearthed some old stock of them, but now that they keep replenishing it, I'm starting to think otherwise.
Quote from: Photekq
« Reply #5061 on: Thu, 23 April 2015, 23:28:44 »
I have no idea. I imagine they are just old unsold stock, but who knows. I wish they had a 10th anniversary 55g silent model though. I'd buy that in a heartbeat.
Offline btctopre
« Reply #5062 on: Fri, 24 April 2015, 00:23:39 »
They are indeed still being manufactured for Leopold (the date on the plate from my ANSI one is November 2014). The new shipment they got in April 3rd should have March manufacturing stickers on them.
Offline GenKaan
  • Mer caps, mindre käbbel
« Reply #5063 on: Fri, 24 April 2015, 02:47:05 »
Just got this baby home :) Found it used and SUPER dirty for $115!
Next to my old main keyboard
Not 100% sure I will keep it, not sure if topre is for me. Most likely end up trying to trade it for a HHKB
|| @Home:: Shine 3 TKL (Mx Red / Deep Space)  || @Work:: G2Pro (Mx Clear / Dye Sub PBT) ||
@Reserve:: HHKB (Topre 45g / Mixed PBT) // Das v3 (Mx Brown / Blank PBT)
« Reply #5064 on: Fri, 24 April 2015, 04:52:46 »
First World Problems
SO Goooooood!  :thumb:
Offline strict
  • TKL Zealot
« Reply #5065 on: Fri, 24 April 2015, 07:22:56 »
Buy a silenced variable weight board and the 55g board, swap the plate over with the plungers still installed, and then sell the non-silenced variable weight you just created.  It should only cost $800 up front and then you can recoup half of it when you sell the other  :))
Offline baldgye
  • Will Smith Disciple
« Reply #5066 on: Fri, 24 April 2015, 07:24:11 »
I dun see no problems here
Offline Ngt
« Reply #5067 on: Fri, 24 April 2015, 07:41:31 »
Here is my 55g HHKB Type-S:
Sorry Vesper but I'm not a big fan of the 55g so far. Way too mushy for me compared to 45g Novatouch. I barely don't hear the thock sound on it. The space bar is rattling I'll add some thick grease so it gets really quiet. I feel it is a bit too heavy for me as on a daily basis. I'll give it some time and I'll see how it goes.
I love the RF orange key. Looks nice with the 2-tone basic set. Powder Puff Purple Fn on his to join the orange key. Looking forward to the color mix. :D
Offline billnye
  • ability man
« Reply #5068 on: Fri, 24 April 2015, 07:44:34 »
Looks really nice ngt! That orange goes really well.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #5069 on: Fri, 24 April 2015, 08:51:33 »
Heyo!
No need to be sorry :P My HHKB currently is sporting 45g domes for alphas and 55g for mods :P Everything seems to feel slightly stiffer in the HHKB compared to the Realforce. Might have to do with the profile/angle, or the lack of plate. 55g may be too a lil' too stiff for alphas in the HHKB for me too :P  55g is super snappy in the HHKB and really fun, more so than the Realforce, but I think it was designed for a plate.
I believe (I have been told by multiple sources) the mushy-ness is a result of the Type-S plungers being the standard Black plungers with padding but without reduced thickness of the plunger base to compensate for the pad. This results in the dome being already somewhat depressed, and reducing the maximum tactile feedback of the dome (making it feel more linear than tactile). The same thing follows for Type-S with 45g. Many people have said the Type-S feels lighter/less stiff than stock HHKB. The Realforce Silent Purple plungers have a thinner plunger base (longer stem) so that the base thickness + padding is the same thickness as a stock Black plunger. Also, the Realforce Purple plunger base is a round shape, while the Black plungers have more of a rounded square base.
You barely hearing the thock though is the padding in the Type-S, not the 55g domes.
Lubing will help with the spacebar rattling, but from my experience, it has more to do with the stabilizers not being snug in the stem hole. My remedy was using tape to fill that up. Let me know if lubing doesn't help you.
« Last Edit: Fri, 24 April 2015, 09:13:08 by VesperSAINT »
Offline Ngt
« Reply #5070 on: Fri, 24 April 2015, 10:13:08 »
Heyo!
No need to be sorry My HHKB currently is sporting 45g domes for alphas and 55g for mods Everything seems to feel slightly stiffer in the HHKB compared to the Realforce. Might have to do with the profile/angle, or the lack of plate. 55g may be too a lil' too stiff for alphas in the HHKB for me too   55g is super snappy in the HHKB and really fun, more so than the Realforce, but I think it was designed for a plate.
Maybe the Type-S is not for me. I prefer the result I had using Spicebar's mod.
I'll keep the board a bit so Azhdar can try it but I don't think I'll keep it as Topre for me is defined by his tactility. So no tactility = no point keeping it. I'll put the domes in my Novatouch when I'll have the time to see how it feels on a metal plate.
Offline Flyersfan1
  • Hi!
« Reply #5071 on: Fri, 24 April 2015, 10:21:26 »
This is encouraging:
Quote from: Photekq
Offline Sygaldry
  • Edema Ruh
« Reply #5072 on: Fri, 24 April 2015, 10:25:50 »
null
Offline sorijealut
    • steam
« Reply #5073 on: Fri, 24 April 2015, 13:29:59 »
Ah the perfect beauty! Someone better get on this quick  :-X
I wish I could buy that off ya but I'm watching my funds as well lol.
GLWS  :thumb:
This is amazing! Can't believe they asked this question  :eek: and there's so many good responses on there.
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #5074 on: Fri, 24 April 2015, 15:03:23 »
Somebody is gonna be a lucky guy when they get that.
Offline btctopre
« Reply #5075 on: Fri, 24 April 2015, 15:16:52 »
Yeah, the value he was giving for the price was very generous (55g Type-S w/ Digilog + Pexon Cable + Brocap for $425 shipped). When I made mine, I felt it was definitely the best combination possible that I had tried out of all the possible combinations for Topre TKL (55g was just too heavy for my joints though).
Though he shouldn't have tainted it with that pleb Cherry sticker ;)
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #5076 on: Fri, 24 April 2015, 19:53:53 »
It just needs the  anniversary keycaps and it would be the perfect Realforce  :)
Offline Sygaldry
  • Edema Ruh
« Reply #5077 on: Fri, 24 April 2015, 20:10:29 »
Thanks for all the compliments lol
The Cherry sticker was there for irony. Easily removed =p
Anyway... the board sold in less than 2 hours.
Will be hard to let it go  :'(
null
Offline Cafeine
    • GeekZone
« Reply #5078 on: Sat, 25 April 2015, 18:50:59 »
My Topre family is complete...
HHKB Type-S ordered, with black blank keycaps + CTRL / Enter color pack + RF 23 U keypad. Going to Japan in 2 weeks so I used a friend to prepare all that @ amazon.co.jp. Then I'll use at least one day in Tokyo to hunt for some "other" Topre stuff. I'm also preparing some questions for Topre to understand WTF IS WRONG WITH THEM. Leopold exclusive models (Realforce 10y) should be sold in Japan too. :/
Own : HHKB Type-S | Leopold FC660C (x2 - 1st Gen & 2014 silenced) | RealForce 87U TKL (55g uniform) | RF 23U | Minila Air MX Blue
Sold : RealForce 88UB 45g | Leopold FC660M (MX Clear) | Filco MJ2 TKL (MX Brown) |  KeyCool 84 (MX Black) | CodeKeyboard TKL (MX Clear)
Offline SeeThruHead
« Reply #5079 on: Sat, 25 April 2015, 19:38:06 »
Just started on the topre bandwagon.
« Last Edit: Sat, 25 April 2015, 19:44:23 by SeeThruHead »
 Painted QFR          Poker 2
« Reply #5080 on: Sun, 26 April 2015, 01:06:54 »
98557-0
Offline btctopre
« Reply #5081 on: Sun, 26 April 2015, 01:15:56 »
rowdy... don't do your hhkb like that, please clean it ;) good looking combination though  :thumb:
« Reply #5082 on: Sun, 26 April 2015, 02:04:27 »
Although I keep it covered, I have to admit that it hasn't been used for at least a month since I got my SSKs.
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #5083 on: Sun, 26 April 2015, 02:38:17 »
Mah Xpost!!!
Offline appleonama
  • Trollo en USA
« Reply #5084 on: Sun, 26 April 2015, 03:08:27 »
Offline Cafeine
    • GeekZone
« Reply #5085 on: Sun, 26 April 2015, 08:57:47 »
Yep, can't fight it. The sexyness of those HHKB / RF is endless. :D
« Reply #5086 on: Sun, 26 April 2015, 10:09:33 »
Digilog.. Niceeee man!  :cool:
holyyyy ****t.. I know people use Novatouch stems but I still cant use anything except Topre keycaps.. Omg the neeeed!  :eek:
That looks damn good man!  :thumb:
  • Kitteh Overlord
  • Say WHAAT...
« Reply #5087 on: Sun, 26 April 2015, 10:10:04 »
OH!!! I love it!!! Not much sexier than a blacked out RF with Reaper in tow!!!
Got some orange and grey/white keys in... figured I'd throw on some color!!!
« Reply #5088 on: Mon, 27 April 2015, 05:58:08 »
The orange highlights - a very nice touch! :)
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #5089 on: Tue, 28 April 2015, 02:08:59 »
Cool looking board. The pink and purple go well with each other but I feel like the red trans Fn does not match them well.
Trans red fn is an eyesore there. Fix it. Thanks. :P
haha yeah it doesn't really match this setup, but i love that cap. :)
I looked again and it is still bothering me. I'm going to hunt down a (retail priced) replacement and get it for you. :P
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #5090 on: Tue, 28 April 2015, 02:37:39 »
haha, you're either too very kind, or it really, really, really bugs you.  or both. :)
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #5091 on: Tue, 28 April 2015, 02:58:30 »
I'm not a nice person.
Offline sth
  • 2 girls 1 cuprubber
« Reply #5092 on: Tue, 28 April 2015, 03:25:22 »
ultimate ctrl.
  • Kitteh Overlord
  • Say WHAAT...
« Reply #5093 on: Tue, 28 April 2015, 03:27:19 »
ultimate ctrl.
hello beautiful!!!
Offline Ngt
« Reply #5094 on: Tue, 28 April 2015, 07:22:20 »
ultimate ctrl.
Really cool board! The red control makes it awesome. Blank and one hard color. I love simplicity and you got it right!  :thumb:
Offline Infrared
« Reply #5095 on: Tue, 28 April 2015, 07:34:27 »
OMG CANT WAIT!!!! Hopefully they actually make them tho..
White Fc660c
Offline billnye
  • ability man
« Reply #5096 on: Tue, 28 April 2015, 17:05:51 »
Throwback to warm summer days ^-^
Offline atlas3686
  • HHKB Elite
« Reply #5097 on: Wed, 29 April 2015, 02:46:27 »
Love it, clean and sexy.
Offline Air tree
« Reply #5098 on: Wed, 29 April 2015, 04:32:17 »
Damn, I'm going to need to some therapy... I'm tempted to go out and find a Novatouch and do the transplant. My quest for the perfect modded HHKB is a death trap.
After I spend all that money on the novatouch, I'll have to start investing in mx keycap sets, it's an endless pit. I can't escape. My quest for  my dream HHKB is scaring me.
And I'm going to want to trade my topre artisans for mx variants.... Hoff, hold me.  :-\
Offline Belfong
« Reply #5099 on: Wed, 29 April 2015, 04:43:01 »
I wonder why Hoff is the go to person for 'hugs' and holding!
